Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] OpenCL 64bit Double errors
- Date: Wed, 29 Jul 2015 18:14:35 -0500
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Tripped over this issue on a number of systems. This time decided to take a closer look.
Test Example Output:
Less than ideal solution.
Error: "Instruction 'ld' requires SM 1.3 or higher, or map_f64_to_f32 directive"
./complex
[starpu][initialize_eager_center_policy] Warning: you are running the default eager scheduler, which is not very smart. Make sure to read the StarPU documentation about adding performance models in order to be able to use the dmda or dmdas scheduler instead.
[starpu][_starpu_opencl_driver_init] Warning: reducing STARPU_OPENCL_PIPELINE to 0 because blocking drivers are not enabled (and simgrid is not enabled)
[starpu][_starpu_opencl_compile_or_load_opencl_from_string] Compilation output
ptxas application ptx input, line 51; error : Instruction 'ld' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas application ptx input, line 52; error : Instruction 'st' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas application ptx input, line 57; error : Instruction 'ld' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas application ptx input, line 58; error : Instruction 'st' requires SM 1.3 or higher, or map_f64_to_f32 directive
ptxas fatal : Ptx assembly aborted due to errors
ptxas application ptx input, line 51; warning : Double is not supported. Demoting to float
[starpu][_starpu_opencl_compile_or_load_opencl_from_string] Error: Failed to build program executable!
[starpu][_starpu_opencl_compile_or_load_opencl_from_string] clBuildProgram: -42 - clGetProgramBuildInfo: -2
[starpu] Unexpected value: <1> returned for starpu_opencl_load_opencl_from_file
[starpu][abort][main()@interface/complex.c:98]
Aborted (core dumped)
./complex
The error is warning that 64bit double isn't supported by the compiler. Which is true:
Device Name Quadro NVS 295
Device Vendor NVIDIA Corporation
Device Vendor ID 0x10de
Device Version OpenCL 1.0 CUDA
Driver Version 340.65
Device OpenCL C Version OpenCL C 1.0
Device Type GPU
Device Profile FULL_PROFILE
Device Topology (NV) PCI-E, 03:00.0
Max compute units 1
Max clock frequency 1300MHz
NVIDIA Compute Capability 1.1
Max work item dimensions 3
Max work item sizes 512x512x64
Max work group size 512
Preferred work group size multiple 32
Warp size (NV) 32
Preferred / native vector sizes
char 1 / 1
short 1 / 1
int 1 / 1
long 1 / 1
half 0 / 0 (n/a)
float 1 / 1
double 0 / 0 (n/a)
Device Type GPU
Max compute units 1
Warp size (NV) 32
char 1 / 1
short 1 / 1
int 1 / 1
long 1 / 1
half 0 / 0 (n/a)
float 1 / 1
double 0 / 0 (n/a)
After reviewing the complex.c file, it does run "can_execute" function. If this test would have executed in cuda, it wouldn't have executed because of "Old card does not support doubles" checking.
This system actually has 2 Nvidia cards. One that does support 64bit and the other doesn't.
At this time, there is no intent on running 64bit floating point.
Options:1. Ignore the failures.
2. Added a #def to turn the tests off
This would work at a source level, but the packaged version of the examples wouldn't auto detect capability.
3. Check if all OpenCL devices are capable of 64bit double. If not, quietly exit test.
Probably the best solution. If this is the preferred solution, I'm inclined to see if we could come up with a patch.
Thanks,
Jeff
- [Starpu-devel] OpenCL 64bit Double errors, Jeff Hand, 30/07/2015
- Re: [Starpu-devel] OpenCL 64bit Double errors, Samuel Thibault, 30/07/2015
