Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Cannot use OpenCL on CPU
Archives de la liste
Chronologique Discussions
  • To: Nathalie Furmento <nathalie.furmento@labri.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Cannot use OpenCL on CPU
  • Date: Thu, 14 Jan 2016 14:26:24 +0100 (CET)
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi Nathalie,
From the command I get the same behavior:
StarPU has found :
2 CPU threads
CPU 0
CPU 1
0 CUDA devices
0 OpenCL devices
topology ...
core 0 PU 0 CPU 0
PU 1
core 1 PU 2 CPU 1
PU 3
bandwidth and latency ...
from/to RAM
RAM 0
RAM 0
I use the svn from commit : r16748 | nfurmento | 2016-01-12 16:08:28 +0100 (mar. 12 janv. 2016)
And I can use OpenCL by hand on my CPU but not with StarPU.
Thanks.
Bérenger Bramas
HiePACS Project
Tel (05 24 57) 40 76
INRIA BORDEAUX Sud Ouest
De: "Nathalie Furmento" <nathalie.furmento@labri.fr>
À: "Berenger Bramas" <berenger.bramas@inria.fr>, starpu-devel@lists.gforge.inria.fr
Envoyé: Jeudi 14 Janvier 2016 14:19:32
Objet: Re: [Starpu-devel] Cannot use OpenCL on CPU
Hi Berenger,
Which version of StarPU are you using? How was it compiled?
If you start starpu_machine_display, what do you get?
Cheers,
Nathalie
On 14/01/2016 14:16, Berenger Bramas wrote:
46446358.36380429.1452777376012.JavaMail.zimbra@inria.fr">
Hello,
I am using OpenCL on CPU (mainly for development purpose)
StarPU was able to detect my CPU (Intel® Core™ i7-4610M CPU @ 3.00GHz × 4) as an OpenCL device until lately.
The following code is compiled well:
#include <starpu.h>
#include <iostream>
#include <vector>
#include <unistd.h>
#ifndef STARPU_USE_OPENCL
#error StarPU must support opencl
#endif
int main(int /*argc*/, char** /*argv*/){
    setenv("STARPU_NCPU","0",1);
    setenv("STARPU_NOPENCL","1",1);
    setenv("STARPU_OPENCL_ONLY_ON_CPUS","1",1);
    setenv("STARPU_OPENCL_ON_CPUS","1",1);
    setenv("STARPU_DISABLE_ASYNCHRONOUS_OPENCL_COPY","1",1);
    setenv("STARPU_OPENCL_PIPELINE","0",0);
    std::cout << "STARPU_MAJOR_VERSION " << STARPU_MAJOR_VERSION << std::endl;
    std::cout << "STARPU_MINOR_VERSION " << STARPU_MINOR_VERSION << std::endl;
    std::cout << "STARPU_MAXOPENCLDEVS " << STARPU_MAXOPENCLDEVS << std::endl;
    unsigned ret;
    struct starpu_conf conf;
    ret = starpu_conf_init(&conf);
    assert(ret == 0);
    ret = starpu_init(&conf);
    assert(ret == 0);
    starpu_pause();
    std::cout << "starpu_worker_get_count " << starpu_worker_get_count() << std::endl;
    std::cout << "starpu_cpu_worker_get_count " << starpu_cpu_worker_get_count() << std::endl;
    std::cout << "starpu_opencl_worker_get_count " << starpu_opencl_worker_get_count() << std::endl;
    starpu_resume();
    starpu_shutdown();
    return 0;
But at execution I get:
$ ./Tests/Debug/testOpenCLCPU
STARPU_MAJOR_VERSION 1
STARPU_MINOR_VERSION 3
STARPU_MAXOPENCLDEVS 8
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-debug (-O0), and is thus not optimized
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-spinlock-check, which slows down a bit
[starpu][starpu_initialize] Warning: StarPU was configured with --enable-verbose, which slows down a bit
[starpu][starpu_initialize] Warning: StarPU was configured with --with-fxt, which slows down a bit
[starpu][load_bus_latency_file_content] loading latencies from /home/berenger/.starpu/sampling//bus/berenger-HP-ProBook-640-G1.latency
[starpu][load_bus_bandwidth_file_content] loading bandwidth from /home/berenger/.starpu/sampling//bus/berenger-HP-ProBook-640-G1.bandwidth
[starpu][_starpu_init_machine_config] No worker found, aborting ...
Thanks for the help.
Bérenger Bramas
HiePACS Project
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
Haut de le page
