Archives de la liste
=2E1-7cplb2duxldnevckobjnofq6tgpxffck/bin
PATH: /home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/hwloc-1=
=2E11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx/bin
PATH: /home/lschnorr/spack-orion/bin
PATH: /usr/local/bin
PATH: /usr/bin
PATH: /bin
PATH: /usr/local/games
PATH: /usr/games
PATH: /usr/local/cuda-7.0/bin
PATH: /grid5000/code/bin
## Core tests. ##
configure:3623: checking build system type
configure:3637: result: x86_64-pc-linux-gnu
configure:3657: checking host system type
configure:3670: result: x86_64-pc-linux-gnu
configure:3690: checking target system type
configure:3703: result: x86_64-pc-linux-gnu
configure:3747: checking for a BSD-compatible install
configure:3815: result: /usr/bin/install -c
configure:3826: checking whether build environment is sane
configure:3881: result: yes
configure:4032: checking for a thread-safe mkdir -p
configure:4071: result: /bin/mkdir -p
configure:4078: checking for gawk
configure:4094: found /usr/bin/gawk
configure:4105: result: gawk
configure:4116: checking whether make sets $(MAKE)
configure:4138: result: yes
configure:4167: checking whether make supports nested variables
configure:4184: result: yes
configure:4322: checking whether make supports nested variables
configure:4339: result: yes
configure:4365: checking for style of include used by make
configure:4393: result: GNU
configure:4464: checking for gcc
configure:4491: result: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc
configure:4720: checking for C compiler version
configure:4729: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc --versio=
n >&5
gcc (GCC) 6.1.0
Copyright (C) 2016 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is N=
O
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOS=
E.
configure:4740: $? =3D 0
configure:4729: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -v >&5
Reading specs from /home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-=
6.1.1/gcc-6.1.0-7cljeqxjfpkacgtkxus4p55nsms53dnv/lib64/gcc/x86_64-pc-linu=
x-gnu/6.1.0/specs
COLLECT_GCC=3D/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1=
/gcc-6.1.0-7cljeqxjfpkacgtkxus4p55nsms53dnv/bin/gcc
COLLECT_LTO_WRAPPER=3D/home/lschnorr/spack-orion/opt/spack/linux-x86_64/g=
cc-6.1.1/gcc-6.1.0-7cljeqxjfpkacgtkxus4p55nsms53dnv/libexec/gcc/x86_64-pc=
-linux-gnu/6.1.0/lto-wrapper
Target: x86_64-pc-linux-gnu
Configured with: /home/lschnorr/spack-orion/var/spack/stage/gcc-6.1.0-7cl=
jeqxjfpkacgtkxus4p55nsms53dnv/gcc-6.1.0/configure --prefix=3D/home/lschno=
rr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/gcc-6.1.0-7cljeqxjfpkacgt=
kxus4p55nsms53dnv --libdir=3D/home/lschnorr/spack-orion/opt/spack/linux-x=
86_64/gcc-6.1.1/gcc-6.1.0-7cljeqxjfpkacgtkxus4p55nsms53dnv/lib64 --disabl=
e-multilib --enable-languages=3Dc,java,c++,fortran,objc,go --with-mpc=3D/=
home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/mpc-1.0.3-hw4x=
t3hkrgza7mjxtytbhhk5dmdyqxpz --with-mpfr=3D/home/lschnorr/spack-orion/opt=
/spack/linux-x86_64/gcc-6.1.1/mpfr-3.1.4-64y7rkdsw6twzec6j523iegh4ozppgdt=
--with-gmp=3D/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1=
/gmp-6.1.0-kg6xsgvr55sx7j6aggt3whq6v5yz6cev --enable-lto --with-quad --wi=
th-sysroot=3D/ --with-stage1-ldflags=3D'-Wl,-rpath,/home/lschnorr/spack-o=
rion/opt/spack/linux-x86_64/gcc-6.1.1/gcc-6.1.0-7cljeqxjfpkacgtkxus4p55ns=
ms53dnv/lib -Wl,-rpath,/home/lschnorr/spack-orion/opt/spack/linux-x86_64/=
gcc-6.1.1/gcc-6.1.0-7cljeqxjfpkacgtkxus4p55nsms53dnv/lib64 -Wl,-rpath,/ho=
me/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/binutils-2.26-xx=
p2w7twwu65gypscb7dz4lfhowwcuxg/lib -Wl,-rpath,/home/lschnorr/spack-orion/=
opt/spack/linux-x86_64/gcc-6.1.1/bison-3.0.4-mxno5gyi2twnajdvvwynmvi3eiot=
bgv7/lib -Wl,-rpath,/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc=
-6.1.1/libsigsegv-2.10-mzeoq3odnae477cxh3d5atiov5inq64l/lib -Wl,-rpath,/h=
ome/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/flex-2.6.0-glov=
nqgdsbs4qnltd3m5zsw7zn3z5xus/lib -Wl,-rpath,/home/lschnorr/spack-orion/op=
t/spack/linux-x86_64/gcc-6.1.1/gmp-6.1.0-kg6xsgvr55sx7j6aggt3whq6v5yz6cev=
/lib -Wl,-rpath,/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1=
=2E1/isl-0.14-xfycwhb3j7yfucgi5q4x2dkdf46shcai/lib -Wl,-rpath,/home/lschn=
orr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/mpc-1.0.3-hw4xt3hkrgza7m=
jxtytbhhk5dmdyqxpz/lib -Wl,-rpath,/home/lschnorr/spack-orion/opt/spack/li=
nux-x86_64/gcc-6.1.1/mpfr-3.1.4-64y7rkdsw6twzec6j523iegh4ozppgdt/lib -sta=
tic-libstdc++ -static-libgcc' --with-boot-ldflags=3D'-Wl,-rpath,/home/lsc=
hnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/gcc-6.1.0-7cljeqxjfpka=
cgtkxus4p55nsms53dnv/lib -Wl,-rpath,/home/lschnorr/spack-orion/opt/spack/=
linux-x86_64/gcc-6.1.1/gcc-6.1.0-7cljeqxjfpkacgtkxus4p55nsms53dnv/lib64 -=
Wl,-rpath,/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/bin=
utils-2.26-xxp2w7twwu65gypscb7dz4lfhowwcuxg/lib -Wl,-rpath,/home/lschnorr=
/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/bison-3.0.4-mxno5gyi2twnajd=
vvwynmvi3eiotbgv7/lib -Wl,-rpath,/home/lschnorr/spack-orion/opt/spack/lin=
ux-x86_64/gcc-6.1.1/libsigsegv-2.10-mzeoq3odnae477cxh3d5atiov5inq64l/lib =
-Wl,-rpath,/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/fl=
ex-2.6.0-glovnqgdsbs4qnltd3m5zsw7zn3z5xus/lib -Wl,-rpath,/home/lschnorr/s=
pack-orion/opt/spack/linux-x86_64/gcc-6.1.1/gmp-6.1.0-kg6xsgvr55sx7j6aggt=
3whq6v5yz6cev/lib -Wl,-rpath,/home/lschnorr/spack-orion/opt/spack/linux-x=
86_64/gcc-6.1.1/isl-0.14-xfycwhb3j7yfucgi5q4x2dkdf46shcai/lib -Wl,-rpath,=
/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/mpc-1.0.3-hw4=
xt3hkrgza7mjxtytbhhk5dmdyqxpz/lib -Wl,-rpath,/home/lschnorr/spack-orion/o=
pt/spack/linux-x86_64/gcc-6.1.1/mpfr-3.1.4-64y7rkdsw6twzec6j523iegh4ozppg=
dt/lib -static-libstdc++ -static-libgcc' --with-gnu-ld --with-ld=3D/home/=
lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/binutils-2.26-xxp2w=
7twwu65gypscb7dz4lfhowwcuxg/bin/ld --with-gnu-as --with-as=3D/home/lschno=
rr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/binutils-2.26-xxp2w7twwu6=
5gypscb7dz4lfhowwcuxg/bin/as --with-isl=3D/home/lschnorr/spack-orion/opt/=
spack/linux-x86_64/gcc-6.1.1/isl-0.14-xfycwhb3j7yfucgi5q4x2dkdf46shcai
Thread model: posix
gcc version 6.1.0 (GCC)=20
configure:4729: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -V >&5
gcc: error: unrecognized command line option '-V'
gcc: fatal error: no input files
compilation terminated.
configure:4740: $? =3D 1
configure:4729: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -qversio=
n >&5
gcc: error: unrecognized command line option '-qversion'; did you mean '-=
-version'?
configure:4760: checking whether the C compiler works
configure:4782: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc conft=
est.c >&5
configure:4786: $? =3D 0
configure:4834: result: yes
configure:4837: checking for C compiler default output file name
configure:4839: result: a.out
configure:4845: checking for suffix of executables
configure:4852: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conft=
est conftest.c >&5
configure:4856: $? =3D 0
configure:4878: result:=20
configure:4900: checking whether we are cross compiling
configure:4908: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conft=
est conftest.c >&5
configure:4912: $? =3D 0
configure:4919: ./conftest
configure:4923: $? =3D 0
configure:4938: result: no
configure:4943: checking for suffix of object files
configure:4965: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c con=
ftest.c >&5
configure:4969: $? =3D 0
configure:4990: result: o
configure:4994: checking whether we are using the GNU C compiler
configure:5013: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c con=
ftest.c >&5
configure:5013: $? =3D 0
configure:5022: result: yes
configure:5031: checking whether /home/lschnorr/spack-orion/lib/spack/env=
/gcc/gcc accepts -g
configure:5051: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g c=
onftest.c >&5
configure:5051: $? =3D 0
configure:5092: result: yes
configure:5109: checking for /home/lschnorr/spack-orion/lib/spack/env/gcc=
/gcc option to accept ISO C89
configure:5172: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -=
O2 conftest.c >&5
configure:5172: $? =3D 0
configure:5185: result: none needed
configure:5210: checking whether /home/lschnorr/spack-orion/lib/spack/env=
/gcc/gcc understands -c and -o together
configure:5232: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c conft=
est.c -o conftest2.o
configure:5235: $? =3D 0
configure:5247: result: yes
configure:5266: checking dependency style of /home/lschnorr/spack-orion/l=
configure:5377: result: gcc3
configure:5442: checking for ar
configure:5458: found /usr/bin/ar
configure:5469: result: ar
configure:5495: checking the archiver (ar) interface
configure:5511: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -O=
2 conftest.c >&5
configure:5511: $? =3D 0
configure:5513: ar cru libconftest.a conftest.o >&5
ar: `u' modifier ignored since `D' is the default (see `U')
configure:5516: $? =3D 0
configure:5544: result: ar
configure:5612: checking for gcc
configure:5639: result: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc
configure:5868: checking for C compiler version
configure:5877: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc --versio=
n >&5
gcc (GCC) 6.1.0
O
E.
configure:5888: $? =3D 0
configure:5877: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -v >&5
x-gnu/6.1.0/specs
Thread model: posix
configure:5877: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -V >&5
configure:5888: $? =3D 1
configure:5877: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -qversio=
n >&5
-version'?
configure:5892: checking whether we are using the GNU C compiler
configure:5920: result: yes
configure:5929: checking whether /home/lschnorr/spack-orion/lib/spack/env=
/gcc/gcc accepts -g
configure:5990: result: yes
configure:6007: checking for /home/lschnorr/spack-orion/lib/spack/env/gcc=
configure:6083: result: none needed
configure:6108: checking whether /home/lschnorr/spack-orion/lib/spack/env=
configure:6145: result: yes
configure:6164: checking dependency style of /home/lschnorr/spack-orion/l=
configure:6275: result: gcc3
configure:6403: checking for C++ compiler version
configure:6412: /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ --versio=
n >&5
g++ (GCC) 6.1.0
O
E.
configure:6423: $? =3D 0
configure:6412: /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ -v >&5
x-gnu/6.1.0/specs
/gcc-6.1.0-7cljeqxjfpkacgtkxus4p55nsms53dnv/bin/g++
Thread model: posix
configure:6412: /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ -V >&5
g++: error: unrecognized command line option '-V'
g++: fatal error: no input files
configure:6423: $? =3D 1
configure:6412: /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ -qversio=
n >&5
g++: error: unrecognized command line option '-qversion'; did you mean '-=
-version'?
configure:6427: checking whether we are using the GNU C++ compiler
configure:6446: /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ -c con=
ftest.cpp >&5
configure:6446: $? =3D 0
configure:6455: result: yes
configure:6464: checking whether /home/lschnorr/spack-orion/lib/spack/env=
/gcc/g++ accepts -g
configure:6484: /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ -c -g c=
onftest.cpp >&5
configure:6484: $? =3D 0
configure:6525: result: yes
configure:6550: checking dependency style of /home/lschnorr/spack-orion/l=
configure:6661: result: gcc3
configure:6681: checking how to run the C preprocessor
configure:6712: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -E conf=
test.c
configure:6712: $? =3D 0
configure:6726: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -E conf=
test.c
conftest.c:14:28: fatal error: ac_nonexistent.h: No such file or director=
y
#include <ac_nonexistent.h>
configure:6726: $? =3D 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "StarPU"
| #define PACKAGE_TARNAME "starpu"
| #define PACKAGE_VERSION "1.3.0"
| #define PACKAGE_STRING "StarPU 1.3.0"
| #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr"
| #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/"
| #define STARPU_MAJOR_VERSION 1
| #define STARPU_MINOR_VERSION 3
| #define STARPU_RELEASE_VERSION 0
| #define PACKAGE "starpu"
| #define VERSION "1.3.0"
| /* end confdefs.h. */
configure:6751: result: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc =
-E
configure:6771: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -E conf=
test.c
configure:6771: $? =3D 0
configure:6785: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -E conf=
test.c
y
configure:6785: $? =3D 1
| /* confdefs.h */
configure:6813: checking for a sed that does not truncate output
configure:6877: result: /bin/sed
configure:6882: checking whether ln -s works
configure:6886: result: yes
configure:6999: checking for Fortran 77 compiler version
configure:7008: /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran --v=
ersion >&5
GNU Fortran (GCC) 6.1.0
O
E.
configure:7019: $? =3D 0
configure:7008: /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran -v =
>&5
x-gnu/6.1.0/specs
/gcc-6.1.0-7cljeqxjfpkacgtkxus4p55nsms53dnv/bin/gfortran
Thread model: posix
configure:7008: /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran -V =
>&5
gfortran: error: unrecognized command line option '-V'
gfortran: fatal error: no input files
configure:7019: $? =3D 1
configure:7008: /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran -qv=
ersion >&5
gfortran: error: unrecognized command line option '-qversion'; did you me=
an '--version'?
configure:7028: checking whether we are using the GNU Fortran 77 compiler=
configure:7041: /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran -c =
conftest.F >&5
configure:7041: $? =3D 0
configure:7050: result: yes
configure:7056: checking whether /home/lschnorr/spack-orion/lib/spack/env=
/gcc/gfortran accepts -g
configure:7067: /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran -c =
-g conftest.f >&5
configure:7067: $? =3D 0
configure:7075: result: yes
configure:7210: checking for Fortran compiler version
configure:7219: /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran --v=
ersion >&5
O
E.
configure:7230: $? =3D 0
configure:7219: /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran -v =
>&5
x-gnu/6.1.0/specs
Thread model: posix
configure:7219: /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran -V =
>&5
configure:7230: $? =3D 1
configure:7219: /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran -qv=
ersion >&5
an '--version'?
configure:7239: checking whether we are using the GNU Fortran compiler
configure:7252: /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran -c =
conftest.F >&5
configure:7252: $? =3D 0
configure:7261: result: yes
configure:7267: checking whether /home/lschnorr/spack-orion/lib/spack/env=
configure:7278: /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran -c =
-g conftest.f >&5
configure:7278: $? =3D 0
configure:7286: result: yes
configure:7319: checking for gstat
configure:7335: found /usr/bin/gstat
configure:7346: result: gstat
configure:7361: checking for gdate
configure:7391: result: no
configure:7361: checking for date
configure:7377: found /bin/date
configure:7388: result: date
configure:7517: checking how to print strings
configure:7544: result: printf
configure:7565: checking for a sed that does not truncate output
configure:7629: result: /bin/sed
configure:7647: checking for grep that handles long lines and -e
configure:7705: result: /bin/grep
configure:7710: checking for egrep
configure:7772: result: /bin/grep -E
configure:7777: checking for fgrep
configure:7839: result: /bin/grep -F
configure:7874: checking for ld used by /home/lschnorr/spack-orion/lib/sp=
ack/env/gcc/gcc
configure:7941: result: /home/lschnorr/spack-orion/opt/spack/linux-x86_64=
/gcc-6.1.1/binutils-2.26-xxp2w7twwu65gypscb7dz4lfhowwcuxg/bin/ld
configure:7948: checking if the linker (/home/lschnorr/spack-orion/opt/sp=
ack/linux-x86_64/gcc-6.1.1/binutils-2.26-xxp2w7twwu65gypscb7dz4lfhowwcuxg=
/bin/ld) is GNU ld
configure:7963: result: yes
configure:7975: checking for BSD- or MS-compatible name lister (nm)
configure:8029: result: /usr/bin/nm -B
configure:8159: checking the name lister (/usr/bin/nm -B) interface
configure:8166: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -O=
2 conftest.c >&5
configure:8169: /usr/bin/nm -B "conftest.o"
configure:8172: output
0000000000000000 B some_variable
configure:8179: result: BSD nm
configure:8183: checking the maximum length of command line arguments
configure:8314: result: 1572864
configure:8362: checking how to convert x86_64-pc-linux-gnu file names to=
x86_64-pc-linux-gnu format
configure:8402: result: func_convert_file_noop
configure:8409: checking how to convert x86_64-pc-linux-gnu file names to=
toolchain format
configure:8429: result: func_convert_file_noop
configure:8436: checking for /home/lschnorr/spack-orion/opt/spack/linux-x=
86_64/gcc-6.1.1/binutils-2.26-xxp2w7twwu65gypscb7dz4lfhowwcuxg/bin/ld opt=
ion to reload object files
configure:8443: result: -r
configure:8517: checking for objdump
configure:8533: found /usr/bin/objdump
configure:8544: result: objdump
configure:8573: checking how to recognize dependent libraries
configure:8773: result: pass_all
configure:8858: checking for dlltool
configure:8888: result: no
configure:8915: checking how to associate runtime and link libraries
configure:8942: result: printf %s\n
configure:9066: checking for archiver @FILE support
configure:9083: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -O=
2 conftest.c >&5
configure:9083: $? =3D 0
configure:9086: ar cru libconftest.a @conftest.lst >&5
configure:9089: $? =3D 0
configure:9094: ar cru libconftest.a @conftest.lst >&5
ar: conftest.o: No such file or directory
configure:9097: $? =3D 1
configure:9109: result: @
configure:9167: checking for strip
configure:9183: found /usr/bin/strip
configure:9194: result: strip
configure:9266: checking for ranlib
configure:9282: found /usr/bin/ranlib
configure:9293: result: ranlib
configure:9395: checking command to parse /usr/bin/nm -B output from /hom=
e/lschnorr/spack-orion/lib/spack/env/gcc/gcc object
configure:9548: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -O=
2 conftest.c >&5
configure:9551: $? =3D 0
configure:9555: /usr/bin/nm -B conftest.o \| sed -n -e 's/^.*[ ]\([ABCDGI=
RSTW][ABCDGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p' | sed =
'/ __gnu_lto/d' \> conftest.nm
configure:9558: $? =3D 0
configure:9624: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conft=
est -g -O2 conftest.c conftstm.o >&5
configure:9627: $? =3D 0
configure:9665: result: ok
configure:9712: checking for sysroot
configure:9742: result: no
configure:9749: checking for a working dd
configure:9787: result: /bin/dd
configure:9791: checking how to truncate binary pipes
configure:9806: result: /bin/dd bs=3D4096 count=3D1
configure:9942: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -O=
2 conftest.c >&5
configure:9945: $? =3D 0
configure:10135: checking for mt
configure:10151: found /bin/mt
configure:10162: result: mt
configure:10185: checking if mt is a manifest tool
configure:10191: mt '-?'
