Archives de la liste
- From: Malcolm Roberts <malcolm.i.w.roberts@gmail.com>
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] 1.2.0rc5 problem with -lGL
- Date: Fri, 18 Dec 2015 13:47:12 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=malcolm.i.w.roberts@gmail.com; spf=Pass smtp.mailfrom=malcolm.i.w.roberts@gmail.com; spf=None smtp.helo=postmaster@mail-wm0-f46.google.com
- Ironport-phdr: 9a23:MojWWxCbvlgi327A1JdtUyQJP3N1i/DPJgcQr6AfoPdwSP78pMbcNUDSrc9gkEXOFd2CrakU1ayO6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6MyZzvn8mJuLTtICxwzAKnZr1zKBjk5S7wjeIxxbVYF6Aq1xHSqWFJcekFjUlhJFaUggqurpzopM0rxQ0L5Klkr5IIEfiiPvdwcbsNFygvKXgoocHmqxTHZQ+O/WcHFGoYlQBHDk7E6gv7V9H/qHjUrO14jQyTOcbxSbV8YzOo4r13U1e8jS4DPDk99SfWzNM2lqVRrQi9vDRwxofVZMeeM/8oLfCVRs8TWWcUBpUZbCdGGI7pMtMC
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello.
I am trying to compile 1.2.0rc5 on an Ubuntu system. After running ./configure --prefix=$HOME/starpu && make, I get the following error:
/usr/bin/ld: cannot find -lGL
In fact, OpenCL is installed:
ls -l /usr/lib/fglrx/libGL*
lrwxrwxrwx 1 root root 10 Sep 11 11:53 /usr/lib/fglrx/libGL.so -> libGL.so.1
lrwxrwxrwx 1 root root 12 Sep 11 11:53 /usr/lib/fglrx/libGL.so.1 -> libGL.so.1.2
-rw-r--r-- 1 root root 867632 Sep 11 11:53 /usr/lib/fglrx/libGL.so.1.2
Best,
~Malcolm Roberts
http://malcolmiwroberts.com
- [Starpu-devel] 1.2.0rc5 problem with -lGL, Malcolm Roberts, 18/12/2015
- Re: [Starpu-devel] 1.2.0rc5 problem with -lGL, Samuel Pitoiset, 18/12/2015
- Re: [Starpu-devel] 1.2.0rc5 problem with -lGL, Malcolm Roberts, 18/12/2015
