Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Build issues On Windows8.1
Archives de la liste
Chronologique Discussions
  • From: Sreeprakash S <sreeprakash.s@creativegenius.co.in>
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Sreeprakash S <sreeprakash.s@creativegenius.co.in>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Build issues On Windows8.1
  • Date: Fri, 20 Feb 2015 12:53:06 +0530
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi Samuel,
   Am using the openCl libraries that came with the Cuda/6.5 SDK. OpenCl version 1.1. I have attached the cl.h and opencl.h files. I just reconfigured it with --enable-verbose and ran hello world again and here's the detailed log before the crash.
[starpu][starpu_init] Warning: StarPU was configured with --enable-verbose, whic
h slows down a bit
[starpu][_starpu_opencl_init] Initialising OpenCL
[starpu][_starpu_opencl_init] Platforms detected: 4
[starpu][_starpu_opencl_init] Platform: NVIDIA CUDA - NVIDIA Corporation
[starpu][_starpu_opencl_init]   1 devices detected
[starpu][_starpu_opencl_init] Platform: AMD Accelerated Parallel Processing - Ad
vanced Micro Devices, Inc.
[starpu][_starpu_opencl_init]   No devices detected on this platform
[starpu][_starpu_opencl_init] Platform: Intel(R) OpenCL - Intel(R) Corporation
[starpu][_starpu_opencl_init] Platform: Experimental OpenCL 2.0 CPU Only Platfor
m - Intel(R) Corporation
[starpu][load_bus_affinity_file_content] loading affinities from C:\Users\sreepr
akash.s/.starpu/sampling//bus/cgw33.affinity
[starpu][load_bus_latency_file_content] loading latencies from C:\Users\sreeprak
ash.s/.starpu/sampling//bus/cgw33.latency
[starpu][load_bus_bandwidth_file_content] loading bandwidth from C:\Users\sreepr
akash.s/.starpu/sampling//bus/cgw33.bandwidth
[starpu][load_sched_policy] Use eager scheduler (eager policy with a central que
ue)
[starpu][initialize_eager_center_policy] Warning: you are running the default ea
ger scheduler, which is not very smart. Make sure to read the StarPU documentati
on about adding performance models in order to be able to use the dmda scheduler
 instead.
[starpu][_starpu_launch_drivers] initialising worker 0
[starpu][_starpu_launch_drivers] initialising [starpu][_starpu_worker_start] wor
ker 0 is ready on logical cpu 1
[starpu][_starpu_worker_start] worker 0 cpuset start at 2
worker 1
[starpu][_starpu_opencl_init_[starpu][_starpu_launch_drivers] initialising worke
r 2
context] Initialising context for dev 0
[starpu][_starpu_launch_drivers] initialising worker 3
[starpu][_starpu_launch_drivers] waiting for worker 0 initialization
[osotpasr piun] [__ssttaarrppuu__owpoernkcelr__lsitmairtt_]g pwuo_rmkeemr_ i0f _
inse erdeeadd y( .o.n/ .l.o/gsircca/ld rcipvue r0s
/[ospteanrcplu/]d[r_isvtearr_poup_ewnocrlk.ecr:_7s9t)a r(t(]n uwlolr)k)e r. .2.
 i<sI nrveaaldiyd  ovna lluoeg>i c(a-l3 0c)p u
 3
Assertion failed: 0, file ../../include/starpu_opencl.h, line 43
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
[st[starpu][_starpu_worker_start] worker 2 cpuset start at 6
[starpu][_starpu_worker_start] worker 0 cpuset start at 0
[starpu][_starpu_memory_manager_set_global_memory_size] Global size forarpu][_st
arpu_worker_start] worker 1 is ready on logical cpu 2
[starpu][_starpu_memory_manager_set_global_memory_size] Global size for nod[star
pu][_star
Regards,
Sreeprakash
On Thu, Feb 19, 2015 at 9:36 PM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
Sreeprakash S, le Thu 19 Feb 2015 21:31:30 +0530, a écrit :
> oops in _starpu_opencl_limit_gpu_mem_if_needed (../../src/drivers/opencl/
> driver_
> opencl.c:79) ((null)) ... <Invalid value> (-30)
> Can you advice me on what could be wrong here.
Well, I don't know: the code just calls
        err = clGetDeviceInfo(devices[devid], CL_DEVICE_GLOBAL_MEM_SIZE, sizeof(totalGlobalMem), &totalGlobalMem, NULL);
        if (err != CL_SUCCESS)
                STARPU_OPENCL_REPORT_ERROR(err);
so it's nothing fancy, just getting the global memory size, but OpenCL
returns an error.  Which OpenCL implementation are you using?
Samuel
 * Copyright (c) 2008-2010 The Khronos Group Inc.
 * Permission is hereby granted, free of charge, to any person obtaining a
 * copy of this software and/or associated documentation files (the
 * "Materials"), to deal in the Materials without restriction, including
 * without limitation the rights to use, copy, modify, merge, publish,
 * distribute, sublicense, and/or sell copies of the Materials, and to
 * permit persons to whom the Materials are furnished to do so, subject to
 * the following conditions:
 * The above copyright notice and this permission notice shall be included
 * in all copies or substantial portions of the Materials.
 * THE MATERIALS ARE PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
 * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
 * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
 * IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY
 * CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT,
 * TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
 * MATERIALS OR THE USE OR OTHER DEALINGS IN THE MATERIALS.
