Archives de la liste
- To: Ricardo Alves <ricardo.alves@it.uu.se>
- Cc: Mathieu Faverge <mathieu.faverge@inria.fr>, Emmanuel Agullo <emmanuel.agullo@inria.fr>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Magma/Plasma on StarPU
- Date: Mon, 15 Jul 2013 13:55:41 +0200 (CEST)
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello,
The magma code using starpu is deprecated. You should probably use morse in
this case (http://icl.cs.utk.edu/morse). This is a research project and the
developers do not plan to make a new release before september, but if you
need it right away they could make you a tarball of the current svn
repository.
Morse provides some examples together with the source code
(morse/magma_morse/timing/). You can see there how exactly it is used.
If you want to know how LU is working you can read this:
http://icl.cs.utk.edu/news_pub/submissions/plagma_lu.pdf
For more exact information you should probably contact morse team (in CC you
can find Emmanuel and Mathieu's address mail).
Let us know if you have further questions!
Best regards,
Andra Hugo
----- Mail original -----
> De: "Ricardo Alves" <ricardo.alves@it.uu.se>
> À: starpu-devel@lists.gforge.inria.fr
> Envoyé: Vendredi 12 Juillet 2013 16:43:54
> Objet: [Starpu-devel] Magma/Plasma on StarPU
> Hello everyone,
> I'm new with StarPU and I'm trying to use a linear algebra library
> with the framework.
> I've found that StarPU supports Magma and Plasma (at least
> partially), however I can't seem to find any StarPU code example
> that use any of the libraries. Can you help find a code sample?
> I'm also still a bit confuse on how the StarPU works with magma or
> plasma. For example, if I want to do LU factorization using plasma,
> do I only need to call the respective plasma method inside a StarPU
> codelet? Does StarPU automatically divides the domains and submits
> parallel tasks or just generates a single task that makes a call to
> the plasma library?
> I apologize if these questions are too obvious or don't make too much
> sense, but like I said, I'm new to StarPU and I'm really having a
> hard time finding anything on Magma/Plasma and StarPU. Maybe you can
> also advise me on some literature on the subject.
> I would really appreciate if you could help me with this problem.
> Thank you for your time.
> Best regards,
> Ricardo Alves.
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
- [Starpu-devel] Magma/Plasma on StarPU, Ricardo Alves, 12/07/2013
- Re: [Starpu-devel] Magma/Plasma on StarPU, Andra Hugo, 15/07/2013
- Re: [Starpu-devel] Magma/Plasma on StarPU, Ricardo Alves, 15/07/2013
