Archives de la liste
qhedpc3eborqra6jspjf/bin
PATH: /builds/spack/opt/spack/linux-x86_64/gcc-4.8/hwloc-1.11.3-h5rqz3ba5=
6snhid26cox3r76jnhbjjrc/bin
PATH: /builds/spack/opt/spack/linux-x86_64/gcc-4.8/openmpi-1.10.2-336gjyr=
lwza2vmaoueye7mpahyvmnuhv/bin
PATH: /builds/spack/bin
PATH: /usr/local/sbin
PATH: /usr/local/bin
PATH: /usr/sbin
PATH: /usr/bin
PATH: /sbin
PATH: /bin
PATH: /usr/games
PATH: /usr/local/games
## Core tests. ##
configure:3578: checking build system type
configure:3592: result: x86_64-unknown-linux-gnu
configure:3612: checking host system type
configure:3625: result: x86_64-unknown-linux-gnu
configure:3645: checking target system type
configure:3658: result: x86_64-unknown-linux-gnu
configure:3702: checking for a BSD-compatible install
configure:3770: result: /usr/bin/install -c
configure:3781: checking whether build environment is sane
configure:3836: result: yes
configure:3987: checking for a thread-safe mkdir -p
configure:4026: result: /bin/mkdir -p
configure:4033: checking for gawk
configure:4049: found /usr/bin/gawk
configure:4060: result: gawk
configure:4071: checking whether make sets $(MAKE)
configure:4093: result: yes
configure:4122: checking whether make supports nested variables
configure:4139: result: yes
configure:4277: checking whether make supports nested variables
configure:4294: result: yes
configure:4320: checking for style of include used by make
configure:4348: result: GNU
configure:4419: checking for gcc
configure:4446: result: /builds/spack/lib/spack/env/gcc/gcc
configure:4675: checking for C compiler version
configure:4684: /builds/spack/lib/spack/env/gcc/gcc --version >&5
gcc-4.8 (Ubuntu 4.8.4-2ubuntu1~14.04.3) 4.8.4
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is N=
O
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOS=
E.
configure:4695: $? =3D 0
configure:4684: /builds/spack/lib/spack/env/gcc/gcc -v >&5
Using built-in specs.
COLLECT_GCC=3D/usr/bin/gcc-4.8
COLLECT_LTO_WRAPPER=3D/usr/lib/gcc/x86_64-linux-gnu/4.8/lto-wrapper
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion=3D'Ubuntu 4.8.4-2u=
buntu1~14.04.3' --with-bugurl=3Dfile:///usr/share/doc/gcc-4.8/README.Bugs=
--enable-languages=3Dc,c++,java,go,d,fortran,objc,obj-c++ --prefix=3D/us=
r --program-suffix=3D-4.8 --enable-shared --enable-linker-build-id --libe=
xecdir=3D/usr/lib --without-included-gettext --enable-threads=3Dposix --w=
ith-gxx-include-dir=3D/usr/include/c++/4.8 --libdir=3D/usr/lib --enable-n=
ls --with-sysroot=3D/ --enable-clocale=3Dgnu --enable-libstdcxx-debug --e=
nable-libstdcxx-time=3Dyes --enable-gnu-unique-object --disable-libmudfla=
p --enable-plugin --with-system-zlib --disable-browser-plugin --enable-ja=
va-awt=3Dgtk --enable-gtk-cairo --with-java-home=3D/usr/lib/jvm/java-1.5.=
0-gcj-4.8-amd64/jre --enable-java-home --with-jvm-root-dir=3D/usr/lib/jvm=
/java-1.5.0-gcj-4.8-amd64 --with-jvm-jar-dir=3D/usr/lib/jvm-exports/java-=
1.5.0-gcj-4.8-amd64 --with-arch-directory=3Damd64 --with-ecj-jar=3D/usr/s=
hare/java/eclipse-ecj.jar --enable-objc-gc --enable-multiarch --disable-w=
error --with-arch-32=3Di686 --with-abi=3Dm64 --with-multilib-list=3Dm32,m=
64,mx32 --with-tune=3Dgeneric --enable-checking=3Drelease --build=3Dx86_6=
4-linux-gnu --host=3Dx86_64-linux-gnu --target=3Dx86_64-linux-gnu
Thread model: posix
gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04.3)=20
configure:4684: /builds/spack/lib/spack/env/gcc/gcc -V >&5
gcc-4.8: error: unrecognized command line option '-V'
gcc-4.8: fatal error: no input files
compilation terminated.
configure:4695: $? =3D 4
configure:4684: /builds/spack/lib/spack/env/gcc/gcc -qversion >&5
/builds/spack/lib/spack/env/gcc/gcc: line 328: $input_log: ambiguous redi=
rect
/builds/spack/lib/spack/env/gcc/gcc: line 329: $output_log: ambiguous red=
irect
gcc-4.8: error: unrecognized command line option '-qversion'
configure:4695: $? =3D 1
configure:4715: checking whether the C compiler works
configure:4737: /builds/spack/lib/spack/env/gcc/gcc conftest.c >&5
rect
irect
configure:4741: $? =3D 0
configure:4789: result: yes
configure:4792: checking for C compiler default output file name
configure:4794: result: a.out
configure:4800: checking for suffix of executables
configure:4807: /builds/spack/lib/spack/env/gcc/gcc -o conftest confte=
st.c >&5
rect
irect
configure:4811: $? =3D 0
configure:4833: result:=20
configure:4855: checking whether we are cross compiling
configure:4863: /builds/spack/lib/spack/env/gcc/gcc -o conftest confte=
st.c >&5
rect
irect
configure:4867: $? =3D 0
configure:4874: ./conftest
configure:4878: $? =3D 0
configure:4893: result: no
configure:4898: checking for suffix of object files
configure:4920: /builds/spack/lib/spack/env/gcc/gcc -c conftest.c >&5
rect
irect
configure:4924: $? =3D 0
configure:4945: result: o
configure:4949: checking whether we are using the GNU C compiler
configure:4968: /builds/spack/lib/spack/env/gcc/gcc -c conftest.c >&5
rect
irect
configure:4968: $? =3D 0
configure:4977: result: yes
configure:4986: checking whether /builds/spack/lib/spack/env/gcc/gcc acce=
pts -g
configure:5006: /builds/spack/lib/spack/env/gcc/gcc -c -g conftest.c >&5=
rect
irect
configure:5006: $? =3D 0
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "StarPU"
| #define PACKAGE_TARNAME "starpu"
| #define PACKAGE_VERSION "1.2.0rc5"
| #define PACKAGE_STRING "StarPU 1.2.0rc5"
| #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr"
| #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/"
| #define STARPU_MAJOR_VERSION 1
| #define STARPU_MINOR_VERSION 2
| #define STARPU_RELEASE_VERSION 0
| #define PACKAGE "starpu"
| #define VERSION "1.2.0rc5"
| /* end confdefs.h. */
|=20
| int
| main ()
|=20
| return 0;
configure:5021: /builds/spack/lib/spack/env/gcc/gcc -c conftest.c >&5
rect
irect
configure:5021: $? =3D 0
| /* confdefs.h */
|=20
| int
| main ()
|=20
| return 0;
configure:5037: /builds/spack/lib/spack/env/gcc/gcc -c -g conftest.c >&5=
rect
irect
configure:5037: $? =3D 0
configure:5047: result: yes
configure:5064: checking for /builds/spack/lib/spack/env/gcc/gcc option t=
o accept ISO C89
configure:5127: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 conftest.=
c >&5
rect
irect
configure:5127: $? =3D 0
configure:5140: result: none needed
configure:5165: checking whether /builds/spack/lib/spack/env/gcc/gcc unde=
rstands -c and -o together
configure:5187: /builds/spack/lib/spack/env/gcc/gcc -c conftest.c -o conf=
test2.o
rect
irect
configure:5190: $? =3D 0
test2.o
rect
irect
configure:5202: result: yes
configure:5221: checking dependency style of /builds/spack/lib/spack/env/=
gcc/gcc
configure:5332: result: gcc3
configure:5397: checking for ar
configure:5413: found /usr/bin/ar
configure:5424: result: ar
configure:5450: checking the archiver (ar) interface
configure:5466: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 conftest.c=
>&5
rect
irect
configure:5466: $? =3D 0
configure:5468: ar cru libconftest.a conftest.o >&5
configure:5471: $? =3D 0
configure:5499: result: ar
configure:5567: checking for gcc
configure:5594: result: /builds/spack/lib/spack/env/gcc/gcc
configure:5823: checking for C compiler version
configure:5832: /builds/spack/lib/spack/env/gcc/gcc --version >&5
O
E.
configure:5843: $? =3D 0
configure:5832: /builds/spack/lib/spack/env/gcc/gcc -v >&5
Thread model: posix
configure:5832: /builds/spack/lib/spack/env/gcc/gcc -V >&5
configure:5843: $? =3D 4
configure:5832: /builds/spack/lib/spack/env/gcc/gcc -qversion >&5
rect
irect
configure:5843: $? =3D 1
configure:5847: checking whether we are using the GNU C compiler
configure:5875: result: yes
configure:5884: checking whether /builds/spack/lib/spack/env/gcc/gcc acce=
pts -g
configure:5945: result: yes
configure:5962: checking for /builds/spack/lib/spack/env/gcc/gcc option t=
o accept ISO C89
configure:6038: result: none needed
configure:6063: checking whether /builds/spack/lib/spack/env/gcc/gcc unde=
configure:6100: result: yes
configure:6119: checking dependency style of /builds/spack/lib/spack/env/=
gcc/gcc
configure:6230: result: gcc3
configure:6358: checking for C++ compiler version
configure:6367: /builds/spack/lib/spack/env/gcc/g++ --version >&5
g++-4.8 (Ubuntu 4.8.4-2ubuntu1~14.04.3) 4.8.4
O
E.
configure:6378: $? =3D 0
configure:6367: /builds/spack/lib/spack/env/gcc/g++ -v >&5
COLLECT_GCC=3D/usr/bin/g++-4.8
Thread model: posix
configure:6367: /builds/spack/lib/spack/env/gcc/g++ -V >&5
g++-4.8: error: unrecognized command line option '-V'
g++-4.8: fatal error: no input files
configure:6378: $? =3D 4
configure:6367: /builds/spack/lib/spack/env/gcc/g++ -qversion >&5
/builds/spack/lib/spack/env/gcc/g++: line 328: $input_log: ambiguous redi=
rect
/builds/spack/lib/spack/env/gcc/g++: line 329: $output_log: ambiguous red=
irect
g++-4.8: error: unrecognized command line option '-qversion'
configure:6378: $? =3D 1
configure:6382: checking whether we are using the GNU C++ compiler
configure:6401: /builds/spack/lib/spack/env/gcc/g++ -c conftest.cpp >&5=
rect
irect
configure:6401: $? =3D 0
configure:6410: result: yes
configure:6419: checking whether /builds/spack/lib/spack/env/gcc/g++ acce=
pts -g
configure:6439: /builds/spack/lib/spack/env/gcc/g++ -c -g conftest.cpp >=
&5
rect
irect
configure:6439: $? =3D 0
| /* confdefs.h */
|=20
| int
| main ()
|=20
| return 0;
configure:6454: /builds/spack/lib/spack/env/gcc/g++ -c conftest.cpp >&5=
rect
irect
configure:6454: $? =3D 0
| /* confdefs.h */
|=20
| int
| main ()
|=20
| return 0;
configure:6470: /builds/spack/lib/spack/env/gcc/g++ -c -g conftest.cpp >=
&5
rect
irect
configure:6470: $? =3D 0
configure:6480: result: yes
configure:6505: checking dependency style of /builds/spack/lib/spack/env/=
gcc/g++
configure:6616: result: gcc3
configure:6636: checking how to run the C preprocessor
configure:6667: /builds/spack/lib/spack/env/gcc/gcc -E conftest.c
rect
irect
configure:6667: $? =3D 0
configure:6681: /builds/spack/lib/spack/env/gcc/gcc -E conftest.c
rect
irect
conftest.c:14:28: fatal error: ac_nonexistent.h: No such file or director=
y
#include <ac_nonexistent.h>
configure:6681: $? =3D 1
| /* confdefs.h */
configure:6706: result: /builds/spack/lib/spack/env/gcc/gcc -E
configure:6726: /builds/spack/lib/spack/env/gcc/gcc -E conftest.c
rect
irect
configure:6726: $? =3D 0
configure:6740: /builds/spack/lib/spack/env/gcc/gcc -E conftest.c
rect
irect
y
configure:6740: $? =3D 1
| /* confdefs.h */
configure:6768: checking for a sed that does not truncate output
configure:6832: result: /bin/sed
configure:6837: checking whether ln -s works
configure:6841: result: yes
configure:6954: checking for Fortran 77 compiler version
configure:6963: /builds/spack/lib/spack/env/gcc/gfortran --version >&5
GNU Fortran (Ubuntu 4.8.4-2ubuntu1~14.04.3) 4.8.4
GNU Fortran comes with NO WARRANTY, to the extent permitted by law.
You may redistribute copies of GNU Fortran
under the terms of the GNU General Public License.
