Archives de la liste
[Starpu-devel] Compile problem when installing StarPU with Xeon Phi support
Chronologique Discussions
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] Compile problem when installing StarPU with Xeon Phi support
- Date: Sat, 27 Sep 2014 01:51:26 +0000
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi everyone,
I'm having a hard time installing StarPU (from a nightly build of 2014-09-22) with MIC support. I keep getting this error:
CC libstarpu_1.2_la-bound.lo
CC libstarpu_1.2_la-profiling_helpers.lo
CC libstarpu_1.2_la-starpu_top.lo
CC libstarpu_1.2_la-starpu_top_task.lo
CC libstarpu_1.2_la-starpu_top_message_queue.lo
CC libstarpu_1.2_la-starpu_top_connection.lo
CC libstarpu_1.2_la-worker_list.lo
CC libstarpu_1.2_la-worker_tree.lo
CC libstarpu_1.2_la-driver_cpu.lo
CC libstarpu_1.2_la-starpu_cublas.lo
CC libstarpu_1.2_la-disk_unistd_o_direct.lo
CC libstarpu_1.2_la-mp_common.lo
CC libstarpu_1.2_la-source_common.lo
CC libstarpu_1.2_la-sink_common.lo
CC libstarpu_1.2_la-driver_mic_common.lo
CC libstarpu_1.2_la-driver_mic_source.lo
CC libstarpu_1.2_la-driver_mic_sink.lo
CC libstarpu_1.2_la-driver_mic_utils.lo
../.././src/drivers/mp_common/sink_common.c(211): error: struct "_starpu_worker" has no field "parallel_sect_mutex"
starpu_pthread_mutex_init(&workers[i].parallel_sect_mutex,NULL);
../.././src/drivers/mp_common/sink_common.c(212): error: struct "_starpu_worker" has no field "parallel_sect_mutex"
starpu_pthread_mutex_destroy(&workers[i].parallel_sect_mutex);
../.././src/drivers/mp_common/sink_common.c(214): error: struct "_starpu_worker" has no field "parallel_sect_cond"
starpu_pthread_cond_init(&workers[i].parallel_sect_cond,NULL);
../.././src/drivers/mp_common/sink_common.c(215): error: struct "_starpu_worker" has no field "parallel_sect_cond"
starpu_pthread_cond_destroy(&workers[i].parallel_sect_cond);
compilation aborted for ../.././src/drivers/mp_common/sink_common.c (code 2)
make[3]: *** [libstarpu_1.2_la-sink_common.lo] Error 1
make[3]: *** Waiting for unfinished jobs....
make[3]: Leaving directory `/home/cpd22821/starpu/starpu-1.2.0/build_mic/src'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/cpd22821/starpu/starpu-1.2.0/build_mic/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/cpd22821/starpu/starpu-1.2.0/build_mic'
make: *** [all] Error 2"
Could someone help me?
Best Regards
David Pereira
- [Starpu-devel] Compile problem when installing StarPU with Xeon Phi support, David Pereira, 27/09/2014
- Re: [Starpu-devel] Compile problem when installing StarPU with Xeon Phi support, Nathalie Furmento, 29/09/2014
