Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [SimpleHelp] Declaring and Using a Codelet in C++
Archives de la liste
Chronologique Discussions
  • To: Starpu Mail List <starpu-devel@lists.gforge.inria.fr>, Starpu Team <nathalie.furmento@labri.fr>, Samuel Thibault <samuel.thibault@inria.fr>
  • Subject: Re: [Starpu-devel] [SimpleHelp] Declaring and Using a Codelet in C++
  • Date: Tue, 9 Jun 2015 15:00:12 -0300
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello StarPU Team,
Just figured it out how to solve this problem, here is the answer:
struct starpu_codelet cl;
starpu_codelet_init(&cl);
cl.where = STARPU_CPU | STARPU_CUDA;
cl.cpu_funcs[0]  = multiply_cpu; //FORGOT [0]
cl.cuda_funcs[0] = multiply_cuda; //FORGOT [0]
cl.nbuffers = 3;
cl.modes[0] = STARPU_R ;
cl.modes[1] = STARPU_R ;
cl.modes[2] = STARPU_RW;
cl.name="hello";
You also have to use EXTERN.
extern "C" void multiply_cpu (void *buffers[], void *args); //FORGOT EXTERN
extern "C" void multiply_cuda(void *buffers[], void *args); //FORGOT EXTERN
Hope this solution to be archived on the forum, so people can use if they have the same problem.
Best,
Joao
On Tue, Jun 9, 2015 at 2:37 PM, Gabriel Gazolla <gabrielgazolla@gmail.com> wrote:
Hello StarPU Team,
I am trying to compile (build.sh) my project  , but on the file matrix_spu.cpp I can't make the "struct starpu_codelet cod" to work.
The idea behind it is to later on, create a vector of starpu_codelet s.
I am receiving errors on lines 16 and 17.
Can you please help me compile this code?
Best Regards,
Joao
Gabriel Gazolla
Doutorando em Computação - IC/UFF
Haut de le page
