Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Miguel Palhas <mpalhas@gmail.com>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] debugging?
- Date: Thu, 20 Jun 2013 15:42:57 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
sorry, that part about the makefile is wrong. here's the correct command for .cu files:
nvcc -x cu -m64 -I/usr/local/include/starpu/1.0 -I/usr/local/cuda/include -I/usr/local/include -I/usr/include/libxml2 -gencode arch=compute_20,code=sm_20 -gencode arch=compute_20,code=sm_21 -gencode arch=compute_30,code=sm_30 -Xcompiler "-m64 -I/usr/local/include/starpu/1.0 -I/usr/local/cuda/include -I/usr/local/include -I/usr/include/libxml2 -Wall -Wno-unused-result -fopenmp" -c -Iinclude -Iinclude/luxrays -I/usr/local/include -I/usr/include/GL -I/usr/local/cuda-5.0/include -I/include -I/home/naps62/projects/beast/include -I/share/edu-mei/freeimage/3.15.4/include -I/home/naps62/projects/msc-thesis/src/starpu_wrapper/include/ src/ppm/math.cu -o build/ppm/math.o
the other 2 are correct
On Thu, Jun 20, 2013 at 3:41 PM, Miguel Palhas <mpalhas@gmail.com> wrote:
Ok it turns out the problem is not about debugging. What i had done was add a condition to the makefile, where if debug mode was enabled, i would use the debug flags instead of optimization ones -O3. What triggered the error was the removal of -O3if i compile withouth both of them, the error still happens. This seems to be something that is optimized out by the compiler when using -O3, but when not using it results in redefinition of those symbolsAnyway, i had to assume this was somehow starpu related, since i never had any problems like this with normal cuda applications.ppm-starpu is the name of my application (from Progressive Photon Mapping). i'll try to work on this, but meanwhile, in case anyone else is interested in trying to figure this out, here's a sample of the compilation commands generated by the makefile:for .cpp files:nvcc -m64 -I/usr/local/include/starpu/1.0 -I/usr/local/cuda/include -I/usr/local/include -I/usr/include/libxml2 -gencode arch=compute_20,code=sm_20 -gencode arch=compute_20,code=sm_21 -gencode arch=compute_30,code=sm_30 -Xcompiler "-m64 -I/usr/local/include/starpu/1.0 -I/usr/local/cuda/include -I/usr/local/include -I/usr/include/libxml2 -Wall -Wno-unused-result -fopenmp" -c -Iinclude -Iinclude/luxrays -I/usr/local/include -I/usr/include/GL -I/usr/local/cuda-5.0/include -I/include -I/home/naps62/projects/beast/include -I/share/edu-mei/freeimage/3.15.4/include -I/home/naps62/projects/msc-thesis/src/starpu_wrapper/include/ src/utils/config.cpp -o build/utils/config.ofor .cu files:nvcc -m64 -I/usr/local/include/starpu/1.0 -I/usr/local/cuda/include -I/usr/local/include -I/usr/include/libxml2 -gencode arch=compute_20,code=sm_20 -gencode arch=compute_20,code=sm_21 -gencode arch=compute_30,code=sm_30 -Xcompiler "-m64 -I/usr/local/include/starpu/1.0 -I/usr/local/cuda/include -I/usr/local/include -I/usr/include/libxml2 -Wall -Wno-unused-result -fopenmp" -c -Iinclude -Iinclude/luxrays -I/usr/local/include -I/usr/include/GL -I/usr/local/cuda-5.0/include -I/include -I/home/naps62/projects/beast/include -I/share/edu-mei/freeimage/3.15.4/include -I/home/naps62/projects/msc-thesis/src/starpu_wrapper/include/ src/ppm/kernels/cpu/intersect_ray_hit_buffer.cpp -o build/ppm/kernels/cpu/intersect_ray_hit_buffer.o
