Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Starpu Test Results
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Stephen Ray Ownbey <Ownbey@uwyo.edu>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] Starpu Test Results
  • Date: Fri, 22 Nov 2013 15:21:36 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
Thanks for the report. However, could you please send us the following information:
- the exact version of StarPU you are using
- the command line you used when calling configure
- the contents of the file config.log
- the patch you applied to the makefiles
Thanks,
Nathalie
On 21/11/2013 22:04, Stephen Ray Ownbey wrote:
The errors are possibly my fault, as I had to modify several of the make files since configure did not correctly incorporate NVidia’s Magma package into the build. I also modified the three files I have attached, so the Cholesky examples would run without generating call magma_init first errors
Regards,
Stephen R. Ownbey
Engineering 2038
(307) 766-6582
ownbey@uwyo.edu
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
