Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU on multiple communicator
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Xavier Lacoste <xavier.lacoste@inria.fr>
  • Cc: Mathieu Faverge <Mathieu.Faverge@inria.fr>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] StarPU on multiple communicator
  • Date: Fri, 30 Jan 2015 13:51:51 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
The functionality should now be fully supported in the branch 1.1.
There is a small test in mpi/tests/comm.c
Please let me know if it works for you.
Cheers,
Nathalie
On 27/01/2015 17:07, Xavier Lacoste wrote:
Sorry,
I didn't see your answer,
Yes this is what I want to do.
Can I see your code to try to understand what is wrong in mine ?
Cheers,
XL
Le 26 janv. 2015 à 11:59, Nathalie Furmento <nathalie.furmento@labri.fr> a
écrit :
I also tested with calling starpu_mpi_insert_task. Again it works fine with
StarPU 1.1 but fails with the trunk.
The data is owned by the node 0 of each sub communicator. The call
starpu_mpi_insert_task(newcomm, &mycodelet,
STARPU_RW, data,
STARPU_EXECUTE_ON_NODE, 1,
0);
results in the execution of the codelet on the processes having a rank 1 in
each sub-communicator, which is if i understood correctly what you would like
to have in your application.
Cheers,
Nathalie
On 26/01/2015 11:35, Nathalie Furmento wrote:
Hello,
I tried a simple application which splits in 2 communicators a group of 4 MPI
processes,
and a communication is made between the rank 0 and the rank 1 of each new sub
communicator.
This works fine with the branch 1.1 of StarPU. However it fails with the
trunk version of
StarPU. Its new communication engine assumes MPI_COMM_WORLD to be the
communicator for all
communications. I am going to have a look at how it can be fixed. I will keep
you informed.
Cheers,
Nathalie
On Jan 23, 16:40, Xavier Lacoste wrote:
Hello,
I am using PaStiX in Jorek (A Tokamak simulation code).
Jorek uses sub-communicators to factorize different matrices on different
communicators (i.e. P0 and P1 factorize mat1 while P2 and P3 factorize mat2).
The two matrices have exactly the same shape, so the same shape block columns
(my data unit in starpu), identified with the same tags, but these data are
in fact different as they belong to different matrices (mat1 and mat2).
As far as I understand this cannot work in StarPU today ( I saw Nathalie who
agrees with me on that ;) ).
P0 and P2 (resp. P1 and P3) will register their data with exactly the same
TAG. Thus we have two different data with the same TAG which could be a
problem.
An other issue is that the rank of the data is set using the sub-communicator
rank which may not be what is expected by StarPU.
All this results in StarPU hanging in a deadlock, certainly waiting for
communications...
I hope I am not too confusing in my explanations.
I'll try a hack in my code to fix that: use global rank when registering data
and retrieve the number of communicators (here my communicators have the same
size hopefully) and add an offset to the TAGS.
I think supporting communicator in StarPU would be a great feature.
Regards,
XL.
Xavier Lacoste
INRIA Bordeaux Sud-Ouest
200, avenue de la Vieille Tour
33405 Talence Cedex
Tél : +33 (0)5 24 57 40 69
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
