Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Link a Tag to a task using starpu_insert_task()
Archives de la liste
Chronologique Discussions
  • From: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • To: mansouri farouk <farouk.mansouri@gipsa-lab.grenoble-inp.fr>, Starpu devel <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] Link a Tag to a task using starpu_insert_task()
  • Date: Wed, 11 Feb 2015 10:42:59 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Samuel Thibault, le Wed 11 Feb 2015 10:15:42 +0100, a écrit :
> > [starpu][starpu_mpi_insert_task][assert failure] STARPU_TAG is not
> > supported
> > in MPI mode
> Yes, we haven't implemented it yet. It shouldn't be very hard to
> implement it, it's a matter of defining the semantic it is supposed to
> have and not have (no tag dependency between different MPI nodes, at
> least for now).
The "implementation" could be as simple as this patch. It however
assumes that there is not tag dependency between different MPI nodes,
without testing it.
Samuel
Index: mpi/src/starpu_mpi_task_insert.c
--- mpi/src/starpu_mpi_task_insert.c (révision 14446)
+++ mpi/src/starpu_mpi_task_insert.c (copie de travail)
@@ -348,7 +348,7 @@
/* STARPU_DATA_MODE_ARRAY handled above */
else if (arg_type==STARPU_TAG)
- STARPU_ASSERT_MSG(0, "STARPU_TAG is not supported in
MPI mode\n");
+ (void)va_arg(varg_list_copy, starpu_tag_t);
else if (arg_type==STARPU_HYPERVISOR_TAG)
@@ -487,6 +487,8 @@
_starpu_mpi_clear_data_after_execution(descrs[i].handle,
descrs[i].mode, me, do_execute, comm);
+ free(descrs);
_STARPU_MPI_LOG_OUT();
return 0;
Haut de le page