For more information about these matters, see the file named COPYING
configure:6974: $? =3D 0
configure:6963: /builds/spack/lib/spack/env/gcc/gfortran -v >&5
COLLECT_GCC=3D/usr/bin/gfortran-4.8
Thread model: posix
configure:6963: /builds/spack/lib/spack/env/gcc/gfortran -V >&5
gfortran-4.8: error: unrecognized command line option '-V'
gfortran-4.8: fatal error: no input files
configure:6974: $? =3D 4
configure:6963: /builds/spack/lib/spack/env/gcc/gfortran -qversion >&5
/builds/spack/lib/spack/env/gcc/gfortran: line 328: $input_log: ambiguous=
redirect
/builds/spack/lib/spack/env/gcc/gfortran: line 329: $output_log: ambiguou=
s redirect
gfortran-4.8: error: unrecognized command line option '-qversion'
configure:6974: $? =3D 1
configure:6983: checking whether we are using the GNU Fortran 77 compiler=
configure:6996: /builds/spack/lib/spack/env/gcc/gfortran -c conftest.F >=
&5
redirect
s redirect
configure:6996: $? =3D 0
configure:7005: result: yes
configure:7011: checking whether /builds/spack/lib/spack/env/gcc/gfortran=
accepts -g
configure:7022: /builds/spack/lib/spack/env/gcc/gfortran -c -g conftest.f=
>&5
redirect
s redirect
configure:7022: $? =3D 0
configure:7030: result: yes
configure:7165: checking for Fortran compiler version
configure:7174: /builds/spack/lib/spack/env/gcc/gfortran --version >&5
configure:7185: $? =3D 0
configure:7174: /builds/spack/lib/spack/env/gcc/gfortran -v >&5
Thread model: posix
configure:7174: /builds/spack/lib/spack/env/gcc/gfortran -V >&5
configure:7185: $? =3D 4
configure:7174: /builds/spack/lib/spack/env/gcc/gfortran -qversion >&5
redirect
s redirect
configure:7185: $? =3D 1
configure:7194: checking whether we are using the GNU Fortran compiler
configure:7207: /builds/spack/lib/spack/env/gcc/gfortran -c conftest.F =
>&5
redirect
s redirect
configure:7207: $? =3D 0
configure:7216: result: yes
configure:7222: checking whether /builds/spack/lib/spack/env/gcc/gfortran=
accepts -g
configure:7233: /builds/spack/lib/spack/env/gcc/gfortran -c -g conftest.=
f >&5
redirect
s redirect
configure:7233: $? =3D 0
configure:7241: result: yes
configure:7274: checking for gstat
configure:7304: result: no
configure:7274: checking for stat
configure:7290: found /usr/bin/stat
configure:7301: result: stat
configure:7316: checking for gdate
configure:7346: result: no
configure:7316: checking for date
configure:7332: found /bin/date
configure:7343: result: date
configure:7402: checking how to print strings
configure:7429: result: printf
configure:7450: checking for a sed that does not truncate output
configure:7514: result: /bin/sed
configure:7532: checking for grep that handles long lines and -e
configure:7590: result: /bin/grep
configure:7595: checking for egrep
configure:7657: result: /bin/grep -E
configure:7662: checking for fgrep
configure:7724: result: /bin/grep -F
configure:7759: checking for ld used by /builds/spack/lib/spack/env/gcc/g=
cc
rect
irect
configure:7826: result: /builds/spack/lib/spack/env/ld
configure:7833: checking if the linker (/builds/spack/lib/spack/env/ld) i=
s GNU ld
configure:7848: result: yes
configure:7860: checking for BSD- or MS-compatible name lister (nm)
configure:7909: result: /usr/bin/nm -B
configure:8039: checking the name lister (/usr/bin/nm -B) interface
configure:8046: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 conftest.c=
>&5
rect
irect
configure:8049: /usr/bin/nm -B "conftest.o"
configure:8052: output
0000000000000000 B some_variable
configure:8059: result: BSD nm
configure:8063: checking the maximum length of command line arguments
configure:8194: result: 1572864
configure:8211: checking whether the shell understands some XSI construct=
s
configure:8221: result: yes
configure:8225: checking whether the shell understands "+=3D"
configure:8231: result: yes
configure:8266: checking how to convert x86_64-unknown-linux-gnu file nam=
es to x86_64-unknown-linux-gnu format
configure:8306: result: func_convert_file_noop
configure:8313: checking how to convert x86_64-unknown-linux-gnu file nam=
es to toolchain format
configure:8333: result: func_convert_file_noop
configure:8340: checking for /builds/spack/lib/spack/env/ld option to rel=
oad object files
configure:8347: result: -r
configure:8421: checking for objdump
configure:8437: found /usr/bin/objdump
configure:8448: result: objdump
configure:8477: checking how to recognize dependent libraries
configure:8675: result: pass_all
configure:8760: checking for dlltool
configure:8790: result: no
configure:8817: checking how to associate runtime and link libraries
configure:8844: result: printf %s\n
configure:8968: checking for archiver @FILE support
configure:8985: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 conftest.c=
>&5
rect
irect
configure:8985: $? =3D 0
configure:8988: ar cru libconftest.a @conftest.lst >&5
configure:8991: $? =3D 0
configure:8996: ar cru libconftest.a @conftest.lst >&5
ar: conftest.o: No such file or directory
configure:8999: $? =3D 1
configure:9011: result: @
configure:9069: checking for strip
configure:9085: found /usr/bin/strip
configure:9096: result: strip
configure:9168: checking for ranlib
configure:9184: found /usr/bin/ranlib
configure:9195: result: ranlib
configure:9297: checking command to parse /usr/bin/nm -B output from /bui=
lds/spack/lib/spack/env/gcc/gcc object
configure:9417: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 conftest.c=
>&5
rect
irect
configure:9420: $? =3D 0
configure:9424: /usr/bin/nm -B conftest.o \| sed -n -e 's/^.*[ ]\([ABCDGI=
RSTW][ABCDGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p' | sed =
'/ __gnu_lto/d' \> conftest.nm
configure:9427: $? =3D 0
configure:9493: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
conftest.c conftstm.o >&5
rect
irect
configure:9496: $? =3D 0
configure:9534: result: ok
configure:9571: checking for sysroot
configure:9601: result: no
configure:9678: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 conftest.c=
>&5
rect
irect
configure:9681: $? =3D 0
configure:9870: checking for mt
configure:9886: found /bin/mt
configure:9897: result: mt
configure:9920: checking if mt is a manifest tool
configure:9926: mt '-?'
configure:9934: result: no
configure:10572: checking for ANSI C header files
configure:10592: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 conftest.=
c >&5
rect
irect
configure:10592: $? =3D 0
rect
irect
rect
irect
configure:10665: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
conftest.c >&5
rect
irect
configure:10665: $? =3D 0
configure:10665: ./conftest
configure:10676: result: yes
configure:10689: checking for sys/types.h
configure:10689: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 conftest.=
c >&5
rect
irect
configure:10689: $? =3D 0
configure:10689: result: yes
configure:10689: checking for sys/stat.h
c >&5
rect
irect
configure:10689: checking for stdlib.h
c >&5
rect
irect
configure:10689: checking for string.h
c >&5
rect
irect
configure:10689: checking for memory.h
c >&5
rect
irect
configure:10689: checking for strings.h
c >&5
rect
irect
configure:10689: checking for inttypes.h
c >&5
rect
irect
configure:10689: checking for stdint.h
c >&5
rect
irect
configure:10689: checking for unistd.h
c >&5
rect
irect
configure:10703: checking for dlfcn.h
configure:10703: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 conftest.=
c >&5
rect
irect
configure:10703: $? =3D 0
configure:10703: result: yes
configure:11220: checking for objdir
configure:11235: result: .libs
configure:11506: checking if /builds/spack/lib/spack/env/gcc/gcc supports=
-fno-rtti -fno-exceptions
configure:11524: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 -fno-rtti=
-fno-exceptions conftest.c >&5
rect
irect
cc1: warning: command line option '-fno-rtti' is valid for C++/ObjC++ but=
not for C [enabled by default]
configure:11528: $? =3D 0
configure:11541: result: no
configure:11868: checking for /builds/spack/lib/spack/env/gcc/gcc option =
to produce PIC
configure:11875: result: -fPIC -DPIC
configure:11883: checking if /builds/spack/lib/spack/env/gcc/gcc PIC flag=
-fPIC -DPIC works
configure:11901: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 -fPIC -DP=
IC -DPIC conftest.c >&5
rect
irect
configure:11905: $? =3D 0
configure:11918: result: yes
configure:11947: checking if /builds/spack/lib/spack/env/gcc/gcc static f=
lag -static works
rect
irect
configure:11975: result: yes
configure:11990: checking if /builds/spack/lib/spack/env/gcc/gcc supports=
-c -o file.o
configure:12011: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 -o out/co=
nftest2.o conftest.c >&5
rect
irect
configure:12015: $? =3D 0
configure:12037: result: yes
configure:12045: checking if /builds/spack/lib/spack/env/gcc/gcc supports=
-c -o file.o
configure:12092: result: yes
configure:12125: checking whether the /builds/spack/lib/spack/env/gcc/gcc=
linker (/builds/spack/lib/spack/env/ld -m elf_x86_64) supports shared li=
braries
configure:13282: result: yes
configure:13319: checking whether -lc should be explicitly linked in
configure:13327: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 conftest.=
c >&5
rect
irect
configure:13330: $? =3D 0
configure:13345: /builds/spack/lib/spack/env/gcc/gcc -shared -fPIC -DPIC=
conftest.o -v -Wl,-soname -Wl,conftest -o conftest 2\>\&1 \| /bin/grep =
-lc \>/dev/null 2\>\&1
configure:13348: $? =3D 0
configure:13362: result: no
configure:13522: checking dynamic linker characteristics
configure:14022: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
-Wl,-rpath -Wl,/foo conftest.c >&5
rect
irect
configure:14022: $? =3D 0
configure:14256: result: GNU/Linux ld.so
configure:14363: checking how to hardcode library paths into programs
configure:14388: result: immediate
configure:14928: checking whether stripping libraries is possible
configure:14933: result: yes
configure:14968: checking if libtool supports shared libraries
configure:14970: result: yes
configure:14973: checking whether to build shared libraries
configure:14994: result: yes
configure:14997: checking whether to build static libraries
configure:15001: result: yes
configure:15024: checking how to run the C++ preprocessor
configure:15051: /builds/spack/lib/spack/env/gcc/g++ -E conftest.cpp
rect
irect
configure:15051: $? =3D 0
configure:15065: /builds/spack/lib/spack/env/gcc/g++ -E conftest.cpp
rect
irect
conftest.cpp:26:28: fatal error: ac_nonexistent.h: No such file or direct=
ory
configure:15065: $? =3D 1
| /* confdefs.h */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_DLFCN_H 1
| #define LT_OBJDIR ".libs/"
configure:15090: result: /builds/spack/lib/spack/env/gcc/g++ -E
configure:15110: /builds/spack/lib/spack/env/gcc/g++ -E conftest.cpp
rect
irect
configure:15110: $? =3D 0
configure:15124: /builds/spack/lib/spack/env/gcc/g++ -E conftest.cpp
rect
irect
ory
configure:15124: $? =3D 1
| /* confdefs.h */
configure:15293: checking for ld used by /builds/spack/lib/spack/env/gcc/=
g++
rect
irect
configure:15360: result: /builds/spack/lib/spack/env/ld -m elf_x86_64
configure:15367: checking if the linker (/builds/spack/lib/spack/env/ld -=
m elf_x86_64) is GNU ld
configure:15382: result: yes
configure:15437: checking whether the /builds/spack/lib/spack/env/gcc/g++=
braries
configure:16439: result: yes
configure:16475: /builds/spack/lib/spack/env/gcc/g++ -c -g -O2 conftest.=
cpp >&5
rect
irect
configure:16478: $? =3D 0
configure:16998: checking for /builds/spack/lib/spack/env/gcc/g++ option =
to produce PIC
configure:17005: result: -fPIC -DPIC
configure:17013: checking if /builds/spack/lib/spack/env/gcc/g++ PIC flag=
-fPIC -DPIC works
configure:17031: /builds/spack/lib/spack/env/gcc/g++ -c -g -O2 -fPIC -DP=
IC -DPIC conftest.cpp >&5
rect
irect
configure:17035: $? =3D 0
configure:17048: result: yes
configure:17071: checking if /builds/spack/lib/spack/env/gcc/g++ static f=
lag -static works
rect
irect
configure:17099: result: yes
configure:17111: checking if /builds/spack/lib/spack/env/gcc/g++ supports=
-c -o file.o
configure:17132: /builds/spack/lib/spack/env/gcc/g++ -c -g -O2 -o out/co=
nftest2.o conftest.cpp >&5
rect
irect
configure:17136: $? =3D 0
configure:17158: result: yes
configure:17163: checking if /builds/spack/lib/spack/env/gcc/g++ supports=
-c -o file.o
configure:17210: result: yes
configure:17240: checking whether the /builds/spack/lib/spack/env/gcc/g++=
braries
configure:17279: result: yes
configure:17420: checking dynamic linker characteristics
configure:18088: result: GNU/Linux ld.so
configure:18141: checking how to hardcode library paths into programs
configure:18166: result: immediate
configure:18314: checking if libtool supports shared libraries
configure:18316: result: yes
configure:18319: checking whether to build shared libraries
configure:18339: result: yes
configure:18342: checking whether to build static libraries
configure:18346: result: yes
configure:18667: checking for /builds/spack/lib/spack/env/gcc/gfortran op=
tion to produce PIC
configure:18674: result: -fPIC
configure:18682: checking if /builds/spack/lib/spack/env/gcc/gfortran PIC=
flag -fPIC works
configure:18700: /builds/spack/lib/spack/env/gcc/gfortran -c -g -O2 -fPIC=
conftest.f >&5
redirect
s redirect
configure:18704: $? =3D 0
configure:18717: result: yes
configure:18740: checking if /builds/spack/lib/spack/env/gcc/gfortran sta=
tic flag -static works
redirect
s redirect
configure:18768: result: yes
configure:18780: checking if /builds/spack/lib/spack/env/gcc/gfortran sup=
ports -c -o file.o
configure:18801: /builds/spack/lib/spack/env/gcc/gfortran -c -g -O2 -o ou=
t/conftest2.o conftest.f >&5
redirect
s redirect
configure:18805: $? =3D 0
configure:18827: result: yes
configure:18832: checking if /builds/spack/lib/spack/env/gcc/gfortran sup=
ports -c -o file.o
configure:18879: result: yes
configure:18909: checking whether the /builds/spack/lib/spack/env/gcc/gfo=
rtran linker (/builds/spack/lib/spack/env/ld -m elf_x86_64) supports shar=
ed libraries
configure:20016: result: yes
configure:20157: checking dynamic linker characteristics
configure:20819: result: GNU/Linux ld.so
configure:20872: checking how to hardcode library paths into programs
configure:20897: result: immediate
configure:21041: checking if libtool supports shared libraries
configure:21043: result: yes
configure:21046: checking whether to build shared libraries
configure:21066: result: yes
configure:21069: checking whether to build static libraries
configure:21073: result: yes
configure:21107: /builds/spack/lib/spack/env/gcc/gfortran -c -g -O2 conf=
test.f >&5
redirect
s redirect
configure:21110: $? =3D 0
configure:21539: checking for /builds/spack/lib/spack/env/gcc/gfortran op=
tion to produce PIC
configure:21546: result: -fPIC
configure:21554: checking if /builds/spack/lib/spack/env/gcc/gfortran PIC=
flag -fPIC works
configure:21572: /builds/spack/lib/spack/env/gcc/gfortran -c -g -O2 -fPIC=
conftest.f >&5
redirect
s redirect
configure:21576: $? =3D 0
configure:21589: result: yes
configure:21612: checking if /builds/spack/lib/spack/env/gcc/gfortran sta=
redirect
s redirect
configure:21640: result: yes
configure:21652: checking if /builds/spack/lib/spack/env/gcc/gfortran sup=
ports -c -o file.o
configure:21673: /builds/spack/lib/spack/env/gcc/gfortran -c -g -O2 -o ou=
redirect
s redirect
configure:21677: $? =3D 0
configure:21699: result: yes
configure:21704: checking if /builds/spack/lib/spack/env/gcc/gfortran sup=
ports -c -o file.o
configure:21751: result: yes
configure:21781: checking whether the /builds/spack/lib/spack/env/gcc/gfo=
ed libraries
configure:22888: result: yes
configure:23029: checking dynamic linker characteristics
configure:23691: result: GNU/Linux ld.so
configure:23744: checking how to hardcode library paths into programs
configure:23769: result: immediate
configure:23822: checking whether ln -s works
configure:23826: result: yes
configure:23834: checking for ANSI C header files
configure:23938: result: yes
configure:23947: checking for C/C++ restrict keyword
configure:23972: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 conftest.=
c >&5
rect
irect
configure:23972: $? =3D 0
configure:23980: result: __restrict
configure:23999: checking for bash
configure:24026: result: /bin/bash
configure:24041: checking for svn
configure:24059: found /usr/bin/svn
configure:24071: result: /usr/bin/svn
configure:24081: checking for svnversion
configure:24099: found /usr/bin/svnversion
configure:24111: result: /usr/bin/svnversion
configure:24198: checking for lib
configure:24231: result: no
configure:24299: checking size of void *
configure:24304: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
conftest.c >&5
rect
irect
configure:24304: $? =3D 0
configure:24304: ./conftest
configure:24318: result: 8
configure:24384: checking for struct timespec
configure:24384: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 conftest.=
c >&5
rect
irect
configure:24384: $? =3D 0
c >&5
rect
irect
conftest.c: In function 'main':
conftest.c:46:30: error: expected expression before ')' token
if (sizeof ((struct timespec)))
configure:24384: $? =3D 1
| /* confdefs.h */
| #define restrict __restrict
| #define STARPU_MIC_USE_RMA 1
| #define STARPU_LINUX_SYS 1
| #define SIZEOF_VOID_P 8
| #define STARPU_BUILD_DIR "/tmp/ci/spack-stage/spack-stage-TG9rM0/starpu=
-1.2.0rc5"
| #define STARPU_SRC_DIR "/tmp/ci/spack-stage/spack-stage-TG9rM0/starpu-1=
=2E2.0rc5/."
