Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Concurrent access to HASH_FIND_PTR(_cache_sent_data[dest], &data, already_sent);
Archives de la liste
Chronologique Discussions
  • To: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Concurrent access to HASH_FIND_PTR(_cache_sent_data[dest], &data, already_sent);
  • Date: Fri, 9 May 2014 11:19:46 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
The issue seems to be fixed.
Thanks,
XL.
Le 5 mai 2014 à 15:00, Nathalie Furmento <nathalie.furmento@labri.fr> a écrit :
Xavier,
it should be fixed in the trunk with revision 12794.
Let me know if it's okay.
Cheers,
Nathalie
On 29/04/2014 17:18, Nathalie Furmento wrote:
Xavier,
I am looking at the problem, i will get back to you as soon as it is fixed.
Cheers,
Nathalie
On 29/04/2014 10:38, Xavier Lacoste wrote:
Hello,
I Get a crash when trying to submit 2 remote tasks at the same time on two workers.
When I had mutex protection around the starpu_mpi_insert_task() the crash disappear.
So I suppose their is something which needs protection in the _starpu_mpi_already_sent() function, maybe around the HASH_FIND_PTR(_cache_sent_data[dest], &data, already_sent);.
As far as I understand, one thread is searching in the hash while an other is reallocating it.
I copy in this mail the backtrace of the crashing mpi node.
Regards,
XL.
0x00007ffff530e9d6 in _starpu_mpi_already_sent (data="0x1327060," dest=1)
    at starpu_mpi_cache.c:229
229             HASH_FIND_PTR(_cache_sent_data[dest], &data, already_sent);
(gdb) thread apply all bt
Thread 7 (Thread 0x7fffa879b950 (LWP 4850)):
#0  0x00007ffff35596f8 in epoll_wait () from /lib64/libc.so.6
#1  0x00007ffff4ae1b79 in epoll_dispatch (base=0x7, arg=0xb8dfc0, tv=0x20)
    at epoll.c:215
#2  0x00007ffff4ae2cfc in opal_event_base_loop (base=0x7, flags=12115904)
    at event.c:838
#3  0x00007ffff4b15938 in opal_progress () at runtime/opal_progress.c:189
#4  0x00007ffff4a3e47e in ompi_request_default_test (rptr=0x7,
    completed=0xb8dfc0, status=0x20) at request/req_test.c:88
#5  0x00007ffff4a62a83 in PMPI_Test (request=0x7, completed=0xb8dfc0,
    status=0x20) at ptest.c:61
#6  0x00007ffff53078c8 in _starpu_mpi_progress_thread_func (arg=0x7)
    at starpu_mpi.c:698
#7  0x00007ffff5bab070 in start_thread () from /lib64/libpthread.so.0
#8  0x00007ffff355910d in clone () from /lib64/libc.so.6
#9  0x0000000000000000 in ?? ()
Thread 5 (Thread 0x7fffeaa27950 (LWP 4848)):
#0  0x00007ffff4af5398 in opal_memory_ptmalloc2_int_malloc (av=0x210, bytes=37)
    at malloc.c:4561
#1  0x00007ffff4af8068 in opal_memory_ptmalloc2_malloc (bytes=528)
    at malloc.c:3433
---Type <return> to continue, or q <return> to quit---
#2  0x00007ffff530eae9 in _starpu_mpi_already_sent (data="0x1328eb0," dest=37)
    at starpu_mpi_cache.c:234
#3  0x00007ffff530c29c in _starpu_mpi_exchange_data_before_execution (
    data="0x210," mode=37, me=-1596362896, dest=32, do_execute=-1594883912,
    comm=0x20) at starpu_mpi_insert_task.c:123
#4  0x00007ffff530b48f in starpu_mpi_insert_task (comm=0x210, codelet=0x25)
    at starpu_mpi_insert_task.c:365
#5  0x000000000054bd5d in starpu_dsysubmit_outgoing_fanin (
    sopalin_data=0xdb15a0, fcblk=0xd1a270, hcblk=0xd1a0a0)
    at /home/lacoste/mateo70/pastix/build_nocuda/starpu/starpu_dsubmit.c:276
