Archives de la liste
[Starpu-devel] starpu_fxt fix: threadid type should be coherent (probably long unsigned)
Chronologique Discussions
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] starpu_fxt fix: threadid type should be coherent (probably long unsigned)
- Date: Wed, 17 Feb 2016 16:40:03 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
Throughout the file src/debug/traces/starpu_fxt.c, argument threadid is sometimes used as "long unsigned int" and sometimes as a simple "int". This was causing slightly bogus paje traces when running StarPU+SimGrid.
I assume that the best way to solve this issue is to convert all threadids into long unsigned int. The attached patch should fix the problem.
Best,
Luka
>From 7e00c39e0c5cc23f2533ff6370238dbcabe7607a Mon Sep 17 00:00:00 2001 From: Luka Stanisic <luka.stanisic@inria.fr> Date: Wed, 17 Feb 2016 15:57:12 +0100 Subject: [PATCH] fixing threadid in the traces to always be "long unsigned" --- src/debug/traces/starpu_fxt.c | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-) diff --git a/src/debug/traces/starpu_fxt.c b/src/debug/traces/starpu_fxt.c index 5e169d3..f95a34e 100644 --- a/src/debug/traces/starpu_fxt.c +++ b/src/debug/traces/starpu_fxt.c @@ -542,7 +542,7 @@ static void mpicommthread_set_state(double time, const char *prefix, const char #endif } -static void recfmt_set_state(double time, const char *event, int workerid, int threadid, const char *name, const char *type) +static void recfmt_set_state(double time, const char *event, int workerid, long unsigned int threadid, const char *name, const char *type) { fprintf(trace_file, "E: %s\n", event); if (name) @@ -550,7 +550,7 @@ static void recfmt_set_state(double time, const char *event, int workerid, int t if (type) fprintf(trace_file, "C: %s\n", type); fprintf(trace_file, "W: %d\n", workerid); - fprintf(trace_file, "T: %d\n", threadid); + fprintf(trace_file, "T: %lu\n", threadid); fprintf(trace_file, "S: %f\n", time); fprintf(trace_file, "\n"); } @@ -560,17 +560,17 @@ static void recfmt_worker_set_state(double time, int workerid, const char *name, recfmt_set_state(time, "SetState", workerid, -1, name, type); } -static void recfmt_thread_set_state(double time, int threadid, const char *name, const char *type) +static void recfmt_thread_set_state(double time, long unsigned int threadid, const char *name, const char *type) { recfmt_set_state(time, "SetState", find_worker_id(threadid), threadid, name, type); } -static void recfmt_thread_push_state(double time, int threadid, const char *name, const char *type) +static void recfmt_thread_push_state(double time, long unsigned int threadid, const char *name, const char *type) { recfmt_set_state(time, "PushState", find_worker_id(threadid), threadid, name, type); } -static void recfmt_thread_pop_state(double time, int threadid) +static void recfmt_thread_pop_state(double time, long unsigned int threadid) { recfmt_set_state(time, "PopState", find_worker_id(threadid), threadid, NULL, NULL); } @@ -627,7 +627,7 @@ static void handle_worker_init_start(struct fxt_ev_64 *ev, struct starpu_fxt_opt int nodeid = ev->param[3]; int bindid = ev->param[4]; int set = ev->param[5]; - int threadid = ev->param[6]; + long unsigned int threadid = ev->param[6]; int new_thread; new_thread = register_worker_id(threadid, workerid, set); @@ -700,9 +700,9 @@ static void handle_worker_init_start(struct fxt_ev_64 *ev, struct starpu_fxt_opt poti_CreateContainer(get_event_time_stamp(ev, options), new_worker_container_alias, "W", new_thread_container_alias, new_worker_container_name); #else if (new_thread) - fprintf(out_paje_file, "7 %.9f %st%d T %smn%d %s%d\n", + fprintf(out_paje_file, "7 %.9f %st%lu T %smn%d %s%d\n", get_event_time_stamp(ev, options), prefix, threadid, prefix, nodeid, prefix, bindid); - fprintf(out_paje_file, "7 %.9f %sw%d W %st%d %s%s%d\n", + fprintf(out_paje_file, "7 %.9f %sw%d W %st%lu %s%s%d\n", get_event_time_stamp(ev, options), prefix, workerid, prefix, threadid, prefix, kindstr, devid); #endif } @@ -749,7 +749,7 @@ static void handle_worker_init_end(struct fxt_ev_64 *ev, struct starpu_fxt_optio static void handle_worker_deinit_start(struct fxt_ev_64 *ev, struct starpu_fxt_options *options) { char *prefix = options->file_prefix; - int threadid = ev->param[0]; + long unsigned int threadid = ev->param[0]; if (out_paje_file) thread_set_state(get_event_time_stamp(ev, options), prefix, threadid, "D"); @@ -1098,7 +1098,7 @@ static void handle_end_codelet_body(struct fxt_ev_64 *ev, struct starpu_fxt_opti static void handle_start_executing(struct fxt_ev_64 *ev, struct starpu_fxt_options *options) { char *prefix = options->file_prefix; - int threadid = ev->param[0]; + long unsigned int threadid = ev->param[0]; if (out_paje_file && !find_sync(threadid)) thread_set_state(get_event_time_stamp(ev, options), prefix, threadid, "E"); @@ -1109,7 +1109,7 @@ static void handle_start_executing(struct fxt_ev_64 *ev, struct starpu_fxt_optio static void handle_end_executing(struct fxt_ev_64 *ev, struct starpu_fxt_options *options) { char *prefix = options->file_prefix; - int threadid = ev->param[0]; + long unsigned int threadid = ev->param[0]; if (out_paje_file && !find_sync(threadid)) thread_set_state(get_event_time_stamp(ev, options), prefix, threadid, "B"); -- 2.5.0
- [Starpu-devel] starpu_fxt fix: threadid type should be coherent (probably long unsigned), Luka Stanisic, 17/02/2016
- Re: [Starpu-devel] starpu_fxt fix: threadid type should be coherent (probably long unsigned), Samuel Thibault, 18/02/2016
