Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Xavier Lacoste <xavier.lacoste@u-bordeaux1.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Error building starpu1.1
- Date: Tue, 08 Oct 2013 15:47:29 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Xavier,
It is a problem with the gcc-plugin. Probably due to an update of your gcc compiler. Could you please tell us on which machine you are running and send us your config.log
In the meantime, you can disable the gcc plugin by setting the configure option --disable-gcc-extensions
Cheers,
Nathalie
On 08/10/2013 15:42, Xavier Lacoste wrote:
Hello,
I did update starpu1.1 then I tried to build it and got :
/bin/sh ../../build-aux/ylwrap c-expr.y y.tab.c c-expr.c y.tab.h c-expr.h
y.output c-expr.output -- /bin/sh
/home/lacoste/starpu/branches/starpu-1.1/build-aux/missing --run bison -y
/home/lacoste/starpu/branches/starpu-1.1/gcc-plugin/src/c-expr.y:19.9-16:
syntax error, unexpected identifier, expecting string
make[2]: *** [c-expr.c] Error 1
what I did :
svn up
./configure
--prefix=/opt/cluster/plafrim-dev/starpu/starpu-1.1/r11282/cuda/4.2/hwloc/1.7/nofxt
--disable-opencl
make&& make install
Did I do something wrong ?
Have a nice day,
XL.
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
- [Starpu-devel] Error building starpu1.1, Xavier Lacoste, 08/10/2013
- Re: [Starpu-devel] Error building starpu1.1, Nathalie Furmento, 08/10/2013
- Re: [Starpu-devel] Error building starpu1.1, Xavier Lacoste, 08/10/2013
