Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] StarPU
- Date: Thu, 26 Jun 2014 12:42:32 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
okay seems like my gcc does like an other parameter order. Both echo calls contains -lstarpu-1.1 So, the output is now: user@host:~/starpu/test$ gcc hello_world.c -o hello_world `pkg-config --cflags libstarpu` `pkg-config --libs libstarpu` In file included from /home/user/starpu-install/include/starpu/1.1/starpu.h:137:0, from hello_world.c:1: /home/user/starpu-install/include/starpu/1.1/starpu_deprecated_api.h:27:2: warning: #warning Your application is using deprecated types. You may want to update to use the latest API, by using tools/dev/rename.sh. [-Wcpp] hello_world.c: In function ‘main’: hello_world.c:19:12: warning: ignoring return value of ‘starpu_init’, declared with attribute warn_unused_result [-Wunused-result] hello_world.c:26:19: warning: ignoring return value of ‘starpu_task_submit’, declared with attribute warn_unused_result [-Wunused-result] user@host:~/starpu/test$ ls hello_world hello_world.c user@host:~/starpu/test$ ./hello_world ./hello_world: error while loading shared libraries: libstarpu-1.1.so.7: cannot open shared object file: No such file or directory Thanks, Thilo Am 26.06.2014 11:49, schrieb Samuel Thibault: Hello, Thilo Kogge, le Wed 25 Jun 2014 18:43:29 +0200, a écrit : I was not able to install the gcc extension on my machine This is not a problem here, the example program you took doesn't use any language extension. gcc `pkg-config --cflags libstarpu` `pkg-config --libs libstarpu` hello_world.c -o hello_world [...] hello_world.c:(.text+0x31): undefined reference to `starpu_init' [...] user@machine:~/starpu/test$ pkg-config --libs libstarpu -L/home/user/starpu-install/lib -L/usr/local/cuda/lib64 -L/home/user/ hwloc-install/lib -lstarpu-1.1 -lcudart -lcublas -lcuda -lstdc++ -lOpenCL -lhwloc Well, I don't see how it could ever happen that starpu_init is missing while -lstarpu-1.1 is passed, as libstarpu always contains the starpu_init function. Could you make sure that nothing odd is happening by calling both gcc `pkg-config --cflags libstarpu` `pkg-config --libs libstarpu` hello_world.c -o hello_world echo `pkg-config --cflags libstarpu` `pkg-config --libs libstarpu` hello_world.c -o hello_world in the same shell, and check that the echo output contains -lstarpu-1.1 Also, perhaps for some reason your linking toolchain prefers -l flags to be appended after C files using their symbols, i.e. rather this: gcc hello_world.c -o hello_world `pkg-config --cflags libstarpu` `pkg-config --libs libstarpu` echo `pkg-config --cflags libstarpu` `pkg-config --libs libstarpu` hello_world.c -o hello_world It looks like if the examples are made for plugin-support. No, only examples inside the gcc-plugin directory are made for plugin support. Samuel |
- [Starpu-devel] StarPU, Thilo Kogge, 19/06/2014
- Re: [Starpu-devel] StarPU, Nathalie Furmento, 19/06/2014
- <Suite(s) possible(s)>
- [Starpu-devel] StarPU, Thilo Kogge, 20/06/2014
- Re: [Starpu-devel] StarPU, Nathalie Furmento, 23/06/2014
- Message indisponible
- Re: [Starpu-devel] StarPU, Thilo Kogge, 25/06/2014
- Re: [Starpu-devel] StarPU, Samuel Thibault, 26/06/2014
- Re: [Starpu-devel] StarPU, Thilo Kogge, 26/06/2014
- Re: [Starpu-devel] StarPU, Thilo Kogge, 27/06/2014
