Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Berenger Bramas <berenger.bramas@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Cannot use OpenCL on CPU
- Date: Thu, 14 Jan 2016 14:30:02 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=Pass smtp.mailfrom=nathalie.furmento@labri.fr; spf=Pass smtp.helo=postmaster@iona.labri.fr
- Ironport-phdr: 9a23:aJ/hrxaMvB5uf9hXc+uTfm3/LSx+4OfEezUN459isYplN5qZpcW+bnLW6fgltlLVR4KTs6sC0LqI9fCxEjFYqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh770q8yYPl0ArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIZoGJ/3dKUgTLFeEC9ucyVsvJWq5lH/Sl6l62ERVGobiFJiGQHA5QqyCp38qCb8uednniOANMj/Vpg1Xy6j5uFlUkm7pj0AMmsf+X3Xg8hxgep1vQikqhpjxMaAZoiJNPN6f66bc84AQGdHQsF5UyVLGIL6YZFZXLlJBvpRs4So/whGlhC5HwT5Qbq3kjI=
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Could you send the output of the
following command:
STARPU_OPENCL_ONLY_ON_CPUS=1 STARPU_OPENCL_ON_CPUS=1 starpu_machine_display Thanks, NathalieOn 14/01/2016 14:26, Berenger Bramas wrote: Hi Nathalie,
From the command I get the same behavior:
StarPU
has found : topology
... bandwidth
and latency ... RAM 0
I use the svn from commit : r16748 | nfurmento | 2016-01-12 16:08:28 +0100 (mar. 12 janv. 2016) And I can use OpenCL by hand on my CPU but not with StarPU.
Thanks.
Bérenger Bramas
INRIA BORDEAUX Sud Ouest De: "Nathalie Furmento" <nathalie.furmento@labri.fr> À: "Berenger Bramas" <berenger.bramas@inria.fr>, starpu-devel@lists.gforge.inria.fr Envoyé: Jeudi 14 Janvier 2016 14:19:32 Objet: Re: [Starpu-devel] Cannot use OpenCL on CPU Hi Berenger,
Which version of StarPU are you using? How was it compiled? If you start starpu_machine_display, what do you get? Cheers, Nathalie On 14/01/2016 14:16, Berenger Bramas wrote: Hello,
I am using OpenCL on CPU (mainly for development
purpose)
StarPU was able to detect my CPU (Intel® Core™
i7-4610M CPU @ 3.00GHz × 4) as an OpenCL device until
lately.
The following code is compiled well:
#include <starpu.h> #include <iostream> #include <vector> #include <unistd.h> #ifndef STARPU_USE_OPENCL #error StarPU must support opencl #endif
int main(int /*argc*/, char** /*argv*/){ setenv("STARPU_NCPU","0",1); setenv("STARPU_NOPENCL","1",1); setenv("STARPU_OPENCL_ONLY_ON_CPUS","1",1); setenv("STARPU_OPENCL_ON_CPUS","1",1); setenv("STARPU_DISABLE_ASYNCHRONOUS_OPENCL_COPY","1",1); setenv("STARPU_OPENCL_PIPELINE","0",0); std::cout << "STARPU_MAJOR_VERSION " << STARPU_MAJOR_VERSION << std::endl; std::cout << "STARPU_MINOR_VERSION " << STARPU_MINOR_VERSION << std::endl; std::cout << "STARPU_MAXOPENCLDEVS " << STARPU_MAXOPENCLDEVS << std::endl; unsigned ret; struct starpu_conf conf; ret = starpu_conf_init(&conf); assert(ret == 0); ret = starpu_init(&conf); assert(ret == 0); starpu_pause();
std::cout << "starpu_worker_get_count " << starpu_worker_get_count() << std::endl; std::cout << "starpu_cpu_worker_get_count " << starpu_cpu_worker_get_count() << std::endl; std::cout << "starpu_opencl_worker_get_count " << starpu_opencl_worker_get_count() << std::endl; starpu_resume();
starpu_shutdown();
return 0; } ==================================================
But at execution I get:
$ ./Tests/Debug/testOpenCLCPU Thanks for the help.
Bérenger Bramas
INRIA BORDEAUX Sud Ouest _______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/mailman/listinfo/starpu-devel |
- [Starpu-devel] Cannot use OpenCL on CPU, Berenger Bramas, 14/01/2016
- Re: [Starpu-devel] Cannot use OpenCL on CPU, Nathalie Furmento, 14/01/2016
- Re: [Starpu-devel] Cannot use OpenCL on CPU, Berenger Bramas, 14/01/2016
- Re: [Starpu-devel] Cannot use OpenCL on CPU, Samuel Thibault, 14/01/2016
