Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: "Eng.Ahmed Hosny" <ahmed.ibrahim@fci.au.edu.eg>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] [Inquiry]Starpu Windows Build
- Date: Mon, 13 Jan 2014 08:50:46 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Dear Ahmed,
Does the command
pkg-config --cflags starpu-1.2
return something?
If not, you should make sure the PKG_CONFIG_PATH variable is properly set, as
explained in the README file of the tutorial directory.
What do you mean by i couldn't add CUDA kernel? It's very likely StarPU will
choose the CPU implementation when executing a basic
codelet. You can force the CUDA implementation by setting STARPU_NCPUS=0 when
running your application. It could also be StarPU
does not see your CUDA devices. Run
starpu_machine_display
to print a list of the devices StarPU finds on your machine.
Regards,
Nathalie Furmento
On Jan 13, 01:51, Eng.Ahmed Hosny wrote:
> Dear Sir,
> I have an inquiry about windows build. Whenever I try to run
> /starpu-win32/share/doc/starpu/tutorial "make hello_world" or even "make
> vector_scal" after setting the environment variable from Cygwin, no such
> file or directory error <starpu.h> error appears. After I tried to add
> include directory to the Makefile, cannot find -lstarpu1.2 error appears.
> I have successfully compiled hello_world sample using starpu_exec.bat but I
> couldn't add CUDA kernel. I tried the tutorial but unfortunately, it
> doesn't work with me. I really appreciate your help for steps to run the
> StarPu environment on Windows.
> Waiting for your kind reply.
> Thanks,
> Best regards,
> Ahmed Hosny Mohammed
> Teaching and Research Assistance
> Computer Science Department
> Faculty of Computers and Information
> Assiut University
> Egypt
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Dr Nathalie Furmento CNRS R&D Engineer
Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
200 avenue de la vieille Tour Tel: +33 (0)5 24 57 41 20
33405 Talence cedex, FRANCE Fax: +33 (0)5 24 57 40 41
- [Starpu-devel] [Inquiry]Starpu Windows Build, Eng . Ahmed Hosny, 13/01/2014
- Re: [Starpu-devel] [Inquiry]Starpu Windows Build, Nathalie Furmento, 13/01/2014
- Message indisponible
- Re: [Starpu-devel] [Inquiry]Starpu Windows Build, Nathalie Furmento, 16/01/2014
