Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] starpu 1.1.0rc1 fail to install on MacOS
- Date: Mon, 15 Jul 2013 14:18:46 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello,
Here is the error I get :
> ./configure --prefix=/Users/lacoste/INRIA/starpu-1.1.0rc1-install # (output
> https://gist.github.com/XL64/cab8cae17b14bb7b4540)
> make
> make install
libtool: install: /usr/local/bin/ginstall -c openmp/.libs/vector_scal_omp
/Users/lacoste/INRIA/starpu-1.1.0rc1-install/lib/starpu/examples/vector_scal_omp
cd starpu-top ; /usr/local/bin/qmake ; make
make[2]: Nothing to be done for `first'.
/usr/local/bin/gmkdir -p /Users/lacoste/INRIA/starpu-1.1.0rc1-install/bin
/bin/sh /Users/lacoste/INRIA/starpu-1.1.0rc1/build-aux/install-sh -c -s
starpu-top/starpu_top /Users/lacoste/INRIA/starpu-1.1.0rc1-install/bin
/Users/lacoste/INRIA/starpu-1.1.0rc1/build-aux/install-sh:
starpu-top/starpu_top does not exist.
make[2]: *** [install-exec-local] Error 1
make[1]: *** [install-am] Error 2
make: *** [install-recursive] Error 1
Indeed, the file is not there, but there is a starpu_top.app
> ls starpu-top
Makefile dataaggregatorwidget.cpp
moc_communicationmanager.o moc_qwt_legend_item.cpp
qwt_abstract_slider.o qwt_scale_widget.o
StarPU-Top-common.pri dataaggregatorwidget.h
moc_communicationthread.cpp moc_qwt_legend_item.o qwt_clipper.o
qwt_series_data.o
StarPU-Top-qwt-embed.pri dataaggregatorwidget.o
moc_communicationthread.o moc_qwt_plot.cpp qwt_color_map.o
qwt_slider.o
StarPU-Top-qwt-embed.pri.in datawidget.cpp
moc_dataaggregatorwidget.cpp moc_qwt_plot.o qwt_curve_fitter.o
qwt_spline.o
StarPU-Top-qwt-system.pri datawidget.h
moc_dataaggregatorwidget.o moc_qwt_plot_canvas.cpp qwt_dial.o
qwt_symbol.o
StarPU-Top-qwt-system.pri.in datawidget.o moc_datawidget.cpp
moc_qwt_plot_canvas.o qwt_dial_needle.o qwt_text.o
StarPU-Top.pro debugconsole.cpp moc_datawidget.o
moc_qwt_scale_widget.cpp qwt_double_range.o
qwt_text_engine.o
StarPU-Top.pro.in debugconsole.h
moc_debugconsole.cpp moc_qwt_scale_widget.o
qwt_dyngrid_layout.o qwt_text_label.o
StarPU-Top.pro.user debugconsole.o moc_debugconsole.o
moc_qwt_slider.cpp qwt_interval.o
qwt_thermo.o
StarPU-Top.pro.user.1.3 debugconsole.ui moc_ganttwidget.cpp
moc_qwt_slider.o qwt_knob.o qwt_wheel.o
TODO.txt extradist moc_ganttwidget.o
moc_qwt_text_label.cpp qwt_legend.o
resources.qrc
aboutdialog.cpp ganttwidget.cpp
moc_interactivewidget.cpp moc_qwt_text_label.o qwt_legend_item.o
sessionsetupmanager.cpp
aboutdialog.h ganttwidget.h
moc_interactivewidget.o moc_qwt_thermo.cpp qwt_math.o
sessionsetupmanager.h
aboutdialog.o ganttwidget.o moc_mainwindow.cpp
moc_qwt_thermo.o qwt_painter.o
sessionsetupmanager.o
aboutdialog.ui images moc_mainwindow.o
moc_qwt_wheel.cpp qwt_plot.o stamp-h4
abstractwidgetwindow.cpp interactivewidget.cpp
moc_preferencesdialog.cpp moc_qwt_wheel.o qwt_plot_axis.o
starpu_top.app
abstractwidgetwindow.h interactivewidget.h
moc_preferencesdialog.o moc_sessionsetupmanager.cpp qwt_plot_canvas.o
starpu_top_types.h
abstractwidgetwindow.o interactivewidget.o
moc_qledindicator.cpp moc_sessionsetupmanager.o qwt_plot_curve.o
taskmanager.cpp
communicationmanager.cpp main.cpp moc_qledindicator.o
preferencesdialog.cpp qwt_plot_dict.o
taskmanager.h
communicationmanager.h main.o
moc_qwt_abstract_slider.cpp preferencesdialog.h qwt_plot_item.o
taskmanager.o
communicationmanager.o mainwindow.cpp
moc_qwt_abstract_slider.o preferencesdialog.o qwt_plot_layout.o
ui_aboutdialog.h
communicationthread.cpp mainwindow.h moc_qwt_dial.cpp
preferencesdialog.ui qwt_plot_seriesitem.o
ui_debugconsole.h
communicationthread.h mainwindow.o moc_qwt_dial.o
qledindicator qwt_plot_xml.o
ui_mainwindow.h
communicationthread.o mainwindow.ui
moc_qwt_dyngrid_layout.cpp qledindicator.o qwt_point_polar.o
ui_preferencesdialog.h
config.h moc_aboutdialog.cpp
moc_qwt_dyngrid_layout.o qrc_resources.cpp
qwt_round_scale_draw.o widgetwindowsmanager.cpp
config.h.in moc_aboutdialog.o moc_qwt_knob.cpp
qrc_resources.o qwt_scale_div.o
widgetwindowsmanager.h
configurationmanager.cpp moc_abstractwidgetwindow.cpp moc_qwt_knob.o
qwt qwt_scale_draw.o
widgetwindowsmanager.o
configurationmanager.h moc_abstractwidgetwindow.o moc_qwt_legend.cpp
qwt_abstract_scale.o qwt_scale_engine.o
configurationmanager.o moc_communicationmanager.cpp moc_qwt_legend.o
qwt_abstract_scale_draw.o qwt_scale_map.o
I just did touch starpu-top/starpu_top to finish the installation without
other problem,
XL.
Le 15 juil. 2013 à 11:50, Samuel Thibault a écrit :
> Hello,
> Xavier Lacoste, le Fri 05 Jul 2013 16:09:29 +0200, a écrit :
>> With starpu 1.1.0rc1 on an Mac (10.7.5), I needed to run "touch
>> starpu-top/starpu_top" to perform make install successfuly because the
>> makefile was trying to create a link with an unexisting file.
> I'm not sure to understand exactly what is happening, I've only noticed
> that we didn't apply the executable extension, but I guess Darwin does
> not use any so it should not matter. Could you post the detailed output
> of config.log and make install?
> Samuel
- [Starpu-devel] starpu 1.1.0rc1 fail to install on MacOS, Xavier Lacoste, 05/07/2013
- Re: [Starpu-devel] starpu 1.1.0rc1 fail to install on MacOS, Samuel Thibault, 15/07/2013
- Re: [Starpu-devel] starpu 1.1.0rc1 fail to install on MacOS, Xavier Lacoste, 15/07/2013
