Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Strange behaviour using GPUs
Archives de la liste
Chronologique Discussions
  • To: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Cc: Mathieu Faverge <Mathieu.Faverge@inria.fr>, starpu-devel@lists.gforge.inria.fr, Pierre Ramet <ramet@labri.fr>
  • Subject: Re: [Starpu-devel] Strange behaviour using GPUs
  • Date: Wed, 10 Jul 2013 11:43:32 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello again,
I still have some things I can't explain with my traces (eg.
http://img46.imageshack.us/img46/7026/ojb.png)
I can see a large period where nothing is done (around 50000) and a data
movement performed with dates : 63306.3 - 28261 which are killing the
performances.
I also had a question about fxt, how do I set the buffer size to be sure all
the event will be registered without having to synchronize on disk, is there
a macro, a compilation option ?
XL.
Le 10 juil. 2013 à 09:43, Xavier Lacoste a écrit :
> Hello,
> Indeed, the behaviour is really better with r10552, I still loose some time
> when I use 9CPUs + 3 GPUs instead of 10+2 but not too much (84.2 s vs 62.4
> s whereas I had 750 s before) ...
> Thanks,
> XL.
> Le 9 juil. 2013 à 15:54, Xavier Lacoste a écrit :
>> Thanks Nathalie,
>> I'll try this when I'll happen to be scheduled on a GPU node... (plafrim
>> scheduler is quite strange today...)
>> XL.
>> Le 9 juil. 2013 à 14:38, Nathalie Furmento a écrit :
>>> Xavier,
>>> There was indeed a bug in 1.1.0rc1 which made dmda queues LIFOs . This
>>> has been fixed in the branch. We actually found out by seeing MAGMA
>>> performances dropping down.
>>> Could you please try and let us know if that also fixes your problem? I
>>> am planning to release 1.1.0rc2 tomorrow, but you could also try by
>>> checking out the svn repository.
>>> Thanks,
>>> Nathalie
>>> in On 09/07/2013 14:19, Xavier Lacoste wrote:
>>>> Hello,
>>>> I tried to compare ParSEC and StarPU using full machines (mirage) on
>>>> PaStiX.
>>>> We achieve to have good scaling with ParSEC by statically scheduling
>>>> task on GPUs.
>>>> So, I tried to reproduce the same scheduling with StarPU 1.1.0rc1 and
>>>> obtained strange behavious.
>>>> My GPUs take all there time FetchingInput and PushingOutputs.
>>>> The output trace can be seen here :
>>>> http://img401.imageshack.us/img401/5213/1pb.png
>>>> Or, on plafrim cluster :
>>>> 9 CPUs + 3 GPUs
>>>> /lustre/lacoste/rsync/log_mirage_AUDI_dmda+LLT+flop+cmin20+frat8+distFlop+selfCopy+fxt_9_3_4231_20130709_120332_crit2_0.5GPUmem.trace
>>>> 10 + 2 :
>>>> /lustre/lacoste/rsync/log_mirage_AUDI_dmda+LLT+flop+cmin20+frat8+distFlop+selfCopy+fxt_10_2_4231_20130709_120332_crit2_0.5GPUmem.trace
>>>> 11 + 1 :
>>>> /lustre/lacoste/rsync/log_mirage_AUDI_dmda+LLT+flop+cmin20+frat8+distFlop+selfCopy+fxt_11_1_4231_20130709_120332_crit2_0.5GPUmem.trace
>>>> 12 + 0 :
>>>> /lustre/lacoste/rsync/log_mirage_AUDI_dmda+LLT+flop+cmin20+frat8+distFlop+selfCopy+fxt_12_0_4231_20130709_120332_crit2_0.5GPUmem.trace
>>>> The results are good with 12 CPUs + 0, adding 1 or 2 GPUs bring no loss,
>>>> but no gain either, adding three slows down the run time by a factor 10.
>>>> Do you have any idea of what can explain this behaviour ?
>>>> With a dynamic scheduling, GPUs are usefull with a small number of CPUs
>>>> but not with the whole machine.
>>>> (My cost model may not be accurate enough for the moment...
>>>> http://img515.imageshack.us/img515/2348/njz.png)
>>>> Thanks,
>>>> XL.
>>>> _______________________________________________
>>>> Starpu-devel mailing list
>>>> Starpu-devel@lists.gforge.inria.fr
>>>> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