configure:10199: result: no
configure:10872: checking for ANSI C header files
configure:10892: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -=
O2 conftest.c >&5
configure:10892: $? =3D 0
configure:10965: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
test -g -O2 conftest.c >&5
configure:10965: $? =3D 0
configure:10965: ./conftest
configure:10976: result: yes
configure:10989: checking for sys/types.h
configure:10989: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -=
O2 conftest.c >&5
configure:10989: $? =3D 0
configure:10989: result: yes
configure:10989: checking for sys/stat.h
O2 conftest.c >&5
configure:10989: checking for stdlib.h
O2 conftest.c >&5
configure:10989: checking for string.h
O2 conftest.c >&5
configure:10989: checking for memory.h
O2 conftest.c >&5
configure:10989: checking for strings.h
O2 conftest.c >&5
configure:10989: checking for inttypes.h
O2 conftest.c >&5
configure:10989: checking for stdint.h
O2 conftest.c >&5
configure:10989: checking for unistd.h
O2 conftest.c >&5
configure:11003: checking for dlfcn.h
configure:11003: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -=
O2 conftest.c >&5
configure:11003: $? =3D 0
configure:11003: result: yes
configure:11570: checking for objdir
configure:11585: result: .libs
configure:11849: checking if /home/lschnorr/spack-orion/lib/spack/env/gcc=
/gcc supports -fno-rtti -fno-exceptions
configure:11867: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -=
O2 -fno-rtti -fno-exceptions conftest.c >&5
cc1: warning: command line option '-fno-rtti' is valid for C++/ObjC++ but=
not for C
configure:11871: $? =3D 0
configure:11884: result: no
configure:12242: checking for /home/lschnorr/spack-orion/lib/spack/env/gc=
c/gcc option to produce PIC
configure:12249: result: -fPIC -DPIC
configure:12257: checking if /home/lschnorr/spack-orion/lib/spack/env/gcc=
/gcc PIC flag -fPIC -DPIC works
configure:12275: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -=
O2 -fPIC -DPIC -DPIC conftest.c >&5
configure:12279: $? =3D 0
configure:12292: result: yes
configure:12321: checking if /home/lschnorr/spack-orion/lib/spack/env/gcc=
/gcc static flag -static works
configure:12349: result: yes
configure:12364: checking if /home/lschnorr/spack-orion/lib/spack/env/gcc=
/gcc supports -c -o file.o
configure:12385: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -=
O2 -o out/conftest2.o conftest.c >&5
configure:12389: $? =3D 0
configure:12411: result: yes
configure:12419: checking if /home/lschnorr/spack-orion/lib/spack/env/gcc=
configure:12466: result: yes
configure:12499: checking whether the /home/lschnorr/spack-orion/lib/spac=
k/env/gcc/gcc linker (/home/lschnorr/spack-orion/opt/spack/linux-x86_64/g=
cc-6.1.1/binutils-2.26-xxp2w7twwu65gypscb7dz4lfhowwcuxg/bin/ld -m elf_x86=
_64) supports shared libraries
configure:13762: result: yes
configure:13799: checking whether -lc should be explicitly linked in
configure:13807: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -=
O2 conftest.c >&5
configure:13810: $? =3D 0
configure:13825: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -shared=
-fPIC -DPIC conftest.o -v -Wl,-soname -Wl,conftest -o conftest 2\>\&1 =
\| /bin/grep -lc \>/dev/null 2\>\&1
configure:13828: $? =3D 0
configure:13842: result: no
configure:14002: checking dynamic linker characteristics
configure:14583: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
test -g -O2 -Wl,-rpath -Wl,/foo conftest.c >&5
configure:14583: $? =3D 0
configure:14832: result: GNU/Linux ld.so
configure:14954: checking how to hardcode library paths into programs
configure:14979: result: immediate
configure:15527: checking whether stripping libraries is possible
configure:15532: result: yes
configure:15567: checking if libtool supports shared libraries
configure:15569: result: yes
configure:15572: checking whether to build shared libraries
configure:15597: result: yes
configure:15600: checking whether to build static libraries
configure:15604: result: yes
configure:15627: checking how to run the C++ preprocessor
configure:15654: /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ -E con=
ftest.cpp
configure:15654: $? =3D 0
configure:15668: /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ -E con=
ftest.cpp
conftest.cpp:26:28: fatal error: ac_nonexistent.h: No such file or direct=
ory
configure:15668: $? =3D 1
| /* confdefs.h */
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_DLFCN_H 1
| #define LT_OBJDIR ".libs/"
configure:15693: result: /home/lschnorr/spack-orion/lib/spack/env/gcc/g++=
-E
configure:15713: /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ -E con=
ftest.cpp
configure:15713: $? =3D 0
configure:15727: /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ -E con=
ftest.cpp
ory
configure:15727: $? =3D 1
| /* confdefs.h */
configure:15889: checking for ld used by /home/lschnorr/spack-orion/lib/s=
pack/env/gcc/g++
configure:15956: result: /home/lschnorr/spack-orion/opt/spack/linux-x86_6=
4/gcc-6.1.1/binutils-2.26-xxp2w7twwu65gypscb7dz4lfhowwcuxg/bin/ld -m elf_=
x86_64
configure:15963: checking if the linker (/home/lschnorr/spack-orion/opt/s=
pack/linux-x86_64/gcc-6.1.1/binutils-2.26-xxp2w7twwu65gypscb7dz4lfhowwcux=
g/bin/ld -m elf_x86_64) is GNU ld
configure:15978: result: yes
configure:16033: checking whether the /home/lschnorr/spack-orion/lib/spac=
k/env/gcc/g++ linker (/home/lschnorr/spack-orion/opt/spack/linux-x86_64/g=
configure:17106: result: yes
configure:17142: /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ -c -g -=
O2 conftest.cpp >&5
configure:17145: $? =3D 0
configure:17626: checking for /home/lschnorr/spack-orion/lib/spack/env/gc=
c/g++ option to produce PIC
configure:17633: result: -fPIC -DPIC
configure:17641: checking if /home/lschnorr/spack-orion/lib/spack/env/gcc=
/g++ PIC flag -fPIC -DPIC works
configure:17659: /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ -c -g -=
O2 -fPIC -DPIC -DPIC conftest.cpp >&5
configure:17663: $? =3D 0
configure:17676: result: yes
configure:17699: checking if /home/lschnorr/spack-orion/lib/spack/env/gcc=
/g++ static flag -static works
configure:17727: result: yes
configure:17739: checking if /home/lschnorr/spack-orion/lib/spack/env/gcc=
/g++ supports -c -o file.o
configure:17760: /home/lschnorr/spack-orion/lib/spack/env/gcc/g++ -c -g -=
O2 -o out/conftest2.o conftest.cpp >&5
configure:17764: $? =3D 0
configure:17786: result: yes
configure:17791: checking if /home/lschnorr/spack-orion/lib/spack/env/gcc=
configure:17838: result: yes
configure:17868: checking whether the /home/lschnorr/spack-orion/lib/spac=
configure:17911: result: yes
configure:18052: checking dynamic linker characteristics
configure:18809: result: GNU/Linux ld.so
configure:18874: checking how to hardcode library paths into programs
configure:18899: result: immediate
configure:19040: checking if libtool supports shared libraries
configure:19042: result: yes
configure:19045: checking whether to build shared libraries
configure:19069: result: yes
configure:19072: checking whether to build static libraries
configure:19076: result: yes
configure:19428: checking for /home/lschnorr/spack-orion/lib/spack/env/gc=
c/gfortran option to produce PIC
configure:19435: result: -fPIC
configure:19443: checking if /home/lschnorr/spack-orion/lib/spack/env/gcc=
/gfortran PIC flag -fPIC works
configure:19461: /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran -c=
-g -O2 -fPIC conftest.f >&5
configure:19465: $? =3D 0
configure:19478: result: yes
configure:19501: checking if /home/lschnorr/spack-orion/lib/spack/env/gcc=
/gfortran static flag -static works
configure:19529: result: yes
configure:19541: checking if /home/lschnorr/spack-orion/lib/spack/env/gcc=
/gfortran supports -c -o file.o
configure:19562: /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran -c=
-g -O2 -o out/conftest2.o conftest.f >&5
configure:19566: $? =3D 0
configure:19588: result: yes
configure:19593: checking if /home/lschnorr/spack-orion/lib/spack/env/gcc=
configure:19640: result: yes
configure:19670: checking whether the /home/lschnorr/spack-orion/lib/spac=
k/env/gcc/gfortran linker (/home/lschnorr/spack-orion/opt/spack/linux-x86=
_64/gcc-6.1.1/binutils-2.26-xxp2w7twwu65gypscb7dz4lfhowwcuxg/bin/ld -m el=
f_x86_64) supports shared libraries
configure:20883: result: yes
configure:21024: checking dynamic linker characteristics
configure:21775: result: GNU/Linux ld.so
configure:21840: checking how to hardcode library paths into programs
configure:21865: result: immediate
configure:22002: checking if libtool supports shared libraries
configure:22004: result: yes
configure:22007: checking whether to build shared libraries
configure:22031: result: yes
configure:22034: checking whether to build static libraries
configure:22038: result: yes
configure:22072: /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran -c=
-g -O2 conftest.f >&5
configure:22075: $? =3D 0
configure:22535: checking for /home/lschnorr/spack-orion/lib/spack/env/gc=
configure:22542: result: -fPIC
configure:22550: checking if /home/lschnorr/spack-orion/lib/spack/env/gcc=
configure:22568: /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran -c=
configure:22572: $? =3D 0
configure:22585: result: yes
configure:22608: checking if /home/lschnorr/spack-orion/lib/spack/env/gcc=
configure:22636: result: yes
configure:22648: checking if /home/lschnorr/spack-orion/lib/spack/env/gcc=
configure:22669: /home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran -c=
configure:22673: $? =3D 0
configure:22695: result: yes
configure:22700: checking if /home/lschnorr/spack-orion/lib/spack/env/gcc=
configure:22747: result: yes
configure:22777: checking whether the /home/lschnorr/spack-orion/lib/spac=
configure:23990: result: yes
configure:24131: checking dynamic linker characteristics
configure:24882: result: GNU/Linux ld.so
configure:24947: checking how to hardcode library paths into programs
configure:24972: result: immediate
configure:25025: checking whether ln -s works
configure:25029: result: yes
configure:25037: checking for ANSI C header files
configure:25141: result: yes
configure:25150: checking for C/C++ restrict keyword
configure:25175: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -=
O2 conftest.c >&5
configure:25175: $? =3D 0
configure:25183: result: __restrict
configure:25202: checking for bash
configure:25229: result: /bin/bash
configure:25244: checking for svn
configure:25262: found /usr/bin/svn
configure:25274: result: /usr/bin/svn
configure:25284: checking for svnversion
configure:25302: found /usr/bin/svnversion
configure:25314: result: /usr/bin/svnversion
configure:25401: checking for lib
configure:25434: result: no
configure:25502: checking size of void *
configure:25507: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:25507: $? =3D 0
configure:25507: ./conftest
configure:25521: result: 8
configure:25587: checking for struct timespec
configure:25587: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -=
O2 conftest.c >&5
configure:25587: $? =3D 0
O2 conftest.c >&5
conftest.c: In function 'main':
conftest.c:46:30: error: expected expression before ')' token
if (sizeof ((struct timespec)))
configure:25587: $? =3D 1
| /* confdefs.h */
| #define restrict __restrict
| #define STARPU_MIC_USE_RMA 1
| #define STARPU_LINUX_SYS 1
| #define SIZEOF_VOID_P 8
| #define STARPU_BUILD_DIR "/tmp/lschnorr/spack-stage/spack-stage-AgZLf5/=
trunk"
| #define STARPU_SRC_DIR "/tmp/lschnorr/spack-stage/spack-stage-AgZLf5/tr=
unk/."
|=20
| #include <sys/types.h>
| #include <sys/stat.h>
| #ifdef HAVE_UNISTD_H
| #include <unistd.h>
| #endif
| #include <time.h>
| #include <pthread.h>
|=20
|=20
| int
| main ()
| return 0;
| return 0;
configure:25587: result: yes
configure:25606: checking for unistd.h
configure:25606: result: yes
configure:25645: checking for pthread_create in -lpthread
configure:25670: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
test -g -O2 conftest.c -lpthread >&5
configure:25670: $? =3D 0
configure:25679: result: yes
configure:25692: checking for library containing sqrt
configure:25723: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
conftest.c:44:6: warning: conflicting types for built-in function 'sqrt'
char sqrt ();
/tmp/ccWx5BuN.o: In function `main':
/tmp/lschnorr/spack-stage/spack-stage-AgZLf5/trunk/conftest.c:48: undefin=
ed reference to `sqrt'
collect2: error: ld returned 1 exit status
configure:25723: $? =3D 1
| /* confdefs.h */
trunk"
unk/."
| #define STARPU_HAVE_STRUCT_TIMESPEC /**/
| #define STARPU_HAVE_UNISTD_H 1
| #define HAVE_LIBPTHREAD 1
|=20
| /* Override any GCC internal prototype to avoid an error.
| Use char because int might match the return type of a GCC
| builtin and then its argument prototype would still apply. */
| #ifdef __cplusplus
| extern "C"
| #endif
| char sqrt ();
| int
| main ()
| return sqrt ();
| return 0;
test -g -O2 conftest.c -lm -lpthread >&5
char sqrt ();
configure:25723: $? =3D 0
configure:25740: result: -lm
configure:25750: checking for main in -lws2_32
configure:25769: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
test -g -O2 conftest.c -lws2_32 -lm -lpthread >&5
/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/binutils-2.26=
-xxp2w7twwu65gypscb7dz4lfhowwcuxg/bin/ld: cannot find -lws2_32
configure:25769: $? =3D 1
| /* confdefs.h */
trunk"
unk/."
|=20
|=20
| int
| main ()
| return main ();
| return 0;
configure:25778: result: no
configure:25792: checking for sysconf
configure:25792: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:25792: $? =3D 0
configure:25792: result: yes
configure:25802: checking for pthread_spin_lock
configure:25802: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:25802: $? =3D 0
configure:25802: result: yes
configure:25818: checking for pthread_barrier_init
configure:25818: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:25818: $? =3D 0
configure:25818: result: yes
configure:25834: checking for pthread_setaffinity_np
configure:25834: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:25834: $? =3D 0
configure:25834: result: yes
configure:25847: checking for posix_memalign
configure:25847: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
conftest.c:65:6: warning: conflicting types for built-in function 'posix_=
memalign'
char posix_memalign ();
configure:25847: $? =3D 0
configure:25847: result: yes
configure:25860: checking for memalign
configure:25860: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:25860: $? =3D 0
configure:25860: result: yes
configure:25873: checking for drand48
configure:25873: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:25873: $? =3D 0
configure:25873: result: yes
configure:25880: checking for erand48_r
configure:25880: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:25880: $? =3D 0
configure:25880: result: yes
configure:25907: checking for strerror_r
configure:25907: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:25907: $? =3D 0
configure:25907: result: yes
configure:25916: checking for setenv
configure:25916: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:25916: $? =3D 0
configure:25916: result: yes
configure:25925: checking for unsetenv
configure:25925: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:25925: $? =3D 0
configure:25925: result: yes
configure:25934: checking for nearbyintf
configure:25934: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
conftest.c:74:6: warning: conflicting types for built-in function 'nearby=
intf'
char nearbyintf ();
configure:25934: $? =3D 0
configure:25934: result: yes
configure:25943: checking for rintf
configure:25943: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
conftest.c:75:6: warning: conflicting types for built-in function 'rintf'=
char rintf ();
configure:25943: $? =3D 0
configure:25943: result: yes
configure:26019: checking malloc.h usability
configure:26019: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -=
O2 conftest.c >&5
configure:26019: $? =3D 0
configure:26019: result: yes
configure:26019: checking malloc.h presence
configure:26019: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -E con=
ftest.c
configure:26019: checking for malloc.h
configure:26042: checking valgrind/valgrind.h usability
configure:26042: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -=
O2 conftest.c >&5
configure:26042: $? =3D 0
configure:26042: result: yes
configure:26042: checking valgrind/valgrind.h presence
configure:26042: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -E con=
ftest.c
configure:26042: checking for valgrind/valgrind.h
configure:26056: checking valgrind/memcheck.h usability
configure:26056: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -=
O2 conftest.c >&5
configure:26056: $? =3D 0
configure:26056: result: yes
configure:26056: checking valgrind/memcheck.h presence
configure:26056: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -E con=
ftest.c
configure:26056: checking for valgrind/memcheck.h
configure:26070: checking valgrind/helgrind.h usability
configure:26070: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -=
O2 conftest.c >&5
configure:26070: $? =3D 0
configure:26070: result: yes
configure:26070: checking valgrind/helgrind.h presence
configure:26070: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -E con=
ftest.c
configure:26070: checking for valgrind/helgrind.h
configure:26089: checking for sched_yield
configure:26089: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:26089: $? =3D 0
configure:26089: result: yes
configure:26099: checking aio.h usability
configure:26099: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -=
O2 conftest.c >&5
configure:26099: $? =3D 0
configure:26099: result: yes
configure:26099: checking aio.h presence
configure:26099: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -E con=
ftest.c
configure:26099: checking for aio.h
configure:26112: checking for mkostemp
configure:26112: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:26112: $? =3D 0
configure:26112: result: yes
configure:26125: checking for pread
configure:26125: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:26125: $? =3D 0
configure:26125: result: yes
configure:26125: checking for pwrite
configure:26137: checking whether the target supports __sync_val_compare_=
and_swap
configure:26154: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:26154: $? =3D 0
configure:26162: result: yes
configure:26172: checking whether the target supports __sync_bool_compare=
_and_swap
configure:26189: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:26189: $? =3D 0
configure:26197: result: yes
configure:26207: checking whether the target supports __sync_fetch_and_ad=
d
configure:26224: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:26224: $? =3D 0
configure:26232: result: yes
configure:26242: checking whether the target supports __sync_fetch_and_or=
configure:26259: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:26259: $? =3D 0
configure:26267: result: yes
configure:26277: checking whether the target supports __sync_lock_test_an=
d_set
configure:26294: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:26294: $? =3D 0
configure:26302: result: yes
configure:26312: checking whether the target supports __sync_synchronize
configure:26329: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:26329: $? =3D 0
configure:26337: result: yes
configure:26349: checking for library containing set_mempolicy
configure:26380: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
test -g -O2 -D_GNU_SOURCE conftest.c >&5
/tmp/cce0wE2H.o: In function `main':
/tmp/lschnorr/spack-stage/spack-stage-AgZLf5/trunk/conftest.c:83: undefin=
ed reference to `set_mempolicy'
configure:26380: $? =3D 1
| /* confdefs.h */
trunk"
unk/."
| #define HAVE_SYSCONF 1
| #define HAVE_PTHREAD_SPIN_LOCK /**/
| #define STARPU_HAVE_PTHREAD_SPIN_LOCK /**/
| #define STARPU_HAVE_PTHREAD_BARRIER /**/
| #define HAVE_PTHREAD_SETAFFINITY_NP 1
| #define HAVE_POSIX_MEMALIGN 1
| #define STARPU_HAVE_POSIX_MEMALIGN 1
| #define HAVE_MEMALIGN 1
| #define STARPU_HAVE_MEMALIGN 1
| #define STARPU_USE_DRAND48 1
| #define STARPU_USE_ERAND48_R 1
| #define STARPU_HAVE_STRERROR_R 1
| #define STARPU_HAVE_SETENV 1
| #define STARPU_HAVE_UNSETENV 1
| #define STARPU_HAVE_NEARBYINTF 1
| #define STARPU_HAVE_RINTF 1
| #define HAVE_MALLOC_H 1
| #define STARPU_HAVE_MALLOC_H 1
| #define HAVE_VALGRIND_VALGRIND_H 1
| #define STARPU_HAVE_VALGRIND_H 1
| #define HAVE_VALGRIND_MEMCHECK_H 1
| #define STARPU_HAVE_MEMCHECK_H 1
| #define HAVE_VALGRIND_HELGRIND_H 1
| #define STARPU_HAVE_HELGRIND_H 1
| #define STARPU_HAVE_SCHED_YIELD 1
| #define HAVE_AIO_H 1
| #define HAVE_MKOSTEMP 1
| #define HAVE_PREAD 1
| #define HAVE_PWRITE 1
| #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1
| #define STARPU_HAVE_SYNC_FETCH_AND_OR 1
| #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1
| #define STARPU_HAVE_SYNC_SYNCHRONIZE 1
|=20
| #ifdef __cplusplus
| extern "C"
| #endif
| char set_mempolicy ();
| int
| main ()
| return set_mempolicy ();
| return 0;
test -g -O2 -D_GNU_SOURCE conftest.c -lnuma >&5
configure:26380: $? =3D 0
configure:26397: result: -lnuma
configure:26411: checking whether libnuma is available
configure:26413: result: yes
configure:26426: checking maximum number of sched_ctxs
configure:26435: result: 10
configure:26513: checking maximum number of CPUs
configure:26522: result: 64
configure:26530: checking whether CPUs should be used
configure:26539: result: yes
configure:26564: checking maximum number of CUDA devices
configure:26573: result: 4
configure:28371: checking whether CUDA should be used
configure:28373: result: no
configure:28472: checking for pkg-config
configure:28490: found /usr/bin/pkg-config
configure:28502: result: /usr/bin/pkg-config
configure:28527: checking pkg-config is at least version 0.9.0
configure:28530: result: yes
configure:28629: checking whether MAGMA should be used
configure:28631: result: no
configure:28635: checking for cufftDoubleComplex
configure:28635: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -=
conftest.c:77:19: fatal error: cufft.h: No such file or directory
#include <cufft.h>
configure:28635: $? =3D 1
| /* confdefs.h */
trunk"
unk/."
