Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] StarPU
- Date: Fri, 27 Jun 2014 08:57:30 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
thank you, seems to work now. I exportet the path to LD_LIBARY_PATH instead of LD_LIBRARY_PATH.
Have a nice day,
Thilo
Am 26.06.2014 13:30, schrieb Samuel Thibault:
Thilo Kogge, le Thu 26 Jun 2014 12:42:32 +0200, a écrit :
user@host:~/starpu/test$ ./hello_worldYou need to put the place where you have installed starpu into your
./hello_world: error while loading shared libraries: libstarpu-1.1.so.7:
cannot
open shared object file: No such file or directory
LD_LIBRARY_PATH environment variable, see the “Setting Flags for
Compiling, Linking and Running Applications” section of the
documentation.
Samuel
- [Starpu-devel] StarPU, Thilo Kogge, 19/06/2014
- Re: [Starpu-devel] StarPU, Nathalie Furmento, 19/06/2014
- <Suite(s) possible(s)>
- [Starpu-devel] StarPU, Thilo Kogge, 20/06/2014
- Re: [Starpu-devel] StarPU, Nathalie Furmento, 23/06/2014
- Message indisponible
- Re: [Starpu-devel] StarPU, Thilo Kogge, 25/06/2014
- Re: [Starpu-devel] StarPU, Samuel Thibault, 26/06/2014
- Re: [Starpu-devel] StarPU, Thilo Kogge, 26/06/2014
- Re: [Starpu-devel] StarPU, Thilo Kogge, 27/06/2014
