Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: starpu-announce@lists.gforge.inria.fr
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] starpu v1.1.0rc2 released
- Date: Wed, 10 Jul 2013 16:01:15 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
The StarPU team is pleased to announce the second release candidate for v1.1.0, the scheduling context release,
https://gforge.inria.fr/frs/?group_id=1570
The tarball along with the md5sum file and the OpenPGP signature are available on the Gforge web site
or on the secondary web site
http://runtime.bordeaux.inria.fr/StarPU/files/
Please test and let us know if you find any issue.
Nathalie , for the StarPU team.
ChangeLog
Changes:
* StarPU-MPI: Fix potential bug for user-defined datatypes. As MPI
can reorder messages, we need to make sure the sending of the size
of the data has been completed.
* Documentation is now generated through doxygen.
Small Changes:
* Explicitly name the non-sleeping-non-running time "Overhead", and use
another color in vite traces.
* Use C99 variadic macro support, not GNU.
* Fix performance regression: dmda queues were inadvertently made
LIFOs in r9611.
* Invert GPU-GPU direct transfer control environment variable name,
i.e environment variable STARPU_ENABLE_CUDA_GPU_GPU_DIRECT should
be used instead of STARPU_DISABLE_CUDA_GPU_GPU_DIRECT.
- [Starpu-devel] starpu v1.1.0rc2 released, Nathalie Furmento, 10/07/2013