|=20
| #include <sys/types.h>
| #include <sys/stat.h>
| #ifdef HAVE_UNISTD_H
| #include <unistd.h>
| #endif
| #include <time.h>
| #include <pthread.h>
|=20
|=20
| int
| main ()
| return 0;
| return 0;
configure:24384: result: yes
configure:24403: checking for unistd.h
configure:24403: result: yes
configure:24442: checking for pthread_create in -lpthread
configure:24467: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
conftest.c -lpthread >&5
rect
irect
configure:24467: $? =3D 0
configure:24476: result: yes
configure:24489: checking for library containing sqrt
configure:24520: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
conftest.c:44:6: warning: conflicting types for built-in function 'sqrt' =
char sqrt ();
/tmp/ccTsRDFl.o: In function `main':
/tmp/ci/spack-stage/spack-stage-TG9rM0/starpu-1.2.0rc5/conftest.c:48: und=
efined reference to `sqrt'
collect2: error: ld returned 1 exit status
configure:24520: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #define STARPU_HAVE_STRUCT_TIMESPEC /**/
| #define STARPU_HAVE_UNISTD_H 1
| #define HAVE_LIBPTHREAD 1
|=20
| /* Override any GCC internal prototype to avoid an error.
| Use char because int might match the return type of a GCC
| builtin and then its argument prototype would still apply. */
| #ifdef __cplusplus
| extern "C"
| #endif
| char sqrt ();
| int
| main ()
| return sqrt ();
| return 0;
conftest.c -lm -lpthread >&5
rect
irect
char sqrt ();
configure:24520: $? =3D 0
configure:24537: result: -lm
configure:24547: checking for main in -lws2_32
configure:24566: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
conftest.c -lws2_32 -lm -lpthread >&5
rect
irect
/usr/bin/ld: cannot find -lws2_32
configure:24566: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
|=20
|=20
| int
| main ()
| return main ();
| return 0;
configure:24575: result: no
configure:24589: checking for sysconf
configure:24589: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:24589: $? =3D 0
configure:24589: result: yes
configure:24599: checking for pthread_spin_lock
configure:24599: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:24599: $? =3D 0
configure:24599: result: yes
configure:24615: checking for pthread_barrier_init
configure:24615: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:24615: $? =3D 0
configure:24615: result: yes
configure:24631: checking for pthread_setaffinity_np
configure:24631: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:24631: $? =3D 0
configure:24631: result: yes
configure:24644: checking for posix_memalign
configure:24644: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:24644: $? =3D 0
configure:24644: result: yes
configure:24657: checking for memalign
configure:24657: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:24657: $? =3D 0
configure:24657: result: yes
configure:24670: checking for drand48
configure:24670: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:24670: $? =3D 0
configure:24670: result: yes
configure:24677: checking for erand48_r
configure:24677: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:24677: $? =3D 0
configure:24677: result: yes
configure:24704: checking for strerror_r
configure:24704: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:24704: $? =3D 0
configure:24704: result: yes
configure:24713: checking for setenv
configure:24713: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:24713: $? =3D 0
configure:24713: result: yes
configure:24722: checking for unsetenv
configure:24722: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:24722: $? =3D 0
configure:24722: result: yes
configure:24731: checking for nearbyintf
configure:24731: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
conftest.c:74:6: warning: conflicting types for built-in function 'nearby=
intf' [enabled by default]
char nearbyintf ();
configure:24731: $? =3D 0
configure:24731: result: yes
configure:24740: checking for rintf
configure:24740: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
conftest.c:75:6: warning: conflicting types for built-in function 'rintf'=
char rintf ();
configure:24740: $? =3D 0
configure:24740: result: yes
configure:24816: checking malloc.h usability
configure:24816: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 conftest.=
c >&5
rect
irect
configure:24816: $? =3D 0
configure:24816: result: yes
configure:24816: checking malloc.h presence
configure:24816: /builds/spack/lib/spack/env/gcc/gcc -E conftest.c
rect
irect
configure:24816: checking for malloc.h
configure:24839: checking valgrind/valgrind.h usability
configure:24839: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 conftest.=
c >&5
rect
irect
conftest.c:88:31: fatal error: valgrind/valgrind.h: No such file or direc=
tory
#include <valgrind/valgrind.h>
configure:24839: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #define HAVE_SYSCONF 1
| #define HAVE_PTHREAD_SPIN_LOCK /**/
| #define STARPU_HAVE_PTHREAD_SPIN_LOCK /**/
| #define STARPU_HAVE_PTHREAD_BARRIER /**/
| #define HAVE_PTHREAD_SETAFFINITY_NP 1
| #define HAVE_POSIX_MEMALIGN 1
| #define STARPU_HAVE_POSIX_MEMALIGN 1
| #define HAVE_MEMALIGN 1
| #define STARPU_HAVE_MEMALIGN 1
| #define STARPU_USE_DRAND48 1
| #define STARPU_USE_ERAND48_R 1
| #define STARPU_HAVE_STRERROR_R 1
| #define STARPU_HAVE_SETENV 1
| #define STARPU_HAVE_UNSETENV 1
| #define STARPU_HAVE_NEARBYINTF 1
| #define STARPU_HAVE_RINTF 1
| #define HAVE_MALLOC_H 1
| #define STARPU_HAVE_MALLOC_H 1
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| # include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| # include <unistd.h>
| #endif
configure:24839: result: no
configure:24839: checking valgrind/valgrind.h presence
configure:24839: /builds/spack/lib/spack/env/gcc/gcc -E conftest.c
rect
irect
conftest.c:55:31: fatal error: valgrind/valgrind.h: No such file or direc=
tory
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
configure:24839: checking for valgrind/valgrind.h
configure:24853: checking valgrind/memcheck.h usability
configure:24853: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 conftest.=
c >&5
rect
irect
conftest.c:88:31: fatal error: valgrind/memcheck.h: No such file or direc=
tory
#include <valgrind/memcheck.h>
configure:24853: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:24853: result: no
configure:24853: checking valgrind/memcheck.h presence
configure:24853: /builds/spack/lib/spack/env/gcc/gcc -E conftest.c
rect
irect
conftest.c:55:31: fatal error: valgrind/memcheck.h: No such file or direc=
tory
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
configure:24853: checking for valgrind/memcheck.h
configure:24867: checking valgrind/helgrind.h usability
configure:24867: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 conftest.=
c >&5
rect
irect
conftest.c:88:31: fatal error: valgrind/helgrind.h: No such file or direc=
tory
#include <valgrind/helgrind.h>
configure:24867: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:24867: result: no
configure:24867: checking valgrind/helgrind.h presence
configure:24867: /builds/spack/lib/spack/env/gcc/gcc -E conftest.c
rect
irect
conftest.c:55:31: fatal error: valgrind/helgrind.h: No such file or direc=
tory
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
configure:24867: checking for valgrind/helgrind.h
configure:24886: checking for sched_yield
configure:24886: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:24886: $? =3D 0
configure:24886: result: yes
configure:24896: checking aio.h usability
configure:24896: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 conftest.=
c >&5
rect
irect
configure:24896: $? =3D 0
configure:24896: result: yes
configure:24896: checking aio.h presence
configure:24896: /builds/spack/lib/spack/env/gcc/gcc -E conftest.c
rect
irect
configure:24896: checking for aio.h
configure:24909: checking for mkostemp
configure:24909: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:24909: $? =3D 0
configure:24909: result: yes
configure:24922: checking for pread
configure:24922: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:24922: $? =3D 0
configure:24922: result: yes
configure:24922: checking for pwrite
rect
irect
configure:24934: checking whether the target supports __sync_val_compare_=
and_swap
configure:24951: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:24951: $? =3D 0
configure:24959: result: yes
configure:24969: checking whether the target supports __sync_bool_compare=
_and_swap
configure:24986: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:24986: $? =3D 0
configure:24994: result: yes
configure:25004: checking whether the target supports __sync_fetch_and_ad=
d
configure:25021: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:25021: $? =3D 0
configure:25029: result: yes
configure:25039: checking whether the target supports __sync_fetch_and_or=
configure:25056: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:25056: $? =3D 0
configure:25064: result: yes
configure:25074: checking whether the target supports __sync_lock_test_an=
d_set
configure:25091: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:25091: $? =3D 0
configure:25099: result: yes
configure:25109: checking whether the target supports __sync_synchronize
configure:25126: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
rect
irect
configure:25126: $? =3D 0
configure:25134: result: yes
configure:25146: checking for library containing set_mempolicy
configure:25177: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
-D_GNU_SOURCE conftest.c >&5
rect
irect
/tmp/cc0yWxGk.o: In function `main':
/tmp/ci/spack-stage/spack-stage-TG9rM0/starpu-1.2.0rc5/conftest.c:77: und=
efined reference to `set_mempolicy'
configure:25177: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #define STARPU_HAVE_SCHED_YIELD 1
| #define HAVE_AIO_H 1
| #define HAVE_MKOSTEMP 1
| #define HAVE_PREAD 1
| #define HAVE_PWRITE 1
| #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1
| #define STARPU_HAVE_SYNC_FETCH_AND_OR 1
| #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1
| #define STARPU_HAVE_SYNC_SYNCHRONIZE 1
|=20
| #ifdef __cplusplus
| extern "C"
| #endif
| char set_mempolicy ();
| int
| main ()
| return set_mempolicy ();
| return 0;
-D_GNU_SOURCE conftest.c -lnuma >&5
rect
irect
/usr/bin/ld: cannot find -lnuma
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
|=20
| #ifdef __cplusplus
| extern "C"
| #endif
| int
| main ()
| return 0;
configure:25194: result: no
configure:25208: checking whether libnuma is available
configure:25210: result: no
configure:25223: checking maximum number of sched_ctxs
configure:25232: result: 10
configure:25310: checking maximum number of CPUs
configure:25319: result: 64
configure:25327: checking whether CPUs should be used
configure:25336: result: yes
configure:25361: checking maximum number of CUDA devices
configure:25370: result: 4
configure:27168: checking whether CUDA should be used
configure:27170: result: no
configure:27269: checking for pkg-config
configure:27287: found /usr/bin/pkg-config
configure:27299: result: /usr/bin/pkg-config
configure:27324: checking pkg-config is at least version 0.9.0
configure:27327: result: yes
configure:27426: checking whether MAGMA should be used
configure:27428: result: no
configure:27432: checking for cufftDoubleComplex
configure:27432: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 -D_GNU_SO=
URCE conftest.c >&5
rect
irect
conftest.c:70:19: fatal error: cufft.h: No such file or directory
#include <cufft.h>
configure:27432: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #define STARPU_NMAX_SCHED_CTXS 10
| #define STARPU_MAXCPUS 64
| #define STARPU_USE_CPU 1
| #define STARPU_MAXCUDADEVS 4
| #include <cufft.h>
|=20
| int
| main ()
| if (sizeof (cufftDoubleComplex))
| return 0;
| return 0;
configure:27432: result: no
configure:27498: checking whether CURAND is available
configure:27500: result: no
configure:27556: checking maximum number of OpenCL devices
configure:27565: result: 8
configure:28185: checking whether OpenCL should be used
configure:28187: result: no
configure:28215: checking whether asynchronous copy should be disabled
configure:28228: result: no
configure:28236: checking whether asynchronous CUDA copy should be disabl=
ed
configure:28249: result: no
configure:28257: checking whether asynchronous OpenCL copy should be disa=
bled
configure:28270: result: no
configure:28278: checking whether asynchronous MIC copy should be disable=
d
configure:28291: result: no
configure:28539: checking whether SimGrid is enabled
configure:28541: result: no
configure:28544: checking whether blocking drivers should be enabled
configure:28553: result: no
configure:28568: checking maximum number of MIC devices
configure:28577: result: 4
configure:28586: checking maximum number of MIC threads
