Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Error building starpu1.1
Archives de la liste
Chronologique Discussions
  • From: Xavier Lacoste <xavier.lacoste@u-bordeaux1.fr>
  • To: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Error building starpu1.1
  • Date: Tue, 8 Oct 2013 16:46:16 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Thanks,
I disabled gcc extensiosn and it's fine,
I'm on mirage004
Cheers,
XL.
Le 8 oct. 2013 à 15:47, Nathalie Furmento a écrit :
> Xavier,
> It is a problem with the gcc-plugin. Probably due to an update of your gcc
> compiler. Could you please tell us on which machine you are running and
> send us your config.log
> In the meantime, you can disable the gcc plugin by setting the configure
> option --disable-gcc-extensions
> Cheers,
> Nathalie
> On 08/10/2013 15:42, Xavier Lacoste wrote:
>> Hello,
>> I did update starpu1.1 then I tried to build it and got :
>> /bin/sh ../../build-aux/ylwrap c-expr.y y.tab.c c-expr.c y.tab.h c-expr.h
>> y.output c-expr.output -- /bin/sh
>> /home/lacoste/starpu/branches/starpu-1.1/build-aux/missing --run bison -y
>> /home/lacoste/starpu/branches/starpu-1.1/gcc-plugin/src/c-expr.y:19.9-16:
>> syntax error, unexpected identifier, expecting string
>> make[2]: *** [c-expr.c] Error 1
>> what I did :
>> svn up
>> ./configure
>> --prefix=/opt/cluster/plafrim-dev/starpu/starpu-1.1/r11282/cuda/4.2/hwloc/1.7/nofxt
>> --disable-opencl
>> make&& make install
>> Did I do something wrong ?
>> Have a nice day,
>> XL.
>> _______________________________________________
>> Starpu-devel mailing list
>> Starpu-devel@lists.gforge.inria.fr
>> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
