Archives de la liste
- To: Jeff Hand <jeffrey.hand@gmail.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] reducing STARPU_OPENCL_PIPELINE to 0
- Date: Mon, 15 Jun 2015 17:43:06 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
(trying to catch up after my vacancies)
Jeff Hand, le Thu 04 Jun 2015 11:25:21 -0500, a écrit :
> [starpu][_starpu_opencl_driver_init] Warning: reducing
> to 0 because blocking drivers are not enabled (and simgrid is not enabled)
Oops, the message is bogus: it complains because blocking drivers are
enabled, which prevents from pipelining tasks (which can not be done
without blocking drivers).
> According to "backport r12085 from trunk: Advise the user to use
> --enable-blocking-drivers to avoid consuming real CPU for virtual CPU
> idling"
> my assumption is "--enable-blocking-drivers" is preferred.
This commit is about simgrid mode only, not about non-simgrid mode.
> As a test, I removed the code setting the pipeline to 0. The performance
> seemed to be about the same. The StarPU tests passed and my tests passed
> with
> the modification.
I'd say it's just by luck that it happens to be actually working :)
It'll however actually be running one task at a time, i.e. just as if
STARPU_OPENCL_PIPELINE was set to 0.
Samuel
- [Starpu-devel] reducing STARPU_OPENCL_PIPELINE to 0, Jeff Hand, 04/06/2015
- Re: [Starpu-devel] reducing STARPU_OPENCL_PIPELINE to 0, Samuel Thibault, 15/06/2015
