Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] debugging?
- Date: Wed, 19 Jun 2013 17:20:38 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
i'm trying to debua my application, adding -g to both nvcc and Xcompiler options
Best Regards
compilation fails when linking, aparently due to starpu, or bad usage of starpu on my part:
In file included from /usr/local/cuda/bin/crt/link.stub:79:0:
/tmp/tmpxft_00004ed5_00000000-1_ppm-starpu_dlink.reg.c:2:1: error: redefinition of ‘const unsigned char def_module_id_str__NV_MODULE_ID []’
/tmp/tmpxft_00004ed5_00000000-1_ppm-starpu_dlink.reg.c:1:1: error: ‘const unsigned char def_module_id_str__NV_MODULE_ID [19]’ previously defined here
/tmp/tmpxft_00004ed5_00000000-1_ppm-starpu_dlink.reg.c: In function ‘void __cudaRegisterLinkedBinary__NV_MODULE_ID(void (*)(void**), void*, void*)’:
/tmp/tmpxft_00004ed5_00000000-1_ppm-starpu_dlink.reg.c:2:1: error: redefinition of ‘void __cudaRegisterLinkedBinary__NV_MODULE_ID(void (*)(void**), void*, void*)’
/tmp/tmpxft_00004ed5_00000000-1_ppm-starpu_dlink.reg.c:1:1: error: ‘void __cudaRegisterLinkedBinary__NV_MODULE_ID(void (*)(void**), void*, void*)’ previously defined here
Any ideas of what could be the problem?
Best Regards
Miguel Palhas
- [Starpu-devel] debugging?, Miguel Palhas, 19/06/2013
- Re: [Starpu-devel] debugging?, Samuel Thibault, 20/06/2013
- Re: [Starpu-devel] debugging?, Miguel Palhas, 20/06/2013
