Archives de la liste
- To: Jeff Hand <jeffrey.hand@gmail.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] OpenCL 64bit Double errors
- Date: Thu, 30 Jul 2015 16:54:30 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Jeff Hand, le Wed 29 Jul 2015 18:14:35 -0500, a écrit :
> [starpu][_starpu_opencl_compile_or_load_opencl_from_string] Error: Failed to
> build program executable!
Indeed, _starpu_opencl_compile_or_load_opencl_from_string seems to
reject not being able to build a program for some device. I'd tend
to think that it should be fine with that and just put a NULL in the
opencl_programs array for those. It'd then be up to the application to
decide whether it is fine with having it not built for all devices. Here
complex.c is: it can simply make can_execute return 0 on devices where
the program couldn't be built. A patch doing that would be welcome
indeed :)
Samuel
- [Starpu-devel] OpenCL 64bit Double errors, Jeff Hand, 30/07/2015
- Re: [Starpu-devel] OpenCL 64bit Double errors, Samuel Thibault, 30/07/2015