/* $Revision: 11985 $ on $Date: 2010-07-15 11:16:06 -0700 (Thu, 15 Jul 2010) $ */
#ifndef __OPENCL_CL_H
#define __OPENCL_CL_H
#ifdef __APPLE__
#include <OpenCL/cl_platform.h>
#else
#include <CL/cl_platform.h>
#endif
#ifdef __cplusplus
extern "C" {
#endif
typedef struct _cl_platform_id *    cl_platform_id;
typedef struct _cl_device_id *      cl_device_id;
typedef struct _cl_context *        cl_context;
typedef struct _cl_command_queue *  cl_command_queue;
typedef struct _cl_mem *            cl_mem;
typedef struct _cl_program *        cl_program;
typedef struct _cl_kernel *         cl_kernel;
typedef struct _cl_event *          cl_event;
typedef struct _cl_sampler *        cl_sampler;
typedef cl_uint             cl_bool;                     /* WARNING!  Unlike cl_ types in cl_platform.h, cl_bool is not guaranteed to be the same size as the bool in kernels. */
typedef cl_ulong            cl_bitfield;
typedef cl_bitfield         cl_device_type;
typedef cl_uint             cl_platform_info;
typedef cl_uint             cl_device_info;
typedef cl_bitfield         cl_device_fp_config;
typedef cl_uint             cl_device_mem_cache_type;
typedef cl_uint             cl_device_local_mem_type;
typedef cl_bitfield         cl_device_exec_capabilities;
typedef cl_bitfield         cl_command_queue_properties;
typedef intptr_t			cl_context_properties;
typedef cl_uint             cl_context_info;
typedef cl_uint             cl_command_queue_info;
typedef cl_uint             cl_channel_order;
typedef cl_uint             cl_channel_type;
typedef cl_bitfield         cl_mem_flags;
typedef cl_uint             cl_mem_object_type;
typedef cl_uint             cl_mem_info;
typedef cl_uint             cl_image_info;
typedef cl_uint             cl_buffer_create_type;
typedef cl_uint             cl_addressing_mode;
typedef cl_uint             cl_filter_mode;
typedef cl_uint             cl_sampler_info;
typedef cl_bitfield         cl_map_flags;
typedef cl_uint             cl_program_info;
typedef cl_uint             cl_program_build_info;
typedef cl_int              cl_build_status;
typedef cl_uint             cl_kernel_info;
typedef cl_uint             cl_kernel_work_group_info;
typedef cl_uint             cl_event_info;
typedef cl_uint             cl_command_type;
typedef cl_uint             cl_profiling_info;
typedef struct _cl_image_format {
    cl_channel_order        image_channel_order;
    cl_channel_type         image_channel_data_type;
} cl_image_format;
typedef struct _cl_buffer_region {
    size_t                  origin;
    size_t                  size;
} cl_buffer_region;
/* Error Codes */
#define CL_SUCCESS                                  0
#define CL_DEVICE_NOT_FOUND                         -1
#define CL_DEVICE_NOT_AVAILABLE                     -2
#define CL_COMPILER_NOT_AVAILABLE                   -3
#define CL_MEM_OBJECT_ALLOCATION_FAILURE            -4
#define CL_OUT_OF_RESOURCES                         -5
#define CL_OUT_OF_HOST_MEMORY                       -6
#define CL_PROFILING_INFO_NOT_AVAILABLE             -7
#define CL_MEM_COPY_OVERLAP                         -8
#define CL_IMAGE_FORMAT_MISMATCH                    -9
#define CL_IMAGE_FORMAT_NOT_SUPPORTED               -10
#define CL_BUILD_PROGRAM_FAILURE                    -11
#define CL_MAP_FAILURE                              -12
#define CL_MISALIGNED_SUB_BUFFER_OFFSET             -13
#define CL_EXEC_STATUS_ERROR_FOR_EVENTS_IN_WAIT_LIST -14
#define CL_INVALID_VALUE                            -30
#define CL_INVALID_DEVICE_TYPE                      -31
#define CL_INVALID_PLATFORM                         -32
#define CL_INVALID_DEVICE                           -33
#define CL_INVALID_CONTEXT                          -34
#define CL_INVALID_QUEUE_PROPERTIES                 -35
#define CL_INVALID_COMMAND_QUEUE                    -36
#define CL_INVALID_HOST_PTR                         -37
#define CL_INVALID_MEM_OBJECT                       -38
#define CL_INVALID_IMAGE_FORMAT_DESCRIPTOR          -39
#define CL_INVALID_IMAGE_SIZE                       -40
#define CL_INVALID_SAMPLER                          -41
#define CL_INVALID_BINARY                           -42
#define CL_INVALID_BUILD_OPTIONS                    -43
#define CL_INVALID_PROGRAM                          -44
#define CL_INVALID_PROGRAM_EXECUTABLE               -45
#define CL_INVALID_KERNEL_NAME                      -46
#define CL_INVALID_KERNEL_DEFINITION                -47
#define CL_INVALID_KERNEL                           -48
#define CL_INVALID_ARG_INDEX                        -49