#6  0x00000000005244cb in sy_trfsp1d_gemm_starpu_common (
    buffers=0x7fffa03a91a8, _args=0x7fffa03a9090, arch=0)
    at /home/lacoste/mateo70/pastix/starpu/starpu_kernels_sy.c:989
#7  0x00000000005258ac in sy_trfsp1d_sparse_gemm_starpu_cpu (
    buffers=0x7fffa03a91a8, _args=0x7fffa03a9090)
    at /home/lacoste/mateo70/pastix/starpu/starpu_kernels_sy.c:1248
#8  0x00007ffff5065ba4 in _starpu_cpu_driver_run_once (cpu_worker=0x210)
    at drivers/cpu/driver_cpu.c:164
#9  0x00007ffff506568b in _starpu_cpu_worker (arg=0x210)
    at drivers/cpu/driver_cpu.c:368
#10 0x00007ffff5bab070 in start_thread () from /lib64/libpthread.so.0
#11 0x00007ffff355910d in clone () from /lib64/libc.so.6
#12 0x0000000000000000 in ?? ()
Thread 4 (Thread 0x7fffea226950 (LWP 4847)):
#0  0x00007ffff530e9d6 in _starpu_mpi_already_sent (data="0x1327060," dest=1)
#1  0x00007ffff530c29c in _starpu_mpi_exchange_data_before_execution (
    data="0x7fffa03a45a0," mode=STARPU_R, me=31, dest=272, do_execute=455171,
    comm=0x1e6cf) at starpu_mpi_insert_task.c:123
#2  0x00007ffff530b48f in starpu_mpi_insert_task (comm=0x7fffa03a45a0,
    codelet=0x1) at starpu_mpi_insert_task.c:365
#3  0x000000000054bd5d in starpu_dsysubmit_outgoing_fanin (
    sopalin_data=0xdb15a0, fcblk=0xd1a230, hcblk=0xd1a0e0)
#4  0x00000000005244cb in sy_trfsp1d_gemm_starpu_common (
    buffers=0x7fffa03a8ad8, _args=0x7fffa03a89c0, arch=0)
#5  0x00000000005258ac in sy_trfsp1d_sparse_gemm_starpu_cpu (
    buffers=0x7fffa03a8ad8, _args=0x7fffa03a89c0)
#6  0x00007ffff5065ba4 in _starpu_cpu_driver_run_once (
    cpu_worker=0x7fffa03a45a0) at drivers/cpu/driver_cpu.c:164
#7  0x00007ffff506568b in _starpu_cpu_worker (arg=0x7fffa03a45a0)
#8  0x00007ffff5bab070 in start_thread () from /lib64/libpthread.so.0
#9  0x00007ffff355910d in clone () from /lib64/libc.so.6
#10 0x0000000000000000 in ?? ()
Thread 1 (Thread 0x7ffff7fbb710 (LWP 4842)):
#0  0x00007ffff5baed59 in pthread_cond_wait@@GLIBC_2.3.2 ()
#1  0x00007ffff5019e96 in _starpu_barrier_counter_wait_for_empty_counter (
    barrier_c=0x7ffff52eefec) at common/barrier_counter.c:41
#2  0x00007ffff501eb9f in starpu_task_wait_for_all () at core/task.c:743
#3  0x00000000004d02ae in sy_starpu_submit_tasks (sopalin_data=0xdb15a0)
    at /home/lacoste/mateo70/pastix/starpu/starpu_submit_tasks_sy.c:1492
#4  0x0000000000463333 in sy_sopalin_thread (m=0xcbbd90, sopaparam=0xcbbfa8)
    at /home/lacoste/mateo70/pastix/sopalin/sopalin3d_sy.c:1198
#5  0x0000000000425dc8 in pastix_task_sopalin (pastix_data=0xcbbd30,
    pastix_comm=0x8ef600, n=12111, colptr=0xc367e0, row=0x7fffecd46010,
    avals=0x7fffeccf6010, b=0xc4e270, rhsnbr=1, loc2glob=0x0)
    at /home/lacoste/mateo70/pastix/sopalin/pastix.c:1588
#6  0x0000000000429677 in pastix (pastix_data=0x7fffffffb1d0,
    avals=0x7fffeccf6010, perm=0xc8c830, invp=0xca42b0, b=0xc4e270, rhs=1,
    iparm=0x7fffffffb258, dparm=0x7fffffffb4e0)
    at /home/lacoste/mateo70/pastix/sopalin/pastix.c:2929
#7  0x000000000042060c in main (argc=24, argv=0x7fffffffb888)
    at /home/lacoste/mateo70/pastix/example/simple.c:205
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Attachment: signature.asc
Description: Message signed with OpenPGP using GPGMail
Haut de le page