| #define STARPU_HAVE_LIBNUMA /**/
| #define STARPU_NMAX_SCHED_CTXS 10
| #define STARPU_MAXCPUS 64
| #define STARPU_USE_CPU 1
| #define STARPU_MAXCUDADEVS 4
| #include <cufft.h>
|=20
| int
| main ()
| if (sizeof (cufftDoubleComplex))
| return 0;
| return 0;
configure:28635: result: no
configure:28701: checking whether CURAND is available
configure:28703: result: no
configure:28759: checking maximum number of OpenCL devices
configure:28768: result: 8
configure:29388: checking whether OpenCL should be used
configure:29390: result: no
configure:29418: checking whether asynchronous copy should be disabled
configure:29431: result: no
configure:29439: checking whether asynchronous CUDA copy should be disabl=
ed
configure:29452: result: no
configure:29460: checking whether asynchronous OpenCL copy should be disa=
bled
configure:29473: result: no
configure:29481: checking whether asynchronous MIC copy should be disable=
d
configure:29494: result: no
configure:29781: checking whether SimGrid is enabled
configure:29783: result: no
configure:29786: checking whether blocking drivers should be enabled
configure:29795: result: no
configure:29835: checking maximum number of MIC devices
configure:29844: result: 4
configure:29853: checking maximum number of MIC threads
configure:29862: result:=20
configure:30438: checking RCCE.h usability
configure:30438: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -g -=
conftest.c:115:18: fatal error: RCCE.h: No such file or directory
#include <RCCE.h>
configure:30438: $? =3D 1
| /* confdefs.h */
trunk"
unk/."
| #define STARPU_MAXOPENCLDEVS 8
| #define STARPU_NON_BLOCKING_DRIVERS 1
| #define STARPU_MAXMICDEVS 4
| #define STARPU_MAXMICCORES 120
| #define STARPU_MAXSCCDEVS 47
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| # include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| # include <unistd.h>
| #endif
| #include <RCCE.h>
configure:30438: result: no
configure:30438: checking RCCE.h presence
configure:30438: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -E -D_=
conftest.c:82:18: fatal error: RCCE.h: No such file or directory
#include <RCCE.h>
| /* confdefs.h */
trunk"
unk/."
| #include <RCCE.h>
configure:30438: checking for RCCE.h
configure:30454: checking for RCCE_init in -lRCCE_bigflags_nongory_nopwrm=
gmt
configure:30479: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
test -g -O2 -D_GNU_SOURCE conftest.c -lRCCE_bigflags_nongory_nopwrmg=
mt -lm -lpthread >&5
-xxp2w7twwu65gypscb7dz4lfhowwcuxg/bin/ld: cannot find -lRCCE_bigflags_non=
gory_nopwrmgmt
configure:30479: $? =3D 1
| /* confdefs.h */
trunk"
unk/."
|=20
| #ifdef __cplusplus
| extern "C"
| #endif
| char RCCE_init ();
| int
| main ()
| return RCCE_init ();
| return 0;
configure:30488: result: no
configure:30536: checking whether RCCE should be used
configure:30538: result: no
configure:30577: checking Maximum number of message-passing kernels
configure:30586: result: 10
configure:30602: checking whether debug mode should be enabled
configure:30611: result: no
configure:30655: checking whether extra checks should be performed
configure:30664: result: no
configure:30672: checking whether debug messages should be displayed
configure:30681: result: no
configure:30697: checking whether coverage testing should be enabled
configure:30706: result: no
configure:30725: checking whether coverity mode should be enabled
configure:30734: result: no
configure:30746: checking whether FxT traces should be generated
configure:30763: result: yes using /home/lschnorr/spack-orion/opt/spack/l=
inux-x86_64/gcc-6.1.0/fxt-0.3.1-7cplb2duxldnevckobjnofq6tgpxffck
configure:30806: checking for FXT
configure:30814: $PKG_CONFIG --exists --print-errors "fxt"
configure:30817: $? =3D 0
configure:30832: $PKG_CONFIG --exists --print-errors "fxt"
configure:30835: $? =3D 0
configure:30885: result: yes
configure:30988: checking for enable_fut_flush
configure:30988: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
test -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE -gdwarf-2 -g3 conftest.=
c -lm -lpthread -L/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-=
6.1.0/fxt-0.3.1-7cplb2duxldnevckobjnofq6tgpxffck/lib -lfxt >&5
configure:30988: $? =3D 0
configure:30988: result: yes
configure:30999: checking for fut_set_filename
configure:30999: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:30999: $? =3D 0
configure:30999: result: yes
configure:31012: checking whether enable_fut_flush is declared
configure:31012: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -O3 =
-g -O2 -gdwarf-2 -g3 -I/home/lschnorr/spack-orion/opt/spack/linux-x86_64=
/gcc-6.1.0/fxt-0.3.1-7cplb2duxldnevckobjnofq6tgpxffck/include -D_GNU_SOU=
RCE conftest.c >&5
conftest.c:127:10: error: 'enable_fut_flush' undeclared (first use in thi=
s function)
(void) enable_fut_flush;
conftest.c:127:10: note: each undeclared identifier is reported only once=
for each function it appears in
configure:31012: $? =3D 1
| /* confdefs.h */
trunk"
unk/."
| #define STARPU_MAXMPKERNELS 10
| #define STARPU_USE_FXT 1
| #define CONFIG_FUT 1
| #define HAVE_ENABLE_FUT_FLUSH 1
| #define HAVE_FUT_SET_FILENAME 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| #ifndef enable_fut_flush
| #ifdef __cplusplus
| #else
| #endif
| #endif
|=20
| return 0;
configure:31012: result: no
configure:31023: checking whether fut_set_filename is declared
configure:31023: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -O3 =
RCE conftest.c >&5
conftest.c:128:10: error: 'fut_set_filename' undeclared (first use in thi=
s function)
(void) fut_set_filename;
conftest.c:128:10: note: each undeclared identifier is reported only once=
configure:31023: $? =3D 1
| /* confdefs.h */
trunk"
unk/."
| #define HAVE_DECL_ENABLE_FUT_FLUSH 0
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| int
| main ()
| #ifndef fut_set_filename
| #ifdef __cplusplus
| #else
| #endif
| #endif
|=20
| return 0;
configure:31023: result: no
configure:31059: checking for POTI
configure:31067: $PKG_CONFIG --exists --print-errors "poti"
Package poti was not found in the pkg-config search path.
Perhaps you should add the directory containing `poti.pc'
to the PKG_CONFIG_PATH environment variable
No package 'poti' found
configure:31070: $? =3D 1
configure:31085: $PKG_CONFIG --exists --print-errors "poti"
configure:31088: $? =3D 1
configure:31116: result: no
configure:31136: checking whether additional locking systems FxT traces s=
hould be enabled
configure:31145: result: no
configure:31153: checking whether performance debugging should be enabled=
configure:31162: result: no
configure:31174: checking whether performance model debugging should be e=
nabled
configure:31183: result: no
configure:31191: checking whether memory stats should be displayed
configure:31200: result: no
configure:31210: checking glpk.h usability
configure:31210: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -O3 =
-g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE conftest.c >&5
conftest.c:123:18: fatal error: glpk.h: No such file or directory
#include <glpk.h>
configure:31210: $? =3D 1
| /* confdefs.h */
trunk"
unk/."
| #define HAVE_DECL_FUT_SET_FILENAME 0
| #define STARPU_ENABLE_PAJE_CODELET_DETAILS 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <glpk.h>
configure:31210: result: no
configure:31210: checking glpk.h presence
configure:31210: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -E -D_=
conftest.c:90:18: fatal error: glpk.h: No such file or directory
#include <glpk.h>
| /* confdefs.h */
trunk"
unk/."
| #include <glpk.h>
configure:31210: checking for glpk.h
configure:31224: checking for main in -lglpk
configure:31243: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
test -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE -gdwarf-2 -g3 conftest.c=
-lglpk >&5
-xxp2w7twwu65gypscb7dz4lfhowwcuxg/bin/ld: cannot find -lglpk
configure:31243: $? =3D 1
| /* confdefs.h */
trunk"
unk/."
|=20
|=20
| int
| main ()
| return main ();
| return 0;
configure:31252: result: no
configure:31270: checking Ayudame.h usability
configure:31270: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -O3 =
conftest.c:123:21: fatal error: Ayudame.h: No such file or directory
#include <Ayudame.h>
configure:31270: $? =3D 1
| /* confdefs.h */
trunk"
unk/."
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
configure:31270: result: no
configure:31270: checking Ayudame.h presence
configure:31270: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -E -D_=
conftest.c:90:21: fatal error: Ayudame.h: No such file or directory
| /* confdefs.h */
trunk"
unk/."
configure:31270: checking for Ayudame.h
configure:31287: checking how many buffers can be manipulated per task
configure:31296: result: 8
configure:31304: checking maximum number of nodes to use
configure:31353: checking maximum number of memory nodes
configure:31355: result: 4
configure:31364: checking whether allocation cache should be used
configure:31373: result: yes
configure:31407: checking using explicit performance model location
configure:31409: result: no
configure:31412: checking performance models location
configure:31414: result: $HOME/.starpu/sampling/
configure:31418: checking for clock_gettime in -lrt
configure:31443: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
-lrt -lm -lpthread >&5
configure:31443: $? =3D 0
configure:31452: result: yes
configure:31465: checking for clock_gettime
configure:31465: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
configure:31465: $? =3D 0
configure:31465: result: yes
configure:31495: checking Maximum number of workers
configure:31497: result: 64
configure:31507: checking Maximum number of workers combinations
configure:31509: result: 64
configure:31520: checking maximum number of implementations
configure:31529: result: 4
configure:31630: checking calibration heuristic of history-based StarPU c=
alibrator
configure:31639: result: 50
configure:31721: result: The mpicc compiler 'no' does not have the execut=
e permission
configure:31789: checking mpicc path
configure:31791: result: no
configure:31843: checking for mpiexec
configure:31875: result: no
configure:31887: checking whether mpiexec is available
configure:31889: result: no
configure:31895: result: The mpiexec script is not valid
configure:31918: checking whether the StarPU MPI library should be genera=
ted
configure:31920: result: no
configure:31979: checking for StarPU-Top
configure:32118: checking whether compiler support -Wall
configure:32140: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
test -Wall -D_GNU_SOURCE -gdwarf-2 -g3 conftest.c -lrt -lm -lpthread =
>&5
conftest.c:105:18: warning: unused variable 'hello' [-Wunused-variable]
const char *hello =3D "Hello World";
configure:32140: $? =3D 0
configure:32143: result: yes
configure:32162: checking whether compiler support -Werror=3Dimplicit
configure:32184: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
test -Werror=3Dimplicit -D_GNU_SOURCE -gdwarf-2 -g3 conftest.c -lrt -=
lm -lpthread >&5
configure:32184: $? =3D 0
configure:32187: result: yes
configure:32206: checking whether compiler support -Werror=3Dimplicit-fun=
ction-declaration
configure:32228: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
test -Werror=3Dimplicit-function-declaration -D_GNU_SOURCE -gdwarf-2 -=
g3 conftest.c -lrt -lm -lpthread >&5
configure:32228: $? =3D 0
configure:32231: result: yes
configure:32681: checking whether GCC supports plug-ins
configure:32736: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -O3 =
/gcc-6.1.1/gcc-6.1.0-7cljeqxjfpkacgtkxus4p55nsms53dnv/lib64/gcc/x86_64-pc=
-linux-gnu/6.1.0/plugin/include conftest.c >&5
In file included from /home/lschnorr/spack-orion/opt/spack/linux-x86_64/g=
cc-6.1.1/gcc-6.1.0-7cljeqxjfpkacgtkxus4p55nsms53dnv/lib64/gcc/x86_64-pc-l=
inux-gnu/6.1.0/plugin/include/config.h:6:0,
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:27,
from conftest.c:100:
/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/gcc-6.1.0-7cl=
jeqxjfpkacgtkxus4p55nsms53dnv/lib64/gcc/x86_64-pc-linux-gnu/6.1.0/plugin/=
include/auto-host.h:1970:0: warning: "PACKAGE_BUGREPORT" redefined
#define PACKAGE_BUGREPORT ""
=20
conftest.c:6:0: note: this is the location of the previous definition
=20
include/auto-host.h:1976:0: warning: "PACKAGE_NAME" redefined
#define PACKAGE_NAME ""
=20
conftest.c:2:0: note: this is the location of the previous definition
=20
include/auto-host.h:1982:0: warning: "PACKAGE_STRING" redefined
#define PACKAGE_STRING ""
=20
conftest.c:5:0: note: this is the location of the previous definition
=20
include/auto-host.h:1988:0: warning: "PACKAGE_TARNAME" redefined
#define PACKAGE_TARNAME ""
=20
conftest.c:3:0: note: this is the location of the previous definition
=20
include/auto-host.h:1994:0: warning: "PACKAGE_URL" redefined
#define PACKAGE_URL ""
=20
conftest.c:7:0: note: this is the location of the previous definition
=20
include/auto-host.h:2000:0: warning: "PACKAGE_VERSION" redefined
#define PACKAGE_VERSION ""
=20
conftest.c:4:0: note: this is the location of the previous definition
=20
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:29:0,
include/coretypes.h:62:1: error: unknown type name 'class'
class rtx_def;
include/coretypes.h:63:3: error: unknown type name 'class'
class rtx_expr_list; /* GET_CODE (X) =3D=3D EXPR_LIST */
include/coretypes.h:64:3: error: unknown type name 'class'
class rtx_insn_list; /* GET_CODE (X) =3D=3D INSN_LIST */
include/coretypes.h:65:3: error: unknown type name 'class'
class rtx_sequence; /* GET_CODE (X) =3D=3D SEQUENCE */
include/coretypes.h:66:3: error: unknown type name 'class'
class rtx_insn;
include/coretypes.h:67:5: error: unknown type name 'class'
class rtx_debug_insn; /* DEBUG_INSN_P (X) */
include/coretypes.h:68:5: error: unknown type name 'class'
class rtx_nonjump_insn; /* NONJUMP_INSN_P (X) */
include/coretypes.h:69:5: error: unknown type name 'class'
class rtx_jump_insn; /* JUMP_P (X) */
include/coretypes.h:70:5: error: unknown type name 'class'
class rtx_call_insn; /* CALL_P (X) */
include/coretypes.h:71:5: error: unknown type name 'class'
class rtx_jump_table_data; /* JUMP_TABLE_DATA_P (X) */
include/coretypes.h:72:5: error: unknown type name 'class'
class rtx_barrier; /* BARRIER_P (X) */
include/coretypes.h:73:5: error: unknown type name 'class'
class rtx_code_label; /* LABEL_P (X) */
include/coretypes.h:74:5: error: unknown type name 'class'
class rtx_note; /* NOTE_P (X) */
include/coretypes.h:86:9: error: unknown type name 'gimple'
typedef gimple *gimple_seq;
include/coretypes.h:260:1: error: unknown type name 'class'
class rtl_opt_pass;
include/coretypes.h:262:1: error: unknown type name 'namespace'
namespace gcc {
include/coretypes.h:262:15: error: expected '=3D', ',', ';', 'asm' or '__=
attribute__' before '{' token
namespace gcc {
include/coretypes.h:266:12: error: expected '=3D', ',', ';', 'asm' or '__=
attribute__' before ':' token
typedef std::pair <tree, tree> tree_pair;
inux-gnu/6.1.0/plugin/include/machmode.h:24:0,
inux-gnu/6.1.0/plugin/include/coretypes.h:342,
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:29,
include/insn-modes.h:296:19: error: unknown type name 'machine_mode'
mode_size_inline (machine_mode mode)
include/insn-modes.h:412:21: error: unknown type name 'machine_mode'
mode_nunits_inline (machine_mode mode)
include/insn-modes.h:530:20: error: unknown type name 'machine_mode'
mode_inner_inline (machine_mode mode)
include/insn-modes.h:648:24: error: unknown type name 'machine_mode'
mode_unit_size_inline (machine_mode mode)
include/insn-modes.h:764:29: error: unknown type name 'machine_mode'
mode_unit_precision_inline (machine_mode mode)
inux-gnu/6.1.0/plugin/include/coretypes.h:342:0,
include/machmode.h:276:8: error: unknown type name 'machine_mode'
extern machine_mode mode_for_size (unsigned int, enum mode_class, int);
include/machmode.h:280:8: error: unknown type name 'machine_mode'
extern machine_mode smallest_mode_for_size (unsigned int,
include/machmode.h:287:8: error: unknown type name 'machine_mode'
extern machine_mode int_mode_for_mode (machine_mode);
include/machmode.h:287:1: warning: parameter names (without types) in fun=
ction declaration
include/machmode.h:289:8: error: unknown type name 'machine_mode'
extern machine_mode bitwise_mode_for_mode (machine_mode);
include/machmode.h:289:1: warning: parameter names (without types) in fun=
ction declaration
include/machmode.h:294:8: error: unknown type name 'machine_mode'
extern machine_mode mode_for_vector (machine_mode, unsigned);
include/machmode.h:294:52: error: expected ')' before 'unsigned'
include/machmode.h:297:1: error: unknown type name 'class'
class bit_field_mode_iterator
include/machmode.h:298:1: error: expected '=3D', ',', ';', 'asm' or '__at=
include/machmode.h:321:8: error: unknown type name 'machine_mode'
extern machine_mode get_best_mode (int, int,
include/machmode.h:325:6: error: unknown type name 'machine_mode'
machine_mode, bool);
include/machmode.h:331:1: warning: parameter names (without types) in fun=
ction declaration
extern unsigned get_mode_alignment (machine_mode);
include/machmode.h:344:8: error: unknown type name 'machine_mode'
extern machine_mode byte_mode;
include/machmode.h:345:8: error: unknown type name 'machine_mode'
extern machine_mode word_mode;
include/machmode.h:346:8: error: unknown type name 'machine_mode'
extern machine_mode ptr_mode;
include/machmode.h:362:3: error: unknown type name 'machine_mode'
machine_mode m;
include/machmode.h:369:14: error: unknown type name 'int_n_data_t'
extern const int_n_data_t int_n_data[NUM_INT_N_ENTS];
inux-gnu/6.1.0/plugin/include/coretypes.h:344:0,
include/wide-int.h:278:10: error: expected '=3D', ',', ';', 'asm' or '__a=
ttribute__' before '<' token
template <typename T> class generic_wide_int;
include/wide-int.h:279:10: error: expected '=3D', ',', ';', 'asm' or '__a=
template <int N> struct fixed_wide_int_storage;
include/wide-int.h:280:1: error: unknown type name 'class'
class wide_int_storage;
include/wide-int.h:286:26: error: expected '=3D', ',', ';', 'asm' or '__a=
typedef generic_wide_int <wide_int_storage> wide_int;
include/wide-int.h:284:20: error: expected '=3D', ',', ';', 'asm' or '__a=
generic_wide_int < fixed_wide_int_storage <N> >
include/wide-int.h:287:9: note: in expansion of macro 'FIXED_WIDE_INT'
typedef FIXED_WIDE_INT (ADDR_MAX_PRECISION) offset_int;
include/wide-int.h:288:9: note: in expansion of macro 'FIXED_WIDE_INT'
typedef FIXED_WIDE_INT (WIDE_INT_MAX_PRECISION) widest_int;
include/wide-int.h:290:10: error: expected '=3D', ',', ';', 'asm' or '__a=
template <bool SE>
include/wide-int.h:293:26: error: expected '=3D', ',', ';', 'asm' or '__a=
typedef generic_wide_int <wide_int_ref_storage <false> > wide_int_ref;
include/wide-int.h:306:1: error: unknown type name 'namespace'
namespace wi
include/wide-int.h:307:1: error: expected '=3D', ',', ';', 'asm' or '__at=
include/wide-int.h:417:1: error: unknown type name 'namespace'
namespace wi
include/wide-int.h:418:1: error: expected '=3D', ',', ';', 'asm' or '__at=
include/wide-int.h:557:1: error: unknown type name 'namespace'
namespace wi
include/wide-int.h:558:1: error: expected '=3D', ',', ';', 'asm' or '__at=
include/wide-int.h:577:7: error: expected identifier or '(' before ':' to=
ken
inline::wi::storage_ref::storage_ref (const HOST_WIDE_INT *val_in,
include/wide-int.h:585:3: error: expected '=3D', ',', ';', 'asm' or '__at=
wi::storage_ref::get_len () const
include/wide-int.h:591:3: error: expected '=3D', ',', ';', 'asm' or '__at=
wi::storage_ref::get_precision () const
include/wide-int.h:597:3: error: expected '=3D', ',', ';', 'asm' or '__at=
wi::storage_ref::get_val () const
include/wide-int.h:625:10: error: expected '=3D', ',', ';', 'asm' or '__a=
template <typename storage>
include/wide-int.h:708:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:711:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:718:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:728:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:739:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:752:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:763:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:774:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:782:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:800:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:809:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:818:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:827:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:835:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:845:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:855:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:871:1: error: unknown type name 'namespace'
namespace wi
include/wide-int.h:872:1: error: expected '=3D', ',', ';', 'asm' or '__at=
include/wide-int.h:883:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:891:10: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:904:10: error: expected '=3D', ',', ';', 'asm' or '__a=
template <bool SE>
include/wide-int.h:923:10: error: expected '=3D', ',', ';', 'asm' or '__a=
template <bool SE>
include/wide-int.h:932:10: error: expected '=3D', ',', ';', 'asm' or '__a=
template <bool SE>
include/wide-int.h:941:10: error: expected '=3D', ',', ';', 'asm' or '__a=
template <bool SE>
include/wide-int.h:949:1: error: unknown type name 'namespace'
namespace wi
include/wide-int.h:950:1: error: expected '=3D', ',', ';', 'asm' or '__at=
include/wide-int.h:962:1: error: unknown type name 'namespace'
namespace wi
include/wide-int.h:963:1: error: expected '=3D', ',', ';', 'asm' or '__at=
include/wide-int.h:972:1: error: unknown type name 'class'
class GTY(()) wide_int_storage
include/wide-int.h:973:1: error: expected '=3D', ',', ';', 'asm' or '__at=
include/wide-int.h:1000:1: error: unknown type name 'namespace'
namespace wi
include/wide-int.h:1001:1: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:1014:24: error: expected '=3D', ',', ';', 'asm' or '__=
inline wide_int_storage::wide_int_storage () {}
include/wide-int.h:1020:10: error: expected '=3D', ',', ';', 'asm' or '__=
attribute__' before '<' token
include/wide-int.h:1031:17: error: expected '=3D', ',', ';', 'asm' or '__=
wide_int_storage::get_precision () const
include/wide-int.h:1037:17: error: expected '=3D', ',', ';', 'asm' or '__=
wide_int_storage::get_val () const
include/wide-int.h:1043:17: error: expected '=3D', ',', ';', 'asm' or '__=
wide_int_storage::get_len () const
include/wide-int.h:1049:17: error: expected '=3D', ',', ';', 'asm' or '__=
