Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Marc Sergent <marc.sergent@inria.fr>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Configure option --with-magma not working
- Date: Thu, 22 May 2014 23:14:40 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
On 22/05/2014 22:49, Marc Sergent wrote:
Le 22/05/2014 22:00, Nathalie Furmento a écrit :
On 22/05/2014 21:34, Marc Sergent wrote:
Hi,
It seems that the documented option --with-magma is not recognized by the
configure script. Actually, Magma can only be linked with StarPU by setting
a correct PKG_CONFIG_PATH to the magma.pc file path.
Best regards,
Marc
Which version of StarPU?
We're working with the latest StarPU release : 1.1.1.
Do you mean you need that option ? Or do you mean it should be removed from the documentation as it has been removed from configure.ac (to use instead pkg-config) ?
Actually the only way to link StarPU with Magma is to define this kind of PKG_CONFIG_PATH. I don't know what should
be better, to let the configure detect Magma by itself of let the user decide to link with Magma or not with the --with-magma
option, like it's actually done for FxT for example.
There is 2 different things here: is it possible to enable or disable a library? and how is the location of the library defined?
Actually, it seems that the make step fails if we only give a PKG_CONFIG_PATH with this kind of error :
Making all in src
Making all in stencil
make[3]: Entering directory `/home/masliah/dev/starpu-1.1.1/examples/stencil'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/masliah/dev/starpu-1.1.1/examples/stencil'
make[3]: Entering directory `/home/masliah/dev/starpu-1.1.1/examples'
CC cholesky_kernels.o
cholesky/cholesky_kernels.c:22:19: fatal error: magma.h: No such file or directory
#include "magma.h"
You should check in config.log if Magma has been properly detected and if the compilation of the example has the correct -I option.
We tried to use the MAGMA_LIBS and MAGMA_CFLAGS environment variables proposed by the ./configure --help, and we
got another error :
These 2 variables are made available by configure itself, when using the command PKG_CHECK_MODULES to look for a module xxx, configure automatically gives you both options: set a correct pkg-config_PATH and defining xxx_libs and xxx_cflags.
In file included from cholesky/cholesky_kernels.c:23:0:
/home/masliah/dev/magma-1.3.0/include/magma_lapack.h:12:2: error: #error Define one of ADD_, NOCHANGE, or UPCASE for how Fortran functions are name mangled.
In file included from /home/masliah/dev/magma-1.3.0/include/magma_lapack.h:16:0,
/home/masliah/dev/magma-1.3.0/include/magma_zlapack.h:23:28: error: ‘FORTRAN_NAME’ declared as function returning a function
#define blasf77_izamax FORTRAN_NAME( izamax, IZAMAX )
We found that it could be a missing -DADD_ compiling option.
Do you mean it is working by adding "-DADD_" to MAGMA_CFLAGS?
Cheers,
Nathalie
- [Starpu-devel] Configure option --with-magma not working, Marc Sergent, 22/05/2014
- Re: [Starpu-devel] Configure option --with-magma not working, Nathalie Furmento, 22/05/2014
- Re: [Starpu-devel] Configure option --with-magma not working, Marc Sergent, 22/05/2014
