Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [Inquiry]Starpu Windows Build
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: "Eng.Ahmed Hosny" <ahmed.ibrahim@fci.au.edu.eg>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [Inquiry]Starpu Windows Build
  • Date: Mon, 13 Jan 2014 14:22:59 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Did you install StarPU yourself? Or did you get a compiled package?
If you did not have any errors when calling make install, the file starpu.h
should then be available in the directory
$STARPU_DIR/include/starpu/1.2, $STARPU_DIR being the directory you specified
when calling configure.ac
As for CUDA, did StarPU detect CUDA when running configure? You can have a
look in the file config.log
Regards,
Nathalie
On Jan 13, 12:29, Eng.Ahmed Hosny wrote:
> Dear Nathalie,
> Thanks for your reply, first I've already set the PKG_CONFIG_PATH
> variable and pkg-config --cflags starpu-1.2 returns with
> -I/c/builds/workspace/starpu-trunk-windows/starpu-1.2.0/build/../../starpu-win32-build-1.2.0/include/starpu/1.2
> -I/usr/local/include
> those directories do not contain starpu.h.
> I meant by adding CUDA kernel, that till now I can only write and run code
> with cpu_funcs only using the batch file starpu_exec. But I do not know a
> specfic way to compile and rund source code with cuda_funcs in windows.
> After running starpu_machine_display, I figured out that Starpu could not
> see my CUDA device also !
> I really appreciate your help. Thanks in advance
> Best regards,
> Ahmed Hosny Mohammed
> Teaching and Research Assistance
> Computer Science Department
> Faculty of Computers and Information
> Assiut University
> Egypt
> ________________________________________
> From: Nathalie Furmento [nathalie.furmento@labri.fr]
> Sent: Monday, January 13, 2014 9:50 AM
> To: Eng.Ahmed Hosny
> Dear Ahmed,
> Does the command
> return something?
> If not, you should make sure the PKG_CONFIG_PATH variable is properly set,
> as explained in the README file of the tutorial directory.
> What do you mean by i couldn't add CUDA kernel? It's very likely StarPU
> will choose the CPU implementation when executing a basic
> codelet. You can force the CUDA implementation by setting STARPU_NCPUS=0
> when running your application. It could also be StarPU
> does not see your CUDA devices. Run
> to print a list of the devices StarPU finds on your machine.
> Regards,
> Nathalie Furmento
> On Jan 13, 01:51, Eng.Ahmed Hosny wrote:
> > Dear Sir,
> > I have an inquiry about windows build. Whenever I try to run
> > /starpu-win32/share/doc/starpu/tutorial "make hello_world" or even "make
> > vector_scal" after setting the environment variable from Cygwin, no such
> > file or directory error <starpu.h> error appears. After I tried to add
> > include directory to the Makefile, cannot find -lstarpu1.2 error appears.
> > I have successfully compiled hello_world sample using starpu_exec.bat
> > but I couldn't add CUDA kernel. I tried the tutorial but unfortunately,
> > it doesn't work with me. I really appreciate your help for steps to run
> > the StarPu environment on Windows.
> > Waiting for your kind reply.
> > Thanks,
> > Best regards,
> > Assiut University
> > Egypt
> > _______________________________________________
> > Starpu-devel mailing list
> > Starpu-devel@lists.gforge.inria.fr
> > http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
> Dr Nathalie Furmento CNRS R&D Engineer
> Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
> 200 avenue de la vieille Tour Tel: +33 (0)5 24 57 41 20
> 33405 Talence cedex, FRANCE Fax: +33 (0)5 24 57 40 41
Dr Nathalie Furmento Ingénieur de recherche CNRS
Haut de le page