wide_int_storage::write_val ()
include/wide-int.h:1055:17: error: expected '=3D', ',', ';', 'asm' or '__=
wide_int_storage::set_len (unsigned int l, bool is_sign_extended)
include/wide-int.h:1065:8: error: unknown type name 'wide_int'
inline wide_int
include/wide-int.h:1066:17: error: expected '=3D', ',', ';', 'asm' or '__=
wide_int_storage::from (const wide_int_ref &x, unsigned int precision,
include/wide-int.h:1078:8: error: unknown type name 'wide_int'
inline wide_int
include/wide-int.h:1079:17: error: expected '=3D', ',', ';', 'asm' or '__=
wide_int_storage::from_array (const HOST_WIDE_INT *val, unsigned int len=
include/wide-int.h:1089:8: error: unknown type name 'wide_int'
inline wide_int
include/wide-int.h:1090:17: error: expected '=3D', ',', ';', 'asm' or '__=
wide_int_storage::create (unsigned int precision)
include/wide-int.h:1097:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <typename T1, typename T2>
include/wide-int.h:1111:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <int N>
include/wide-int.h:1135:1: error: unknown type name 'namespace'
namespace wi
include/wide-int.h:1136:1: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:1149:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <int N>
include/wide-int.h:1153:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <int N>
include/wide-int.h:1163:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <int N>
include/wide-int.h:1170:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <int N>
include/wide-int.h:1177:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <int N>
include/wide-int.h:1184:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <int N>
include/wide-int.h:1191:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <int N>
include/wide-int.h:1201:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <int N>
include/wide-int.h:1214:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <int N>
include/wide-int.h:1226:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <int N>
include/wide-int.h:1236:1: error: unknown type name 'class'
class trailing_wide_int_storage
include/wide-int.h:1237:1: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:1264:26: error: expected '=3D', ',', ';', 'asm' or '__=
typedef generic_wide_int <trailing_wide_int_storage> trailing_wide_int;
include/wide-int.h:1267:1: error: unknown type name 'namespace'
namespace wi
include/wide-int.h:1268:1: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:1278:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <int N>
include/wide-int.h:1301:33: error: expected '=3D', ',', ';', 'asm' or '__=
inline trailing_wide_int_storage::
include/wide-int.h:1309:26: error: expected '=3D', ',', ';', 'asm' or '__=
trailing_wide_int_storage::get_len () const
include/wide-int.h:1315:26: error: expected '=3D', ',', ';', 'asm' or '__=
trailing_wide_int_storage::get_precision () const
include/wide-int.h:1321:26: error: expected '=3D', ',', ';', 'asm' or '__=
trailing_wide_int_storage::get_val () const
include/wide-int.h:1327:26: error: expected '=3D', ',', ';', 'asm' or '__=
trailing_wide_int_storage::write_val ()
include/wide-int.h:1333:26: error: expected '=3D', ',', ';', 'asm' or '__=
trailing_wide_int_storage::set_len (unsigned int len, bool is_sign_exten=
ded)
include/wide-int.h:1341:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1352:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <int N>
include/wide-int.h:1362:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <int N>
include/wide-int.h:1372:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <int N>
include/wide-int.h:1388:1: error: unknown type name 'namespace'
namespace wi
include/wide-int.h:1389:1: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:1402:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <typename T, bool signed_p>
include/wide-int.h:1409:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1422:1: error: unknown type name 'namespace'
namespace wi
include/wide-int.h:1423:1: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:1451:1: error: unknown type name 'namespace'
namespace wi
include/wide-int.h:1452:1: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:1472:10: error: expected '=3D', ',', ';', 'asm' or '__=
inline wi::hwi_with_prec::hwi_with_prec (HOST_WIDE_INT v, unsigned int p=
include/wide-int.h:1479:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1486:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1493:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1500:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1507:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1514:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1520:1: error: unknown type name 'namespace'
namespace wi
include/wide-int.h:1521:1: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:1537:3: error: expected '=3D', ',', ';', 'asm' or '__a=
wi::int_traits <wi::hwi_with_prec>::get_precision (const wi::hwi_with_pr=
ec &x)
include/wide-int.h:1542:10: error: expected '=3D', ',', ';', 'asm' or '__=
inline wi::storage_ref
include/wide-int.h:1560:1: error: unknown type name 'namespace'
namespace wi
include/wide-int.h:1561:1: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:1619:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1628:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1637:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1652:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1662:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1676:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1687:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1696:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1735:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1743:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1776:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1801:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1812:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1820:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1828:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1839:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1847:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1855:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1866:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1874:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1882:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1894:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1931:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1973:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1984:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:1997:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2005:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2014:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2022:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2041:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2071:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2079:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2098:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2112:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2120:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2129:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2143:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2151:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2159:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2180:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2201:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2222:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2243:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2264:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2307:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2337:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2380:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2409:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2430:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2446:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2455:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2464:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2481:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2498:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2506:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2516:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2539:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2548:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2558:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2583:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2625:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2649:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2671:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2691:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2700:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2710:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2736:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2746:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2772:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2814:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2823:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2841:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2885:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2929:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2961:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2974:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:2992:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:3010:3: error: expected '=3D', ',', ';', 'asm' or '__a=
wi::parity (const wide_int_ref &x)
include/wide-int.h:3016:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:3043:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:3053:9: error: expected '=3D', ',', ';', 'asm' or '__a=
template<typename T>
include/wide-int.h:3059:9: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:3065:9: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:3071:9: error: expected '=3D', ',', ';', 'asm' or '__a=
template<int N>
include/wide-int.h:3077:9: error: expected '=3D', ',', ';', 'asm' or '__a=
template<int N>
include/wide-int.h:3083:9: error: expected '=3D', ',', ';', 'asm' or '__a=
template<int N>
include/wide-int.h:3089:1: error: unknown type name 'namespace'
namespace wi
include/wide-int.h:3090:1: error: expected '=3D', ',', ';', 'asm' or '__a=
include/wide-int.h:3136:8: error: unknown type name 'wide_int'
inline wide_int
include/wide-int.h:3137:3: error: expected '=3D', ',', ';', 'asm' or '__a=
wi::mask (unsigned int width, bool negate_p, unsigned int precision)
include/wide-int.h:3147:8: error: unknown type name 'wide_int'
inline wide_int
include/wide-int.h:3148:3: error: expected '=3D', ',', ';', 'asm' or '__a=
wi::shifted_mask (unsigned int start, unsigned int width, bool negate_p,=
include/wide-int.h:3159:8: error: unknown type name 'wide_int'
inline wide_int
include/wide-int.h:3160:3: error: expected '=3D', ',', ';', 'asm' or '__a=
wi::set_bit_in_zero (unsigned int bit, unsigned int precision)
include/wide-int.h:3167:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:3181:10: error: expected '=3D', ',', ';', 'asm' or '__=
include/wide-int.h:3195:10: error: expected '=3D', ',', ';', 'asm' or '__=
inux-gnu/6.1.0/plugin/include/coretypes.h:345:0,
include/double-int.h:58:3: error: expected specifier-qualifier-list befor=
e 'static'
static double_int from_uhwi (unsigned HOST_WIDE_INT cst);
include/double-int.h:207:8: error: unknown type name 'double_int'
inline double_int
include/double-int.h:208:11: error: expected '=3D', ',', ';', 'asm' or '_=
_attribute__' before ':' token
double_int::from_shwi (HOST_WIDE_INT cst)
include/double-int.h:230:8: error: unknown type name 'double_int'
inline double_int
include/double-int.h:231:11: error: expected '=3D', ',', ';', 'asm' or '_=
double_int::from_uhwi (unsigned HOST_WIDE_INT cst)
include/double-int.h:239:8: error: unknown type name 'double_int'
inline double_int
include/double-int.h:240:11: error: expected '=3D', ',', ';', 'asm' or '_=
double_int::from_pair (HOST_WIDE_INT high, unsigned HOST_WIDE_INT low)
include/double-int.h:248:19: error: expected '=3D', ',', ';', 'asm' or '_=
_attribute__' before '&' token
inline double_int &
include/double-int.h:255:19: error: expected '=3D', ',', ';', 'asm' or '_=
inline double_int &
include/double-int.h:262:19: error: expected '=3D', ',', ';', 'asm' or '_=
inline double_int &
include/double-int.h:269:19: error: expected '=3D', ',', ';', 'asm' or '_=
inline double_int &
include/double-int.h:276:19: error: expected '=3D', ',', ';', 'asm' or '_=
inline double_int &
include/double-int.h:287:11: error: expected '=3D', ',', ';', 'asm' or '_=
double_int::to_shwi () const
include/double-int.h:296:11: error: expected '=3D', ',', ';', 'asm' or '_=
double_int::to_uhwi () const
include/double-int.h:304:11: error: expected '=3D', ',', ';', 'asm' or '_=
double_int::fits_uhwi () const
include/double-int.h:313:8: error: unknown type name 'double_int'
inline double_int
include/double-int.h:314:11: error: expected '=3D', ',', ';', 'asm' or '_=
double_int::operator ~ () const
include/double-int.h:324:8: error: unknown type name 'double_int'
inline double_int
include/double-int.h:325:11: error: expected '=3D', ',', ';', 'asm' or '_=
double_int::operator | (double_int b) const
include/double-int.h:335:8: error: unknown type name 'double_int'
inline double_int
include/double-int.h:336:11: error: expected '=3D', ',', ';', 'asm' or '_=
double_int::operator & (double_int b) const
include/double-int.h:346:8: error: unknown type name 'double_int'
inline double_int
include/double-int.h:347:11: error: expected '=3D', ',', ';', 'asm' or '_=
double_int::and_not (double_int b) const
include/double-int.h:357:8: error: unknown type name 'double_int'
inline double_int
include/double-int.h:358:11: error: expected '=3D', ',', ';', 'asm' or '_=
double_int::operator ^ (double_int b) const
include/double-int.h:366:31: error: unknown type name 'double_int'
void dump_double_int (FILE *, double_int, bool);
include/double-int.h:377:11: error: expected '=3D', ',', ';', 'asm' or '_=
double_int::is_zero () const
include/double-int.h:385:11: error: expected '=3D', ',', ';', 'asm' or '_=
double_int::is_one () const
include/double-int.h:393:11: error: expected '=3D', ',', ';', 'asm' or '_=
double_int::is_minus_one () const
include/double-int.h:401:11: error: expected '=3D', ',', ';', 'asm' or '_=
double_int::is_negative () const
include/double-int.h:409:11: error: expected '=3D', ',', ';', 'asm' or '_=
double_int::operator =3D=3D (double_int cst2) const
include/double-int.h:417:11: error: expected '=3D', ',', ';', 'asm' or '_=
double_int::operator !=3D (double_int cst2) const
include/double-int.h:425:11: error: expected '=3D', ',', ';', 'asm' or '_=
double_int::popcount () const
include/double-int.h:434:33: error: unknown type name 'double_int'
void mpz_set_double_int (mpz_t, double_int, bool);
include/double-int.h:435:1: error: unknown type name 'double_int'
double_int mpz_get_double_int (const_tree, mpz_t, bool);
include/double-int.h:435:1: note: use 'struct' keyword to refer to the ty=
pe
include/double-int.h:438:1: error: unknown type name 'namespace'
namespace wi
include/double-int.h:439:1: error: expected '=3D', ',', ';', 'asm' or '__=
include/double-int.h:453:3: error: expected '=3D', ',', ';', 'asm' or '__=
wi::int_traits <double_int>::get_precision (const double_int &)
include/double-int.h:458:10: error: expected '=3D', ',', ';', 'asm' or '_=
inux-gnu/6.1.0/plugin/include/coretypes.h:346:0,
include/real.h:200:1: error: unknown type name 'class'
class format_helper
include/real.h:201:1: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/real.h:214:21: error: expected '=3D', ',', ';', 'asm' or '__attri=
inline format_helper::format_helper (machine_mode m)
include/real.h:225:1: warning: parameter names (without types) in functio=
n declaration
extern bool HONOR_NANS (machine_mode);
include/real.h:227:13: error: conflicting types for 'HONOR_NANS'
extern bool HONOR_NANS (const_rtx);
include/real.h:226:13: note: previous declaration of 'HONOR_NANS' was her=
e
extern bool HONOR_NANS (const_tree);
include/real.h:230:1: warning: parameter names (without types) in functio=
n declaration
extern bool HONOR_SNANS (machine_mode);
include/real.h:232:13: error: conflicting types for 'HONOR_SNANS'
extern bool HONOR_SNANS (const_rtx);
include/real.h:231:13: note: previous declaration of 'HONOR_SNANS' was he=
re
extern bool HONOR_SNANS (const_tree);
include/real.h:236:1: warning: parameter names (without types) in functio=
n declaration
extern bool HONOR_INFINITIES (machine_mode);
include/real.h:238:13: error: conflicting types for 'HONOR_INFINITIES'
extern bool HONOR_INFINITIES (const_rtx);
include/real.h:237:13: note: previous declaration of 'HONOR_INFINITIES' w=
as here
extern bool HONOR_INFINITIES (const_tree);
include/real.h:242:1: warning: parameter names (without types) in functio=
n declaration
extern bool HONOR_SIGNED_ZEROS (machine_mode);
include/real.h:244:13: error: conflicting types for 'HONOR_SIGNED_ZEROS'
extern bool HONOR_SIGNED_ZEROS (const_rtx);
include/real.h:243:13: note: previous declaration of 'HONOR_SIGNED_ZEROS'=
was here
extern bool HONOR_SIGNED_ZEROS (const_tree);
include/real.h:248:1: warning: parameter names (without types) in functio=
n declaration
extern bool HONOR_SIGN_DEPENDENT_ROUNDING (machine_mode);
include/real.h:250:13: error: conflicting types for 'HONOR_SIGN_DEPENDENT=
_ROUNDING'
extern bool HONOR_SIGN_DEPENDENT_ROUNDING (const_rtx);
include/real.h:249:13: note: previous declaration of 'HONOR_SIGN_DEPENDEN=
T_ROUNDING' was here
extern bool HONOR_SIGN_DEPENDENT_ROUNDING (const_tree);
include/real.h:283:46: error: unknown type name 'format_helper'
extern void real_convert (REAL_VALUE_TYPE *, format_helper,
include/real.h:287:49: error: expected ')' before 'const'
extern bool exact_real_truncate (format_helper, const REAL_VALUE_TYPE *)=
include/real.h:296:24: error: unknown type name 'machine_mode'
size_t, int, machine_mode);
include/real.h:309:65: error: unknown type name 'format_helper'
extern void real_from_string3 (REAL_VALUE_TYPE *, const char *, format_h=
elper);
include/real.h:311:62: error: unknown type name 'format_helper'
extern long real_to_target (long *, const REAL_VALUE_TYPE *, format_help=
er);
include/real.h:314:10: error: unknown type name 'format_helper'
format_helper);
include/real.h:318:61: error: unknown type name 'format_helper'
extern bool real_nan (REAL_VALUE_TYPE *, const char *, int, format_helpe=
r);
include/real.h:320:50: error: unknown type name 'machine_mode'
extern void real_maxval (REAL_VALUE_TYPE *, int, machine_mode);
include/real.h:322:49: error: unknown type name 'format_helper'
extern void real_2expN (REAL_VALUE_TYPE *, int, format_helper);
include/real.h:61:25: error: expected ')' before 'struct'
#define REAL_VALUE_TYPE struct real_value
include/real.h:397:60: note: in expansion of macro 'REAL_VALUE_TYPE'
extern REAL_VALUE_TYPE real_value_truncate (format_helper, REAL_VALUE_TY=
PE);
include/real.h:402:1: warning: parameter names (without types) in functio=
n declaration
extern int significand_size (format_helper);
include/real.h:404:57: error: unknown type name 'format_helper'
extern REAL_VALUE_TYPE real_from_string2 (const char *, format_helper);
include/real.h:461:59: error: unknown type name 'machine_mode'
extern rtx const_double_from_real_value (REAL_VALUE_TYPE, machine_mode);=
include/real.h:464:48: note: in expansion of macro 'REAL_VALUE_TYPE'
extern bool exact_real_inverse (format_helper, REAL_VALUE_TYPE *);
include/real.h:469:1: warning: parameter names (without types) in functio=
n declaration
bool real_can_shorten_arithmetic (machine_mode, machine_mode);
include/real.h:478:43: error: unknown type name 'format_helper'
extern bool real_powi (REAL_VALUE_TYPE *, format_helper,
include/real.h:482:44: error: unknown type name 'format_helper'
extern void real_trunc (REAL_VALUE_TYPE *, format_helper,
include/real.h:484:44: error: unknown type name 'format_helper'
extern void real_floor (REAL_VALUE_TYPE *, format_helper,
include/real.h:486:43: error: unknown type name 'format_helper'
extern void real_ceil (REAL_VALUE_TYPE *, format_helper,
include/real.h:488:44: error: unknown type name 'format_helper'
extern void real_round (REAL_VALUE_TYPE *, format_helper,
include/real.h:495:54: error: unknown type name 'format_helper'
extern bool real_isinteger (const REAL_VALUE_TYPE *, format_helper);
include/real.h:505:8: error: unknown type name 'wide_int'
extern wide_int real_to_integer (const REAL_VALUE_TYPE *, bool *, int);
include/real.h:505:17: error: conflicting types for 'real_to_integer'
include/real.h:303:22: note: previous declaration of 'real_to_integer' wa=
s here
extern HOST_WIDE_INT real_to_integer (const REAL_VALUE_TYPE *);
include/real.h:506:51: error: unknown type name 'format_helper'
extern void real_from_integer (REAL_VALUE_TYPE *, format_helper,
include/real.h:507:17: warning: type defaults to 'int' in declaration of =
'wide_int_ref' [-Wimplicit-int]
const wide_int_ref &, signop);
include/real.h:507:30: error: expected ';', ',' or ')' before '&' token
inux-gnu/6.1.0/plugin/include/coretypes.h:347:0,
include/fixed-value.h:25:3: error: unknown type name 'double_int'
double_int data; /* Store data up to 2 wide integers. */
include/fixed-value.h:26:3: error: unknown type name 'machine_mode'
machine_mode mode; /* Use machine mode to know IBIT and FBIT. */
include/fixed-value.h:46:60: error: unknown type name 'machine_mode'
extern rtx const_fixed_from_fixed_value (FIXED_VALUE_TYPE, machine_mode)=
include/fixed-value.h:51:12: warning: parameter names (without types) in =
function declaration
machine_mode);
include/fixed-value.h:56:30: error: unknown type name 'double_int'
const_fixed_from_double_int (double_int payload,
include/fixed-value.h:57:30: error: unknown type name 'machine_mode'
machine_mode mode)
include/fixed-value.h:66:11: error: unknown type name 'machine_mode'
machine_mode);
include/fixed-value.h:72:48: error: unknown type name 'machine_mode'
extern bool fixed_convert (FIXED_VALUE_TYPE *, machine_mode,
include/fixed-value.h:76:57: error: unknown type name 'machine_mode'
extern bool fixed_convert_from_int (FIXED_VALUE_TYPE *, machine_mode,
include/fixed-value.h:77:9: error: unknown type name 'double_int'
double_int, bool, bool);
