Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU fails when using dmda/pheft with more than 1 GPU
Archives de la liste
Chronologique Discussions
  • From: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • To: David Pereira <david_sape@hotmail.com>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] StarPU fails when using dmda/pheft with more than 1 GPU
  • Date: Mon, 22 Sep 2014 12:10:52 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
David Pereira, le Sat 20 Sep 2014 23:30:27 +0100, a écrit :
> I found the reason of the unspecified launch failure. It turns out that it
> was
> from destroying a cusparse handle (twice).
> Is there a way to initialize cusparse across all GPU devices the same way
> we do
> with cublas (starpu_cublas_init)?
Yes, this is described in details in the documentation, under “How To
Initialize A Computation Library Once For Each Worker?”
Basically you want to call starpu_execute_on_each_worker, which is
actually exactly what starpu_cublas_init does.
> > > Also, is it possible that a CUDA program runs faster when using StarPU
> > > (using one GPU) than running the program without the framework? The
> > > StarPU version has parallel tasks unlike the version without the
> > > framework (which does not use streams).
> > StarPU implements a lot of optimisations such as overlapping data
> > transfers with computations, which are often not easy to code directly
> > in the application. The parallel implementation of tasks can also of
> > course considerably reduce the critical path in the task graph.
> How can overlapping data transfers with computations improve execution time
> of
> the StarPU version (using only 1 GPU)
> over running only in the GPU?, since my algorithm runs completely in the GPU
> without transfers to the CPU?
Ah, then I don't think StarPU could gain much. I guess you could check
on the trace the details of what is happening, and compare with the
execution without using StarPU.
> Also, even with parallel implementation of tasks, if I only execute on a
> single
> GPU (without concurrent kernels), I think I'm not supposed to have better
> results with StarPU (which I have).
Yes.
Samuel
Haut de le page
