Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Magma/Plasma on StarPU
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] Magma/Plasma on StarPU
  • Date: Fri, 12 Jul 2013 16:43:54 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello everyone,
I'm new with StarPU and I'm trying to use a linear algebra library with the
framework.
I've found that StarPU supports Magma and Plasma (at least partially),
however I can't seem to find any StarPU code example that use any of the
libraries. Can you help find a code sample?
I'm also still a bit confuse on how the StarPU works with magma or plasma.
For example, if I want to do LU factorization using plasma, do I only need to
call the respective plasma method inside a StarPU codelet? Does StarPU
automatically divides the domains and submits parallel tasks or just
generates a single task that makes a call to the plasma library?
I apologize if these questions are too obvious or don't make too much sense,
but like I said, I'm new to StarPU and I'm really having a hard time finding
anything on Magma/Plasma and StarPU. Maybe you can also advise me on some
literature on the subject.
I would really appreciate if you could help me with this problem. Thank you
for your time.
Best regards,
Ricardo Alves.
Haut de le page
