Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] reducing STARPU_OPENCL_PIPELINE to 0
- Date: Thu, 4 Jun 2015 11:25:21 -0500
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Warning message
[starpu][_starpu_opencl_driver_init] Warning: reducing STARPU_OPENCL_PIPELINE to 0 because blocking drivers are not enabled (and simgrid is not enabled)
configured StarPU:
../configure --disable-cuda --with-hwloc --enable-blocking-drivers
#if !defined(STARPU_SIMGRID) && !defined(STARPU_NON_BLOCKING_DRIVERS)
if (worker->pipeline_length >= 1)
/* We need non-blocking drivers, to poll for OPENCL task
* termination */
_STARPU_DISP("Warning: reducing STARPU_OPENCL_PIPELINE to 0 because blocking drivers are not enabled (and simgrid is not enabled)\n");
worker->pipeline_length = 0;
#endif
configured StarPU:
* termination */
#endif
Based of the error message:
- blocking drivers are enabled (Even though comment says "blocking drivers are not enabled". Is the comment right?)
- Simgrid is disabled
STARPU_OPENCL_PIPELINE:
Specify how many asynchronous tasks are submitted in advance on OpenCL devices. This for instance permits to overlap task management with the execution of previous tasks, but it also allows concurrent execution on Fermi cards, which otherwise bring spurious synchronizations. The default is 2. Setting the value to 0 forces a synchronous execution of all tasks.
According to "backport r12085 from trunk: Advise the user to use
--enable-blocking-drivers to avoid consuming real CPU for virtual CPU
idling" my assumption is "--enable-blocking-drivers" is preferred.
As a test, I removed the code setting the pipeline to 0. The performance seemed to be about the same. The StarPU tests passed and my tests passed with the modification.
Should STARPU_OPENCL_PIPELINE be set to 0?
- [Starpu-devel] reducing STARPU_OPENCL_PIPELINE to 0, Jeff Hand, 04/06/2015
- Re: [Starpu-devel] reducing STARPU_OPENCL_PIPELINE to 0, Samuel Thibault, 15/06/2015
