Archives de la liste
- From: Sreeprakash S <sreeprakash.s@creativegenius.co.in>
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Sreeprakash S <sreeprakash.s@creativegenius.co.in>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Build issues On Windows8.1
- Date: Tue, 17 Feb 2015 16:27:07 +0530
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi Samuel,
Once again thanks for the prompt response. I tried configuring it with native winthreads options enabled, as you suggested, but it still kept giving the same errors. This is the configure command that I gave.
sh-3.1$ ../configure --prefix=$PWD/target --with-hwloc="C:/HWLOC" --with-cuda-d
ir="C:/StarPu/CUDA/v6.5" --with-cuda-include-dir="C:/StarPu/Cuda/v6.5/include"
--with-cuda-lib-dir="c:/StarPu/Cuda/v6.5/lib/win32" --with-opencl-dir="c:/StarP
u/Cuda/v6.5" --with-opencl-include-dir="c:/StarPu/Cuda/v6.5/include/cl" --with-
opencl-lib-dir="c:/StarPu/Cuda/v6.5/lib/win32" --disable-build-doc --enable-qui
ck-check --enable-native-winthreads
If its an issue with the latest version of mingw can I try rolling it back to a particular version and start building it. If so, can you mention the mingw version for which starPu will definitely build.
Thanks in advance,
Sreeprakash
On Mon, Feb 16, 2015 at 10:55 PM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
Sreeprakash S, le Mon 16 Feb 2015 20:30:25 +0530, a écrit :
> In file included from c:\mingw\include\unistd.h:95:0,
> from ../../src/common/timing.h:29,
> from ../../src/common/timing.c:22:
> c:\mingw\include\parts\time.h:65:8: error: redefinition of 'struct timespec'
> struct timespec
> In file included from ../../include/starpu_thread.h:26:0,
> from ../../include/starpu.h:44,
> from ../../src/common/timing.c:18:
> c:\mingw\include\pthread.h:320:8: note: originally defined here
> struct timespec {
Ew. So your version of mingw actually has conflicting definitions in
time.h and pthread.h...
You can try to give ./configure the --enable-native-winthreads option,
to use our own pthread.h, to avoid the conflict?
Samuel
- [Starpu-devel] Build issues On Windows8.1, Sreeprakash S, 16/02/2015
- Re: [Starpu-devel] Build issues On Windows8.1, Samuel Thibault, 16/02/2015
- Re: [Starpu-devel] Build issues On Windows8.1, Sreeprakash S, 16/02/2015
- Re: [Starpu-devel] Build issues On Windows8.1, Sreeprakash S, 17/02/2015
- Re: [Starpu-devel] Build issues On Windows8.1, Samuel Thibault, 17/02/2015
- Re: [Starpu-devel] Build issues On Windows8.1, Sreeprakash S, 18/02/2015