configure:28595: result:=20
configure:29168: checking RCCE.h usability
configure:29168: /builds/spack/lib/spack/env/gcc/gcc -c -g -O2 -D_GNU_SO=
URCE conftest.c >&5
rect
irect
conftest.c:108:18: fatal error: RCCE.h: No such file or directory
#include <RCCE.h>
configure:29168: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #define STARPU_MAXOPENCLDEVS 8
| #define STARPU_NON_BLOCKING_DRIVERS 1
| #define STARPU_MAXMICDEVS 4
| #define STARPU_MAXMICCORES 120
| #define STARPU_MAXSCCDEVS 47
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <RCCE.h>
configure:29168: result: no
configure:29168: checking RCCE.h presence
configure:29168: /builds/spack/lib/spack/env/gcc/gcc -E -D_GNU_SOURCE =
conftest.c
rect
irect
conftest.c:75:18: fatal error: RCCE.h: No such file or directory
#include <RCCE.h>
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #include <RCCE.h>
configure:29168: checking for RCCE.h
configure:29184: checking for RCCE_init in -lRCCE_bigflags_nongory_nopwrm=
gmt
configure:29209: /builds/spack/lib/spack/env/gcc/gcc -o conftest -g -O2 =
-D_GNU_SOURCE conftest.c -lRCCE_bigflags_nongory_nopwrmgmt -lm -lpth=
read >&5
rect
irect
/usr/bin/ld: cannot find -lRCCE_bigflags_nongory_nopwrmgmt
configure:29209: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
|=20
| #ifdef __cplusplus
| extern "C"
| #endif
| char RCCE_init ();
| int
| main ()
| return RCCE_init ();
| return 0;
configure:29218: result: no
configure:29266: checking whether RCCE should be used
configure:29268: result: no
configure:29307: checking Maximum number of message-passing kernels
configure:29316: result: 10
configure:29332: checking whether debug mode should be enabled
configure:29341: result: no
configure:29373: checking whether extra checks should be performed
configure:29382: result: no
configure:29390: checking whether debug messages should be displayed
configure:29399: result: no
configure:29415: checking whether coverage testing should be enabled
configure:29424: result: no
configure:29443: checking whether FxT traces should be generated
configure:29460: result: yes using /builds/spack/opt/spack/linux-x86_64/g=
cc-4.8/fxt-0.3.1-kzb77zly4fisqhedpc3eborqra6jspjf
configure:29503: checking for FXT
configure:29511: $PKG_CONFIG --exists --print-errors "fxt"
configure:29514: $? =3D 0
configure:29529: $PKG_CONFIG --exists --print-errors "fxt"
configure:29532: $? =3D 0
configure:29582: result: yes
configure:29685: checking for enable_fut_flush
configure:29685: /builds/spack/lib/spack/env/gcc/gcc -o conftest -O3 -g -=
O2 -gdwarf-2 -g3 -D_GNU_SOURCE -gdwarf-2 -g3 conftest.c -lm -lpthre=
ad -L/builds/spack/opt/spack/linux-x86_64/gcc-4.8/fxt-0.3.1-kzb77zly4fis=
qhedpc3eborqra6jspjf/lib -lfxt >&5
rect
irect
configure:29685: $? =3D 0
configure:29685: result: yes
configure:29696: checking for fut_set_filename
configure:29696: /builds/spack/lib/spack/env/gcc/gcc -o conftest -O3 -g -=
rect
irect
configure:29696: $? =3D 0
configure:29696: result: yes
configure:29709: checking whether enable_fut_flush is declared
configure:29709: /builds/spack/lib/spack/env/gcc/gcc -c -O3 -g -O2 -gdwar=
f-2 -g3 -I/builds/spack/opt/spack/linux-x86_64/gcc-4.8/fxt-0.3.1-kzb77zl=
y4fisqhedpc3eborqra6jspjf/include -D_GNU_SOURCE conftest.c >&5
rect
irect
conftest.c:120:10: error: 'enable_fut_flush' undeclared (first use in thi=
s function)
(void) enable_fut_flush;
conftest.c:120:10: note: each undeclared identifier is reported only once=
for each function it appears in
configure:29709: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #define STARPU_MAXMPKERNELS 10
| #define STARPU_USE_FXT 1
| #define CONFIG_FUT 1
| #define HAVE_ENABLE_FUT_FLUSH 1
| #define HAVE_FUT_SET_FILENAME 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| #ifndef enable_fut_flush
| #ifdef __cplusplus
| #else
| #endif
| #endif
|=20
| return 0;
configure:29709: result: no
configure:29720: checking whether fut_set_filename is declared
configure:29720: /builds/spack/lib/spack/env/gcc/gcc -c -O3 -g -O2 -gdwar=
rect
irect
conftest.c:121:10: error: 'fut_set_filename' undeclared (first use in thi=
s function)
(void) fut_set_filename;
conftest.c:121:10: note: each undeclared identifier is reported only once=
configure:29720: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #define HAVE_DECL_ENABLE_FUT_FLUSH 0
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| #ifndef fut_set_filename
| #ifdef __cplusplus
| #else
| #endif
| #endif
|=20
| return 0;
configure:29720: result: no
configure:29750: checking for POTI
configure:29758: $PKG_CONFIG --exists --print-errors "poti"
Package poti was not found in the pkg-config search path.
Perhaps you should add the directory containing `poti.pc'
to the PKG_CONFIG_PATH environment variable
No package 'poti' found
configure:29761: $? =3D 1
configure:29776: $PKG_CONFIG --exists --print-errors "poti"
configure:29779: $? =3D 1
configure:29807: result: no
configure:29827: checking whether additional locking systems FxT traces s=
hould be enabled
configure:29836: result: no
configure:29844: checking whether performance debugging should be enabled=
configure:29853: result: no
configure:29865: checking whether performance model debugging should be e=
nabled
configure:29874: result: no
configure:29882: checking whether statistics should be generated
configure:29891: result: no
configure:29903: checking whether memory stats should be displayed
configure:29912: result: no
configure:29922: checking glpk.h usability
configure:29922: /builds/spack/lib/spack/env/gcc/gcc -c -O3 -g -O2 -gdwar=
f-2 -g3 -D_GNU_SOURCE conftest.c >&5
rect
irect
conftest.c:116:18: fatal error: glpk.h: No such file or directory
#include <glpk.h>
configure:29922: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #define HAVE_DECL_FUT_SET_FILENAME 0
| #define STARPU_ENABLE_PAJE_CODELET_DETAILS 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <glpk.h>
configure:29922: result: no
configure:29922: checking glpk.h presence
configure:29922: /builds/spack/lib/spack/env/gcc/gcc -E -D_GNU_SOURCE c=
onftest.c
rect
irect
conftest.c:83:18: fatal error: glpk.h: No such file or directory
#include <glpk.h>
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #include <glpk.h>
configure:29922: checking for glpk.h
configure:29936: checking for main in -lglpk
configure:29955: /builds/spack/lib/spack/env/gcc/gcc -o conftest -O3 -g -=
O2 -gdwarf-2 -g3 -D_GNU_SOURCE -gdwarf-2 -g3 conftest.c -lglpk >&5=
rect
irect
/usr/bin/ld: cannot find -lglpk
configure:29955: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
|=20
|=20
| int
| main ()
| return main ();
| return 0;
configure:29964: result: no
configure:29982: checking Ayudame.h usability
configure:29982: /builds/spack/lib/spack/env/gcc/gcc -c -O3 -g -O2 -gdwar=
rect
irect
conftest.c:116:21: fatal error: Ayudame.h: No such file or directory
#include <Ayudame.h>
configure:29982: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:29982: result: no
configure:29982: checking Ayudame.h presence
configure:29982: /builds/spack/lib/spack/env/gcc/gcc -E -D_GNU_SOURCE c=
onftest.c
rect
irect
conftest.c:83:21: fatal error: Ayudame.h: No such file or directory
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
configure:29982: checking for Ayudame.h
configure:29999: checking how many buffers can be manipulated per task
configure:30008: result: 8
configure:30016: checking maximum number of nodes to use
configure:30065: checking maximum number of memory nodes
configure:30067: result: 4
configure:30076: checking whether allocation cache should be used
configure:30085: result: yes
configure:30119: checking using explicit performance model location
configure:30121: result: no
configure:30124: checking performance models location
configure:30126: result: $HOME/.starpu/sampling/
configure:30130: checking for clock_gettime in -lrt
configure:30155: /builds/spack/lib/spack/env/gcc/gcc -o conftest -O3 -g -=
O2 -gdwarf-2 -g3 -D_GNU_SOURCE -gdwarf-2 -g3 conftest.c -lrt -lm -l=
pthread >&5
rect
irect
configure:30155: $? =3D 0
configure:30164: result: yes
configure:30177: checking for clock_gettime
configure:30177: /builds/spack/lib/spack/env/gcc/gcc -o conftest -O3 -g -=
O2 -gdwarf-2 -g3 -D_GNU_SOURCE -gdwarf-2 -g3 conftest.c -lrt -lm -lp=
thread >&5
rect
irect
configure:30177: $? =3D 0
configure:30177: result: yes
configure:30207: checking Maximum number of workers
configure:30209: result: 64
configure:30219: checking Maximum number of workers combinations
configure:30221: result: 64
configure:30232: checking maximum number of implementations
configure:30241: result: 4
configure:30258: checking leveldb/db.h usability
configure:30258: /builds/spack/lib/spack/env/gcc/g++ -c -O3 -g -O2 -gdwar=
f-2 -g3 -D_GNU_SOURCE conftest.cpp >&5
rect
irect
conftest.cpp:124:24: fatal error: leveldb/db.h: No such file or directory=
#include <leveldb/db.h>
configure:30258: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #define STARPU_NMAXBUFS 8
| #define STARPU_MAXNODES 4
| #define STARPU_USE_ALLOCATION_CACHE 1
| #define HAVE_LIBRT 1
| #define HAVE_CLOCK_GETTIME 1
| #define STARPU_NMAXWORKERS 64
| #define STARPU_NMAX_COMBINEDWORKERS 64
| #define STARPU_MAXIMPLEMENTATIONS 4
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:30258: result: no
configure:30258: checking leveldb/db.h presence
configure:30258: /builds/spack/lib/spack/env/gcc/g++ -E -D_GNU_SOURCE c=
onftest.cpp
rect
irect
conftest.cpp:91:24: fatal error: leveldb/db.h: No such file or directory
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
configure:30258: checking for leveldb/db.h
configure:30272: checking for main in -lleveldb
configure:30291: /builds/spack/lib/spack/env/gcc/g++ -o conftest -O3 -g -=
O2 -gdwarf-2 -g3 -D_GNU_SOURCE -gdwarf-2 -g3 conftest.cpp -lleveldb =
>&5
rect
irect
/usr/bin/ld: cannot find -lleveldb
configure:30291: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
|=20
|=20
| int
| main ()
| return main ();
| return 0;
configure:30300: result: no
configure:30332: checking calibration heuristic of history-based StarPU c=
alibrator
configure:30341: result: 50
configure:30376: checking for mpicc
configure:30395: found /builds/spack/opt/spack/linux-x86_64/gcc-4.8/openm=
pi-1.10.2-336gjyrlwza2vmaoueye7mpahyvmnuhv/bin/mpicc
configure:30408: result: /builds/spack/opt/spack/linux-x86_64/gcc-4.8/ope=
nmpi-1.10.2-336gjyrlwza2vmaoueye7mpahyvmnuhv/bin/mpicc
configure:30491: checking mpicc path
configure:30493: result: /builds/spack/opt/spack/linux-x86_64/gcc-4.8/ope=
configure:30545: checking for mpiexec
configure:30564: found /builds/spack/opt/spack/linux-x86_64/gcc-4.8/openm=
pi-1.10.2-336gjyrlwza2vmaoueye7mpahyvmnuhv/bin/mpiexec
configure:30577: result: /builds/spack/opt/spack/linux-x86_64/gcc-4.8/ope=
nmpi-1.10.2-336gjyrlwza2vmaoueye7mpahyvmnuhv/bin/mpiexec
configure:30589: checking whether mpiexec is available
configure:30591: result: /builds/spack/opt/spack/linux-x86_64/gcc-4.8/ope=
configure:30612: checking whether MPI tests should be run
configure:30614: result: no
configure:30620: checking whether the StarPU MPI library should be genera=
ted
configure:30622: result: yes
configure:30670: checking for StarPU-Top
configure:30809: checking whether compiler support -Wall
configure:30831: /builds/spack/lib/spack/env/gcc/gcc -o conftest -Wall -=
D_GNU_SOURCE -gdwarf-2 -g3 conftest.c -lrt -lm -lpthread >&5
rect
irect
conftest.c:99:18: warning: unused variable 'hello' [-Wunused-variable]
const char *hello =3D "Hello World";
configure:30831: $? =3D 0
configure:30834: result: yes
configure:30853: checking whether compiler support -Werror=3Dimplicit
configure:30875: /builds/spack/lib/spack/env/gcc/gcc -o conftest -Werror=3D=
implicit -D_GNU_SOURCE -gdwarf-2 -g3 conftest.c -lrt -lm -lpthread >=
&5
rect
irect
configure:30875: $? =3D 0
configure:30878: result: yes
configure:30897: checking whether compiler support -Werror=3Dimplicit-fun=
ction-declaration
configure:30919: /builds/spack/lib/spack/env/gcc/gcc -o conftest -Werror=3D=
implicit-function-declaration -D_GNU_SOURCE -gdwarf-2 -g3 conftest.c =
rect
irect
configure:30919: $? =3D 0
configure:30922: result: yes
configure:31223: checking whether GCC supports plug-ins
configure:31278: /builds/spack/lib/spack/env/gcc/gcc -c -O3 -g -O2 -gdwar=
f-2 -g3 -Iplugin/include conftest.c >&5
rect
irect
conftest.c:94:24: fatal error: gcc-plugin.h: No such file or directory
#include <gcc-plugin.h>
configure:31278: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #define STARPU_HISTORYMAXERROR 50
| #define STARPU_USE_MPI /**/
| #define STARPU_HAVE_FC /**/
| #include <tree.h>
| #include <gimple.h>
|=20
| #if defined __INTEL_COMPILER || defined __ICC
| Beware, this compiler is a fake. Don't use it.