include/fixed-value.h:80:58: error: unknown type name 'machine_mode'
extern bool fixed_convert_from_real (FIXED_VALUE_TYPE *, machine_mode,
include/fixed-value.h:84:57: error: unknown type name 'machine_mode'
extern void real_convert_from_fixed (REAL_VALUE_TYPE *, machine_mode,
inux-gnu/6.1.0/plugin/include/hash-table.h:235:0,
inux-gnu/6.1.0/plugin/include/coretypes.h:348,
include/ggc.h:132:6: error: conflicting types for 'ggc_internal_alloc'
ggc_internal_alloc (size_t s CXX_MEM_STAT_INFO)
include/ggc.h:126:14: note: previous declaration of 'ggc_internal_alloc' =
was here
extern void *ggc_internal_alloc (size_t, void (*)(void *), size_t,
include/ggc.h: In function 'ggc_internal_alloc':
include/ggc.h:134:10: error: too many arguments to function 'ggc_internal=
_alloc'
return ggc_internal_alloc (s, NULL, 0, 1 PASS_MEM_STAT);
include/ggc.h:132:6: note: declared here
include/ggc.h: At top level:
include/ggc.h:146:1: error: conflicting types for 'ggc_internal_cleared_a=
lloc'
ggc_internal_cleared_alloc (size_t s CXX_MEM_STAT_INFO)
include/ggc.h:140:14: note: previous declaration of 'ggc_internal_cleared=
_alloc' was here
extern void *ggc_internal_cleared_alloc (size_t, void (*)(void *),
include/ggc.h: In function 'ggc_internal_cleared_alloc':
include/ggc.h:148:10: error: too many arguments to function 'ggc_internal=
_cleared_alloc'
return ggc_internal_cleared_alloc (s, NULL, 0, 1 PASS_MEM_STAT);
include/ggc.h:146:1: note: declared here
include/ggc.h:163:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/ggc.h:170:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/ggc.h:181:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/ggc.h:193:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/ggc.h:206:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/ggc.h:218:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/ggc.h:295:15: error: unknown type name 'gimple'
static inline gimple *
include/ggc.h: In function 'ggc_alloc_cleared_gimple_statement_stat':
include/ggc.h:298:11: error: 'gimple' undeclared (first use in this funct=
ion)
return (gimple *) ggc_internal_cleared_alloc (s PASS_MEM_STAT);
include/ggc.h:298:11: note: each undeclared identifier is reported only o=
nce for each function it appears in
include/ggc.h:298:19: error: expected expression before ')' token
include/ggc.h: In function 'gt_ggc_mx':
include/ggc.h:304:26: error: 'const_cast' undeclared (first use in this f=
unction)
ggc_test_and_set_mark (const_cast<char *> (s));
include/ggc.h:80:5: note: in definition of macro 'ggc_test_and_set_mark'
((EXPR) !=3D NULL && ((void *) (EXPR)) !=3D (void *) 1 && ! ggc_set_ma=
rk (EXPR))
include/ggc.h:304:37: error: expected expression before 'char'
rk (EXPR))
include/ggc.h:80:33: note: in definition of macro 'ggc_test_and_set_mark'=
rk (EXPR))
include/ggc.h:80:73: note: in definition of macro 'ggc_test_and_set_mark'=
rk (EXPR))
include/ggc.h: In function 'gt_pch_nx':
include/ggc.h:308:1: error: parameter name omitted
gt_pch_nx (const char *)
include/ggc.h:313:1: error: conflicting types for 'gt_ggc_mx'
gt_ggc_mx (int)
include/ggc.h:302:1: note: previous definition of 'gt_ggc_mx' was here
gt_ggc_mx (const char *s)
include/ggc.h:313:1: error: parameter name omitted
gt_ggc_mx (int)
include/ggc.h:318:1: error: conflicting types for 'gt_pch_nx'
gt_pch_nx (int)
include/ggc.h:308:1: note: previous definition of 'gt_pch_nx' was here
include/ggc.h:318:1: error: parameter name omitted
gt_pch_nx (int)
include/ggc.h:323:1: error: conflicting types for 'gt_pch_nx'
gt_pch_nx (unsigned int)
include/ggc.h:318:1: note: previous definition of 'gt_pch_nx' was here
gt_pch_nx (int)
include/ggc.h:323:1: error: parameter name omitted
inux-gnu/6.1.0/plugin/include/hash-table.h:236:0,
include/vec.h: At top level:
include/vec.h:197:8: error: field 'register_overhead' declared as a funct=
ion
void register_overhead (void *, size_t, size_t CXX_MEM_STAT_INFO);
include/vec.h:198:8: error: field 'release_overhead' declared as a functi=
on
void release_overhead (void *, size_t, bool CXX_MEM_STAT_INFO);
include/vec.h:199:3: error: expected specifier-qualifier-list before 'sta=
tic'
static unsigned calculate_allocation (vec_prefix *, unsigned, bool);
include/vec.h:225:11: error: expected '=3D', ',', ';', 'asm' or '__attrib=
vec_prefix::calculate_allocation (vec_prefix *pfx, unsigned reserve,
include/vec.h:235:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
template<typename, typename, typename> struct vec;
include/vec.h:258:3: error: expected specifier-qualifier-list before 'typ=
edef'
typedef vl_ptr default_layout;
include/vec.h:274:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:298:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:321:3: error: expected specifier-qualifier-list before 'typ=
edef'
typedef vl_embed default_layout;
include/vec.h:334:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
template<typename T, typename A>
include/vec.h:349:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:387:21: error: expected identifier or '(' before ':' token
struct va_gc_atomic : va_gc
include/vec.h:403:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:416:3: error: expected specifier-qualifier-list before 'tem=
plate'
template <typename T, typename A, typename L>
include/vec.h:419:8: error: unknown type name 'vnull'
extern vnull vNULL;
include/vec.h:448:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:511:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:520:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:529:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:538:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:548:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:559:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:571:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:582:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:591:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:603:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:614:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:627:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:643:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:654:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:665:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:675:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:684:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:702:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:710:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:721:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:736:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:751:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:777:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:796:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:815:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:828:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:841:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:854:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:866:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:878:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:894:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:907:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:919:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:933:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:945:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:982:9: error: expected '=3D', ',', ';', 'asm' or '__attribu=
include/vec.h:1021:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1033:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1046:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1058:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1070:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1079:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1090:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1099:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1107:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1145:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1226:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
template<typename T, size_t N =3D 0>
include/vec.h:1248:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1262:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1273:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1284:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1304:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1327:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1366:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1386:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1422:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1435:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1447:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1468:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1482:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1499:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1511:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1522:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1533:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1548:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1566:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1579:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1592:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1604:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1615:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1628:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1639:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1650:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1661:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1673:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1689:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1698:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
include/vec.h:1707:9: error: expected '=3D', ',', ';', 'asm' or '__attrib=
inux-gnu/6.1.0/plugin/include/hash-table.h:238:0,
include/inchash.h:34:1: error: unknown type name 'namespace'
namespace inchash
include/inchash.h:35:1: error: expected '=3D', ',', ';', 'asm' or '__attr=
inux-gnu/6.1.0/plugin/include/hash-table.h:240:0,
include/hash-traits.h:25:10: error: expected '=3D', ',', ';', 'asm' or '_=
_attribute__' before '<' token
template <typename Type>
include/hash-traits.h:34:10: error: expected '=3D', ',', ';', 'asm' or '_=
include/hash-traits.h:43:10: error: expected '=3D', ',', ';', 'asm' or '_=
include/hash-traits.h:52:10: error: expected '=3D', ',', ';', 'asm' or '_=
include/hash-traits.h:61:10: error: expected '=3D', ',', ';', 'asm' or '_=
include/hash-traits.h:70:10: error: expected '=3D', ',', ';', 'asm' or '_=
include/hash-traits.h:82:10: error: expected '=3D', ',', ';', 'asm' or '_=
template <typename Type, Type Empty, Type Deleted =3D Empty>
include/hash-traits.h:96:10: error: expected '=3D', ',', ';', 'asm' or '_=
template <typename Type, Type Empty, Type Deleted>
include/hash-traits.h:103:10: error: expected '=3D', ',', ';', 'asm' or '=
__attribute__' before '<' token
include/hash-traits.h:110:10: error: expected '=3D', ',', ';', 'asm' or '=
include/hash-traits.h:118:10: error: expected '=3D', ',', ';', 'asm' or '=
include/hash-traits.h:125:10: error: expected '=3D', ',', ';', 'asm' or '=
include/hash-traits.h:132:10: error: expected '=3D', ',', ';', 'asm' or '=
include/hash-traits.h:143:10: error: expected '=3D', ',', ';', 'asm' or '=
include/hash-traits.h:158:10: error: expected '=3D', ',', ';', 'asm' or '=
include/hash-traits.h:167:10: error: expected '=3D', ',', ';', 'asm' or '=
include/hash-traits.h:175:10: error: expected '=3D', ',', ';', 'asm' or '=
include/hash-traits.h:182:10: error: expected '=3D', ',', ';', 'asm' or '=
include/hash-traits.h:189:10: error: expected '=3D', ',', ';', 'asm' or '=
include/hash-traits.h:196:10: error: expected '=3D', ',', ';', 'asm' or '=
include/hash-traits.h:206:20: error: expected identifier or '(' before ':=
' token
struct string_hash : pointer_hash <const char>
include/hash-traits.h:213:12: error: expected '=3D', ',', ';', 'asm' or '=
__attribute__' before ':' token
string_hash::hash (const char *id)
include/hash-traits.h:219:12: error: expected '=3D', ',', ';', 'asm' or '=
string_hash::equal (const char *id1, const char *id2)
include/hash-traits.h:226:9: error: expected '=3D', ',', ';', 'asm' or '_=
include/hash-traits.h:255:9: error: expected '=3D', ',', ';', 'asm' or '_=
include/hash-traits.h:271:10: error: expected '=3D', ',', ';', 'asm' or '=
include/hash-traits.h:277:10: error: expected '=3D', ',', ';', 'asm' or '=
include/hash-traits.h:283:10: error: expected '=3D', ',', ';', 'asm' or '=
include/hash-traits.h:289:10: error: expected '=3D', ',', ';', 'asm' or '=
include/hash-traits.h:296:10: error: expected '=3D', ',', ';', 'asm' or '=
include/hash-traits.h:302:27: error: expected identifier or '(' before ':=
' token
struct nofree_string_hash : string_hash, typed_noop_remove <const char *=
include/hash-traits.h:304:10: error: expected '=3D', ',', ';', 'asm' or '=
template <typename T> struct default_hash_traits : T {};
include/hash-traits.h:306:10: error: expected '=3D', ',', ';', 'asm' or '=
inux-gnu/6.1.0/plugin/include/hash-table.h:241:0,
include/hash-map-traits.h:31:10: error: expected '=3D', ',', ';', 'asm' o=
r '__attribute__' before '<' token
template <typename H, typename Value>
include/hash-map-traits.h:44:10: error: expected '=3D', ',', ';', 'asm' o=
include/hash-map-traits.h:51:10: error: expected '=3D', ',', ';', 'asm' o=
include/hash-map-traits.h:59:10: error: expected '=3D', ',', ';', 'asm' o=
include/hash-map-traits.h:68:10: error: expected '=3D', ',', ';', 'asm' o=
include/hash-map-traits.h:76:10: error: expected '=3D', ',', ';', 'asm' o=
include/hash-map-traits.h:84:10: error: expected '=3D', ',', ';', 'asm' o=
include/hash-map-traits.h:92:10: error: expected '=3D', ',', ';', 'asm' o=
include/hash-map-traits.h:105:10: error: expected '=3D', ',', ';', 'asm' =
or '__attribute__' before '<' token
template <typename Value>
include/hash-map-traits.h:115:10: error: expected '=3D', ',', ';', 'asm' =
include/hash-map-traits.h:123:10: error: expected '=3D', ',', ';', 'asm' =
include/hash-map-traits.h:131:10: error: expected '=3D', ',', ';', 'asm' =
include/hash-map-traits.h:139:10: error: expected '=3D', ',', ';', 'asm' =
include/hash-map-traits.h:147:10: error: expected '=3D', ',', ';', 'asm' =
include/hash-map-traits.h:159:10: error: expected '=3D', ',', ';', 'asm' =
template <typename Key, typename Value>
include/hash-map-traits.h:167:10: error: expected '=3D', ',', ';', 'asm' =
include/hash-map-traits.h:174:10: error: expected '=3D', ',', ';', 'asm' =
inux-gnu/6.1.0/plugin/include/coretypes.h:348:0,
include/hash-table.h:243:9: error: expected '=3D', ',', ';', 'asm' or '__=
template<typename, typename, typename> class hash_map;
include/hash-table.h:244:9: error: expected '=3D', ',', ';', 'asm' or '__=
template<typename, typename> class hash_set;
include/hash-table.h:249:10: error: expected '=3D', ',', ';', 'asm' or '_=
include/hash-table.h:259:10: error: expected '=3D', ',', ';', 'asm' or '_=
include/hash-table.h:269:10: error: expected '=3D', ',', ';', 'asm' or '_=
include/hash-table.h:341:1: error: unknown type name 'class'
class mem_usage;
include/hash-table.h:356:10: error: expected '=3D', ',', ';', 'asm' or '_=
template <typename Descriptor,
inux-gnu/6.1.0/plugin/include/hash-table.h:560:0,
include/mem-stats.h:25:9: error: expected '=3D', ',', ';', 'asm' or '__at=
template<typename Key, typename Value,
include/mem-stats.h:37:3: error: expected specifier-qualifier-list before=
'inline'
inline
include/mem-stats.h:129:3: error: expected specifier-qualifier-list befor=
e 'mem_usage'
mem_usage (): m_allocated (0), m_times (0), m_peak (0), m_instances (1=
include/mem-stats.h:250:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <class T>
include/mem-stats.h:261:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <class T>
include/mem-stats.h:382:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <class T>
include/mem-stats.h:391:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <class T>
include/mem-stats.h:401:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <class T>
include/mem-stats.h:432:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <class T>
include/mem-stats.h:448:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <class T>
include/mem-stats.h:470:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <class T>
include/mem-stats.h:483:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <class T>
include/mem-stats.h:500:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <class T>
include/mem-stats.h:522:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <class T>
include/mem-stats.h:536:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <class T>
include/mem-stats.h:547:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <class T>
include/mem-stats.h:568:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <class T>
include/mem-stats.h:593:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <class T>
include/mem-stats.h:612:10: error: expected '=3D', ',', ';', 'asm' or '__=
template <class T>
inux-gnu/6.1.0/plugin/include/hash-table.h:561:0,
include/hash-map.h:24:9: error: expected '=3D', ',', ';', 'asm' or '__att=
template<typename KeyId, typename Value,
include/hash-map.h:247:9: error: expected '=3D', ',', ';', 'asm' or '__at=
template<typename K, typename V, typename H>
include/hash-map.h:254:9: error: expected '=3D', ',', ';', 'asm' or '__at=
include/hash-map.h:261:9: error: expected '=3D', ',', ';', 'asm' or '__at=
include/hash-table.h:563:29: error: expected '=3D', ',', ';', 'asm' or '_=
extern mem_alloc_description<mem_usage> hash_table_usage;
include/hash-table.h:568:9: error: expected '=3D', ',', ';', 'asm' or '__=
template<typename Descriptor, template<typename Type> class Allocator>
include/hash-table.h:590:9: error: expected '=3D', ',', ';', 'asm' or '__=
include/hash-table.h:619:9: error: expected '=3D', ',', ';', 'asm' or '__=
include/hash-table.h:639:9: error: expected '=3D', ',', ';', 'asm' or '__=
include/hash-table.h:667:9: error: expected '=3D', ',', ';', 'asm' or '__=
include/hash-table.h:701:9: error: expected '=3D', ',', ';', 'asm' or '__=
include/hash-table.h:762:9: error: expected '=3D', ',', ';', 'asm' or '__=
include/hash-table.h:799:9: error: expected '=3D', ',', ';', 'asm' or '__=
include/hash-table.h:816:9: error: expected '=3D', ',', ';', 'asm' or '__=
include/hash-table.h:853:9: error: expected '=3D', ',', ';', 'asm' or '__=
include/hash-table.h:914:9: error: expected '=3D', ',', ';', 'asm' or '__=
include/hash-table.h:933:9: error: expected '=3D', ',', ';', 'asm' or '__=
include/hash-table.h:959:10: error: expected '=3D', ',', ';', 'asm' or '_=
include/hash-table.h:977:9: error: expected '=3D', ',', ';', 'asm' or '__=
include/hash-table.h:993:9: error: expected '=3D', ',', ';', 'asm' or '__=
include/hash-table.h:1014:9: error: expected '=3D', ',', ';', 'asm' or '_=
template<typename E>
include/hash-table.h:1033:9: error: expected '=3D', ',', ';', 'asm' or '_=
template<typename D>
include/hash-table.h:1051:9: error: expected '=3D', ',', ';', 'asm' or '_=
include/hash-table.h:1068:9: error: expected '=3D', ',', ';', 'asm' or '_=
include/hash-table.h:1075:9: error: expected '=3D', ',', ';', 'asm' or '_=
template<typename H>
inux-gnu/6.1.0/plugin/include/coretypes.h:349:0,
include/hash-set.h:24:9: error: expected '=3D', ',', ';', 'asm' or '__att=
template<typename KeyId, typename Traits =3D default_hash_traits<KeyId> =
include/hash-set.h:128:9: error: expected '=3D', ',', ';', 'asm' or '__at=
template<typename K, typename H>
include/hash-set.h:135:9: error: expected '=3D', ',', ';', 'asm' or '__at=
include/hash-set.h:142:9: error: expected '=3D', ',', ';', 'asm' or '__at=
inux-gnu/6.1.0/plugin/include/input.h:24:0,
inux-gnu/6.1.0/plugin/include/coretypes.h:350,
include/line-map.h:281:3: error: expected specifier-qualifier-list before=
'static'
static source_range from_location (source_location loc)
include/line-map.h:345:43: error: expected identifier or '(' before ':' t=
oken
struct GTY((tag ("1"))) line_map_ordinary : public line_map {
include/line-map.h:391:40: error: expected identifier or '(' before ':' t=
oken
struct GTY((tag ("2"))) line_map_macro : public line_map {
include/line-map.h:498:8: error: unknown type name 'line_map_ordinary'
inline line_map_ordinary *
include/line-map.h: In function 'linemap_check_ordinary':
include/line-map.h:502:11: error: 'line_map_ordinary' undeclared (first u=
se in this function)
return (line_map_ordinary *)map;
include/line-map.h:502:30: error: expected expression before ')' token
include/line-map.h: At top level:
include/line-map.h:509:14: error: unknown type name 'line_map_ordinary'
inline const line_map_ordinary *
include/line-map.h:510:1: error: conflicting types for 'linemap_check_ord=
inary'
linemap_check_ordinary (const struct line_map *map)
include/line-map.h:499:1: note: previous definition of 'linemap_check_ord=
inary' was here
linemap_check_ordinary (struct line_map *map)
include/line-map.h:513:17: error: unknown type name 'line_map_ordinary'
return (const line_map_ordinary *)map;
include/line-map.h:519:8: error: unknown type name 'line_map_macro'
inline line_map_macro *linemap_check_macro (line_map *map)
include/line-map.h:519:45: error: unknown type name 'line_map'
include/line-map.h:528:14: error: unknown type name 'line_map_macro'
inline const line_map_macro *
include/line-map.h:529:28: error: unknown type name 'line_map'
linemap_check_macro (const line_map *map)
include/line-map.h: In function 'linemap_check_macro':
include/line-map.h:531:50: warning: passing argument 1 of 'linemap_macro_=
expansion_map_p' from incompatible pointer type [-Wincompatible-pointer-t=
ypes]
linemap_assert (linemap_macro_expansion_map_p (map));
include/line-map.h:485:44: note: in definition of macro 'linemap_assert'
#define linemap_assert(EXPR) ((void)(0 && (EXPR)))
include/line-map.h:492:1: note: expected 'const struct line_map *' but ar=
gument is of type 'const int *'
linemap_macro_expansion_map_p (const struct line_map *);
include/line-map.h:532:17: error: unknown type name 'line_map_macro'
return (const line_map_macro *)map;
include/line-map.h:538:27: error: unknown type name 'line_map'
MAP_START_LOCATION (const line_map *map)
include/line-map.h: In function 'MAP_START_LOCATION':
include/line-map.h:540:13: error: request for member 'start_location' in =
