Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: starpu-announce@lists.gforge.inria.fr
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: [Starpu-devel] StarPU v1.2.0rc5 released
- Date: Thu, 17 Dec 2015 15:38:18 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=Pass smtp.helo=postmaster@iona.labri.fr
- Ironport-phdr: 9a23:l6JmlB3Fjc3hJBv9smDT+DRfVm0co7zxezQtwd8ZsegQLfad9pjvdHbS+e9qxAeQG96LtbQf0qGI6OjJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6MyZ/unL7ps7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtbTazgZ7l9RLpeCykgOG0d4MzwqQKFQgWI/HQRFGQQiBtBRQbfvz/gWZKklCLmtuN52STSE9DsSL0yRTPqu6FiVB/hjCYKcTAk6mTajNB3pKZSqgig4RJlld2HKLqJPeZzK/uONegRQnBMC55c
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
All,
The StarPU team is pleased to announce the fifth release candidate of v1.2.0.
This new branch notably brings an out-of-core support, a MIC Xeon Phi support, an OpenMP runtime support, and a new internal communication system for MPI.
The rc5 specifically enables more tests for Simgrid and the Xeon Phi architecture, along with some fixes for MacOS and XeonPhi. The whole Changelog is available below.
The tarball along with the md5sum file and the OpenPGP signature are available on the Gforge web site
https://gforge.inria.fr/frs/?group_id=1570
or on the secondary web site
http://starpu.gforge.inria.fr/files/
We are hoping this to be the last release candidate before being able to release 1.2.0
Best season's greetings,
Nathalie, for the StarPU team.
StarPU 1.2.0rc5 (svn revision 16709)
New features:
* Add asynchronous partition planning. It only supports coherency through
the home node of data for now.
Small features:
* Add configure option to disable fortran --disable-fortran
* Add configure option to give path for smpirun executable --with-smpirun
* Add configure option to disable the build of tests --disable-build-tests
* Add starpu-all-tasks debugging support
Small changes:
* Update starpu_task_build() to set starpu_task::cl_arg_free to 1 if
some arguments of type ::STARPU_VALUE are given.
* Simplify performance model loading API
* Better semantic for environment variables STARPU_NMIC and
STARPU_NMICDEVS, the number of devices and the number of cores.
STARPU_NMIC will be the number of devices, and STARPU_NMICCORES
will be the number of cores per device.
- [Starpu-devel] StarPU v1.2.0rc5 released, Nathalie Furmento, 17/12/2015