| #endif
|=20
| tree fndecl; gimple call;
| int
| main ()
| /* Clang 3.1 doesn't support nested functions, so try to
| discriminate it this way. */
| tree foo (void)
| return lookup_name (get_identifier ("puts"));
| fndecl =3D foo ();
| call =3D gimple_build_call (fndecl, 0);
| return 0;
configure:31294: result: no
configure:31578: WARNING: GCC plug-ins not supported; StarPU's GCC plug-i=
n will not be built
configure:31716: checking for OpenMP runtime support
configure:31733: result: no
configure:31739: checking whether compiler support -fopenmp
configure:31761: /builds/spack/lib/spack/env/gcc/gcc -o conftest -fopenmp=
-D_GNU_SOURCE -gdwarf-2 -g3 conftest.c -lrt -lm -lpthread >&5
rect
irect
configure:31761: $? =3D 0
configure:31764: result: yes
configure:31803: checking for SOCL
configure:31818: result: no
configure:31867: checking for gdb
configure:31885: found /usr/bin/gdb
configure:31898: result: /usr/bin/gdb
configure:32126: checking whether OpenGL rendering is enabled
configure:32130: result: no
configure:32141: checking for X
configure:32249: /builds/spack/lib/spack/env/gcc/gcc -E -D_GNU_SOURCE c=
onftest.c
rect
irect
configure:32249: $? =3D 0
configure:32280: /builds/spack/lib/spack/env/gcc/gcc -o conftest -O3 -g -=
O2 -gdwarf-2 -g3 -D_GNU_SOURCE -gdwarf-2 -g3 conftest.c -lX11 -lrt -=
lm -lpthread >&5
rect
irect
configure:32280: $? =3D 0
configure:32330: result: libraries , headers=20
configure:32429: /builds/spack/lib/spack/env/gcc/gcc -o conftest -O3 -g -=
thread -lX11 >&5
rect
irect
configure:32429: $? =3D 0
configure:32527: checking for gethostbyname
configure:32527: /builds/spack/lib/spack/env/gcc/gcc -o conftest -O3 -g -=
thread >&5
rect
irect
configure:32527: $? =3D 0
configure:32527: result: yes
configure:32624: checking for connect
configure:32624: /builds/spack/lib/spack/env/gcc/gcc -o conftest -O3 -g -=
thread >&5
rect
irect
configure:32624: $? =3D 0
configure:32624: result: yes
configure:32673: checking for remove
configure:32673: /builds/spack/lib/spack/env/gcc/gcc -o conftest -O3 -g -=
thread >&5
rect
irect
configure:32673: $? =3D 0
configure:32673: result: yes
configure:32722: checking for shmat
configure:32722: /builds/spack/lib/spack/env/gcc/gcc -o conftest -O3 -g -=
thread >&5
rect
irect
configure:32722: $? =3D 0
configure:32722: result: yes
configure:32780: checking for IceConnectionNumber in -lICE
configure:32805: /builds/spack/lib/spack/env/gcc/gcc -o conftest -O3 -g -=
O2 -gdwarf-2 -g3 -D_GNU_SOURCE -gdwarf-2 -g3 conftest.c -lICE -lrt =
-lm -lpthread >&5
rect
irect
configure:32805: $? =3D 0
configure:32814: result: yes
configure:33297: checking for library containing sgemm_
configure:33328: /builds/spack/lib/spack/env/gcc/gcc -o conftest -O3 -g -=
O2 -gdwarf-2 -g3 -D_GNU_SOURCE -gdwarf-2 -g3 conftest.c >&5
rect
irect
/tmp/ccxVAUXk.o: In function `main':
/tmp/ci/spack-stage/spack-stage-TG9rM0/starpu-1.2.0rc5/conftest.c:107: un=
defined reference to `sgemm_'
configure:33328: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #define STARPU_GDB_PATH "/usr/bin/gdb"
| #define STARPU_HAVE_X11 1
|=20
| #ifdef __cplusplus
| extern "C"
| #endif
| char sgemm_ ();
| int
| main ()
| return sgemm_ ();
| return 0;
O2 -gdwarf-2 -g3 -D_GNU_SOURCE -gdwarf-2 -g3 conftest.c -lblas >&5=
rect
irect
/usr/bin/ld: cannot find -lblas
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
|=20
| #ifdef __cplusplus
| extern "C"
| #endif
| char sgemm_ ();
| int
| main ()
| return sgemm_ ();
| return 0;
configure:33345: result: no
configure:33416: checking which BLAS lib should be used
configure:33418: result: none
configure:33442: checking for FFTW
configure:33450: $PKG_CONFIG --exists --print-errors "fftw3"
Package fftw3 was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3.pc'
No package 'fftw3' found
configure:33453: $? =3D 1
configure:33468: $PKG_CONFIG --exists --print-errors "fftw3"
configure:33471: $? =3D 1
configure:33499: result: no
configure:33529: checking for FFTWF
configure:33537: $PKG_CONFIG --exists --print-errors "fftw3f"
Package fftw3f was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3f.pc'
No package 'fftw3f' found
configure:33540: $? =3D 1
configure:33555: $PKG_CONFIG --exists --print-errors "fftw3f"
configure:33558: $? =3D 1
configure:33586: result: no
configure:33616: checking for FFTWL
configure:33624: $PKG_CONFIG --exists --print-errors "fftw3l"
Package fftw3l was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3l.pc'
No package 'fftw3l' found
configure:33627: $? =3D 1
configure:33642: $PKG_CONFIG --exists --print-errors "fftw3l"
configure:33645: $? =3D 1
configure:33673: result: no
configure:33849: checking hwloc.h usability
configure:33849: /builds/spack/lib/spack/env/gcc/gcc -c -O3 -g -O2 -gdwar=
f-2 -g3 -D_GNU_SOURCE -I/builds/spack/opt/spack/linux-x86_64/gcc-4.8/h=
wloc-1.11.3-h5rqz3ba56snhid26cox3r76jnhbjjrc/include conftest.c >&5
rect
irect
configure:33849: $? =3D 0
configure:33849: result: yes
configure:33849: checking hwloc.h presence
configure:33849: /builds/spack/lib/spack/env/gcc/gcc -E -D_GNU_SOURCE -=
I/builds/spack/opt/spack/linux-x86_64/gcc-4.8/hwloc-1.11.3-h5rqz3ba56snhi=
rect
irect
configure:33849: checking for hwloc.h
configure:33858: checking for main in -lhwloc
configure:33877: /builds/spack/lib/spack/env/gcc/gcc -o conftest -O3 -g -=
O2 -gdwarf-2 -g3 -D_GNU_SOURCE -I/builds/spack/opt/spack/linux-x86_64/=
gcc-4.8/hwloc-1.11.3-h5rqz3ba56snhid26cox3r76jnhbjjrc/include -gdwarf-2 =
-g3 -L/builds/spack/opt/spack/linux-x86_64/gcc-4.8/hwloc-1.11.3-h5rqz3ba=
56snhid26cox3r76jnhbjjrc/lib conftest.c -lhwloc -lrt -lm -lpthread >&5
rect
irect
configure:33877: $? =3D 0
configure:33886: result: yes
configure:33917: checking whether hwloc_cuda_get_device_osdev_by_index is=
declared
configure:33917: /builds/spack/lib/spack/env/gcc/gcc -c -O3 -g -O2 -gdwar=
rect
irect
In file included from conftest.c:97:0:
/builds/spack/opt/spack/linux-x86_64/gcc-4.8/hwloc-1.11.3-h5rqz3ba56snhid=
26cox3r76jnhbjjrc/include/hwloc/cuda.h:26:18: fatal error: cuda.h: No suc=
h file or directory
#include <cuda.h>
configure:33917: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #define STARPU_HAVE_HWLOC 1
| #include <hwloc/cuda.h>
|=20
| int
| main ()
| #ifndef hwloc_cuda_get_device_osdev_by_index
| #ifdef __cplusplus
| (void) hwloc_cuda_get_device_osdev_by_index;
| #else
| #endif
| #endif
|=20
| return 0;
configure:33917: result: no
configure:33939: checking whether hwloc should be used
configure:33941: result: yes
configure:33946: checking f77.h usability
configure:33946: /builds/spack/lib/spack/env/gcc/gcc -c -O3 -g -O2 -gdwar=
rect
irect
conftest.c:131:17: fatal error: f77.h: No such file or directory
#include <f77.h>
configure:33946: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #define HAVE_DECL_HWLOC_CUDA_GET_DEVICE_OSDEV_BY_INDEX 0
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <f77.h>
configure:33946: result: no
configure:33946: checking f77.h presence
configure:33946: /builds/spack/lib/spack/env/gcc/gcc -E -D_GNU_SOURCE c=
onftest.c
rect
irect
conftest.c:98:17: fatal error: f77.h: No such file or directory
#include <f77.h>
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
| #include <f77.h>
configure:33946: checking for f77.h
configure:33975: checking for icc
configure:34005: result: no
configure:34072: checking for help2man
configure:34102: result: no
configure:34123: checking for struct cudaDeviceProp.pciDomainID
configure:34123: /builds/spack/lib/spack/env/gcc/gcc -c -O3 -g -O2 -gdwar=
rect
irect
conftest.c:98:30: fatal error: cuda_runtime_api.h: No such file or direct=
ory
#include <cuda_runtime_api.h>
configure:34123: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
|=20
| int
| main ()
| static struct cudaDeviceProp ac_aggr;
| if (ac_aggr.pciDomainID)
| return 0;
| return 0;
rect
irect
ory
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
|=20
| int
| main ()
| if (sizeof ac_aggr.pciDomainID)
| return 0;
| return 0;
configure:34123: result: no
configure:34132: checking for struct cudaDeviceProp.pciBusID
configure:34132: /builds/spack/lib/spack/env/gcc/gcc -c -O3 -g -O2 -gdwar=
rect
irect
ory
configure:34132: $? =3D 1
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
|=20
| int
| main ()
| if (ac_aggr.pciBusID)
| return 0;
| return 0;
rect
irect
ory
| /* confdefs.h */
-1.2.0rc5"
=2E2.0rc5/."