#define CL_INVALID_ARG_VALUE                        -50
#define CL_INVALID_ARG_SIZE                         -51
#define CL_INVALID_KERNEL_ARGS                      -52
#define CL_INVALID_WORK_DIMENSION                   -53
#define CL_INVALID_WORK_GROUP_SIZE                  -54
#define CL_INVALID_WORK_ITEM_SIZE                   -55
#define CL_INVALID_GLOBAL_OFFSET                    -56
#define CL_INVALID_EVENT_WAIT_LIST                  -57
#define CL_INVALID_EVENT                            -58
#define CL_INVALID_OPERATION                        -59
#define CL_INVALID_GL_OBJECT                        -60
#define CL_INVALID_BUFFER_SIZE                      -61
#define CL_INVALID_MIP_LEVEL                        -62
#define CL_INVALID_GLOBAL_WORK_SIZE                 -63
#define CL_INVALID_PROPERTY                         -64
/* OpenCL Version */
#define CL_VERSION_1_0                              1
#define CL_VERSION_1_1                              1
/* cl_bool */
#define CL_FALSE                                    0
#define CL_TRUE                                     1
/* cl_platform_info */
#define CL_PLATFORM_PROFILE                         0x0900
#define CL_PLATFORM_VERSION                         0x0901
#define CL_PLATFORM_NAME                            0x0902
#define CL_PLATFORM_VENDOR                          0x0903
#define CL_PLATFORM_EXTENSIONS                      0x0904
/* cl_device_type - bitfield */
#define CL_DEVICE_TYPE_DEFAULT                      (1 << 0)
#define CL_DEVICE_TYPE_CPU                          (1 << 1)
#define CL_DEVICE_TYPE_GPU                          (1 << 2)
#define CL_DEVICE_TYPE_ACCELERATOR                  (1 << 3)
#define CL_DEVICE_TYPE_ALL                          0xFFFFFFFF
/* cl_device_info */
#define CL_DEVICE_TYPE                              0x1000
#define CL_DEVICE_VENDOR_ID                         0x1001
#define CL_DEVICE_MAX_COMPUTE_UNITS                 0x1002
#define CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS          0x1003
#define CL_DEVICE_MAX_WORK_GROUP_SIZE               0x1004
#define CL_DEVICE_MAX_WORK_ITEM_SIZES               0x1005
#define CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR       0x1006
#define CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT      0x1007
#define CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT        0x1008
#define CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG       0x1009
#define CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT      0x100A
#define CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE     0x100B
#define CL_DEVICE_MAX_CLOCK_FREQUENCY               0x100C
#define CL_DEVICE_ADDRESS_BITS                      0x100D
#define CL_DEVICE_MAX_READ_IMAGE_ARGS               0x100E
#define CL_DEVICE_MAX_WRITE_IMAGE_ARGS              0x100F
#define CL_DEVICE_MAX_MEM_ALLOC_SIZE                0x1010
#define CL_DEVICE_IMAGE2D_MAX_WIDTH                 0x1011
#define CL_DEVICE_IMAGE2D_MAX_HEIGHT                0x1012
#define CL_DEVICE_IMAGE3D_MAX_WIDTH                 0x1013
#define CL_DEVICE_IMAGE3D_MAX_HEIGHT                0x1014
#define CL_DEVICE_IMAGE3D_MAX_DEPTH                 0x1015
#define CL_DEVICE_IMAGE_SUPPORT                     0x1016
#define CL_DEVICE_MAX_PARAMETER_SIZE                0x1017
#define CL_DEVICE_MAX_SAMPLERS                      0x1018
#define CL_DEVICE_MEM_BASE_ADDR_ALIGN               0x1019
#define CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE          0x101A
#define CL_DEVICE_SINGLE_FP_CONFIG                  0x101B
#define CL_DEVICE_GLOBAL_MEM_CACHE_TYPE             0x101C
#define CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE         0x101D
#define CL_DEVICE_GLOBAL_MEM_CACHE_SIZE             0x101E
#define CL_DEVICE_GLOBAL_MEM_SIZE                   0x101F
#define CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE          0x1020
#define CL_DEVICE_MAX_CONSTANT_ARGS                 0x1021
#define CL_DEVICE_LOCAL_MEM_TYPE                    0x1022
#define CL_DEVICE_LOCAL_MEM_SIZE                    0x1023
#define CL_DEVICE_ERROR_CORRECTION_SUPPORT          0x1024
#define CL_DEVICE_PROFILING_TIMER_RESOLUTION        0x1025
#define CL_DEVICE_ENDIAN_LITTLE                     0x1026
#define CL_DEVICE_AVAILABLE                         0x1027
#define CL_DEVICE_COMPILER_AVAILABLE                0x1028
#define CL_DEVICE_EXECUTION_CAPABILITIES            0x1029
#define CL_DEVICE_QUEUE_PROPERTIES                  0x102A
#define CL_DEVICE_NAME                              0x102B
