Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Using Temanejo with StarPU
Archives de la liste
Chronologique Discussions
  • To: s1sebuch <s1sebuch@stmail.uni-bayreuth.de>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Using Temanejo with StarPU
  • Date: Fri, 17 Apr 2015 09:19:52 -0500
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Running Ubuntu 14.04 with Temanjo 1.1 error
Exception in thread Thread-1:
Traceback (most recent call last):
  File "/usr/lib/python2.7/threading.py", line 810, in __bootstrap_inner
    self.run()
  File "/usr/local/lib/python2.7/dist-packages/temanejo/temanejo.py", line 4032, in run
    client_conf.init(runtime_id)
  File "/usr/local/lib/python2.7/dist-packages/temanejo/temanejo_client_config.py", line 59, in init
    runtime_type = client_t[client_id]
IndexError: list index out of range
Using Temanjo 1.0 worked fine for me.
On Fri, Apr 17, 2015 at 8:11 AM, <jeffrey.hand@gmail.com> wrote:
Try using the older version Temanejo than the newest version. I'm using Ubuntu 14.04 and had an issue.  There seemed to be some sort of library dependency issue.
Typo'd from my iPhone
> On Apr 17, 2015, at 6:38 AM, s1sebuch <s1sebuch@stmail.uni-bayreuth.de> wrote:
> Dear StarPU development team.
> I have recently started using StarPU for my Thesis and am currently unable to use Temanejo. Although StarPU does locate Temanejo  in the configure script(ayudame.h is found), I am unable to connect to any StarPU application. Furthermore I tried using the LD_PRELOAD command (LD_PRELOAD=<ayudame_directory>/lib/libayudame.so ./application <parameters>), but my application continues with its execution and does not report the ayudame port. I am using StarPU 1.2.0rc1 and Temanejo 1.1 on an OpenSuse Linux System. Is there any Troubleshooting or known workarounds for this kind of problem availible.
> Best regards
> Sebastian Buchholz
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