something not a structure or union
return map->start_location;
include/line-map.h:546:42: error: unknown type name 'line_map_ordinary'
ORDINARY_MAP_STARTING_LINE_NUMBER (const line_map_ordinary *ord_map)
include/line-map.h: In function 'ORDINARY_MAP_STARTING_LINE_NUMBER':
include/line-map.h:548:17: error: request for member 'to_line' in somethi=
return ord_map->to_line;
include/line-map.h:557:41: error: unknown type name 'line_map_ordinary'
ORDINARY_MAP_INCLUDER_FILE_INDEX (const line_map_ordinary *ord_map)
include/line-map.h: In function 'ORDINARY_MAP_INCLUDER_FILE_INDEX':
/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/gcc-6.1.0-7cl=
jeqxjfpkacgtkxus4p55nsms53dnv/lib64/gcc/x86_64-pc-linux-gnu/6.1.0/plugin/=
include/line-map.h:559:17: error: request for member 'included_from' in s=
return ord_map->included_from;
include/line-map.h:568:40: error: unknown type name 'line_map_ordinary'
ORDINARY_MAP_IN_SYSTEM_HEADER_P (const line_map_ordinary *ord_map)
include/line-map.h: In function 'ORDINARY_MAP_IN_SYSTEM_HEADER_P':
include/line-map.h:570:17: error: request for member 'sysp' in something =
return ord_map->sysp;
include/line-map.h:576:31: error: unknown type name 'line_map_ordinary'
ORDINARY_MAP_FILE_NAME (const line_map_ordinary *ord_map)
include/line-map.h: In function 'ORDINARY_MAP_FILE_NAME':
include/line-map.h:578:17: error: request for member 'to_file' in somethi=
return ord_map->to_file;
include/line-map.h:583:8: error: unknown type name 'cpp_hashnode'
inline cpp_hashnode *
include/line-map.h:584:24: error: unknown type name 'line_map_macro'
MACRO_MAP_MACRO (const line_map_macro *macro_map)
include/line-map.h: In function 'MACRO_MAP_MACRO':
include/line-map.h:586:19: error: request for member 'macro' in something=
return macro_map->macro;
include/line-map.h:593:35: error: unknown type name 'line_map_macro'
MACRO_MAP_NUM_MACRO_TOKENS (const line_map_macro *macro_map)
include/line-map.h: In function 'MACRO_MAP_NUM_MACRO_TOKENS':
include/line-map.h:595:19: error: request for member 'n_tokens' in someth=
return macro_map->n_tokens;
include/line-map.h:602:28: error: unknown type name 'line_map_macro'
MACRO_MAP_LOCATIONS (const line_map_macro *macro_map)
include/line-map.h: In function 'MACRO_MAP_LOCATIONS':
include/line-map.h:604:19: error: request for member 'macro_locations' in=
return macro_map->macro_locations;
include/line-map.h:610:43: error: unknown type name 'line_map_macro'
MACRO_MAP_EXPANSION_POINT_LOCATION (const line_map_macro *macro_map)
include/line-map.h: In function 'MACRO_MAP_EXPANSION_POINT_LOCATION':
include/line-map.h:612:19: error: request for member 'expansion' in somet=
return macro_map->expansion;
include/line-map.h:626:3: error: unknown type name 'line_map_ordinary'
line_map_ordinary * GTY ((length ("%h.used"))) maps;
include/line-map.h:641:3: error: unknown type name 'line_map_macro'
line_map_macro * GTY ((length ("%h.used"))) maps;
include/line-map.h:657:3: error: unknown type name 'source_range'
source_range src_range;
include/line-map.h:683:3: error: unknown type name 'maps_info_ordinary'
maps_info_ordinary info_ordinary;
include/line-map.h:685:3: error: unknown type name 'maps_info_macro'
maps_info_macro info_macro;
include/line-map.h:730:27: error: unknown type name 'line_maps'
LINEMAPS_ALLOCATED (const line_maps *set, bool map_kind)
include/line-map.h: In function 'LINEMAPS_ALLOCATED':
include/line-map.h:733:15: error: request for member 'info_macro' in some=
return set->info_macro.allocated;
include/line-map.h:735:15: error: request for member 'info_ordinary' in s=
return set->info_ordinary.allocated;
include/line-map.h:740:21: error: expected identifier or '(' before '&' t=
oken
inline unsigned int &
include/line-map.h:752:22: error: unknown type name 'line_maps'
LINEMAPS_USED (const line_maps *set, bool map_kind)
include/line-map.h: In function 'LINEMAPS_USED':
include/line-map.h:755:15: error: request for member 'info_macro' in some=
return set->info_macro.used;
include/line-map.h:757:15: error: request for member 'info_ordinary' in s=
return set->info_ordinary.used;
include/line-map.h:762:21: error: expected identifier or '(' before '&' t=
oken
include/line-map.h:775:23: error: unknown type name 'line_maps'
LINEMAPS_CACHE (const line_maps *set, bool map_kind)
include/line-map.h: In function 'LINEMAPS_CACHE':
include/line-map.h:778:15: error: request for member 'info_macro' in some=
return set->info_macro.cache;
include/line-map.h:780:15: error: request for member 'info_ordinary' in s=
return set->info_ordinary.cache;
include/line-map.h:785:21: error: expected identifier or '(' before '&' t=
oken
include/line-map.h:795:8: error: unknown type name 'line_map'
inline line_map *
include/line-map.h:796:24: error: unknown type name 'line_maps'
LINEMAPS_MAP_AT (const line_maps *set, bool map_kind, int index)
include/line-map.h: In function 'LINEMAPS_MAP_AT':
include/line-map.h:799:16: error: request for member 'info_macro' in some=
return &set->info_macro.maps[index];
include/line-map.h:801:16: error: request for member 'info_ordinary' in s=
return &set->info_ordinary.maps[index];
include/line-map.h:807:8: error: unknown type name 'line_map'
inline line_map *
include/line-map.h:808:26: error: unknown type name 'line_maps'
LINEMAPS_LAST_MAP (const line_maps *set, bool map_kind)
include/line-map.h:817:8: error: unknown type name 'line_map'
inline line_map *
include/line-map.h:818:36: error: unknown type name 'line_maps'
LINEMAPS_LAST_ALLOCATED_MAP (const line_maps *set, bool map_kind)
include/line-map.h:826:8: error: unknown type name 'line_map_ordinary'
include/line-map.h:827:31: error: unknown type name 'line_maps'
LINEMAPS_ORDINARY_MAPS (const line_maps *set)
include/line-map.h: In function 'LINEMAPS_ORDINARY_MAPS':
include/line-map.h:829:13: error: request for member 'info_ordinary' in s=
return set->info_ordinary.maps;
include/line-map.h:833:8: error: unknown type name 'line_map_ordinary'
include/line-map.h:834:33: error: unknown type name 'line_maps'
LINEMAPS_ORDINARY_MAP_AT (const line_maps *set, int index)
include/line-map.h: In function 'LINEMAPS_ORDINARY_MAP_AT':
include/line-map.h:837:44: error: request for member 'info_ordinary' in s=
linemap_assert ((unsigned int)index < set->info_ordinary.used);
include/line-map.h:838:14: error: request for member 'info_ordinary' in s=
include/line-map.h:844:36: error: unknown type name 'line_maps'
LINEMAPS_ORDINARY_ALLOCATED (const line_maps *set)
include/line-map.h:851:31: error: unknown type name 'line_maps'
LINEMAPS_ORDINARY_USED (const line_maps *set)
include/line-map.h:859:32: error: unknown type name 'line_maps'
LINEMAPS_ORDINARY_CACHE (const line_maps *set)
include/line-map.h:866:21: error: expected identifier or '(' before '&' t=
oken
include/line-map.h:874:8: error: unknown type name 'line_map_ordinary'
include/line-map.h:875:35: error: unknown type name 'line_maps'
LINEMAPS_LAST_ORDINARY_MAP (const line_maps *set)
include/line-map.h: In function 'LINEMAPS_LAST_ORDINARY_MAP':
include/line-map.h:877:11: error: 'line_map_ordinary' undeclared (first u=
return (line_map_ordinary *)LINEMAPS_LAST_MAP (set, false);
include/line-map.h:877:30: error: expected expression before ')' token
include/line-map.h:882:8: error: unknown type name 'line_map_ordinary'
include/line-map.h:883:45: error: unknown type name 'line_maps'
LINEMAPS_LAST_ALLOCATED_ORDINARY_MAP (const line_maps *set)
include/line-map.h: In function 'LINEMAPS_LAST_ALLOCATED_ORDINARY_MAP':
include/line-map.h:885:11: error: 'line_map_ordinary' undeclared (first u=
return (line_map_ordinary *)LINEMAPS_LAST_ALLOCATED_MAP (set, false);
include/line-map.h:885:30: error: expected expression before ')' token
include/line-map.h:890:8: error: unknown type name 'line_map_macro'
include/line-map.h:891:28: error: unknown type name 'line_maps'
LINEMAPS_MACRO_MAPS (const line_maps *set)
include/line-map.h: In function 'LINEMAPS_MACRO_MAPS':
include/line-map.h:893:13: error: request for member 'info_macro' in some=
return set->info_macro.maps;
include/line-map.h:897:8: error: unknown type name 'line_map_macro'
include/line-map.h:898:30: error: unknown type name 'line_maps'
LINEMAPS_MACRO_MAP_AT (const line_maps *set, int index)
include/line-map.h: In function 'LINEMAPS_MACRO_MAP_AT':
include/line-map.h:901:44: error: request for member 'info_macro' in some=
linemap_assert ((unsigned int)index < set->info_macro.used);
include/line-map.h:902:14: error: request for member 'info_macro' in some=
include/line-map.h:908:33: error: unknown type name 'line_maps'
LINEMAPS_MACRO_ALLOCATED (const line_maps *set)
include/line-map.h:915:28: error: unknown type name 'line_maps'
LINEMAPS_MACRO_USED (const line_maps *set)
include/line-map.h:923:29: error: unknown type name 'line_maps'
LINEMAPS_MACRO_CACHE (const line_maps *set)
include/line-map.h:930:21: error: expected identifier or '(' before '&' t=
oken
include/line-map.h:937:8: error: unknown type name 'line_map_macro'
include/line-map.h:938:32: error: unknown type name 'line_maps'
LINEMAPS_LAST_MACRO_MAP (const line_maps *set)
include/line-map.h: In function 'LINEMAPS_LAST_MACRO_MAP':
include/line-map.h:940:11: error: 'line_map_macro' undeclared (first use =
in this function)
return (line_map_macro *)LINEMAPS_LAST_MAP (set, true);
include/line-map.h:940:27: error: expected expression before ')' token
include/line-map.h:946:39: error: unknown type name 'line_maps'
LINEMAPS_MACRO_LOWEST_LOCATION (const line_maps *set)
include/line-map.h:954:8: error: unknown type name 'line_map_macro'
include/line-map.h:955:42: error: unknown type name 'line_maps'
LINEMAPS_LAST_ALLOCATED_MACRO_MAP (const line_maps *set)
include/line-map.h: In function 'LINEMAPS_LAST_ALLOCATED_MACRO_MAP':
include/line-map.h:957:11: error: 'line_map_macro' undeclared (first use =
in this function)
return (line_map_macro *)LINEMAPS_LAST_ALLOCATED_MAP (set, true);
include/line-map.h:957:27: error: expected expression before ')' token
include/line-map.h:963:13: error: unknown type name 'source_range'
source_range,
include/line-map.h:969:8: error: unknown type name 'source_range'
extern source_range get_range_from_loc (line_maps *set, source_location =
loc);
include/line-map.h:969:41: error: unknown type name 'line_maps'
loc);
include/line-map.h:983:18: error: unknown type name 'line_maps'
pure_location_p (line_maps *set, source_location loc);
include/line-map.h:990:10: error: unknown type name 'source_range'
source_range src_range,
include/line-map.h:1049:47: error: unknown type name 'line_map_macro'
const char* linemap_map_get_macro_name (const line_map_macro *);
include/line-map.h:1075:4: error: unknown type name 'line_maps'
(line_maps *set, const line_map_macro *macro_map, source_location loca=
tion);
include/line-map.h:1075:26: error: unknown type name 'line_map_macro'
tion);
include/line-map.h:1084:20: error: unknown type name 'line_map_ordinary'
SOURCE_LINE (const line_map_ordinary *ord_map, source_location loc)
include/line-map.h: In function 'SOURCE_LINE':
include/line-map.h:1086:25: error: request for member 'start_location' in=
return ((loc - ord_map->start_location)
include/line-map.h:1087:14: error: request for member 'm_column_and_range=
_bits' in something not a structure or union
>> ord_map->m_column_and_range_bits) + ord_map->to_line;
include/line-map.h:1087:50: error: request for member 'to_line' in someth=
include/line-map.h:1092:22: error: unknown type name 'line_map_ordinary'
SOURCE_COLUMN (const line_map_ordinary *ord_map, source_location loc)
include/line-map.h: In function 'SOURCE_COLUMN':
include/line-map.h:1094:25: error: request for member 'start_location' in=
include/line-map.h:1095:20: error: request for member 'm_column_and_range=
& ((1 << ord_map->m_column_and_range_bits) - 1)) >> ord_map->m_range_=
bits;
include/line-map.h:1095:63: error: request for member 'm_range_bits' in s=
bits;
include/line-map.h:1101:34: error: unknown type name 'line_map_ordinary'
LAST_SOURCE_LINE_LOCATION (const line_map_ordinary *map)
include/line-map.h: In function 'LAST_SOURCE_LINE_LOCATION':
include/line-map.h:1103:19: error: request for member 'start_location' in=
return (((map[1].start_location - 1
include/line-map.h:1104:11: error: request for member 'start_location' in=
- map->start_location)
include/line-map.h:1105:18: error: request for member 'm_column_and_range=
& ~((1 << map->m_column_and_range_bits) - 1))
include/line-map.h:1106:9: error: request for member 'start_location' in =
include/line-map.h:1113:25: error: unknown type name 'line_map_ordinary'
LAST_SOURCE_LINE (const line_map_ordinary *map)
include/line-map.h:1121:27: error: unknown type name 'line_map_ordinary'
LAST_SOURCE_COLUMN (const line_map_ordinary *map)
include/line-map.h:1129:8: error: unknown type name 'line_map_ordinary'
include/line-map.h:1130:45: error: unknown type name 'line_map_ordinary'
INCLUDED_FROM (struct line_maps *set, const line_map_ordinary *ord_map)
include/line-map.h: In function 'INCLUDED_FROM':
include/line-map.h:1132:19: error: request for member 'included_from' in =
return ((ord_map->included_from =3D=3D -1)
include/line-map.h:1134:44: error: request for member 'included_from' in =
: LINEMAPS_ORDINARY_MAP_AT (set, ord_map->included_from));
include/line-map.h:1134:32: warning: passing argument 1 of 'LINEMAPS_ORDI=
NARY_MAP_AT' from incompatible pointer type [-Wincompatible-pointer-types=
include/line-map.h:834:1: note: expected 'const int *' but argument is of=
type 'struct line_maps *'
include/line-map.h:1140:20: error: unknown type name 'line_map_ordinary'
MAIN_FILE_P (const line_map_ordinary *ord_map)
include/line-map.h: In function 'MAIN_FILE_P':
include/line-map.h:1142:17: error: request for member 'included_from' in =
return ord_map->included_from < 0;
include/line-map.h:1155:39: error: unknown type name 'line_maps'
linemap_position_for_line_and_column (line_maps *set,
include/line-map.h:1156:17: error: unknown type name 'line_map_ordinary'
const line_map_ordinary *,
include/line-map.h:1169:21: error: unknown type name 'line_map_ordinary'
LINEMAP_FILE (const line_map_ordinary *ord_map)
include/line-map.h: In function 'LINEMAP_FILE':
include/line-map.h:1171:17: error: request for member 'to_file' in someth=
include/line-map.h:1176:21: error: unknown type name 'line_map_ordinary'
LINEMAP_LINE (const line_map_ordinary *ord_map)
include/line-map.h: In function 'LINEMAP_LINE':
include/line-map.h:1178:17: error: request for member 'to_line' in someth=
include/line-map.h:1186:21: error: unknown type name 'line_map_ordinary'
LINEMAP_SYSP (const line_map_ordinary *ord_map)
include/line-map.h: In function 'LINEMAP_SYSP':
include/line-map.h:1188:17: error: request for member 'sysp' in something=
include/line-map.h:1265:1: error: unknown type name 'class'
class fixit_hint;
include/line-map.h:1266:3: error: unknown type name 'class'
class fixit_insert;
include/line-map.h:1267:3: error: unknown type name 'class'
class fixit_remove;
include/line-map.h:1268:3: error: unknown type name 'class'
class fixit_replace;
include/line-map.h:1342:1: error: unknown type name 'class'
class rich_location
include/line-map.h:1343:1: error: expected '=3D', ',', ';', 'asm' or '__a=
ttribute__' before '{' token
include/line-map.h:1412:1: error: unknown type name 'class'
class fixit_hint
include/line-map.h:1413:1: error: expected '=3D', ',', ';', 'asm' or '__a=
include/line-map.h:1423:1: error: unknown type name 'class'
class fixit_insert : public fixit_hint
include/line-map.h:1423:20: error: expected '=3D', ',', ';', 'asm' or '__=
include/line-map.h:1442:1: error: unknown type name 'class'
class fixit_remove : public fixit_hint
include/line-map.h:1442:20: error: expected '=3D', ',', ';', 'asm' or '__=
include/line-map.h:1457:1: error: unknown type name 'class'
class fixit_replace : public fixit_hint
include/line-map.h:1457:21: error: expected '=3D', ',', ';', 'asm' or '__=
include/line-map.h:1539:14: error: unknown type name 'line_map_ordinary'
const line_map_ordinary **loc_map);
In file included from /home/lschnorr/spack-orion/opt/spack/linux-x86_64/g=
cc-6.1.1/gcc-6.1.0-7cljeqxjfpkacgtkxus4p55nsms53dnv/lib64/gcc/x86_64-pc-l=
inux-gnu/6.1.0/plugin/include/coretypes.h:350:0,
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:29,
from conftest.c:100:
include/input.h:36:13: error: variably modified 'builtins_location_check'=
at file scope
extern char builtins_location_check[(BUILTINS_LOCATION
inux-gnu/6.1.0/plugin/include/coretypes.h:351:0,
include/is-a.h:145:10: error: expected '=3D', ',', ';', 'asm' or '__attri=
include/is-a.h:163:10: error: expected '=3D', ',', ';', 'asm' or '__attri=
include/is-a.h:178:10: error: expected '=3D', ',', ';', 'asm' or '__attri=
template <typename T, typename U>
include/is-a.h:188:10: error: expected '=3D', ',', ';', 'asm' or '__attri=
include/is-a.h:199:10: error: expected '=3D', ',', ';', 'asm' or '__attri=
include/is-a.h:215:10: error: expected '=3D', ',', ';', 'asm' or '__attri=
inux-gnu/6.1.0/plugin/include/coretypes.h:352:0,
include/memory-block.h:26:1: error: unknown type name 'class'
class memory_block_pool
include/memory-block.h:27:1: error: expected '=3D', ',', ';', 'asm' or '_=
_attribute__' before '{' token
include/memory-block.h:53:18: error: expected '=3D', ',', ';', 'asm' or '=
memory_block_pool::allocate ()
include/memory-block.h:66:18: error: expected '=3D', ',', ';', 'asm' or '=
memory_block_pool::release (void *uncast_block)
inux-gnu/6.1.0/plugin/include/tm.h:22:0,
inux-gnu/6.1.0/plugin/include/backend.h:28,
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:30,
include/options.h:5162:54: error: unknown type name 'cl_optimization'
extern void cl_optimization_print_diff (FILE *, int, cl_optimization *pt=
r1, cl_optimization *ptr2);
include/options.h:5162:77: error: unknown type name 'cl_optimization'
include/options.h:5174:55: error: unknown type name 'cl_target_option'
extern void cl_target_option_print_diff (FILE *, int, cl_target_option *=
ptr1, cl_target_option *ptr2);
include/options.h:5174:79: error: unknown type name 'cl_target_option'
include/options.h:5194:28: error: unknown type name 'diagnostic_context'
diagnostic_context *dc);
include/options.h:5202:28: error: unknown type name 'diagnostic_context'
include/options.h:5210:28: error: unknown type name 'diagnostic_context'
include/options.h:5218:28: error: unknown type name 'diagnostic_context'
include/options.h:5226:28: error: unknown type name 'diagnostic_context'
include/options.h:5234:28: error: unknown type name 'diagnostic_context'
include/options.h:5242:28: error: unknown type name 'diagnostic_context'
include/options.h:5250:28: error: unknown type name 'diagnostic_context'
include/options.h:5258:28: error: unknown type name 'diagnostic_context'
include/options.h:5266:28: error: unknown type name 'diagnostic_context'
include/options.h:5274:28: error: unknown type name 'diagnostic_context'
include/options.h:5282:28: error: unknown type name 'diagnostic_context'
include/options.h:5284:37: warning: 'struct cpp_options' declared inside =
parameter list will not be visible outside of this definition or declarat=
ion
struct cpp_options * cpp_opts);
include/options.h:5286:45: warning: 'struct cpp_options' declared inside =
ion
const struct cpp_options * cpp_opts);
inux-gnu/6.1.0/plugin/include/backend.h:29:0,
include/function.h:31:3: error: expected specifier-qualifier-list before =
'rtx_insn'
rtx_insn *first;
include/function.h:129:3: error: expected specifier-qualifier-list before=
'rtx_insn_list'
rtx_insn_list *x_forced_labels;
include/function.h:138:3: error: expected specifier-qualifier-list before=
'rtx_code_label'
rtx_code_label *ehr_label;
include/function.h:258:3: error: expected specifier-qualifier-list before=
'vec'
vec<tree, va_gc> *local_decls;
include/function.h:418:25: error: expected identifier or '(' before ':' t=
oken
struct used_type_hasher : ggc_ptr_hash<types_used_by_vars_entry>
include/function.h:429:26: error: expected '=3D', ',', ';', 'asm' or '__a=
extern GTY(()) hash_table<used_type_hasher> *types_used_by_vars_hash;
include/function.h:435:19: error: expected '=3D', ',', ';', 'asm' or '__a=
extern GTY(()) vec<tree, va_gc> *types_used_by_cur_var_decl;
inux-gnu/6.1.0/plugin/include/system.h:1132:0,
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:28,
include/hwint.h:54:26: error: expected ')' before 'long'
# define HOST_WIDE_INT long
include/function.h:570:48: note: in expansion of macro 'HOST_WIDE_INT'
extern rtx assign_stack_local_1 (machine_mode, HOST_WIDE_INT, int, int);=
include/function.h:571:46: note: in expansion of macro 'HOST_WIDE_INT'
extern rtx assign_stack_local (machine_mode, HOST_WIDE_INT, int);
include/function.h:572:54: note: in expansion of macro 'HOST_WIDE_INT'
extern rtx assign_stack_temp_for_type (machine_mode, HOST_WIDE_INT, tree=
include/function.h:573:45: note: in expansion of macro 'HOST_WIDE_INT'
extern rtx assign_stack_temp (machine_mode, HOST_WIDE_INT);
include/function.h:582:52: error: expected ')' before 'unsigned'
extern rtx get_hard_reg_initial_val (machine_mode, unsigned int);
include/function.h:583:52: error: expected ')' before 'unsigned'
extern rtx has_hard_reg_initial_val (machine_mode, unsigned int);
include/function.h:593:48: error: expected ')' before 'tree'
extern void locate_and_pad_parm (machine_mode, tree, int, int, int,
include/function.h:633:36: error: expected declaration specifiers or '...=
' before 'rtx_insn'
extern void set_return_jump_label (rtx_insn *);
include/function.h:634:34: error: expected declaration specifiers or '...=
' before 'rtx_insn'
extern bool active_insn_between (rtx_insn *head, rtx_insn *tail);
include/function.h:634:50: error: expected declaration specifiers or '...=
' before 'rtx_insn'
include/function.h:635:11: error: expected '=3D', ',', ';', 'asm' or '__a=
extern vec<edge> convert_jumps_to_returns (basic_block last_bb, bool sim=
ple_p,
inux-gnu/6.1.0/plugin/include/backend.h:30:0,
include/bitmap.h:133:20: error: expected identifier or '(' before ':' tok=
en
struct bitmap_usage: public mem_usage
include/bitmap.h:189:29: error: expected '=3D', ',', ';', 'asm' or '__att=
extern mem_alloc_description<bitmap_usage> bitmap_mem_desc;
include/bitmap.h:242:3: error: unknown type name 'bitmap_element'
bitmap_element *first; /* First element in linked list. */
include/bitmap.h:243:3: error: unknown type name 'bitmap_element'
bitmap_element * GTY((skip(""))) current; /* Last element looked at. =
include/bitmap.h:244:3: error: unknown type name 'bitmap_obstack'
bitmap_obstack *obstack; /* Obstack to allocate elements from.