#define CL_DEVICE_VENDOR                            0x102C
#define CL_DRIVER_VERSION                           0x102D
#define CL_DEVICE_PROFILE                           0x102E
#define CL_DEVICE_VERSION                           0x102F
#define CL_DEVICE_EXTENSIONS                        0x1030
#define CL_DEVICE_PLATFORM                          0x1031
/* 0x1032 reserved for CL_DEVICE_DOUBLE_FP_CONFIG */
/* 0x1033 reserved for CL_DEVICE_HALF_FP_CONFIG */
#define CL_DEVICE_PREFERRED_VECTOR_WIDTH_HALF       0x1034
#define CL_DEVICE_HOST_UNIFIED_MEMORY               0x1035
#define CL_DEVICE_NATIVE_VECTOR_WIDTH_CHAR          0x1036
#define CL_DEVICE_NATIVE_VECTOR_WIDTH_SHORT         0x1037
#define CL_DEVICE_NATIVE_VECTOR_WIDTH_INT           0x1038
#define CL_DEVICE_NATIVE_VECTOR_WIDTH_LONG          0x1039
#define CL_DEVICE_NATIVE_VECTOR_WIDTH_FLOAT         0x103A
#define CL_DEVICE_NATIVE_VECTOR_WIDTH_DOUBLE        0x103B
#define CL_DEVICE_NATIVE_VECTOR_WIDTH_HALF          0x103C
#define CL_DEVICE_OPENCL_C_VERSION                  0x103D
/* cl_device_fp_config - bitfield */
#define CL_FP_DENORM                                (1 << 0)
#define CL_FP_INF_NAN                               (1 << 1)
#define CL_FP_ROUND_TO_NEAREST                      (1 << 2)
#define CL_FP_ROUND_TO_ZERO                         (1 << 3)
#define CL_FP_ROUND_TO_INF                          (1 << 4)
#define CL_FP_FMA                                   (1 << 5)
#define CL_FP_SOFT_FLOAT                            (1 << 6)
/* cl_device_mem_cache_type */
#define CL_NONE                                     0x0
#define CL_READ_ONLY_CACHE                          0x1
#define CL_READ_WRITE_CACHE                         0x2
/* cl_device_local_mem_type */
#define CL_LOCAL                                    0x1
#define CL_GLOBAL                                   0x2
/* cl_device_exec_capabilities - bitfield */
#define CL_EXEC_KERNEL                              (1 << 0)
#define CL_EXEC_NATIVE_KERNEL                       (1 << 1)
/* cl_command_queue_properties - bitfield */
#define CL_QUEUE_OUT_OF_ORDER_EXEC_MODE_ENABLE      (1 << 0)
#define CL_QUEUE_PROFILING_ENABLE                   (1 << 1)
/* cl_context_info  */
#define CL_CONTEXT_REFERENCE_COUNT                  0x1080
#define CL_CONTEXT_DEVICES                          0x1081
#define CL_CONTEXT_PROPERTIES                       0x1082
#define CL_CONTEXT_NUM_DEVICES                      0x1083
/* cl_context_info + cl_context_properties */
#define CL_CONTEXT_PLATFORM                         0x1084
/* cl_command_queue_info */
#define CL_QUEUE_CONTEXT                            0x1090
#define CL_QUEUE_DEVICE                             0x1091
#define CL_QUEUE_REFERENCE_COUNT                    0x1092
#define CL_QUEUE_PROPERTIES                         0x1093
/* cl_mem_flags - bitfield */
#define CL_MEM_READ_WRITE                           (1 << 0)
#define CL_MEM_WRITE_ONLY                           (1 << 1)
#define CL_MEM_READ_ONLY                            (1 << 2)
#define CL_MEM_USE_HOST_PTR                         (1 << 3)
#define CL_MEM_ALLOC_HOST_PTR                       (1 << 4)
#define CL_MEM_COPY_HOST_PTR                        (1 << 5)
/* cl_channel_order */
#define CL_R                                        0x10B0
#define CL_A                                        0x10B1
#define CL_RG                                       0x10B2
#define CL_RA                                       0x10B3
#define CL_RGB                                      0x10B4
#define CL_RGBA                                     0x10B5
#define CL_BGRA                                     0x10B6
#define CL_ARGB                                     0x10B7
#define CL_INTENSITY                                0x10B8
#define CL_LUMINANCE                                0x10B9
#define CL_Rx                                       0x10BA
#define CL_RGx                                      0x10BB
#define CL_RGBx                                     0x10BC
/* cl_channel_type */
#define CL_SNORM_INT8                               0x10D0
#define CL_SNORM_INT16                              0x10D1
#define CL_UNORM_INT8                               0x10D2
#define CL_UNORM_INT16                              0x10D3
#define CL_UNORM_SHORT_565                          0x10D4
#define CL_UNORM_SHORT_555                          0x10D5
#define CL_UNORM_INT_101010                         0x10D6
#define CL_SIGNED_INT8                              0x10D7
#define CL_SIGNED_INT16                             0x10D8
#define CL_SIGNED_INT32                             0x10D9
