Archives de la liste
- To: Jeff Hand <jeffrey.hand@gmail.com>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Using Temanejo with StarPU
- Date: Tue, 21 Apr 2015 15:46:44 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
s1sebuch, le Tue 21 Apr 2015 14:51:42 +0200, a écrit :
> sorry for the late reply, I was uablke to access my test system. I am not
> sure to which ayudame interface you are referring to. I have only the
> Temanejo debugger as an access interface to ayudame installed.
That is what I meant.
> If start an
> application through the Temanejo interface I recieve the following error:
> "Temanejo-ERROR: Connection to host could not be established.". If I try to
> start the application with the LD-Preload instruction, the application just
> carries on executing without stopping and reporting the ayudame port
> address.
Ok. I've just tried, it should really be stopping. Does ./configure
properly reports ayudame enabled: yes? Please also post your config.log
Samuel
- [Starpu-devel] Using Temanejo with StarPU, s1sebuch, 17/04/2015
- Message indisponible
- Re: [Starpu-devel] Using Temanejo with StarPU, Jeff Hand, 17/04/2015
- Re: [Starpu-devel] Using Temanejo with StarPU, Samuel Thibault, 17/04/2015
- Re: [Starpu-devel] Using Temanejo with StarPU, s1sebuch, 21/04/2015
- Re: [Starpu-devel] Using Temanejo with StarPU, Samuel Thibault, 21/04/2015