include/bitmap.h:249:8: error: unknown type name 'bitmap_element'
extern bitmap_element bitmap_zero_bits; /* Zero bitmap element */
include/bitmap.h:250:8: error: unknown type name 'bitmap_obstack'
extern bitmap_obstack bitmap_default_obstack; /* Default bitmap obstac=
k */
include/bitmap.h:329:40: error: unknown type name 'bitmap_obstack'
extern void bitmap_obstack_initialize (bitmap_obstack *);
include/bitmap.h:330:37: error: unknown type name 'bitmap_obstack'
extern void bitmap_obstack_release (bitmap_obstack *);
include/bitmap.h:338:38: error: unknown type name 'bitmap_obstack'
bitmap_initialize_stat (bitmap head, bitmap_obstack *obstack MEM_STAT_DE=
CL)
include/bitmap.h:348:42: error: unknown type name 'bitmap_obstack'
extern bitmap bitmap_obstack_alloc_stat (bitmap_obstack *obstack MEM_STA=
T_DECL);
include/bitmap.h:359:26: warning: type defaults to 'int' in declaration o=
f 'bitmap_head' [-Wimplicit-int]
extern void debug (const bitmap_head &ref);
include/bitmap.h:359:38: error: expected ';', ',' or ')' before '&' token=
include/bitmap.h:360:26: error: unknown type name 'bitmap_head'
extern void debug (const bitmap_head *ptr);
include/bitmap.h:383:3: error: unknown type name 'bitmap_element'
bitmap_element *elt1;
include/bitmap.h:386:3: error: unknown type name 'bitmap_element'
bitmap_element *elt2;
include/bitmap.h:401:20: error: unknown type name 'bitmap_iterator'
bmp_iter_set_init (bitmap_iterator *bi, const_bitmap map,
include/bitmap.h:443:20: error: unknown type name 'bitmap_iterator'
bmp_iter_and_init (bitmap_iterator *bi, const_bitmap map1, const_bitmap =
map2,
include/bitmap.h:511:26: error: unknown type name 'bitmap_iterator'
bmp_iter_and_compl_init (bitmap_iterator *bi,
include/bitmap.h:560:16: error: unknown type name 'bitmap_iterator'
bmp_iter_next (bitmap_iterator *bi, unsigned *bit_no)
include/bitmap.h:569:20: error: unknown type name 'bitmap_iterator'
bmp_iter_next_bit (bitmap_iterator * bi, unsigned *bit_no)
include/bitmap.h:592:15: error: unknown type name 'bitmap_iterator'
bmp_iter_set (bitmap_iterator *bi, unsigned *bit_no)
include/bitmap.h:635:15: error: unknown type name 'bitmap_iterator'
bmp_iter_and (bitmap_iterator *bi, unsigned *bit_no)
include/bitmap.h:698:21: error: unknown type name 'bitmap_iterator'
bmp_iter_and_compl (bitmap_iterator *bi, unsigned *bit_no)
inux-gnu/6.1.0/plugin/include/backend.h:31:0,
include/sbitmap.h:101:1: error: conflicting types for 'bitmap_bit_p'
bitmap_bit_p (const_sbitmap map, int bitno)
include/bitmap.h:319:12: note: previous declaration of 'bitmap_bit_p' was=
here
extern int bitmap_bit_p (bitmap, int);
include/sbitmap.h:111:1: error: conflicting types for 'bitmap_set_bit'
bitmap_set_bit (sbitmap map, int bitno)
include/bitmap.h:316:13: note: previous declaration of 'bitmap_set_bit' w=
as here
extern bool bitmap_set_bit (bitmap, int);
include/sbitmap.h:121:1: error: conflicting types for 'bitmap_clear_bit'
bitmap_clear_bit (sbitmap map, int bitno)
include/bitmap.h:313:13: note: previous declaration of 'bitmap_clear_bit'=
was here
extern bool bitmap_clear_bit (bitmap, int);
include/sbitmap.h:150:20: error: unknown type name 'sbitmap_iterator'
bmp_iter_set_init (sbitmap_iterator *i, const_sbitmap bmp,
include/sbitmap.h:170:15: error: unknown type name 'sbitmap_iterator'
bmp_iter_set (sbitmap_iterator *i, unsigned int *n)
include/sbitmap.h:196:16: error: unknown type name 'sbitmap_iterator'
bmp_iter_next (sbitmap_iterator *i, unsigned *bit_no ATTRIBUTE_UNUSED)
include/sbitmap.h:225:13: error: conflicting types for 'dump_bitmap'
extern void dump_bitmap (FILE *, const_sbitmap);
include/bitmap.h:355:13: note: previous definition of 'dump_bitmap' was h=
ere
inline void dump_bitmap (FILE *file, const_bitmap map)
include/sbitmap.h:226:30: warning: type defaults to 'int' in declaration =
of 'simple_bitmap_def' [-Wimplicit-int]
extern void debug_raw (const simple_bitmap_def &ref);
include/sbitmap.h:226:48: error: expected ';', ',' or ')' before '&' toke=
n
include/sbitmap.h:227:30: error: unknown type name 'simple_bitmap_def'
extern void debug_raw (const simple_bitmap_def *ptr);
include/sbitmap.h:229:26: warning: type defaults to 'int' in declaration =
extern void debug (const simple_bitmap_def &ref);
include/sbitmap.h:229:44: error: expected ';', ',' or ')' before '&' toke=
n
include/sbitmap.h:230:26: error: unknown type name 'simple_bitmap_def'
extern void debug (const simple_bitmap_def *ptr);
include/sbitmap.h:237:13: error: conflicting types for 'bitmap_copy'
extern void bitmap_copy (sbitmap, const_sbitmap);
include/bitmap.h:256:13: note: previous declaration of 'bitmap_copy' was =
here
extern void bitmap_copy (bitmap, const_bitmap);
include/sbitmap.h:238:12: error: conflicting types for 'bitmap_equal_p'
extern int bitmap_equal_p (const_sbitmap, const_sbitmap);
include/bitmap.h:262:13: note: previous declaration of 'bitmap_equal_p' w=
as here
extern bool bitmap_equal_p (const_bitmap, const_bitmap);
include/sbitmap.h:239:13: error: conflicting types for 'bitmap_empty_p'
extern bool bitmap_empty_p (const_sbitmap);
include/bitmap.h:272:13: note: previous definition of 'bitmap_empty_p' wa=
s here
inline bool bitmap_empty_p (const_bitmap map)
include/sbitmap.h:240:13: error: conflicting types for 'bitmap_clear'
extern void bitmap_clear (sbitmap);
include/bitmap.h:253:13: note: previous declaration of 'bitmap_clear' was=
here
extern void bitmap_clear (bitmap);
include/sbitmap.h:245:13: error: conflicting types for 'bitmap_ior_and_co=
mpl'
extern bool bitmap_ior_and_compl (sbitmap, const_sbitmap,
include/bitmap.h:306:13: note: previous declaration of 'bitmap_ior_and_co=
mpl' was here
extern bool bitmap_ior_and_compl (bitmap DST, const_bitmap A,
include/sbitmap.h:247:13: error: conflicting types for 'bitmap_and_compl'=
extern void bitmap_and_compl (sbitmap, const_sbitmap, const_sbitmap);
include/bitmap.h:292:13: note: previous declaration of 'bitmap_and_compl'=
was here
extern bool bitmap_and_compl (bitmap, const_bitmap, const_bitmap);
include/sbitmap.h:253:13: error: conflicting types for 'bitmap_intersect_=
p'
extern bool bitmap_intersect_p (const_sbitmap, const_sbitmap);
include/bitmap.h:265:13: note: previous declaration of 'bitmap_intersect_=
p' was here
extern bool bitmap_intersect_p (const_bitmap, const_bitmap);
include/sbitmap.h:254:13: error: conflicting types for 'bitmap_and'
extern bool bitmap_and (sbitmap, const_sbitmap, const_sbitmap);
include/bitmap.h:290:13: note: previous declaration of 'bitmap_and' was h=
ere
extern void bitmap_and (bitmap, const_bitmap, const_bitmap);
include/sbitmap.h:255:13: error: conflicting types for 'bitmap_ior'
extern bool bitmap_ior (sbitmap, const_sbitmap, const_sbitmap);
include/bitmap.h:298:13: note: previous declaration of 'bitmap_ior' was h=
ere
extern bool bitmap_ior (bitmap, const_bitmap, const_bitmap);
include/sbitmap.h:256:13: error: conflicting types for 'bitmap_xor'
extern bool bitmap_xor (sbitmap, const_sbitmap, const_sbitmap);
include/bitmap.h:300:13: note: previous declaration of 'bitmap_xor' was h=
ere
extern void bitmap_xor (bitmap, const_bitmap, const_bitmap);
include/sbitmap.h:259:12: error: conflicting types for 'bitmap_first_set_=
bit'
extern int bitmap_first_set_bit (const_sbitmap);
include/bitmap.h:362:17: note: previous declaration of 'bitmap_first_set_=
bit' was here
extern unsigned bitmap_first_set_bit (const_bitmap);
include/sbitmap.h:260:12: error: conflicting types for 'bitmap_last_set_b=
it'
extern int bitmap_last_set_bit (const_sbitmap);
include/bitmap.h:363:17: note: previous declaration of 'bitmap_last_set_b=
it' was here
extern unsigned bitmap_last_set_bit (const_bitmap);
include/sbitmap.h:262:13: error: conflicting types for 'debug_bitmap'
extern void debug_bitmap (const_sbitmap);
include/bitmap.h:322:13: note: previous declaration of 'debug_bitmap' was=
here
extern void debug_bitmap (const_bitmap);
inux-gnu/6.1.0/plugin/include/backend.h:32:0,
include/basic-block.h:39:5: error: expected specifier-qualifier-list befo=
re 'rtx_insn'
rtx_insn *r;
include/basic-block.h:78:3: error: expected specifier-qualifier-list befo=
re 'rtx_insn'
rtx_insn *end_;
include/basic-block.h:122:3: error: expected specifier-qualifier-list bef=
ore 'vec'
vec<edge, va_gc> *preds;
include/basic-block.h:167:13: error: size of array '__assert_gimple_bb_sm=
aller_rtl_bb' is negative
typedef int __assert_gimple_bb_smaller_rtl_bb
include/basic-block.h: In function 'single_succ_p':
include/basic-block.h:324:26: warning: implicit declaration of function '=
vec_safe_length' [-Wimplicit-function-declaration]
#define EDGE_COUNT(ev) vec_safe_length (ev)
include/basic-block.h:334:10: note: in expansion of macro 'EDGE_COUNT'
return EDGE_COUNT (bb->succs) =3D=3D 1;
include/basic-block.h:334:24: error: 'const struct basic_block_def' has n=
o member named 'succs'
include/basic-block.h:324:43: note: in definition of macro 'EDGE_COUNT'
include/basic-block.h: In function 'single_pred_p':
include/basic-block.h:342:24: error: 'const struct basic_block_def' has n=
o member named 'preds'
return EDGE_COUNT (bb->preds) =3D=3D 1;
include/basic-block.h: In function 'single_succ_edge':
include/basic-block.h:327:33: error: 'const struct basic_block_def' has n=
#define EDGE_SUCC(bb,i) (*(bb)->succs)[(i)]
include/basic-block.h:352:10: note: in expansion of macro 'EDGE_SUCC'
return EDGE_SUCC (bb, 0);
include/basic-block.h: In function 'single_pred_edge':
include/basic-block.h:326:33: error: 'const struct basic_block_def' has n=
#define EDGE_PRED(bb,i) (*(bb)->preds)[(i)]
include/basic-block.h:362:10: note: in expansion of macro 'EDGE_PRED'
return EDGE_PRED (bb, 0);
include/basic-block.h: At top level:
include/basic-block.h:387:3: error: expected specifier-qualifier-list bef=
ore 'vec'
vec<edge, va_gc> **container;
include/basic-block.h:390:18: error: expected '=3D', ',', ';', 'asm' or '=
static inline vec<edge, va_gc> *
include/basic-block.h:401:15: error: unknown type name 'edge_iterator'
static inline edge_iterator
include/basic-block.h:402:16: error: expected ')' before '<' token
ei_start_1 (vec<edge, va_gc> **ev)
include/basic-block.h:414:15: error: unknown type name 'edge_iterator'
include/basic-block.h:415:15: error: expected ')' before '<' token
ei_last_1 (vec<edge, va_gc> **ev)
include/basic-block.h:427:11: error: unknown type name 'edge_iterator'
ei_end_p (edge_iterator i)
include/basic-block.h:435:22: error: unknown type name 'edge_iterator'
ei_one_before_end_p (edge_iterator i)
include/basic-block.h:442:10: error: unknown type name 'edge_iterator'
ei_next (edge_iterator *i)
include/basic-block.h:450:10: error: unknown type name 'edge_iterator'
ei_prev (edge_iterator *i)
include/basic-block.h:458:10: error: unknown type name 'edge_iterator'
ei_edge (edge_iterator i)
include/basic-block.h:467:15: error: unknown type name 'edge_iterator'
ei_safe_edge (edge_iterator i)
include/basic-block.h:477:10: error: unknown type name 'edge_iterator'
ei_cond (edge_iterator ei, edge *p)
include/basic-block.h: In function 'bb_in_transaction':
include/basic-block.h:527:12: error: 'struct basic_block_def' has no memb=
er named 'flags'
return bb->flags & BB_IN_TRANSACTION;
include/basic-block.h: In function 'bb_has_eh_pred':
include/basic-block.h:535:3: error: unknown type name 'edge_iterator'
edge_iterator ei;
include/basic-block.h:535:3: note: use 'struct' keyword to refer to the t=
ype
include/basic-block.h:397:24: warning: implicit declaration of function '=
ei_start_1' [-Wimplicit-function-declaration]
#define ei_start(iter) ei_start_1 (&(iter))
include/basic-block.h:507:17: note: in expansion of macro 'ei_start'
for ((ITER) =3D ei_start ((EDGE_VEC)); \
include/basic-block.h:537:3: note: in expansion of macro 'FOR_EACH_EDGE'
FOR_EACH_EDGE (e, ei, bb->preds)
include/basic-block.h:537:27: error: 'struct basic_block_def' has no memb=
er named 'preds'
include/basic-block.h:397:38: note: in definition of macro 'ei_start'
include/basic-block.h:508:8: warning: implicit declaration of function 'e=
i_cond' [-Wimplicit-function-declaration]
ei_cond ((ITER), &(EDGE)); \
include/basic-block.h:509:8: warning: implicit declaration of function 'e=
i_next' [-Wimplicit-function-declaration]
ei_next (&(ITER)))
include/basic-block.h: In function 'bb_has_abnormal_pred':
include/basic-block.h:550:3: error: unknown type name 'edge_iterator'
edge_iterator ei;
include/basic-block.h:550:3: note: use 'struct' keyword to refer to the t=
ype
include/basic-block.h:552:27: error: 'struct basic_block_def' has no memb=
er named 'preds'
include/basic-block.h:552:3: note: in expansion of macro 'FOR_EACH_EDGE'
include/basic-block.h:562:24: error: expected ')' before '<' token
find_fallthru_edge (vec<edge, va_gc> *edges)
include/basic-block.h: In function 'has_abnormal_or_eh_outgoing_edge_p':
include/basic-block.h:627:3: error: unknown type name 'edge_iterator'
edge_iterator ei;
include/basic-block.h:627:3: note: use 'struct' keyword to refer to the t=
ype
include/basic-block.h:629:27: error: 'struct basic_block_def' has no memb=
er named 'succs'
FOR_EACH_EDGE (e, ei, bb->succs)
include/basic-block.h:629:3: note: in expansion of macro 'FOR_EACH_EDGE'
include/basic-block.h: In function 'has_abnormal_call_or_eh_pred_edge_p':=
include/basic-block.h:643:3: error: unknown type name 'edge_iterator'
edge_iterator ei;
include/basic-block.h:643:3: note: use 'struct' keyword to refer to the t=
ype
include/basic-block.h:645:27: error: 'struct basic_block_def' has no memb=
er named 'preds'
include/basic-block.h:645:3: note: in expansion of macro 'FOR_EACH_EDGE'
inux-gnu/6.1.0/plugin/include/cfg.h:23:0,
inux-gnu/6.1.0/plugin/include/backend.h:33,
include/dominance.h: At top level:
include/dominance.h:39:34: error: unknown type name 'function'
extern void free_dominance_info (function *, enum cdi_direction);
include/dominance.h:44:11: error: expected '=3D', ',', ';', 'asm' or '__a=
extern vec<basic_block> get_dominated_by (enum cdi_direction, basic_bloc=
k);
include/dominance.h:45:11: error: expected '=3D', ',', ';', 'asm' or '__a=
extern vec<basic_block> get_dominated_by_region (enum cdi_direction,
include/dominance.h:48:11: error: expected '=3D', ',', ';', 'asm' or '__a=
extern vec<basic_block> get_dominated_to_depth (enum cdi_direction,
include/dominance.h:50:11: error: expected '=3D', ',', ';', 'asm' or '__a=
extern vec<basic_block> get_all_dominated_blocks (enum cdi_direction,
include/dominance.h:68:29: error: unknown type name 'cdi_direction'
checking_verify_dominators (cdi_direction dir)
include/dominance.h:76:9: error: unknown type name 'vec'
vec<basic_block> , bool);
include/dominance.h:81:39: error: unknown type name 'function'
extern enum dom_state dom_info_state (function *, enum cdi_direction);
include/dominance.h:84:35: error: unknown type name 'function'
extern bool dom_info_available_p (function *, enum cdi_direction);
inux-gnu/6.1.0/plugin/include/backend.h:33:0,
include/cfg.h:45:3: error: expected specifier-qualifier-list before 'vec'=
vec<basic_block, va_gc> *x_basic_block_info;
include/cfg.h:77:24: error: unknown type name 'function'
extern void init_flow (function *);
include/cfg.h:78:26: error: unknown type name 'function'
extern void clear_edges (function *);
include/cfg.h:93:29: error: expected ')' before '&' token
extern void debug (edge_def &ref);
include/cfg.h:94:20: error: unknown type name 'edge_def'
extern void debug (edge_def *ptr);
include/cfg.h:116:28: warning: 'struct loop' declared inside parameter li=
st will not be visible outside of this definition or declaration
void set_loop_copy (struct loop *, struct loop *);
inux-gnu/6.1.0/plugin/include/cfghooks.h:24:0,
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:31,
include/predict.h:57:8: error: unknown type name 'optimization_type'
extern optimization_type function_optimization_type (struct function *);=
include/predict.h:60:8: error: unknown type name 'optimization_type'
extern optimization_type bb_optimization_type (const_basic_block);
include/predict.h:77:31: error: expected declaration specifiers or '...' =
before 'rtx_insn'
extern void predict_insn_def (rtx_insn *, enum br_predictor, enum predic=
tion);
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:31:0,
include/cfghooks.h:66:30: error: unknown type name 'pretty_printer'
void (*dump_bb_for_graph) (pretty_printer *, basic_block);
include/cfghooks.h:157:15: error: unknown type name 'vec'
edge, vec<edge> *,
include/cfghooks.h:202:32: error: unknown type name 'pretty_printer'
extern void dump_bb_for_graph (pretty_printer *, basic_block);
include/cfghooks.h:212:39: error: unknown type name 'gimple'
extern edge split_block (basic_block, gimple *);
include/cfghooks.h:218:20: error: conflicting types for 'create_basic_blo=
ck'
extern basic_block create_basic_block (gimple_seq, basic_block);
include/cfghooks.h:217:20: note: previous declaration of 'create_basic_bl=
ock' was here
extern basic_block create_basic_block (rtx, rtx, basic_block);
include/cfghooks.h:242:11: error: unknown type name 'vec'
vec<edge> *to_remove,
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:32:0,
include/hard-reg-set.h:537:25: error: unknown type name 'hard_reg_set_ite=
rator'
hard_reg_set_iter_init (hard_reg_set_iterator *iter, HARD_REG_SET set,
include/hard-reg-set.h:560:24: error: unknown type name 'hard_reg_set_ite=
rator'
hard_reg_set_iter_set (hard_reg_set_iterator *iter, unsigned *regno)
include/hard-reg-set.h:595:25: error: unknown type name 'hard_reg_set_ite=
rator'
hard_reg_set_iter_next (hard_reg_set_iterator *iter, unsigned *regno)
include/hard-reg-set.h:619:36: error: expected identifier or '(' before '=
:' token
