Archives de la liste
Re: [Starpu-devel] Task which accesses multiple time the same handle with different access modes.
Chronologique Discussions
- From: Jean-Marie Couteyen <jean-marie.couteyen@inria.fr>
- To: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Task which accesses multiple time the same handle with different access modes.
- Date: Tue, 24 Feb 2015 10:58:49 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello, I made a patch for "implicit_data_depcs.c" to remove the circular dependency. I used yesterday trunk version. - In the case "severak predecessors, adding sync task", when a handle is used multiple time by the same task (RW after R), a dependency is added between the "post_sync_task" and the "sync_task" by "_starpu_add_sync_task". Then a dependency is added between the "sync_task" and the "post_sync_task" by "_starpu_add_accessor". - In order to ignore the post_sync_task in "_starpu_add_sync_task", I added an argument to differentiate the task that must be ignored from the post_sync_task. - Now, the dependencies between the post_sync_task and the sync_task is no longer added. The MWE seems to work correctly now, although I did not check the interactions with the DSM. Regards, Jean-Marie Couteyen Le 19/02/2015 17:31, Jean-Marie
Couteyen a écrit :
54E60FEB.6090505@inria.fr">Hello, |
+++ implicit_data_deps.c.jm 2015-02-24 10:41:01.016032000 +0100
@@ -100,7 +100,7 @@
/* This adds a new synchronization task which depends on all the previous
accessors */
-static void _starpu_add_sync_task(starpu_data_handle_t handle, struct
starpu_task *pre_sync_task, struct starpu_task *post_sync_task)
+static void _starpu_add_sync_task(starpu_data_handle_t handle, struct
starpu_task *pre_sync_task, struct starpu_task *post_sync_task, struct
starpu_task *ignored_task)
/* Count the existing accessors */
unsigned naccessors = 0;
@@ -108,7 +108,7 @@
l = handle->last_submitted_accessors.next;
while (l != &handle->last_submitted_accessors)
- if (l->task != post_sync_task)
+ if (l->task != ignored_task)
naccessors++;
l = l->next;
@@ -123,7 +123,7 @@
STARPU_ASSERT(l->task);
task_array[i++] = l->task;
_starpu_add_dependency(handle, l->task, pre_sync_task);
@@ -251,7 +251,7 @@
* combine with others anyway, use it
* as synchronization task by making it
* wait for the previous ones. */
- _starpu_add_sync_task(handle, pre_sync_task, post_sync_task);
+ _starpu_add_sync_task(handle, pre_sync_task, post_sync_task,
post_sync_task);
} else {
_STARPU_DEP_DEBUG("several predecessors, adding sync task\n");
/* insert an empty synchronization task
@@ -269,7 +269,7 @@
sync_task->cl = NULL;
/* Make this task wait for the previous ones */
- _starpu_add_sync_task(handle, sync_task, sync_task);
+ _starpu_add_sync_task(handle, sync_task, sync_task, post_sync_task);
/* And the requested task wait for this one */
_starpu_add_accessor(handle, pre_sync_task, post_sync_task,
post_sync_task_dependency_slot);
- [Starpu-devel] Task which accesses multiple time the same handle with different access modes., Jean-Marie Couteyen, 19/02/2015
- Re: [Starpu-devel] Task which accesses multiple time the same handle with different access modes., Jean-Marie Couteyen, 24/02/2015
- Re: [Starpu-devel] Task which accesses multiple time the same handle with different access modes., Samuel Thibault, 24/02/2015
