Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] StarPU Configuration/Build error
- Date: Thu, 4 Dec 2014 19:25:09 -0500
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi,
I am trying to build StarPU 1.3 from source on a machine with NVIDIA GPU and CUDA 5.5. This is the command I am using
../configure --without-hwloc --disable-opencl --with-cuda-dir=/opt/nvidia/cudatoolkit/default --with-cuda-include-dir=/opt/nvidia/cudatoolkit/default/include --with-cuda-lib-dir=/opt/nvidia/cudatoolkit/default/lib64
I get an error during configuration
checking for library containing set_mempolicy... -lnuma
checking whether libnuma is available... yes
checking maximum number of sched_ctxs... 10
checking maximum number of CPUs... 64
checking whether CPUs should be used... yes
checking maximum number of CUDA devices... 4
checking whether CUDA is available in /opt/nvidia/cudatoolkit/default...
checking cuda.h usability... yes
checking cuda.h presence... yes
checking for cuda.h... yes
checking whether CUDA is available with: -L/opt/nvidia/cudatoolkit/default/lib64...
checking for main in -lcuda... no
checking whether CUDA is available...
checking cuda.h usability... no
checking cuda.h presence... no
checking for cuda.h... no
checking whether CUDA is available in /usr/local/cuda...
checking whether CUDA is available in /c/cuda...
checking whether CUDA is available in /cygdrive/c/cuda...
checking whether CUDA is available in /opt/cuda...
checking whether CUDA is available with: -L/opt/nvidia/cudatoolkit/default/lib...
checking whether CUDA is available with: -L/opt/nvidia/cudatoolkit/default/lib/x64...
checking whether CUDA is available with: -L/opt/nvidia/cudatoolkit/default/lib/Win32...
checking whether CUDA is available in /.....
checking whether CUDA is working... no
configure: error: cannot find CUDA
It seems that it initially finds CUDA installation in the path specified, but continues to look at other locations.
I have attached that config.log file.
Please let me know if I am missing something.
Thanks,
Pushkar
config.log
Description: Binary data
- [Starpu-devel] StarPU Configuration/Build error, Pushkar Ratnalikar, 05/12/2014
- Re: [Starpu-devel] StarPU Configuration/Build error, Nathalie Furmento, 05/12/2014
