Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Build issues On Windows8.1
Archives de la liste
Chronologique Discussions
  • From: Sreeprakash S <sreeprakash.s@creativegenius.co.in>
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Sreeprakash S <sreeprakash.s@creativegenius.co.in>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Build issues On Windows8.1
  • Date: Tue, 17 Feb 2015 20:24:38 +0530
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi Samuel,
PFA, the config log, the Make output and the make file generated.
P.S : I tried the same on a different machine, using the same version of mingw and starpu (disabling cuda as its using an AMD card), and got the same errors.
Will try reverting to the older mingw version and check.
Thanks And Regards,
Sreeprakash
On Tue, Feb 17, 2015 at 7:11 PM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
Sreeprakash S, le Tue 17 Feb 2015 16:27:07 +0530, a écrit :
> Once again thanks for the prompt response. I tried configuring it with native
> winthreads options enabled, as you suggested, but it still kept giving the same
> errors.
That's not supposed to happen: it's not supposed to be even seeing
pthread.h from mingw32. Could you please post your config.log file and
make output?
> If so, can you mention the mingw version for which starPu will
> definitely build.
Apparently on our machine we use version 3.17.
Samuel
In file included from C:/StarPu/Cuda/v6.5/include/builtin_types.h:60:0,
from C:/StarPu/Cuda/v6.5/include/cuda_runtime.h:67,
from ../../include/starpu_data_interfaces.h:29,
from ../../include/starpu.h:48,
from ../../src/common/utils.h:21,
from ../../src/common/barrier.c:18:
C:/StarPu/Cuda/v6.5/include/vector_types.h:73:0: warning: ignoring #pragma
warni
ng [-Wunknown-pragmas]
#pragma warning(push)
C:/StarPu/Cuda/v6.5/include/vector_types.h:74:0: warning: ignoring #pragma
warni
#pragma warning(disable: 4201 4408)
C:/StarPu/Cuda/v6.5/include/vector_types.h:350:0: warning: ignoring #pragma
warn
ing [-Wunknown-pragmas]
#pragma warning(pop)
CC libstarpu_1.1_la-bitmap.lo
In file included from C:/StarPu/Cuda/v6.5/include/device_types.h:53:0,
from C:/StarPu/Cuda/v6.5/include/builtin_types.h:56,
from ../../src/common/bitmap.c:17:
C:/StarPu/Cuda/v6.5/include/host_defines.h:79:0: warning: "__cdecl" redefined
[e
nabled by default]
#define __cdecl
../../src/common/bitmap.c:1:0: note: this is the location of the previous
defini
tion
/* StarPU --- Runtime system for heterogeneous multicore architectures.
warni
warni
warn
CC libstarpu_1.1_la-barrier_counter.lo
from ../../src/common/barrier_counter.h:20,
from ../../src/common/barrier_counter.c:17:
[e
nabled by default]
#define __cdecl
../../src/common/barrier_counter.c:1:0: note: this is the location of the
previo
us definition
warni
warni
warn
CC libstarpu_1.1_la-hash.lo
from ../../src/common/hash.c:18:
[e
nabled by default]
#define __cdecl
../../src/common/hash.c:1:0: note: this is the location of the previous
definiti
on
warni
warni
warn
CC libstarpu_1.1_la-rwlock.lo
from ../../src/common/rwlock.h:22,
from ../../src/common/rwlock.c:22:
[e
nabled by default]
#define __cdecl
../../src/common/rwlock.c:1:0: note: this is the location of the previous
defini
tion
warni
warni
warn
CC libstarpu_1.1_la-starpu_spinlock.lo
from ../../src/common/thread.h:21,
from ../../src/common/starpu_spinlock.h:24,
from ../../src/common/starpu_spinlock.c:18:
[e
nabled by default]
#define __cdecl
../../src/common/starpu_spinlock.c:1:0: note: this is the location of the
previo
us definition
warni
warni
warn
CC libstarpu_1.1_la-timing.lo
from ../../src/common/timing.c:18:
[e
nabled by default]
#define __cdecl
../../src/common/timing.c:1:0: note: this is the location of the previous
defini
tion
warni
warni
warn
In file included from c:\mingw\include\unistd.h:95:0,
from ../../src/common/timing.h:29,
from ../../src/common/timing.c:22:
c:\mingw\include\parts\time.h:65:8: error: redefinition of 'struct timespec'
struct timespec
In file included from ../../include/starpu_thread.h:26:0,
from ../../include/starpu.h:44,
d:/works/mine/opencl/starpu_1_1_3/build/../include/pthread_win32/pthread.h:276:8
: note: originally defined here
struct timespec {
../../src/common/timing.c: In function '_starpu_timing_init':
../../src/common/timing.c:178:3: warning: 'usleep' is deprecated (declared at
c:
\mingw\include\unistd.h:129) [-Wdeprecated-declarations]
usleep(500000);
../../src/common/timing.c: At top level:
../../src/common/timing.c:224:8: error: conflicting types for
'starpu_timing_tim
espec_delay_us'
double starpu_timing_timespec_delay_us(struct timespec *start, struct
timespec
*end)
In file included from ../../include/starpu.h:63:0,
../../include/starpu_profiling.h:167:8: note: previous declaration of
'starpu_ti
ming_timespec_delay_us' was here
timespec
*end);
../../src/common/timing.c: In function 'starpu_timing_timespec_delay_us':
../../src/common/timing.c:228:2: warning: passing argument 1 of
'starpu_timespec
_sub' from incompatible pointer type [enabled by default]
starpu_timespec_sub(end, start, &diff);
../../include/starpu_profiling.h:150:29: note: expected 'const struct
timespec *
' but argument is of type 'struct timespec *'
static __starpu_inline void starpu_timespec_sub(const struct timespec *a,
../../src/common/timing.c:228:2: warning: passing argument 2 of
'starpu_timespec
timespec *
../../src/common/timing.c:228:2: warning: passing argument 3 of
'starpu_timespec
../../include/starpu_profiling.h:150:29: note: expected 'struct timespec *'
but
../../src/common/timing.c:235:8: error: conflicting types for
'starpu_timing_tim
espec_to_us'
double starpu_timing_timespec_to_us(struct timespec *ts)
../../include/starpu_profiling.h:168:8: note: previous declaration of
'starpu_ti
ming_timespec_to_us' was here
double starpu_timing_timespec_to_us(struct timespec *ts);
make[2]: *** [libstarpu_1.1_la-timing.lo] Error 1
make[2]: Leaving directory `/d/works/mine/opencl/starpu_1_1_3/build/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/d/works/mine/opencl/starpu_1_1_3/build/src'
make: *** [all-recursive] Error 1
Attachment: config.log
Description: Binary data
Attachment: Makefile
Haut de le page
