Archives de la liste
Re: [Starpu-devel] Compile problem when installing StarPU with Xeon Phi support
Chronologique Discussions
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: David Pereira <david_sape@hotmail.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Compile problem when installing StarPU with Xeon Phi support
- Date: Mon, 29 Sep 2014 14:54:57 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi David,
The MIC code has not been tested in a while. The machine we did the test on is
no longer available, i am currently trying to do the compilation on another
machine. I will let you know as soon as i am succesfull.
Cheers,
Nathalie
On Sep 27, 01:51, David Pereira wrote:
> Hi everyone,
> I'm having a hard time installing StarPU (from a nightly build of
> 2014-09-22)
> with MIC support. I keep getting this error:
> CC libstarpu_1.2_la-bound.lo
> CC libstarpu_1.2_la-profiling_helpers.lo
> CC libstarpu_1.2_la-starpu_top.lo
> CC libstarpu_1.2_la-starpu_top_task.lo
> CC libstarpu_1.2_la-starpu_top_message_queue.lo
> CC libstarpu_1.2_la-starpu_top_connection.lo
> CC libstarpu_1.2_la-worker_list.lo
> CC libstarpu_1.2_la-worker_tree.lo
> CC libstarpu_1.2_la-driver_cpu.lo
> CC libstarpu_1.2_la-starpu_cublas.lo
> CC libstarpu_1.2_la-disk_unistd_o_direct.lo
> CC libstarpu_1.2_la-mp_common.lo
> CC libstarpu_1.2_la-source_common.lo
> CC libstarpu_1.2_la-sink_common.lo
> CC libstarpu_1.2_la-driver_mic_common.lo
> CC libstarpu_1.2_la-driver_mic_source.lo
> CC libstarpu_1.2_la-driver_mic_sink.lo
> CC libstarpu_1.2_la-driver_mic_utils.lo
> ../.././src/drivers/mp_common/sink_common.c(211): error: struct
> "_starpu_worker" has no field "parallel_sect_mutex"
> starpu_pthread_mutex_init(&workers[i].parallel_sect_mutex,NULL);
> ../.././src/drivers/mp_common/sink_common.c(212): error: struct
> starpu_pthread_mutex_destroy(&workers[i].parallel_sect_mutex);
> ../.././src/drivers/mp_common/sink_common.c(214): error: struct
> "_starpu_worker" has no field "parallel_sect_cond"
> starpu_pthread_cond_init(&workers[i].parallel_sect_cond,NULL);
> ../.././src/drivers/mp_common/sink_common.c(215): error: struct
> starpu_pthread_cond_destroy(&workers[i].parallel_sect_cond);
> compilation aborted for ../.././src/drivers/mp_common/sink_common.c (code 2)
> make[3]: *** [libstarpu_1.2_la-sink_common.lo] Error 1
> make[3]: *** Waiting for unfinished jobs....
> make[3]: Leaving directory
> `/home/cpd22821/starpu/starpu-1.2.0/build_mic/src'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home/cpd22821/starpu/starpu-1.2.0/build_mic'
> make: *** [all] Error 2"
> Could someone help me?
> Best Regards
> David Pereira
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Dr Nathalie Furmento CNRS R&D Engineer
Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
200 avenue de la vieille Tour Tel: +33 (0)5 24 57 41 20
33405 Talence cedex, FRANCE Fax: +33 (0)5 24 57 40 41
- [Starpu-devel] Compile problem when installing StarPU with Xeon Phi support, David Pereira, 27/09/2014
- Re: [Starpu-devel] Compile problem when installing StarPU with Xeon Phi support, Nathalie Furmento, 29/09/2014