and linking:nvcc -link -m64 -L/usr/local/lib -L/usr/local/cuda/lib64 -lstarpu-1.0 -lcudart -lcublas -lcuda -lstdc++ -lhwloc -gencode arch=compute_20,code=sm_20 -gencode arch=compute_20,code=sm_21 -gencode arch=compute_30,code=sm_30 -Xcompiler "-fopenmp" -L/usr/lib -L/usr/local/lib -L/opt/local/lib -L/usr/local/cuda-5.0/lib -L/lib -L/home/naps62/projects/beast/lib -L/share/edu-mei/freeimage/3.15.4/lib/linux -L/share/edu-mei/freeimage/3.15.4/lib -L/usr/local/cuda-5.0/lib64 -L/usr/local/cuda-5.0/lib -lglut -lGLU -lGL -lboost_program_options -lboost_system -lboost_thread-mt -lboost_chrono -lfreeimage -lbeast build/main.o build/utils/action_list.o build/utils/config.o build/utils/dumps.o build/luxrays/accelerators/qbvhaccel.o build/luxrays/utils/properties.o build/luxrays/utils/sdl/extmeshcache.o build/luxrays/utils/sdl/light.o build/luxrays/utils/sdl/scene.o build/luxrays/utils/sdl/sdl.o build/luxrays/utils/sdl/spd.o build/luxrays/utils/sdl/texmap.o build/luxrays/utils/plymesh/rply.o build/luxrays/utils/core/exttrianglemesh.o build/luxrays/core/dataset.o build/luxrays/core/trianglemesh.o build/luxrays/core/geometry/bbox.o build/luxrays/core/geometry/matrix4x4.o build/luxrays/core/geometry/ray.o build/luxrays/core/geometry/transform.o build/ppm/display.o build/ppm/engine.o build/ppm/film.o build/ppm/ptrfreescene.o build/ppm/kernels/advance_eye_paths.o build/ppm/kernels/codelets.o build/ppm/kernels/generate_eye_paths.o build/ppm/kernels/intersect_ray_hit_buffer.o build/ppm/kernels/cpu/advance_eye_paths.o build/ppm/kernels/cpu/generate_eye_paths.o build/ppm/kernels/cpu/intersect_ray_hit_buffer.o build/ppm/math.o build/ppm/kernels/helpers.o -o bin/ppm-starpu--On Thu, Jun 20, 2013 at 12:42 PM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
Hello,
Miguel Palhas, le Wed 19 Jun 2013 18:21:07 +0200, a écrit :
> i'm trying to debua my application, adding -g to both nvcc and XcompilerWhen linking your application I guess?
> options
> compilation fails when linking,
I don't really see what is coming from starpu actually:
> aparently due to starpu, or bad usage of starpu on my part:
ppm-starpu is something from your application I guess? We do not have
> In file included from /usr/local/cuda/bin/crt/link.stub:79:0:
> /tmp/tmpxft_00004ed5_00000000-1_ppm-starpu_dlink.reg.c:2:1: error: redefinition
> of ‘const unsigned char def_module_id_str__NV_MODULE_ID []’
such name in starpu.
This all looks like cuda issues, actually. How do you pass -g to nvcc
> /tmp/tmpxft_00004ed5_00000000-1_ppm-starpu_dlink.reg.c:1:1: error: ‘const
> unsigned char def_module_id_str__NV_MODULE_ID [19]’ previously defined here
> /tmp/tmpxft_00004ed5_00000000-1_ppm-starpu_dlink.reg.c: In function ‘void
> __cudaRegisterLinkedBinary__NV_MODULE_ID(void (*)(void**), void*, void*)’:
> of ‘void __cudaRegisterLinkedBinary__NV_MODULE_ID(void (*)(void**), void*,
> void*)’
> /tmp/tmpxft_00004ed5_00000000-1_ppm-starpu_dlink.reg.c:1:1: error: ‘void
and Xcompiler, exactly?
Samuel
CumprimentosMiguel Palhas
Cumprimentos
Miguel Palhas
- [Starpu-devel] debugging?, Miguel Palhas, 19/06/2013
- Re: [Starpu-devel] debugging?, Samuel Thibault, 20/06/2013
- Re: [Starpu-devel] debugging?, Miguel Palhas, 20/06/2013