#define CL_UNSIGNED_INT8                            0x10DA
#define CL_UNSIGNED_INT16                           0x10DB
#define CL_UNSIGNED_INT32                           0x10DC
#define CL_HALF_FLOAT                               0x10DD
#define CL_FLOAT                                    0x10DE
/* cl_mem_object_type */
#define CL_MEM_OBJECT_BUFFER                        0x10F0
#define CL_MEM_OBJECT_IMAGE2D                       0x10F1
#define CL_MEM_OBJECT_IMAGE3D                       0x10F2
/* cl_mem_info */
#define CL_MEM_TYPE                                 0x1100
#define CL_MEM_FLAGS                                0x1101
#define CL_MEM_SIZE                                 0x1102
#define CL_MEM_HOST_PTR                             0x1103
#define CL_MEM_MAP_COUNT                            0x1104
#define CL_MEM_REFERENCE_COUNT                      0x1105
#define CL_MEM_CONTEXT                              0x1106
#define CL_MEM_ASSOCIATED_MEMOBJECT                 0x1107
#define CL_MEM_OFFSET                               0x1108
/* cl_image_info */
#define CL_IMAGE_FORMAT                             0x1110
#define CL_IMAGE_ELEMENT_SIZE                       0x1111
#define CL_IMAGE_ROW_PITCH                          0x1112
#define CL_IMAGE_SLICE_PITCH                        0x1113
#define CL_IMAGE_WIDTH                              0x1114
#define CL_IMAGE_HEIGHT                             0x1115
#define CL_IMAGE_DEPTH                              0x1116
/* cl_addressing_mode */
#define CL_ADDRESS_NONE                             0x1130
#define CL_ADDRESS_CLAMP_TO_EDGE                    0x1131
#define CL_ADDRESS_CLAMP                            0x1132
#define CL_ADDRESS_REPEAT                           0x1133
#define CL_ADDRESS_MIRRORED_REPEAT                  0x1134
/* cl_filter_mode */
#define CL_FILTER_NEAREST                           0x1140
#define CL_FILTER_LINEAR                            0x1141
/* cl_sampler_info */
#define CL_SAMPLER_REFERENCE_COUNT                  0x1150
#define CL_SAMPLER_CONTEXT                          0x1151
#define CL_SAMPLER_NORMALIZED_COORDS                0x1152
#define CL_SAMPLER_ADDRESSING_MODE                  0x1153
#define CL_SAMPLER_FILTER_MODE                      0x1154
/* cl_map_flags - bitfield */
#define CL_MAP_READ                                 (1 << 0)
#define CL_MAP_WRITE                                (1 << 1)
/* cl_program_info */
#define CL_PROGRAM_REFERENCE_COUNT                  0x1160
#define CL_PROGRAM_CONTEXT                          0x1161
#define CL_PROGRAM_NUM_DEVICES                      0x1162
#define CL_PROGRAM_DEVICES                          0x1163
#define CL_PROGRAM_SOURCE                           0x1164
#define CL_PROGRAM_BINARY_SIZES                     0x1165
#define CL_PROGRAM_BINARIES                         0x1166
/* cl_program_build_info */
#define CL_PROGRAM_BUILD_STATUS                     0x1181
#define CL_PROGRAM_BUILD_OPTIONS                    0x1182
#define CL_PROGRAM_BUILD_LOG                        0x1183
/* cl_build_status */
#define CL_BUILD_SUCCESS                            0
#define CL_BUILD_NONE                               -1
#define CL_BUILD_ERROR                              -2
#define CL_BUILD_IN_PROGRESS                        -3
/* cl_kernel_info */
#define CL_KERNEL_FUNCTION_NAME                     0x1190
#define CL_KERNEL_NUM_ARGS                          0x1191
#define CL_KERNEL_REFERENCE_COUNT                   0x1192
#define CL_KERNEL_CONTEXT                           0x1193
#define CL_KERNEL_PROGRAM                           0x1194
/* cl_kernel_work_group_info */
#define CL_KERNEL_WORK_GROUP_SIZE                   0x11B0
#define CL_KERNEL_COMPILE_WORK_GROUP_SIZE           0x11B1
#define CL_KERNEL_LOCAL_MEM_SIZE                    0x11B2
#define CL_KERNEL_PREFERRED_WORK_GROUP_SIZE_MULTIPLE 0x11B3
#define CL_KERNEL_PRIVATE_MEM_SIZE                  0x11B4
/* cl_event_info  */
#define CL_EVENT_COMMAND_QUEUE                      0x11D0
#define CL_EVENT_COMMAND_TYPE                       0x11D1
#define CL_EVENT_REFERENCE_COUNT                    0x11D2
#define CL_EVENT_COMMAND_EXECUTION_STATUS           0x11D3
#define CL_EVENT_CONTEXT                            0x11D4
/* cl_command_type */
#define CL_COMMAND_NDRANGE_KERNEL                   0x11F0
#define CL_COMMAND_TASK                             0x11F1
#define CL_COMMAND_NATIVE_KERNEL                    0x11F2
#define CL_COMMAND_READ_BUFFER                      0x11F3
#define CL_COMMAND_WRITE_BUFFER                     0x11F4
