Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] starpu 1.1 and execute_on_worker
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] starpu 1.1 and execute_on_worker
  • Date: Mon, 26 Jan 2015 17:50:30 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
I moved to branche 1.1 (from trunk 1.2) and get an error when submiting a task.
        ret =
            starpu_mpi_insert_task(sopalin_data->sopar->pastix_comm, cl,
                                   STARPU_VALUE, &sopalin_data, sizeof(z_Sopalin_Data_t*),
                                   STARPU_VALUE, &cblk,        sizeof(z_SolverCblk*),
                                   STARPU_VALUE, &blok,        sizeof(z_SolverBlok*),
                                   STARPU_VALUE, &fcblk,       sizeof(z_SolverCblk*),
                                   STARPU_R,     L_handle[itercblk],
                                   STARPU_COMMUTE|STARPU_RW,    *L_target_handle,
                                   STARPU_SCRATCH, starpu_loop_data->WORK_handle,
                                   STARPU_R,  starpu_loop_data->blocktab_handles[dst_proc],
                                   STARPU_EXECUTE_ON_WORKER, workerid,
                                   STARPU_CALLBACK,     z_prof_callback,
                                   STARPU_CALLBACK_ARG, sopalin_data->gemm_stats,
                                   STARPU_PRIORITY, prio,
                                   0);
The starpu_mpi_insert_task goes through the va_arg list several time and at line 469, when examining STARPU_EXECUTE_ON_WORKER, it goes line 473 (as if a buffer was the next argument) and then crash when trying to get the rank of what StarPU expect to be a data which is in fact the workerid...
This happen without MPI on curie (CCRT). I may be doing something wrong but the fact that the other va_list inspection succeed let me think there can be a mistake in the tests in this loop.
If I remove the STARPU_EXECUTE_ON_WORKER part it works again.
regards,
XL.
Xavier Lacoste
INRIA Bordeaux Sud-Ouest
200, avenue de la Vieille Tour
33405 Talence Cedex
Tél : +33 (0)5 24 57 40 69
Haut de le page
