Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: mansouri farouk <farouk.mansouri@gipsa-lab.grenoble-inp.fr>
- Cc: Starpu devel <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Link a Tag to a task using starpu_insert_task()
- Date: Wed, 11 Feb 2015 10:15:42 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
mansouri farouk, le Tue 10 Feb 2015 15:54:39 +0100, a écrit :
> [starpu][starpu_mpi_insert_task][assert failure] STARPU_TAG is not supported
> in MPI mode
Yes, we haven't implemented it yet. It shouldn't be very hard to
implement it, it's a matter of defining the semantic it is supposed to
have and not have (no tag dependency between different MPI nodes, at
least for now).
> Can someone tell me if it is possible to use Tag dependecy over Starpu_MPI ?
> If not how can i do that otherwise ?
With StarPU 1.2, you can modify the task after creating it with
StarPU-MPI: call starpu_mpi_task_build, then you can modify it before
submitting it, and calling starpu_mpi_task_post_build to finish. See the
insert_task_compute.c testcase.
Samuel
- [Starpu-devel] Link a Tag to a task using starpu_insert_task(), mansouri farouk, 10/02/2015
- Re: [Starpu-devel] Link a Tag to a task using starpu_insert_task(), Samuel Thibault, 11/02/2015
- Re: [Starpu-devel] Link a Tag to a task using starpu_insert_task(), mansouri farouk, 12/02/2015
- Re: [Starpu-devel] Link a Tag to a task using starpu_insert_task(), mansouri farouk, 13/02/2015