#define CL_COMMAND_COPY_BUFFER                      0x11F5
#define CL_COMMAND_READ_IMAGE                       0x11F6
#define CL_COMMAND_WRITE_IMAGE                      0x11F7
#define CL_COMMAND_COPY_IMAGE                       0x11F8
#define CL_COMMAND_COPY_IMAGE_TO_BUFFER             0x11F9
#define CL_COMMAND_COPY_BUFFER_TO_IMAGE             0x11FA
#define CL_COMMAND_MAP_BUFFER                       0x11FB
#define CL_COMMAND_MAP_IMAGE                        0x11FC
#define CL_COMMAND_UNMAP_MEM_OBJECT                 0x11FD
#define CL_COMMAND_MARKER                           0x11FE
#define CL_COMMAND_ACQUIRE_GL_OBJECTS               0x11FF
#define CL_COMMAND_RELEASE_GL_OBJECTS               0x1200
#define CL_COMMAND_READ_BUFFER_RECT                 0x1201
#define CL_COMMAND_WRITE_BUFFER_RECT                0x1202
#define CL_COMMAND_COPY_BUFFER_RECT                 0x1203
#define CL_COMMAND_USER                             0x1204
/* command execution status */
#define CL_COMPLETE                                 0x0
#define CL_RUNNING                                  0x1
#define CL_SUBMITTED                                0x2
#define CL_QUEUED                                   0x3
/* cl_buffer_create_type  */
#define CL_BUFFER_CREATE_TYPE_REGION                0x1220
/* cl_profiling_info  */
#define CL_PROFILING_COMMAND_QUEUED                 0x1280
#define CL_PROFILING_COMMAND_SUBMIT                 0x1281
#define CL_PROFILING_COMMAND_START                  0x1282
#define CL_PROFILING_COMMAND_END                    0x1283
/* Platform API */
extern CL_API_ENTRY cl_int CL_API_CALL
clGetPlatformIDs(cl_uint          /* num_entries */,
                 cl_platform_id * /* platforms */,
                 cl_uint *        /* num_platforms */) CL_API_SUFFIX__VERSION_1_0;
clGetPlatformInfo(cl_platform_id   /* platform */,
                  cl_platform_info /* param_name */,
                  size_t           /* param_value_size */,
                  void *           /* param_value */,
                  size_t *         /* param_value_size_ret */) CL_API_SUFFIX__VERSION_1_0;
/* Device APIs */
clGetDeviceIDs(cl_platform_id   /* platform */,
               cl_device_type   /* device_type */,
               cl_device_id *   /* devices */,
               cl_uint *        /* num_devices */) CL_API_SUFFIX__VERSION_1_0;
clGetDeviceInfo(cl_device_id    /* device */,
                cl_device_info  /* param_name */,
/* Context APIs  */
extern CL_API_ENTRY cl_context CL_API_CALL
clCreateContext(const cl_context_properties * /* properties */,
                cl_uint                       /* num_devices */,
                const cl_device_id *          /* devices */,
                void (CL_CALLBACK * /* pfn_notify */)(const char *, const void *, size_t, void *),
                void *                        /* user_data */,
                cl_int *                      /* errcode_ret */) CL_API_SUFFIX__VERSION_1_0;
clCreateContextFromType(const cl_context_properties * /* properties */,
                        void (CL_CALLBACK *     /* pfn_notify*/ )(const char *, const void *, size_t, void *),
clRetainContext(cl_context /* context */) CL_API_SUFFIX__VERSION_1_0;
clReleaseContext(cl_context /* context */) CL_API_SUFFIX__VERSION_1_0;
clGetContextInfo(cl_context         /* context */,
                 cl_context_info    /* param_name */,
/* Command Queue APIs */
extern CL_API_ENTRY cl_command_queue CL_API_CALL
clCreateCommandQueue(cl_context                     /* context */,
                     cl_command_queue_properties    /* properties */,
clRetainCommandQueue(cl_command_queue /* command_queue */) CL_API_SUFFIX__VERSION_1_0;
clReleaseCommandQueue(cl_command_queue /* command_queue */) CL_API_SUFFIX__VERSION_1_0;
clGetCommandQueueInfo(cl_command_queue      /* command_queue */,
                      cl_command_queue_info /* param_name */,
#ifdef CL_USE_DEPRECATED_OPENCL_1_0_APIS
#warning CL_USE_DEPRECATED_OPENCL_1_0_APIS is defined. These APIs are unsupported and untested in OpenCL 1.1!
 *  WARNING:
 *     This API introduces mutable state into the OpenCL implementation. It has been REMOVED
 *  to better facilitate thread safety.  The 1.0 API is not thread safe. It is not tested by the
 *  OpenCL 1.1 conformance test, and consequently may not work or may not work dependably.
 *  It is likely to be non-performant. Use of this API is not advised. Use at your own risk.
 *  Software developers previously relying on this API are instructed to set the command queue
 *  properties when creating the queue, instead.
