Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Pushkar Ratnalikar <pratnali@umail.iu.edu>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] StarPU Configuration/Build error
- Date: Fri, 05 Dec 2014 09:53:33 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi,
configure finds the CUDA include files ... > checking whether CUDA
is available in /opt/nvidia/cudatoolkit/default...
> checking cuda.h usability... yes
> checking cuda.h presence... yes
> checking for cuda.h... yes
but not the lib files ... > checking whether CUDA
is available with: -L/opt/nvidia/cudatoolkit/default/lib64...
> checking for main in
-lcuda... no
You should make sure that they are available in /opt/nvidia/cudatoolkit/default/lib64. Regards, Nathalie On 05/12/2014 01:25, Pushkar Ratnalikar wrote: Hi,
I am trying to build StarPU 1.3 from source on a machine
with NVIDIA GPU and CUDA 5.5. This is the command I am using
../configure --without-hwloc --disable-opencl --with-cuda-dir=/opt/nvidia/cudatoolkit/default
--with-cuda-include-dir=/opt/nvidia/cudatoolkit/default/include
--with-cuda-lib-dir=/opt/nvidia/cudatoolkit/default/lib64
I get an error during configuration
checking for library
containing set_mempolicy... -lnuma
checking whether libnuma is
available... yes
checking maximum
number of sched_ctxs... 10
checking maximum
number of CPUs... 64
checking whether CPUs
should be used... yes
checking maximum
number of CUDA devices... 4
checking for main in -lcuda... no
is available...
checking cuda.h usability... no
checking cuda.h presence... no
checking for cuda.h... no
is available in /usr/local/cuda...
is available in /c/cuda...
is available in /cygdrive/c/cuda...
is available in /opt/cuda...
is available with: -L/opt/nvidia/cudatoolkit/default/lib...
is available with: -L/opt/nvidia/cudatoolkit/default/lib/x64...
is available with: -L/opt/nvidia/cudatoolkit/default/lib/Win32...
is available in /.....
is working... no
configure: error:
cannot find CUDA
It seems that it initially finds CUDA installation in the
path specified, but continues to look at other locations.
I have attached that config.log file.
Please let me know if I am missing something.
Thanks,
Pushkar
_______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel |
- [Starpu-devel] StarPU Configuration/Build error, Pushkar Ratnalikar, 05/12/2014
- Re: [Starpu-devel] StarPU Configuration/Build error, Nathalie Furmento, 05/12/2014
