Archives de la liste
Re: [Starpu-devel] starpu_fxt fix: threadid type should be coherent (probably long unsigned)
Chronologique Discussions
- To: Luka Stanisic <luka.stanisic@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] starpu_fxt fix: threadid type should be coherent (probably long unsigned)
- Date: Thu, 18 Feb 2016 11:51:53 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Luka Stanisic, on Wed 17 Feb 2016 16:40:03 +0100, wrote:
> I assume that the best way to solve this issue is to convert all threadids
> into long unsigned int. The attached patch should fix the problem.
Indeed, please commit (I've just added you to the project, so you can
also work on your perfmodel extension).
Samuel
- [Starpu-devel] starpu_fxt fix: threadid type should be coherent (probably long unsigned), Luka Stanisic, 17/02/2016
- Re: [Starpu-devel] starpu_fxt fix: threadid type should be coherent (probably long unsigned), Samuel Thibault, 18/02/2016