clSetCommandQueueProperty(cl_command_queue              /* command_queue */,
                          cl_bool                        /* enable */,
                          cl_command_queue_properties * /* old_properties */) CL_EXT_SUFFIX__VERSION_1_0_DEPRECATED;
#endif /* CL_USE_DEPRECATED_OPENCL_1_0_APIS */
/* Memory Object APIs */
extern CL_API_ENTRY cl_mem CL_API_CALL
clCreateBuffer(cl_context   /* context */,
               cl_mem_flags /* flags */,
               size_t       /* size */,
               void *       /* host_ptr */,
clCreateSubBuffer(cl_mem                   /* buffer */,
                  cl_buffer_create_type    /* buffer_create_type */,
                  const void *             /* buffer_create_info */,
                  cl_int *                 /* errcode_ret */) CL_API_SUFFIX__VERSION_1_1;
clCreateImage2D(cl_context              /* context */,
                const cl_image_format * /* image_format */,
                size_t                  /* image_width */,
                size_t                  /* image_height */,
                size_t                  /* image_row_pitch */,
clCreateImage3D(cl_context              /* context */,
                size_t                  /* image_depth */,
                size_t                  /* image_slice_pitch */,
clRetainMemObject(cl_mem /* memobj */) CL_API_SUFFIX__VERSION_1_0;
clReleaseMemObject(cl_mem /* memobj */) CL_API_SUFFIX__VERSION_1_0;
clGetSupportedImageFormats(cl_context           /* context */,
                           cl_mem_object_type   /* image_type */,
                           cl_image_format *    /* image_formats */,
                           cl_uint *            /* num_image_formats */) CL_API_SUFFIX__VERSION_1_0;
clGetMemObjectInfo(cl_mem           /* memobj */,
                   cl_mem_info      /* param_name */,
clGetImageInfo(cl_mem           /* image */,
               cl_image_info    /* param_name */,
clSetMemObjectDestructorCallback(  cl_mem /* memobj */,
                                    void (CL_CALLBACK * /*pfn_notify*/)( cl_mem /* memobj */, void* /*user_data*/),
                                    void * /*user_data */ )             CL_API_SUFFIX__VERSION_1_1;
/* Sampler APIs  */
extern CL_API_ENTRY cl_sampler CL_API_CALL
clCreateSampler(cl_context          /* context */,
                cl_bool             /* normalized_coords */,
                cl_addressing_mode  /* addressing_mode */,
                cl_filter_mode      /* filter_mode */,
clRetainSampler(cl_sampler /* sampler */) CL_API_SUFFIX__VERSION_1_0;
clReleaseSampler(cl_sampler /* sampler */) CL_API_SUFFIX__VERSION_1_0;
clGetSamplerInfo(cl_sampler         /* sampler */,
                 cl_sampler_info    /* param_name */,
/* Program Object APIs  */
extern CL_API_ENTRY cl_program CL_API_CALL
clCreateProgramWithSource(cl_context        /* context */,
                          cl_uint           /* count */,
                          const char **     /* strings */,
                          const size_t *    /* lengths */,
clCreateProgramWithBinary(cl_context                     /* context */,
                          const cl_device_id *           /* device_list */,
                          const unsigned char **         /* binaries */,
                          cl_int *                       /* binary_status */,
clRetainProgram(cl_program /* program */) CL_API_SUFFIX__VERSION_1_0;
clReleaseProgram(cl_program /* program */) CL_API_SUFFIX__VERSION_1_0;
clBuildProgram(cl_program           /* program */,
               const char *         /* options */,
               void (CL_CALLBACK *  /* pfn_notify */)(cl_program /* program */, void * /* user_data */),
               void *               /* user_data */) CL_API_SUFFIX__VERSION_1_0;
clUnloadCompiler(void) CL_API_SUFFIX__VERSION_1_0;
clGetProgramInfo(cl_program         /* program */,
                 cl_program_info    /* param_name */,
clGetProgramBuildInfo(cl_program            /* program */,
                      cl_program_build_info /* param_name */,
/* Kernel Object APIs */
extern CL_API_ENTRY cl_kernel CL_API_CALL
clCreateKernel(cl_program      /* program */,
               const char *    /* kernel_name */,
clCreateKernelsInProgram(cl_program     /* program */,
                         cl_uint        /* num_kernels */,
                         cl_kernel *    /* kernels */,
                         cl_uint *      /* num_kernels_ret */) CL_API_SUFFIX__VERSION_1_0;
clRetainKernel(cl_kernel    /* kernel */) CL_API_SUFFIX__VERSION_1_0;
clReleaseKernel(cl_kernel   /* kernel */) CL_API_SUFFIX__VERSION_1_0;
clSetKernelArg(cl_kernel    /* kernel */,
               cl_uint      /* arg_index */,
               size_t       /* arg_size */,
               const void * /* arg_value */) CL_API_SUFFIX__VERSION_1_0;
clGetKernelInfo(cl_kernel       /* kernel */,
                cl_kernel_info  /* param_name */,
clGetKernelWorkGroupInfo(cl_kernel                  /* kernel */,
                         cl_kernel_work_group_info  /* param_name */,
/* Event Object APIs  */
clWaitForEvents(cl_uint             /* num_events */,
                const cl_event *    /* event_list */) CL_API_SUFFIX__VERSION_1_0;
clGetEventInfo(cl_event         /* event */,
               cl_event_info    /* param_name */,
extern CL_API_ENTRY cl_event CL_API_CALL
clCreateUserEvent(cl_context    /* context */,
clRetainEvent(cl_event /* event */) CL_API_SUFFIX__VERSION_1_0;
clReleaseEvent(cl_event /* event */) CL_API_SUFFIX__VERSION_1_0;
clSetUserEventStatus(cl_event   /* event */,
                     cl_int     /* execution_status */) CL_API_SUFFIX__VERSION_1_1;
clSetEventCallback( cl_event    /* event */,
                    cl_int      /* command_exec_callback_type */,
                    void (CL_CALLBACK * /* pfn_notify */)(cl_event, cl_int, void *),
                    void *      /* user_data */) CL_API_SUFFIX__VERSION_1_1;
/* Profiling APIs  */
clGetEventProfilingInfo(cl_event            /* event */,
                        cl_profiling_info   /* param_name */,