|=20
| int
| main ()
| if (sizeof ac_aggr.pciBusID)
| return 0;
| return 0;
configure:34132: result: no
configure:34294: checking whether documentation should be compiled
configure:34296: result: no
configure:34479: checking that generated files are newer than configure
configure:34485: result: done
configure:34740: creating ./config.status
## Running config.status. ##
This file was extended by StarPU config.status 1.2.0rc5, which was
generated by GNU Autoconf 2.69. Invocation command line was
CONFIG_FILES =3D=20
CONFIG_HEADERS =3D=20
CONFIG_LINKS =3D=20
CONFIG_COMMANDS =3D=20
$ ./config.status=20
on ubuntu-14-04-1-amd64
config.status:1648: creating tests/regression/regression.sh
config.status:1648: creating tests/regression/profiles
config.status:1648: creating tests/regression/profiles.build.only
config.status:1648: creating Makefile
config.status:1648: creating src/Makefile
config.status:1648: creating tools/Makefile
config.status:1648: creating tools/starpu_codelet_profile
config.status:1648: creating tools/starpu_codelet_histo_profile
config.status:1648: creating tools/starpu_workers_activity
config.status:1648: creating tools/starpu_paje_draw_histogram
config.status:1648: creating tools/starpu_paje_state_stats
config.status:1648: creating tools/starpu_paje_summary
config.status:1648: creating tools/starpu_paje_sort
config.status:1648: creating tools/starpu_smpirun
config.status:1648: creating socl/Makefile
config.status:1648: creating socl/src/Makefile
config.status:1648: creating socl/examples/Makefile
config.status:1648: creating socl/vendors/socl.icd
config.status:1648: creating socl/vendors/install/socl.icd
config.status:1648: creating libstarpu.pc
config.status:1648: creating starpu-1.0.pc
config.status:1648: creating starpu-1.1.pc
config.status:1648: creating starpu-1.2.pc
config.status:1648: creating mpi/libstarpumpi.pc
config.status:1648: creating mpi/starpumpi-1.0.pc
config.status:1648: creating mpi/starpumpi-1.1.pc
config.status:1648: creating mpi/starpumpi-1.2.pc
config.status:1648: creating starpufft/Makefile
config.status:1648: creating starpufft/src/Makefile
config.status:1648: creating starpufft/tests/Makefile
config.status:1648: creating starpufft/libstarpufft.pc
config.status:1648: creating starpufft/starpufft-1.0.pc
config.status:1648: creating starpufft/starpufft-1.1.pc
config.status:1648: creating starpufft/starpufft-1.2.pc
config.status:1648: creating examples/Makefile
config.status:1648: creating examples/stencil/Makefile
config.status:1648: creating tests/Makefile
config.status:1648: creating tests/loader-cross.sh
config.status:1648: creating examples/loader-cross.sh
config.status:1648: creating examples/stencil/loader-cross.sh
config.status:1648: creating mpi/Makefile
config.status:1648: creating mpi/src/Makefile
config.status:1648: creating mpi/tests/Makefile
config.status:1648: creating mpi/examples/Makefile
config.status:1648: creating starpu-top/StarPU-Top.pro
config.status:1648: creating starpu-top/StarPU-Top-qwt-embed.pri
config.status:1648: creating starpu-top/StarPU-Top-qwt-system.pri
config.status:1648: creating gcc-plugin/Makefile
config.status:1648: creating gcc-plugin/src/Makefile
config.status:1648: creating gcc-plugin/tests/Makefile
config.status:1648: creating gcc-plugin/tests/run-test
config.status:1648: creating gcc-plugin/examples/Makefile
config.status:1648: creating sc_hypervisor/Makefile
config.status:1648: creating sc_hypervisor/src/Makefile
config.status:1648: creating sc_hypervisor/examples/Makefile
config.status:1648: creating doc/Makefile
config.status:1648: creating doc/doxygen/Makefile
config.status:1648: creating doc/doxygen/doxygen-config.cfg
config.status:1648: creating doc/doxygen/doxygen_filter.sh
config.status:1648: creating tools/msvc/starpu_var.bat
config.status:1648: creating src/common/config.h
config.status:1648: creating include/starpu_config.h
config.status:1648: creating gcc-plugin/include/starpu-gcc/config.h
config.status:1648: creating starpu-top/config.h
config.status:1908: executing depfiles commands
config.status:1908: executing libtool commands
config.status:1908: executing executable-scripts commands
configure:37877:
CPUs enabled: yes
CUDA enabled: no
OpenCL enabled: no
SCC enabled: no
MIC enabled: no
Compile-time limits
(change these with --enable-maxcpus, --enable-maxcudadev,
--enable-maxopencldev, --enable-maxmicdev, --enable-maxnodes,
--enable-maxbuffers)
(Note these numbers do not represent the number of detected
devices, but the maximum number of devices StarPU can manage)
Maximum number of CPUs: 64
Maximum number of CUDA devices: 0
Maximum number of OpenCL devices: 0
Maximum number of SCC devices: 0
Maximum number of MIC threads: 0
Maximum number of memory nodes: 4
Maximum number of task buffers: 8
GPU-GPU transfers: no
Allocation cache: yes
Magma enabled: no
BLAS library: none
hwloc: yes
FxT trace enabled: yes
StarPU-Top: no
Documentation: no
Examples: yes
StarPU Extensions:
MPI enabled: yes
MPI test suite: no
FFT Support: no
GCC plug-in: no
GCC plug-in test suite (requires GNU Guile): no
OpenMP runtime support enabled: no
SOCL enabled: no
SOCL test suite: no
Scheduler Hypervisor: no
simgrid enabled: no
ayudame enabled: no
## Cache variables. ##
ac_cv_build=3Dx86_64-unknown-linux-gnu
ac_cv_c_compiler_gnu=3Dyes
ac_cv_c_restrict=3D__restrict
ac_cv_cxx_compiler_gnu=3Dyes
ac_cv_env_BLAS_LIBS_set=3D
ac_cv_env_BLAS_LIBS_value=3D
ac_cv_env_CCC_set=3D
ac_cv_env_CCC_value=3D
ac_cv_env_CC_set=3Dset
ac_cv_env_CC_value=3D/builds/spack/lib/spack/env/gcc/gcc
ac_cv_env_CFLAGS_set=3D
ac_cv_env_CFLAGS_value=3D
ac_cv_env_CPPFLAGS_set=3D
ac_cv_env_CPPFLAGS_value=3D
ac_cv_env_CPP_set=3D
ac_cv_env_CPP_value=3D
ac_cv_env_CXXCPP_set=3D
ac_cv_env_CXXCPP_value=3D
ac_cv_env_CXXFLAGS_set=3D
ac_cv_env_CXXFLAGS_value=3D
ac_cv_env_CXX_set=3Dset
ac_cv_env_CXX_value=3D/builds/spack/lib/spack/env/gcc/g++
ac_cv_env_F77_set=3Dset
ac_cv_env_F77_value=3D/builds/spack/lib/spack/env/gcc/gfortran
ac_cv_env_FCFLAGS_set=3D
ac_cv_env_FCFLAGS_value=3D
ac_cv_env_FC_set=3Dset
ac_cv_env_FC_value=3D/builds/spack/lib/spack/env/gcc/gfortran
ac_cv_env_FFLAGS_set=3D
ac_cv_env_FFLAGS_value=3D
ac_cv_env_FFTWF_CFLAGS_set=3D
ac_cv_env_FFTWF_CFLAGS_value=3D
ac_cv_env_FFTWF_LIBS_set=3D
ac_cv_env_FFTWF_LIBS_value=3D
ac_cv_env_FFTWL_CFLAGS_set=3D
ac_cv_env_FFTWL_CFLAGS_value=3D
ac_cv_env_FFTWL_LIBS_set=3D
ac_cv_env_FFTWL_LIBS_value=3D
ac_cv_env_FFTW_CFLAGS_set=3D
ac_cv_env_FFTW_CFLAGS_value=3D
ac_cv_env_FFTW_LIBS_set=3D
ac_cv_env_FFTW_LIBS_value=3D
ac_cv_env_FXT_CFLAGS_set=3D
ac_cv_env_FXT_CFLAGS_value=3D
ac_cv_env_FXT_LDFLAGS_set=3D
ac_cv_env_FXT_LDFLAGS_value=3D
ac_cv_env_FXT_LIBS_set=3D
ac_cv_env_FXT_LIBS_value=3D
ac_cv_env_HWLOC_CFLAGS_set=3D
ac_cv_env_HWLOC_CFLAGS_value=3D
ac_cv_env_HWLOC_LIBS_set=3D
ac_cv_env_HWLOC_LIBS_value=3D
ac_cv_env_LDFLAGS_set=3D
ac_cv_env_LDFLAGS_value=3D
ac_cv_env_LIBS_set=3D
ac_cv_env_LIBS_value=3D
ac_cv_env_MAGMA_CFLAGS_set=3D
ac_cv_env_MAGMA_CFLAGS_value=3D
ac_cv_env_MAGMA_LIBS_set=3D
ac_cv_env_MAGMA_LIBS_value=3D
ac_cv_env_NVCCFLAGS_set=3D
ac_cv_env_NVCCFLAGS_value=3D
ac_cv_env_NVCC_set=3D
ac_cv_env_NVCC_value=3D
ac_cv_env_PKG_CONFIG_set=3D
ac_cv_env_PKG_CONFIG_value=3D
ac_cv_env_POTI_CFLAGS_set=3D
ac_cv_env_POTI_CFLAGS_value=3D
ac_cv_env_POTI_LIBS_set=3D
ac_cv_env_POTI_LIBS_value=3D
ac_cv_env_STARPU_MS_LIB_set=3D
ac_cv_env_STARPU_MS_LIB_value=3D
ac_cv_env_XMKMF_set=3D
ac_cv_env_XMKMF_value=3D
ac_cv_env_build_alias_set=3D
ac_cv_env_build_alias_value=3D
ac_cv_env_host_alias_set=3D
ac_cv_env_host_alias_value=3D
ac_cv_env_target_alias_set=3D
ac_cv_env_target_alias_value=3D
ac_cv_f77_compiler_gnu=3Dyes
ac_cv_fc_compiler_gnu=3Dyes
ac_cv_func_clock_gettime=3Dyes
ac_cv_func_connect=3Dyes
ac_cv_func_drand48=3Dyes
ac_cv_func_enable_fut_flush=3Dyes
ac_cv_func_erand48_r=3Dyes
ac_cv_func_fut_set_filename=3Dyes
ac_cv_func_gethostbyname=3Dyes
ac_cv_func_memalign=3Dyes
ac_cv_func_mkostemp=3Dyes
ac_cv_func_nearbyintf=3Dyes
ac_cv_func_posix_memalign=3Dyes
ac_cv_func_pread=3Dyes
ac_cv_func_pthread_barrier_init=3Dyes
ac_cv_func_pthread_setaffinity_np=3Dyes
ac_cv_func_pthread_spin_lock=3Dyes
ac_cv_func_pwrite=3Dyes
ac_cv_func_remove=3Dyes
ac_cv_func_rintf=3Dyes
ac_cv_func_sched_yield=3Dyes
ac_cv_func_setenv=3Dyes
ac_cv_func_shmat=3Dyes
ac_cv_func_strerror_r=3Dyes
ac_cv_func_sysconf=3Dyes
ac_cv_func_unsetenv=3Dyes
ac_cv_have_decl_enable_fut_flush=3Dno
ac_cv_have_decl_fut_set_filename=3Dno
ac_cv_have_decl_hwloc_cuda_get_device_osdev_by_index=3Dno
ac_cv_have_gcc_plugins=3Dno
ac_cv_have_sync_bool_compare_and_swap=3Dyes
ac_cv_have_sync_fetch_and_add=3Dyes
ac_cv_have_sync_fetch_and_or=3Dyes
ac_cv_have_sync_lock_test_and_set=3Dyes
ac_cv_have_sync_synchronize=3Dyes
ac_cv_have_sync_val_compare_and_swap=3Dyes
ac_cv_have_x=3D'have_x=3Dyes ac_x_includes=3D'\'''\''
ac_x_libraries=3D'\=
ac_cv_header_Ayudame_h=3Dno
ac_cv_header_RCCE_h=3Dno
ac_cv_header_aio_h=3Dyes
