Archives de la liste
- From: Malcolm Roberts <malcolm.i.w.roberts@gmail.com>
- To: Samuel Pitoiset <samuel.pitoiset@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] 1.2.0rc5 problem with -lGL
- Date: Fri, 18 Dec 2015 15:20:38 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=malcolm.i.w.roberts@gmail.com; spf=Pass smtp.mailfrom=malcolm.i.w.roberts@gmail.com; spf=None smtp.helo=postmaster@mail-wm0-f45.google.com
- Ironport-phdr: 9a23:OR2ipBMX7enfHEzs9cAl6mtUPXoX/o7sNwtQ0KIMzox0KPTyrarrMEGX3/hxlliBBdydsKIazbKO+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStCU15z//tvx0qOQSj0AvCC6b7J2IUf+hiTqne5Sv7FfLL0swADCuHpCdrce72ppIVWOg0S0vZ/or9ZLuh5dsPM59sNGTb6yP+FhFeQZX3waNDUO7cj2uB2LdQqT4XoHX3lexgFBBhXI6FfiX4v2szD3qsJ83jObNIv4V+Zndy6l6vJOQRvjjyMCfwQ++mzNltc42KdSpBmmoxk5wsjLJpuSPvdkYrj1ctYTRG4HVcFUAX8SSrigZpcCWrJSdd1TqJPw8h5X9UOz
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello, Samuel.
Thanks for the response. I ran the command
rm -rf starpu-1.2.0rc && tar -xvf starpu-1.2.0rc5.tar.gz && cd starpu-1.2.0rc5 && ./configure --prefix=$HOME/starpu --disable-opengl-render && make && cd ..
and I still get the error
/usr/bin/ld: cannot find -lGL
Best,
~Malcolm
On 18/12/2015 15:03, Samuel Pitoiset wrote:
Hello Malcom,
If you don't need OpenGL, try to disable it with --disable-opengl-render.
Cheers,
Samuel.
----- Mail original -----
De: "Malcolm Roberts" <malcolm.i.w.roberts@gmail.com>
À: starpu-devel@lists.gforge.inria.fr
Envoyé: Vendredi 18 Décembre 2015 13:47:12
Objet: [Starpu-devel] 1.2.0rc5 problem with -lGL
Hello.
I am trying to compile 1.2.0rc5 on an Ubuntu system. After running
./configure --prefix=$HOME/starpu && make, I get the following error:
In fact, OpenCL is installed:
ls -l /usr/lib/fglrx/libGL*
lrwxrwxrwx 1 root root 10 Sep 11 11:53 /usr/lib/fglrx/libGL.so ->
libGL.so.1
lrwxrwxrwx 1 root root 12 Sep 11 11:53 /usr/lib/fglrx/libGL.so.1 ->
libGL.so.1.2
-rw-r--r-- 1 root root 867632 Sep 11 11:53 /usr/lib/fglrx/libGL.so.1.2
Best,
~Malcolm Roberts
http://malcolmiwroberts.com
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
- [Starpu-devel] 1.2.0rc5 problem with -lGL, Malcolm Roberts, 18/12/2015
- Re: [Starpu-devel] 1.2.0rc5 problem with -lGL, Samuel Pitoiset, 18/12/2015
- Re: [Starpu-devel] 1.2.0rc5 problem with -lGL, Malcolm Roberts, 18/12/2015