/* Flush and Finish APIs */
clFlush(cl_command_queue /* command_queue */) CL_API_SUFFIX__VERSION_1_0;
clFinish(cl_command_queue /* command_queue */) CL_API_SUFFIX__VERSION_1_0;
/* Enqueued Commands APIs */
clEnqueueReadBuffer(cl_command_queue    /* command_queue */,
                    cl_bool             /* blocking_read */,
                    size_t              /* offset */,
                    size_t              /* cb */,
                    void *              /* ptr */,
                    cl_uint             /* num_events_in_wait_list */,
                    const cl_event *    /* event_wait_list */,
                    cl_event *          /* event */) CL_API_SUFFIX__VERSION_1_0;
clEnqueueReadBufferRect(cl_command_queue    /* command_queue */,
                        const size_t *      /* buffer_origin */,
                        const size_t *      /* host_origin */,
                        const size_t *      /* region */,
                        size_t              /* buffer_row_pitch */,
                        size_t              /* buffer_slice_pitch */,
                        size_t              /* host_row_pitch */,
                        size_t              /* host_slice_pitch */,
                        void *              /* ptr */,
                        cl_event *          /* event */) CL_API_SUFFIX__VERSION_1_1;
clEnqueueWriteBuffer(cl_command_queue   /* command_queue */,
                     cl_bool            /* blocking_write */,
                     size_t             /* cb */,
                     const void *       /* ptr */,
clEnqueueWriteBufferRect(cl_command_queue    /* command_queue */,
clEnqueueCopyBuffer(cl_command_queue    /* command_queue */,
                    cl_mem              /* src_buffer */,
                    cl_mem              /* dst_buffer */,
                    size_t              /* src_offset */,
                    size_t              /* dst_offset */,
                    size_t              /* cb */,
clEnqueueCopyBufferRect(cl_command_queue    /* command_queue */,
                        const size_t *      /* src_origin */,
                        const size_t *      /* dst_origin */,
                        size_t              /* src_row_pitch */,
                        size_t              /* src_slice_pitch */,
                        size_t              /* dst_row_pitch */,
                        size_t              /* dst_slice_pitch */,
clEnqueueReadImage(cl_command_queue     /* command_queue */,
                   cl_mem               /* image */,
                   const size_t *       /* origin[3] */,
                   const size_t *       /* region[3] */,
                   size_t               /* row_pitch */,
                   size_t               /* slice_pitch */,
                   void *               /* ptr */,
clEnqueueWriteImage(cl_command_queue    /* command_queue */,
                    cl_mem              /* image */,
                    size_t              /* input_row_pitch */,
                    size_t              /* input_slice_pitch */,
clEnqueueCopyImage(cl_command_queue     /* command_queue */,
                   cl_mem               /* src_image */,
                   cl_mem               /* dst_image */,
                   const size_t *       /* src_origin[3] */,
                   const size_t *       /* dst_origin[3] */,
clEnqueueCopyImageToBuffer(cl_command_queue /* command_queue */,
clEnqueueCopyBufferToImage(cl_command_queue /* command_queue */,
extern CL_API_ENTRY void * CL_API_CALL
clEnqueueMapBuffer(cl_command_queue /* command_queue */,
                   cl_bool          /* blocking_map */,
                   cl_map_flags     /* map_flags */,
                   size_t           /* cb */,
                   cl_event *       /* event */,
clEnqueueMapImage(cl_command_queue  /* command_queue */,
                  cl_mem            /* image */,
                  size_t *          /* image_row_pitch */,
                  size_t *          /* image_slice_pitch */,
clEnqueueUnmapMemObject(cl_command_queue /* command_queue */,
                        void *           /* mapped_ptr */,
clEnqueueNDRangeKernel(cl_command_queue /* command_queue */,
                       cl_uint          /* work_dim */,
                       const size_t *   /* global_work_offset */,
                       const size_t *   /* global_work_size */,
                       const size_t *   /* local_work_size */,
clEnqueueTask(cl_command_queue  /* command_queue */,
clEnqueueNativeKernel(cl_command_queue  /* command_queue */,
					  void (CL_CALLBACK *user_func)(void *),
                      void *            /* args */,
                      size_t            /* cb_args */,
                      cl_uint           /* num_mem_objects */,
                      const cl_mem *    /* mem_list */,
                      const void **     /* args_mem_loc */,
clEnqueueMarker(cl_command_queue    /* command_queue */,
clEnqueueWaitForEvents(cl_command_queue /* command_queue */,
clEnqueueBarrier(cl_command_queue /* command_queue */) CL_API_SUFFIX__VERSION_1_0;
/* Extension function access
 * Returns the extension function address for the given function name,
 * or NULL if a valid function can not be found.  The client must
 * check to make sure the address is not NULL, before using or
 * calling the returned function address.
extern CL_API_ENTRY void * CL_API_CALL clGetExtensionFunctionAddress(const char * /* func_name */) CL_API_SUFFIX__VERSION_1_0;
#ifdef __cplusplus
#endif
#endif  /* __OPENCL_CL_H */
/* $Revision: 11708 $ on $Date: 2010-06-13 23:36:24 -0700 (Sun, 13 Jun 2010) $ */
#ifndef __OPENCL_H
#define __OPENCL_H
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __APPLE__
#include <OpenCL/cl.h>
#include <OpenCL/cl_gl.h>
#include <OpenCL/cl_gl_ext.h>
#include <OpenCL/cl_ext.h>
#else
#include <CL/cl.h>
#include <CL/cl_gl.h>
#include <CL/cl_gl_ext.h>
#include <CL/cl_ext.h>
#endif
#ifdef __cplusplus
#endif
#endif  /* __OPENCL_H   */
Haut de le page