ac_cv_header_dlfcn_h=3Dyes
ac_cv_header_f77_h=3Dno
ac_cv_header_glpk_h=3Dno
ac_cv_header_hwloc_h=3Dyes
ac_cv_header_inttypes_h=3Dyes
ac_cv_header_leveldb_db_h=3Dno
ac_cv_header_malloc_h=3Dyes
ac_cv_header_memory_h=3Dyes
ac_cv_header_stdc=3Dyes
ac_cv_header_stdint_h=3Dyes
ac_cv_header_stdlib_h=3Dyes
ac_cv_header_string_h=3Dyes
ac_cv_header_strings_h=3Dyes
ac_cv_header_sys_stat_h=3Dyes
ac_cv_header_sys_types_h=3Dyes
ac_cv_header_unistd_h=3Dyes
ac_cv_header_valgrind_helgrind_h=3Dno
ac_cv_header_valgrind_memcheck_h=3Dno
ac_cv_header_valgrind_valgrind_h=3Dno
ac_cv_host=3Dx86_64-unknown-linux-gnu
ac_cv_lib_ICE_IceConnectionNumber=3Dyes
ac_cv_lib_RCCE_bigflags_nongory_nopwrmgmt_RCCE_init=3Dno
ac_cv_lib_glpk_main=3Dno
ac_cv_lib_hwloc=3Dac_cv_lib_hwloc_main
ac_cv_lib_hwloc_main=3Dyes
ac_cv_lib_leveldb_main=3Dno
ac_cv_lib_pthread_pthread_create=3Dyes
ac_cv_lib_rt_clock_gettime=3Dyes
ac_cv_lib_ws2_32=3Dac_cv_lib_ws2_32_main
ac_cv_lib_ws2_32_main=3Dno
ac_cv_member_struct_cudaDeviceProp_pciBusID=3Dno
ac_cv_member_struct_cudaDeviceProp_pciDomainID=3Dno
ac_cv_objext=3Do
ac_cv_path_EGREP=3D'/bin/grep -E'
ac_cv_path_FGREP=3D'/bin/grep -F'
ac_cv_path_GDB=3D/usr/bin/gdb
ac_cv_path_GREP=3D/bin/grep
ac_cv_path_SED=3D/bin/sed
ac_cv_path_ac_pt_PKG_CONFIG=3D/usr/bin/pkg-config
ac_cv_path_install=3D'/usr/bin/install -c'
ac_cv_path_mkdir=3D/bin/mkdir
ac_cv_path_mpicc_path=3D/builds/spack/opt/spack/linux-x86_64/gcc-4.8/open=
ac_cv_path_mpiexec_path=3D/builds/spack/opt/spack/linux-x86_64/gcc-4.8/op=
enmpi-1.10.2-336gjyrlwza2vmaoueye7mpahyvmnuhv/bin/mpiexec
ac_cv_path_svncommand=3D/usr/bin/svn
ac_cv_path_svnversioncommand=3D/usr/bin/svnversion
ac_cv_prog_AWK=3Dgawk
ac_cv_prog_BASH=3D/bin/bash
ac_cv_prog_CPP=3D'/builds/spack/lib/spack/env/gcc/gcc -E'
ac_cv_prog_CXXCPP=3D'/builds/spack/lib/spack/env/gcc/g++ -E'
ac_cv_prog_PROG_DATE=3Ddate
ac_cv_prog_PROG_STAT=3Dstat
ac_cv_prog_ac_ct_AR=3Dar
ac_cv_prog_ac_ct_CC=3D/builds/spack/lib/spack/env/gcc/gcc
ac_cv_prog_ac_ct_MANIFEST_TOOL=3Dmt
ac_cv_prog_ac_ct_OBJDUMP=3Dobjdump
ac_cv_prog_ac_ct_RANLIB=3Dranlib
ac_cv_prog_ac_ct_STRIP=3Dstrip
ac_cv_prog_cc_c89=3D
ac_cv_prog_cc_g=3Dyes
ac_cv_prog_cxx_g=3Dyes
ac_cv_prog_f77_g=3Dyes
ac_cv_prog_fc_g=3Dyes
ac_cv_prog_make_make_set=3Dyes
ac_cv_search_set_mempolicy=3Dno
ac_cv_search_sgemm_=3Dno
ac_cv_search_sqrt=3D-lm
ac_cv_sizeof_void_p=3D8
ac_cv_target=3Dx86_64-unknown-linux-gnu
ac_cv_type_cufftDoubleComplex=3Dno
ac_cv_type_struct_timespec=3Dyes
am_cv_CC_dependencies_compiler_type=3Dgcc3
am_cv_CXX_dependencies_compiler_type=3Dgcc3
am_cv_ar_interface=3Dar
am_cv_make_support_nested_variables=3Dyes
am_cv_prog_cc_c_o=3Dyes
lt_cv_ar_at_file=3D@
lt_cv_archive_cmds_need_lc=3Dno
lt_cv_deplibs_check_method=3Dpass_all
lt_cv_file_magic_cmd=3D'$MAGIC_CMD'
lt_cv_file_magic_test_file=3D
lt_cv_ld_reload_flag=3D-r
lt_cv_nm_interface=3D'BSD nm'
lt_cv_objdir=3D.libs
lt_cv_path_LD=3D/builds/spack/lib/spack/env/ld
lt_cv_path_LDCXX=3D'/builds/spack/lib/spack/env/ld -m elf_x86_64'
lt_cv_path_NM=3D'/usr/bin/nm -B'
lt_cv_path_mainfest_tool=3Dno
lt_cv_prog_compiler_c_o=3Dyes
lt_cv_prog_compiler_c_o_CXX=3Dyes
lt_cv_prog_compiler_c_o_F77=3Dyes
lt_cv_prog_compiler_c_o_FC=3Dyes
lt_cv_prog_compiler_pic=3D'-fPIC -DPIC'
lt_cv_prog_compiler_pic_CXX=3D'-fPIC -DPIC'
lt_cv_prog_compiler_pic_F77=3D-fPIC
lt_cv_prog_compiler_pic_FC=3D-fPIC
lt_cv_prog_compiler_pic_works=3Dyes
lt_cv_prog_compiler_pic_works_CXX=3Dyes
lt_cv_prog_compiler_pic_works_F77=3Dyes
lt_cv_prog_compiler_pic_works_FC=3Dyes
lt_cv_prog_compiler_rtti_exceptions=3Dno
lt_cv_prog_compiler_static_works=3Dyes
lt_cv_prog_compiler_static_works_CXX=3Dyes
lt_cv_prog_compiler_static_works_F77=3Dyes
lt_cv_prog_compiler_static_works_FC=3Dyes
lt_cv_prog_gnu_ld=3Dyes
lt_cv_prog_gnu_ldcxx=3Dyes
lt_cv_sharedlib_from_linklib_cmd=3D'printf %s\n'
lt_cv_shlibpath_overrides_runpath=3Dno
lt_cv_sys_global_symbol_pipe=3D'sed -n -e '\''s/^.*[ ]\([ABCDGIRSTW][ABC=
DGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p'\'' | sed
/ __gnu_lto/d'\'''
lt_cv_sys_global_symbol_to_c_name_address=3D'sed -n -e '\''s/^: \([^ ]*\)=
[ ]*$/ {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \([^ ]*\) \([=
^ ]*\)$/ {"\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_c_name_address_lib_prefix=3D'sed -n -e '\''s/^=
: \([^ ]*\)[ ]*$/ {\"\1\", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW]* \(=
[^ ]*\) \(lib[^ ]*\)$/ {"\2", (void *) \&\2},/p'\'' -e '\''s/^[ABCDGIRST=
W]* \([^ ]*\) \([^ ]*\)$/ {"lib\2", (void *) \&\2},/p'\'''
lt_cv_sys_global_symbol_to_cdecl=3D'sed -n -e '\''s/^T .* \(.*\)$/extern =
int \1();/p'\'' -e '\''s/^[ABCDGIRSTW]* .* \(.*\)$/extern char \1;/p'\'''=
lt_cv_sys_max_cmd_len=3D1572864
lt_cv_to_host_file_cmd=3Dfunc_convert_file_noop
lt_cv_to_tool_file_cmd=3Dfunc_convert_file_noop
pkg_cv_FXT_CFLAGS=3D'-I/builds/spack/opt/spack/linux-x86_64/gcc-4.8/fxt-0=
=2E3.1-kzb77zly4fisqhedpc3eborqra6jspjf/include '
pkg_cv_FXT_LIBS=3D'-L/builds/spack/opt/spack/linux-x86_64/gcc-4.8/fxt-0.3=
=2E1-kzb77zly4fisqhedpc3eborqra6jspjf/lib -lfxt '
## Output variables. ##
ACLOCAL=3D'${SHELL} /tmp/ci/spack-stage/spack-stage-TG9rM0/starpu-1.2.0rc=
5/build-aux/missing aclocal-1.15'
AMDEPBACKSLASH=3D'\'
AMDEP_FALSE=3D'#'
AMDEP_TRUE=3D''
AMTAR=3D'$${TAR-tar}'
AM_BACKSLASH=3D'\'
AM_DEFAULT_V=3D'$(AM_DEFAULT_VERBOSITY)'
AM_DEFAULT_VERBOSITY=3D'0'
AM_V=3D'$(V)'
AR=3D'ar'
AS=3D'as'
ATLASDIR=3D''
ATLAS_BLAS_LIB_FALSE=3D''
ATLAS_BLAS_LIB_TRUE=3D'#'
AUTOCONF=3D'${SHELL} /tmp/ci/spack-stage/spack-stage-TG9rM0/starpu-1.2.0r=
c5/build-aux/missing autoconf'
AUTOHEADER=3D'${SHELL} /tmp/ci/spack-stage/spack-stage-TG9rM0/starpu-1.2.=
0rc5/build-aux/missing autoheader'
AUTOMAKE=3D'${SHELL} /tmp/ci/spack-stage/spack-stage-TG9rM0/starpu-1.2.0r=
c5/build-aux/missing automake-1.15'
AWK=3D'gawk'
BASH=3D'/bin/bash'
BLAS_LIB=3D'none'
BLAS_LIBS=3D''
BUILD_DOC_FALSE=3D''
BUILD_DOC_TRUE=3D'#'
BUILD_EXAMPLES_FALSE=3D'#'
BUILD_EXAMPLES_TRUE=3D''
BUILD_GCC_PLUGIN_FALSE=3D''
BUILD_GCC_PLUGIN_TRUE=3D'#'
BUILD_SOCL_FALSE=3D''
BUILD_SOCL_TRUE=3D'#'
BUILD_STARPUFFT_EXAMPLES_FALSE=3D''
BUILD_STARPUFFT_EXAMPLES_TRUE=3D'#'
BUILD_STARPUFFT_FALSE=3D''
BUILD_STARPUFFT_TRUE=3D'#'
BUILD_STARPU_TOP_FALSE=3D''
BUILD_STARPU_TOP_TRUE=3D'#'
BUILD_TESTS_FALSE=3D'#'
BUILD_TESTS_TRUE=3D''
CC=3D'/builds/spack/lib/spack/env/gcc/gcc'
CCDEPMODE=3D'depmode=3Dgcc3'
CC_OR_MPICC=3D'/builds/spack/opt/spack/linux-x86_64/gcc-4.8/openmpi-1.10.=
2-336gjyrlwza2vmaoueye7mpahyvmnuhv/bin/mpicc'
CFLAGS=3D'-O3 -g -O2 -gdwarf-2 -g3 '
COVERAGE=3D'no'
CPPFLAGS=3D' -D_GNU_SOURCE '
CXX=3D'/builds/spack/lib/spack/env/gcc/g++'
CXXDEPMODE=3D'depmode=3Dgcc3'
CXXFLAGS=3D'-O3 -g -O2 -gdwarf-2 -g3 '
CYGPATH_W=3D'echo'
DEFS=3D'-DHAVE_CONFIG_H'
DEPDIR=3D'.deps'
DLLTOOL=3D'false'
DSYMUTIL=3D''
DUMPBIN=3D''
ECHO_C=3D''
ECHO_N=3D'-n'
ECHO_T=3D''
EXEEXT=3D''
F77=3D'/builds/spack/lib/spack/env/gcc/gfortran'
FC=3D'/builds/spack/lib/spack/env/gcc/gfortran'
FCFLAGS=3D'-g -O2'
FFLAGS=3D'-g -O2'
FFTWF_CFLAGS=3D''
FFTWF_LIBS=3D''
FFTWL_CFLAGS=3D''
FFTWL_LIBS=3D''
FFTW_CFLAGS=3D''
FFTW_LIBS=3D''
FXTDIR=3D'/builds/spack/opt/spack/linux-x86_64/gcc-4.8/fxt-0.3.1-kzb77zly=
4fisqhedpc3eborqra6jspjf'
FXT_CFLAGS=3D'-I/builds/spack/opt/spack/linux-x86_64/gcc-4.8/fxt-0.3.1-kz=
FXT_LDFLAGS=3D''
FXT_LIBS=3D'-L/builds/spack/opt/spack/linux-x86_64/gcc-4.8/fxt-0.3.1-kzb7=
GCC_FOR_PLUGIN=3D''
GCC_FOR_PLUGIN_LIBTOOL_TAG=3D''
GCC_PLUGIN_DIR_PKGCONFIG=3D''
GCC_PLUGIN_INCLUDE_DIR=3D'plugin/include'
GCC_PLUGIN_PKGCONFIG=3D''
GDB=3D'/usr/bin/gdb'
GLOBAL_AM_CFLAGS=3D' -Wall -Werror=3Dimplicit -Werror=3Dimplicit-function=
-declaration'
GOTODIR=3D''
GOTO_BLAS_LIB_FALSE=3D''
GOTO_BLAS_LIB_TRUE=3D'#'
GREP=3D'/bin/grep'
GUILE=3D''
HAVE_FFTWFL=3D''
HAVE_OPENGL_FALSE=3D''
HAVE_OPENGL_TRUE=3D'#'
HAVE_PTR_DEREFS_MAY_ALIAS_P_FALSE=3D''
HAVE_PTR_DEREFS_MAY_ALIAS_P_TRUE=3D'#'
HAVE_X11_FALSE=3D'#'
HAVE_X11_TRUE=3D''
HELP2MAN=3D''
HWLOC_CFLAGS=3D'-I/builds/spack/opt/spack/linux-x86_64/gcc-4.8/hwloc-1.11=
=2E3-h5rqz3ba56snhid26cox3r76jnhbjjrc/include'
HWLOC_LIBS=3D'-L/builds/spack/opt/spack/linux-x86_64/gcc-4.8/hwloc-1.11.3=
-h5rqz3ba56snhid26cox3r76jnhbjjrc/lib -lhwloc'
HWLOC_REQUIRES=3D'hwloc'
ICC=3D''
INSTALL_DATA=3D'${INSTALL} -m 644'
INSTALL_PROGRAM=3D'${INSTALL}'
INSTALL_SCRIPT=3D'${INSTALL}'
INSTALL_STRIP_PROGRAM=3D'$(install_sh) -c -s'
LD=3D'/builds/spack/lib/spack/env/ld -m elf_x86_64'
LDFLAGS=3D' -gdwarf-2 -g3 '
LIBOBJS=3D''
LIBS=3D'-lrt -lm -lpthread '
LIBSOCL_INTERFACE_AGE=3D'0'
LIBSOCL_INTERFACE_CURRENT=3D'0'
LIBSOCL_INTERFACE_REVISION=3D'1'
LIBSTARPUFFT_INTERFACE_AGE=3D'0'
LIBSTARPUFFT_INTERFACE_CURRENT=3D'0'
LIBSTARPUFFT_INTERFACE_REVISION=3D'0'
LIBSTARPUMPI_INTERFACE_AGE=3D'0'
LIBSTARPUMPI_INTERFACE_CURRENT=3D'1'
LIBSTARPUMPI_INTERFACE_REVISION=3D'2'
LIBSTARPU_INTERFACE_AGE=3D'0'
LIBSTARPU_INTERFACE_CURRENT=3D'4'
LIBSTARPU_INTERFACE_REVISION=3D'0'
LIBSTARPU_LDFLAGS=3D'-L/builds/spack/opt/spack/linux-x86_64/gcc-4.8/hwloc=
-1.11.3-h5rqz3ba56snhid26cox3r76jnhbjjrc/lib -lhwloc -L/builds/spack/opt/=
