Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Marc Sergent <marc.sergent@inria.fr>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Configure option --with-magma not working
- Date: Thu, 22 May 2014 22:00:40 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
On 22/05/2014 21:34, Marc Sergent wrote:
Hi,
It seems that the documented option --with-magma is not recognized by the
configure script. Actually, Magma can only be linked with StarPU by setting
a correct PKG_CONFIG_PATH to the magma.pc file path.
Best regards,
Marc
Which version of StarPU?
Do you mean you need that option ? Or do you mean it should be removed from the documentation as it has been removed from configure.ac (to use instead pkg-config) ?
Cheers,
Nathalie
- [Starpu-devel] Configure option --with-magma not working, Marc Sergent, 22/05/2014
- Re: [Starpu-devel] Configure option --with-magma not working, Nathalie Furmento, 22/05/2014
- Re: [Starpu-devel] Configure option --with-magma not working, Marc Sergent, 22/05/2014
