Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, starpu-devel <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Problems with memory in CUDA
- Date: Mon, 21 Oct 2013 16:37:52 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Thank you for your answer, I will do that.
Cyril.
Le 21/10/2013 16:32, Samuel Thibault a écrit :
> Cyril Bordage, le Mon 21 Oct 2013 16:12:59 +0200, a écrit :
>> The "out of memory" can occur at different locations.
>> I have found one example again : in cudaMemset for the initialization of
>> a redux handle.
> D'oh, cudaMemset running out of memory...
>> #3 0x00007fffec920322 in __GI___assert_fail (assertion=0x4ae460 "_b ==
>> cudaSuccess", file=0x4ae435 "utils/starpu.c", line=157,
>> function=0x4ae640 <__PRETTY_FUNCTION__.14205>
>> "init_vector_cuda_func") at assert.c:101
>> #4 0x000000000043e16a in init_vector_cuda_func (buffers=0x7fff7f244978,
>> cl_arg=0x0) at utils/starpu.c:157
> And we clearly don't want to make you systematically check for out of
> memory conditions in cudaMemset calls...
> I guess we don't really have another better option than defaulting to
> using only e.g. 90% of the available memory, to let cuda have 10% for
> its own uses. You can already do that easily by setting e.g.
> export STARPU_LIMIT_CUDA_MEM=3600
> if your GPUs have 4GiB memory.
> Samuel
- [Starpu-devel] Problems with memory in CUDA, Cyril Bordage, 21/10/2013
- Re: [Starpu-devel] Problems with memory in CUDA, Nathalie Furmento, 21/10/2013
- Re: [Starpu-devel] Problems with memory in CUDA, Cyril Bordage, 21/10/2013
- Re: [Starpu-devel] Problems with memory in CUDA, Samuel Thibault, 21/10/2013