spack/linux-x86_64/gcc-4.8/fxt-0.3.1-kzb77zly4fisqhedpc3eborqra6jspjf/lib=
-lfxt '
LIBSTARPU_LINK=3D'libstarpu-1.2.la'
LIBTOOL=3D'$(SHELL) $(top_builddir)/libtool'
LIPO=3D''
LN_S=3D'ln -s'
LTLIBOBJS=3D''
MAGMA_CFLAGS=3D''
MAGMA_LIBS=3D''
MAKEINFO=3D'${SHELL} /tmp/ci/spack-stage/spack-stage-TG9rM0/starpu-1.2.0r=
c5/build-aux/missing makeinfo'
MANIFEST_TOOL=3D':'
MKDIR_P=3D'/bin/mkdir -p'
MKL_BLAS_LIB_FALSE=3D''
MKL_BLAS_LIB_TRUE=3D'#'
MPICC=3D'/builds/spack/opt/spack/linux-x86_64/gcc-4.8/openmpi-1.10.2-336g=
MPICC_LDFLAGS=3D'-pthread -Wl,-rpath -Wl,/builds/spack/opt/spack/linux-x8=
6_64/gcc-4.8/openmpi-1.10.2-336gjyrlwza2vmaoueye7mpahyvmnuhv/lib -Wl,--en=
able-new-dtags -L/builds/spack/opt/spack/linux-x86_64/gcc-4.8/openmpi-1.1=
0.2-336gjyrlwza2vmaoueye7mpahyvmnuhv/lib -lmpi'
MPIEXEC=3D'/builds/spack/opt/spack/linux-x86_64/gcc-4.8/openmpi-1.10.2-33=
6gjyrlwza2vmaoueye7mpahyvmnuhv/bin/mpiexec'
NMEDIT=3D''
NO_BLAS_LIB_FALSE=3D'#'
NO_BLAS_LIB_TRUE=3D''
NVCC=3D''
NVCCFLAGS=3D''
OBJDUMP=3D'objdump'
OBJEXT=3D'o'
OTOOL64=3D''
OTOOL=3D''
PACKAGE=3D'starpu'
PACKAGE_BUGREPORT=3D'starpu-devel@lists.gforge.inria.fr'
PACKAGE_NAME=3D'StarPU'
PACKAGE_STRING=3D'StarPU 1.2.0rc5'
PACKAGE_TARNAME=3D'starpu'
PACKAGE_URL=3D'http://runtime.bordeaux.inria.fr/StarPU/'
PACKAGE_VERSION=3D'1.2.0rc5'
PATH_SEPARATOR=3D':'
PKG_CONFIG=3D'/usr/bin/pkg-config'
POTI_CFLAGS=3D''
POTI_LIBS=3D''
PROG_DATE=3D'date'
PROG_STAT=3D'stat'
QMAKE=3D''
QWT_PRI=3D''
RANLIB=3D'ranlib'
RUN_GCC_PLUGIN_TESTS_FALSE=3D''
RUN_GCC_PLUGIN_TESTS_TRUE=3D'#'
SED=3D'/bin/sed'
SET_MAKE=3D''
SHELL=3D'/bin/bash'
SIMGRID_CFLAGS=3D''
SIMGRID_LIBS=3D''
SOCL_OCL_LIB_OPENCL_DIR=3D''
SOCL_VENDORS=3D'vendors/install/socl.icd'
STARPU_BLAS_LDFLAGS=3D' '
STARPU_BUILD_DIR=3D'/tmp/ci/spack-stage/spack-stage-TG9rM0/starpu-1.2.0rc=
5'
STARPU_BUILD_SC_HYPERVISOR_FALSE=3D''
STARPU_BUILD_SC_HYPERVISOR_TRUE=3D'#'
STARPU_COI_CPPFLAGS=3D''
STARPU_COI_LDFLAGS=3D''
STARPU_COVERAGE_ENABLED_FALSE=3D''
STARPU_COVERAGE_ENABLED_TRUE=3D'#'
STARPU_CROSS_COMPILING_FALSE=3D''
STARPU_CROSS_COMPILING_TRUE=3D'#'
STARPU_CUDA_CPPFLAGS=3D''
STARPU_CUDA_FORTRAN_LDFLAGS=3D''
STARPU_CUDA_LDFLAGS=3D''
STARPU_CUFFT_LDFLAGS=3D''
STARPU_CURAND_LDFLAGS=3D''
STARPU_DEVEL_FALSE=3D''
STARPU_DEVEL_TRUE=3D'#'
STARPU_EFFECTIVE_VERSION=3D'1.2'
STARPU_ENABLE_STATS=3D'no'
STARPU_EXPORTED_LIBS=3D''
STARPU_EXPORT_DYNAMIC=3D''
STARPU_GCC_VERSION_MAJOR=3D''
STARPU_GCC_VERSION_MINOR=3D''
STARPU_GLPK_LDFLAGS=3D' '
STARPU_HAVE_AM111_FALSE=3D'#'
STARPU_HAVE_AM111_TRUE=3D''
STARPU_HAVE_CUFFTDOUBLECOMPLEX_FALSE=3D''
STARPU_HAVE_CUFFTDOUBLECOMPLEX_TRUE=3D'#'
STARPU_HAVE_DARWIN_FALSE=3D''
STARPU_HAVE_DARWIN_TRUE=3D'#'
STARPU_HAVE_F77_H=3D'no'
STARPU_HAVE_F77_H_FALSE=3D''
STARPU_HAVE_F77_H_TRUE=3D'#'
STARPU_HAVE_FC_FALSE=3D'#'
STARPU_HAVE_FC_TRUE=3D''
STARPU_HAVE_FFTW=3D''
STARPU_HAVE_FFTWF=3D''
STARPU_HAVE_FFTWF_FALSE=3D''
STARPU_HAVE_FFTWF_TRUE=3D'#'
STARPU_HAVE_FFTWL_FALSE=3D''
STARPU_HAVE_FFTWL_TRUE=3D'#'
STARPU_HAVE_FFTW_FALSE=3D''
STARPU_HAVE_FFTW_TRUE=3D'#'
STARPU_HAVE_HELP2MAN_FALSE=3D''
STARPU_HAVE_HELP2MAN_TRUE=3D'#'
STARPU_HAVE_HWLOC=3D'1'
STARPU_HAVE_ICC_FALSE=3D''
STARPU_HAVE_ICC_TRUE=3D'#'
STARPU_HAVE_LEVELDB_FALSE=3D''
STARPU_HAVE_LEVELDB_TRUE=3D'#'
STARPU_HAVE_MAGMA=3D''
STARPU_HAVE_MAGMA_FALSE=3D''
STARPU_HAVE_MAGMA_TRUE=3D'#'
STARPU_HAVE_MS_LIB_FALSE=3D''
STARPU_HAVE_MS_LIB_TRUE=3D'#'
STARPU_HAVE_OPENMP_FALSE=3D'#'
STARPU_HAVE_OPENMP_TRUE=3D''
STARPU_HAVE_WINDOWS_FALSE=3D''
STARPU_HAVE_WINDOWS_TRUE=3D'#'
STARPU_LEVELDB_LDFLAGS=3D' '
STARPU_LIBNUMA_LDFLAGS=3D' '
STARPU_LINUX_SYS_FALSE=3D'#'
STARPU_LINUX_SYS_TRUE=3D''
STARPU_LONG_CHECK_FALSE=3D''
STARPU_LONG_CHECK_TRUE=3D'#'
STARPU_MAJOR_VERSION=3D'1'
STARPU_MINOR_VERSION=3D'2'
STARPU_MPI_CHECK_FALSE=3D''
STARPU_MPI_CHECK_TRUE=3D'#'
STARPU_MS_LIB=3D''
STARPU_MS_LIB_ARCH=3D'X64'
STARPU_NEW_CHECK_FALSE=3D''
STARPU_NEW_CHECK_TRUE=3D'#'
STARPU_OPENCL_CPPFLAGS=3D''
STARPU_OPENCL_DATAdir=3D''
STARPU_OPENCL_LDFLAGS=3D''
STARPU_OPENGL_RENDER=3D'no'
STARPU_OPENGL_RENDER_LDFLAGS=3D''
STARPU_OPENMP_FALSE=3D''
STARPU_OPENMP_TRUE=3D'#'
STARPU_PERF_DEBUG=3D'no'
STARPU_QUICK_CHECK_FALSE=3D''
STARPU_QUICK_CHECK_TRUE=3D'#'
STARPU_QWT_INCLUDE=3D''
STARPU_QWT_LDFLAGS=3D''
STARPU_RCCE_CFLAGS=3D''
STARPU_RCCE_CPPFLAGS=3D''
STARPU_RCCE_LDFLAGS=3D''
STARPU_RELEASE_VERSION=3D'0'
STARPU_SANITIZE_FALSE=3D''
STARPU_SANITIZE_TRUE=3D'#'
STARPU_SCIF_CPPFLAGS=3D''
STARPU_SCIF_LDFLAGS=3D''
STARPU_SC_HYPERVISOR=3D''
STARPU_SC_HYPERVISOR_DEBUG=3D'no'
STARPU_SC_HYPERVISOR_DEBUG_FALSE=3D''
STARPU_SC_HYPERVISOR_DEBUG_TRUE=3D'#'
STARPU_SIMGRID_FALSE=3D''
STARPU_SIMGRID_TRUE=3D'#'
STARPU_SRC_DIR=3D'/tmp/ci/spack-stage/spack-stage-TG9rM0/starpu-1.2.0rc5/=
=2E'
STARPU_USE_CPU=3D'yes'
STARPU_USE_CPU_FALSE=3D'#'
STARPU_USE_CPU_TRUE=3D''
STARPU_USE_CUDA=3D'no'
STARPU_USE_CUDA_FALSE=3D''
STARPU_USE_CUDA_TRUE=3D'#'
STARPU_USE_FXT=3D'yes'
STARPU_USE_FXT_FALSE=3D'#'
STARPU_USE_FXT_TRUE=3D''
STARPU_USE_MIC_FALSE=3D''
STARPU_USE_MIC_TRUE=3D'#'
STARPU_USE_MP_FALSE=3D''
STARPU_USE_MP_TRUE=3D'#'
STARPU_USE_OPENCL=3D'no'
STARPU_USE_OPENCL_FALSE=3D''
STARPU_USE_OPENCL_TRUE=3D'#'
STARPU_USE_SCC_FALSE=3D''
STARPU_USE_SCC_TRUE=3D'#'
STARPU_USE_SC_HYPERVISOR_FALSE=3D''
STARPU_USE_SC_HYPERVISOR_TRUE=3D'#'
STARPU_USE_SOCL_FALSE=3D''
STARPU_USE_SOCL_TRUE=3D'#'
STARPU_USE_TOP=3D'no'
STATS=3D'no'
STRIP=3D'strip'
SYSTEM_BLAS_LIB_FALSE=3D''
SYSTEM_BLAS_LIB_TRUE=3D'#'
USE_MPI=3D'yes'
USE_MPI_FALSE=3D'#'
USE_MPI_TRUE=3D''
XMKMF=3D''
X_CFLAGS=3D''
X_EXTRA_LIBS=3D''
X_LIBS=3D''
X_PRE_LIBS=3D' -lSM -lICE'
YACC=3D'${SHELL} /tmp/ci/spack-stage/spack-stage-TG9rM0/starpu-1.2.0rc5/b=
uild-aux/missing bison'
ac_ct_AR=3D'ar'
ac_ct_CC=3D'/builds/spack/lib/spack/env/gcc/gcc'
ac_ct_CXX=3D''
ac_ct_DUMPBIN=3D''
ac_ct_F77=3D''
ac_ct_FC=3D''
am__EXEEXT_FALSE=3D''
am__EXEEXT_TRUE=3D'#'
am__fastdepCC_FALSE=3D'#'
am__fastdepCC_TRUE=3D''
am__fastdepCXX_FALSE=3D'#'
am__fastdepCXX_TRUE=3D''
am__include=3D'include'
am__isrc=3D''
am__leading_dot=3D'.'
am__nodep=3D'_no'
am__quote=3D''
am__tar=3D'$${TAR-tar} chof - "$$tardir"'
am__untar=3D'$${TAR-tar} xf -'
bindir=3D'${exec_prefix}/bin'
build=3D'x86_64-unknown-linux-gnu'
build_alias=3D''
build_cpu=3D'x86_64'
build_os=3D'linux-gnu'
build_vendor=3D'unknown'
datadir=3D'${datarootdir}'
datarootdir=3D'${prefix}/share'
docdir=3D'${datarootdir}/doc/${PACKAGE_TARNAME}'
doxygencommand=3D''
dvidir=3D'${docdir}'
epstopdfcommand=3D''
exec_prefix=3D'${prefix}'
gccplugindir=3D''
host=3D'x86_64-unknown-linux-gnu'
host_alias=3D''
host_cpu=3D'x86_64'
host_os=3D'linux-gnu'
host_vendor=3D'unknown'
htmldir=3D'${docdir}'
includedir=3D'${prefix}/include'
infodir=3D'${datarootdir}/info'
install_sh=3D'${SHELL} /tmp/ci/spack-stage/spack-stage-TG9rM0/starpu-1.2.=
0rc5/build-aux/install-sh'
libdir=3D'${exec_prefix}/lib'
libexecdir=3D'${exec_prefix}/libexec'
localedir=3D'${datarootdir}/locale'
localstatedir=3D'${prefix}/var'
mandir=3D'${datarootdir}/man'
mkdir_p=3D'$(MKDIR_P)'
mpicc_path=3D'/builds/spack/opt/spack/linux-x86_64/gcc-4.8/openmpi-1.10.2=
mpiexec_path=3D'/builds/spack/opt/spack/linux-x86_64/gcc-4.8/openmpi-1.10=
=2E2-336gjyrlwza2vmaoueye7mpahyvmnuhv/bin/mpiexec'
oldincludedir=3D'/usr/include'
pdfdir=3D'${docdir}'
pdflatexcommand=3D''
pkglibdir=3D'${libdir}/starpu'
prefix=3D'/builds/spack/opt/spack/linux-x86_64/gcc-4.8/starpu-1.2.0rc5-24=
z5f3ubmzropahfnwsaqz7up6hoykbs'
program_transform_name=3D's,x,x,'
psdir=3D'${docdir}'
sbindir=3D'${exec_prefix}/sbin'
sharedstatedir=3D'${prefix}/com'
smpirun_path=3D''
svncommand=3D'/usr/bin/svn'
svnversioncommand=3D'/usr/bin/svnversion'
sysconfdir=3D'${prefix}/etc'
target=3D'x86_64-unknown-linux-gnu'
target_alias=3D''
target_cpu=3D'x86_64'
target_os=3D'linux-gnu'
target_vendor=3D'unknown'
## confdefs.h. ##
/* confdefs.h */
#define PACKAGE_NAME "StarPU"
#define PACKAGE_TARNAME "starpu"
#define PACKAGE_VERSION "1.2.0rc5"
#define PACKAGE_STRING "StarPU 1.2.0rc5"
#define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr"
#define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/"
#define STARPU_MAJOR_VERSION 1
#define STARPU_MINOR_VERSION 2
#define STARPU_RELEASE_VERSION 0
#define PACKAGE "starpu"
#define VERSION "1.2.0rc5"
#define STDC_HEADERS 1
#define HAVE_SYS_TYPES_H 1
#define HAVE_SYS_STAT_H 1
#define HAVE_STDLIB_H 1
#define HAVE_STRING_H 1
#define HAVE_MEMORY_H 1
#define HAVE_STRINGS_H 1
#define HAVE_INTTYPES_H 1
#define HAVE_STDINT_H 1
#define HAVE_UNISTD_H 1
#define HAVE_DLFCN_H 1
#define LT_OBJDIR ".libs/"
#define restrict __restrict
#define STARPU_MIC_USE_RMA 1
#define STARPU_LINUX_SYS 1
#define SIZEOF_VOID_P 8
#define STARPU_BUILD_DIR "/tmp/ci/spack-stage/spack-stage-TG9rM0/starpu-1=
=2E2.0rc5"
#define STARPU_SRC_DIR "/tmp/ci/spack-stage/spack-stage-TG9rM0/starpu-1.2=
=2E0rc5/."
#define STARPU_HAVE_STRUCT_TIMESPEC /**/
#define STARPU_HAVE_UNISTD_H 1
#define HAVE_LIBPTHREAD 1
configure: exit 0
--------------070603030401070507040100--
- [no subject], Unknown, 16/12/2020