struct simplifiable_subregs_hasher : nofree_ptr_hash <simplifiable_subre=
g>
include/hard-reg-set.h:628:8: error: field 'finalize' declared as a funct=
ion
void finalize ();
include/hard-reg-set.h:707:3: error: expected specifier-qualifier-list be=
fore 'hash_table'
hash_table <simplifiable_subregs_hasher> *x_simplifiable_subregs;
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:33:0,
include/cfgrtl.h:24:36: error: expected declaration specifiers or '...' b=
efore 'rtx_insn'
extern void delete_insn_and_edges (rtx_insn *);
include/cfgrtl.h:26:50: error: expected declaration specifiers or '...' b=
efore 'rtx_insn'
extern basic_block create_basic_block_structure (rtx_insn *, rtx_insn *,=
include/cfgrtl.h:26:62: error: expected declaration specifiers or '...' b=
efore 'rtx_insn'
include/cfgrtl.h:27:8: error: expected declaration specifiers or '...' be=
fore 'rtx_note'
rtx_note *, basic_block);
include/cfgrtl.h:30:17: error: expected '=3D', ',', ';', 'asm' or '__attr=
ibute__' before '*' token
extern rtx_insn *entry_of_function (void);
include/cfgrtl.h:35:17: error: expected '=3D', ',', ';', 'asm' or '__attr=
extern rtx_note *bb_note (basic_block);
include/cfgrtl.h:36:23: error: expected '=3D', ',', ';', 'asm' or '__attr=
extern rtx_code_label *block_label (basic_block);
include/cfgrtl.h:43:46: warning: type defaults to 'int' in declaration of=
'rtx_insn' [-Wimplicit-int]
extern void print_rtl_with_bb (FILE *, const rtx_insn *, int);
include/cfgrtl.h:43:55: error: expected ';', ',' or ')' before '*' token
include/cfgrtl.h:45:17: error: expected '=3D', ',', ';', 'asm' or '__attr=
extern rtx_insn *get_last_bb_insn (basic_block);
include/cfgrtl.h:50:17: error: expected '=3D', ',', ';', 'asm' or '__attr=
extern rtx_insn *unlink_insn_chain (rtx_insn *, rtx_insn *);
include/cfgrtl.h:52:17: error: expected '=3D', ',', ';', 'asm' or '__attr=
extern rtx_insn *duplicate_insn_chain (rtx_insn *, rtx_insn *);
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:34:0,
include/cfganal.h:34:1: error: unknown type name 'class'
class control_dependences
include/cfganal.h:35:1: error: expected '=3D', ',', ';', 'asm' or '__attr=
include/cfganal.h:65:70: error: expected ';', ',' or ')' before '=3D' tok=
en
extern int inverted_post_order_compute (int *, sbitmap *start_points =3D=
0);
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:36:0,
include/cfgbuild.h:23:41: warning: type defaults to 'int' in declaration =
of 'rtx_insn' [-Wimplicit-int]
extern bool inside_basic_block_p (const rtx_insn *);
include/cfgbuild.h:23:50: error: expected ';', ',' or ')' before '*' toke=
n
include/cfgbuild.h:24:40: warning: type defaults to 'int' in declaration =
extern bool control_flow_insn_p (const rtx_insn *);
include/cfgbuild.h:24:49: error: expected ';', ',' or ')' before '*' toke=
n
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:37:0,
include/cfgcleanup.h:26:60: error: expected declaration specifiers or '..=
=2E' before 'rtx_insn'
extern int flow_find_cross_jump (basic_block, basic_block, rtx_insn **,
include/cfgcleanup.h:27:6: error: expected declaration specifiers or '...=
' before 'rtx_insn'
rtx_insn **, enum replace_direction*);
include/cfgcleanup.h:29:11: error: expected declaration specifiers or '..=
rtx_insn **, rtx_insn **, int);
include/cfgcleanup.h:29:24: error: expected declaration specifiers or '..=
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:39:0,
include/ipa-ref.h:25:1: error: unknown type name 'class'
class varpool_node;
include/ipa-ref.h:26:1: error: unknown type name 'class'
class symtab_node;
include/ipa-ref.h:42:1: error: expected specifier-qualifier-list before '=
public'
public:
include/ipa-ref.h:75:1: error: expected specifier-qualifier-list before '=
public'
public:
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:42:0,
include/tree-core.h:201:16: error: expected expression before 'int'
CFN_##ENUM =3D int (ENUM),
include/builtins.def:164:3: note: in expansion of macro 'DEF_BUILTIN'
DEF_BUILTIN (ENUM, NAME, BUILT_IN_NORMAL, BT_LAST, BT_LAST, false, fal=
se, \
include/builtins.def:265:1: note: in expansion of macro 'DEF_BUILTIN_STUB=
DEF_BUILTIN_STUB(BUILT_IN_NONE, (const char *)0)
include/tree-core.h:819:18: error: unknown type name 'hash_set'
void *, hash_set<tree> *);
include/tree-core.h:1284:3: error: expected specifier-qualifier-list befo=
re 'vec'
vec<constructor_elt, va_gc> *elts;
include/tree-core.h:1334:11: error: unknown type name 'gimple'
union { gimple *stmt; tree ssa_name; } GTY((skip(""))) loc;
include/tree-core.h:1345:3: error: unknown type name 'gimple'
gimple *def_stmt;
include/tree-core.h:1407:3: error: expected specifier-qualifier-list befo=
re 'vec'
vec<tree, va_gc> *nonlocalized_vars;
include/tree-core.h:1481:3: error: expected specifier-qualifier-list befo=
re 'vec'
vec<tree, va_gc> *base_accesses;
include/tree-core.h:1879:3: error: expected specifier-qualifier-list befo=
re 'vec'
vec<tree, va_gc> *pending_statics;
include/tree-core.h:1920:3: error: expected specifier-qualifier-list befo=
re 'vec'
vec<tree, va_gc> *to;
include/tree-core.h:1969:19: error: expected '=3D', ',', ';', 'asm' or '_=
extern GTY(()) vec<alias_pair, va_gc> *alias_pairs;
include/tree-core.h:1982:20: error: expected '=3D', ',', ';', 'asm' or '_=
extern GTY (()) vec<tree, va_gc> *all_translation_units;
include/tree-core.h:2004:16: error: unknown type name 'builtin_info_type'=
extern GTY(()) builtin_info_type builtin_info[(int)END_BUILTINS];
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:43:0,
include/fold-const.h:28:74: error: expected ';', ',' or ')' before '=3D' =
token
extern int native_encode_expr (const_tree, unsigned char *, int, int off=
=3D -1);
include/fold-const.h:76:52: error: unknown type name 'offset_int'
extern tree get_array_ctor_element_at_index (tree, offset_int);
include/fold-const.h:86:57: error: unknown type name 'gimple'
extern void fold_undefer_overflow_warnings (bool, const gimple *, int);
include/fold-const.h:120:8: error: unknown type name 'offset_int'
extern offset_int mem_ref_offset (const_tree);
include/fold-const.h:140:50: error: unknown type name 'combined_fn'
extern bool tree_call_nonnegative_warnv_p (tree, combined_fn, tree, tree=
include/fold-const.h:143:53: error: expected ')' before 'tree'
extern bool integer_valued_real_unary_p (tree_code, tree, int);
include/fold-const.h:144:54: error: expected ')' before 'tree'
extern bool integer_valued_real_binary_p (tree_code, tree, tree, int);
include/fold-const.h:145:54: error: expected ')' before 'tree'
extern bool integer_valued_real_call_p (combined_fn, tree, tree, int);
include/fold-const.h:147:46: error: expected ';', ',' or ')' before '=3D'=
token
extern bool integer_valued_real_p (tree, int =3D 0);
include/fold-const.h:171:62: error: expected ';', ',' or ')' before '=3D'=
token
extern bool tree_expr_nonnegative_warnv_p (tree, bool *, int =3D 0);
include/fold-const.h:180:46: warning: type defaults to 'int' in declarati=
on of 'wide_int' [-Wimplicit-int]
extern bool expr_not_equal_to (tree t, const wide_int &);
include/fold-const.h:180:55: error: expected ';', ',' or ')' before '&' t=
oken
include/fold-const.h:183:1: warning: parameter names (without types) in f=
unction declaration
extern bool negate_mathfn_p (combined_fn);
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:45:0,
include/plugin.h:170:46: error: unknown type name 'diagnostic_context'
extern void plugins_internal_error_function (diagnostic_context *,
In file included from conftest.c:101:0:
include/tree.h:27:8: error: unknown type name 'combined_fn'
inline combined_fn
include/tree.h:28:17: error: unknown type name 'built_in_function'
as_combined_fn (built_in_function fn)
include/tree.h:35:8: error: unknown type name 'combined_fn'
inline combined_fn
include/tree.h:36:17: error: unknown type name 'internal_fn'
as_combined_fn (internal_fn fn)
include/tree.h:44:15: error: unknown type name 'combined_fn'
builtin_fn_p (combined_fn code)
include/tree.h:52:8: error: unknown type name 'built_in_function'
inline built_in_function
include/tree.h:53:16: error: unknown type name 'combined_fn'
as_builtin_fn (combined_fn code)
include/tree.h:62:16: error: unknown type name 'combined_fn'
internal_fn_p (combined_fn code)
include/tree.h:70:8: error: unknown type name 'internal_fn'
inline internal_fn
include/tree.h:71:17: error: unknown type name 'combined_fn'
as_internal_fn (combined_fn code)
include/tree.h:1147:15: error: unknown type name 'source_range'
static inline source_range
include/tree.h: In function 'get_expr_source_range':
include/tree.h:1151:10: warning: implicit declaration of function 'get_ra=
nge_from_loc' [-Wimplicit-function-declaration]
return get_range_from_loc (line_table, loc);
include/tree.h: At top level:
include/tree.h:1818:8: error: unknown type name 'machine_mode'
extern machine_mode element_mode (const_tree t);
include/tree.h:2885:11: error: expected '=3D', ',', ';', 'asm' or '__attr=
extern vec<tree, va_gc> **decl_debug_args_lookup (tree);
include/tree.h:2886:11: error: expected '=3D', ',', ';', 'asm' or '__attr=
extern vec<tree, va_gc> **decl_debug_args_insert (tree);
include/tree.h:3827:38: error: unknown type name 'vec'
extern tree build_nt_call_vec (tree, vec<tree, va_gc> *);
include/tree.h:3827:48: error: unknown type name 'va_gc'
include/tree.h:3911:39: error: unknown type name 'double_int'
extern tree double_int_to_tree (tree, double_int);
include/tree.h:3913:48: warning: type defaults to 'int' in declaration of=
'wide_int_ref' [-Wimplicit-int]
extern tree wide_int_to_tree (tree type, const wide_int_ref &cst);
include/tree.h:3913:61: error: expected ';', ',' or ')' before '&' token
include/tree.h:3914:41: warning: type defaults to 'int' in declaration of=
extern tree force_fit_type (tree, const wide_int_ref &, int, bool);
include/tree.h:3914:54: error: expected ';', ',' or ')' before '&' token
include/tree.h:3926:43: error: unknown type name 'vec'
extern tree build_vector_from_ctor (tree, vec<constructor_elt, va_gc> *)=
include/tree.h:3926:64: error: unknown type name 'va_gc'
include/tree.h:3930:38: error: unknown type name 'vec'
extern tree build_constructor (tree, vec<constructor_elt, va_gc> *);
include/tree.h:3930:59: error: unknown type name 'va_gc'
include/tree.h:3945:45: warning: type defaults to 'int' in declaration of=
'vec' [-Wimplicit-int]
extern tree build_tree_list_vec_stat (const vec<tree, va_gc> *MEM_STAT_D=
ECL);
include/tree.h:3945:48: error: expected ';', ',' or ')' before '<' token
ECL);
include/tree.h:3964:41: error: unknown type name 'vec'
extern tree build_call_vec (tree, tree, vec<tree, va_gc> *);
include/tree.h:3964:51: error: unknown type name 'va_gc'
include/tree.h:3966:56: error: unknown type name 'vec'
extern tree build_call_expr_loc_vec (location_t, tree, vec<tree, va_gc> =
include/tree.h:3966:66: error: unknown type name 'va_gc'
include/tree.h:3971:13: error: conflicting types for 'build_call_expr_int=
ernal_loc'
extern tree build_call_expr_internal_loc (location_t, enum internal_fn,
include/tree.h:3969:13: note: previous declaration of 'build_call_expr_in=
ternal_loc' was here
include/tree.h:3973:52: error: unknown type name 'combined_fn'
extern tree maybe_build_call_expr_loc (location_t, combined_fn, tree,
include/tree.h:3983:48: error: unknown type name 'machine_mode'
extern tree build_pointer_type_for_mode (tree, machine_mode, bool);
include/tree.h:3985:50: error: unknown type name 'machine_mode'
extern tree build_reference_type_for_mode (tree, machine_mode, bool);
include/tree.h:3987:47: error: unknown type name 'machine_mode'
extern tree build_vector_type_for_mode (tree, machine_mode);
include/tree.h:4014:37: error: unknown type name 'vec'
extern bool vec_member (const_tree, vec<tree, va_gc> *);
include/tree.h:4014:47: error: unknown type name 'va_gc'
include/tree.h:4050:55: error: unknown type name 'signop'
extern unsigned int tree_int_cst_min_precision (tree, signop);
include/tree.h:4278:11: error: expected '=3D', ',', ';', 'asm' or '__attr=
ibute__' before '<' token
extern vec<tree, va_gc> *ctor_to_vec (tree);
include/tree.h:4383:45: error: unknown type name 'vec'
extern void find_placeholder_in_expr (tree, vec<tree> *);
include/tree.h:4541:26: error: unknown type name 'function_args_iterator'=
function_args_iter_init (function_args_iterator *i, const_tree fntype)
include/tree.h:4550:30: error: unknown type name 'function_args_iterator'=
function_args_iter_cond_ptr (function_args_iterator *i)
include/tree.h:4559:26: error: unknown type name 'function_args_iterator'=
function_args_iter_cond (function_args_iterator *i)
include/tree.h:4566:26: error: unknown type name 'function_args_iterator'=
function_args_iter_next (function_args_iterator *i)
include/tree.h:4603:8: error: unknown type name 'combined_fn'
extern combined_fn get_call_combined_fn (const_tree);
include/tree.h:4629:1: warning: parameter names (without types) in functi=
on declaration
extern const char *combined_fn_name (combined_fn);
include/tree.h:4747:1: error: unknown type name 'namespace'
namespace inchash
include/tree.h:4748:1: error: expected '=3D', ',', ';', 'asm' or '__attri=
include/tree.h: In function 'iterative_hash_expr':
include/tree.h:4758:11: error: expected expression before ':' token
inchash::hash hstate (seed);
include/tree.h:4759:3: error: duplicate label 'inchash'
inchash::add_expr (tree, hstate);
include/tree.h:4758:3: note: previous definition of 'inchash' was here
include/tree.h:4759:11: error: expected expression before ':' token
include/tree.h:4760:10: error: 'hstate' undeclared (first use in this fun=
ction)
return hstate.end ();
include/tree.h:4790:16: error: expected ';', ',' or ')' before '=3D' toke=
n
bool strict=3Dfalse);
include/tree.h:4797:54: error: unknown type name 'hash_set'
extern tree walk_tree_1 (tree*, walk_tree_fn, void*, hash_set<tree>*,
include/tree.h:4798:5: error: unknown type name 'walk_tree_lh'
walk_tree_lh);
include/tree.h:4800:10: error: unknown type name 'walk_tree_lh'
walk_tree_lh);
include/tree.h:4839:34: error: expected ';', ',' or ')' before '=3D' toke=
n
bool trust_type_canonical =3D true);
include/tree.h:4890:35: error: expected identifier or '(' before ':' toke=
n
struct tree_decl_map_cache_hasher : ggc_cache_ptr_hash<tree_decl_map>
include/tree.h:4917:40: error: unknown type name 'call_expr_arg_iterator'=
init_call_expr_arg_iterator (tree exp, call_expr_arg_iterator *iter)
include/tree.h:4925:52: error: unknown type name 'const_call_expr_arg_ite=
rator'
init_const_call_expr_arg_iterator (const_tree exp, const_call_expr_arg_i=
terator *iter)
include/tree.h:4935:21: error: unknown type name 'call_expr_arg_iterator'=
next_call_expr_arg (call_expr_arg_iterator *iter)
include/tree.h:4946:27: error: unknown type name 'const_call_expr_arg_ite=
rator'
next_const_call_expr_arg (const_call_expr_arg_iterator *iter)
include/tree.h:4961:32: error: unknown type name 'call_expr_arg_iterator'=
first_call_expr_arg (tree exp, call_expr_arg_iterator *iter)
include/tree.h:4968:44: error: unknown type name 'const_call_expr_arg_ite=
rator'
first_const_call_expr_arg (const_tree exp, const_call_expr_arg_iterator =
*iter)
include/tree.h:4977:30: error: unknown type name 'call_expr_arg_iterator'=
more_call_expr_args_p (const call_expr_arg_iterator *iter)
include/tree.h: In function 'more_call_expr_args_p':
include/tree.h:4979:15: error: request for member 'i' in something not a =
structure or union
return (iter->i < iter->n);
include/tree.h:4979:25: error: request for member 'n' in something not a =
structure or union
include/tree.h: In function 'builtin_decl_explicit':
include/tree.h:5009:38: error: request for member 'decl' in something not=
return builtin_info[(size_t)fncode].decl;
include/tree.h: In function 'builtin_decl_implicit':
include/tree.h:5019:32: error: request for member 'implicit_p' in somethi=
if (!builtin_info[uns_fncode].implicit_p)
include/tree.h:5022:34: error: request for member 'decl' in something not=
return builtin_info[uns_fncode].decl;
include/tree.h: In function 'set_builtin_decl':
include/tree.h:5036:24: error: request for member 'decl' in something not=
builtin_info[ufncode].decl =3D decl;
include/tree.h:5037:24: error: request for member 'implicit_p' in somethi=
builtin_info[ufncode].implicit_p =3D implicit_p;
include/tree.h:5038:24: error: request for member 'declared_p' in somethi=
builtin_info[ufncode].declared_p =3D false;
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:28:0,
include/tree.h: In function 'set_builtin_decl_implicit_p':
include/tree.h:5049:37: error: request for member 'decl' in something not=
&& builtin_info[uns_fncode].decl !=3D NULL_TREE);
include/system.h:738:49: note: in definition of macro 'gcc_checking_asser=
t'
#define gcc_checking_assert(EXPR) ((void)(0 && (EXPR)))
include/tree.h:5051:27: error: request for member 'implicit_p' in somethi=
builtin_info[uns_fncode].implicit_p =3D implicit_p;
include/tree.h: In function 'set_builtin_decl_declared_p':
include/tree.h:5062:37: error: request for member 'decl' in something not=
t'
include/tree.h:5064:27: error: request for member 'declared_p' in somethi=
builtin_info[uns_fncode].declared_p =3D declared_p;
include/tree.h: In function 'builtin_decl_explicit_p':
include/tree.h:5074:39: error: request for member 'decl' in something not=
return (builtin_info[(size_t)fncode].decl !=3D NULL_TREE);
include/tree.h: In function 'builtin_decl_implicit_p':
include/tree.h:5085:35: error: request for member 'decl' in something not=
return (builtin_info[uns_fncode].decl !=3D NULL_TREE
include/tree.h:5086:31: error: request for member 'implicit_p' in somethi=
&& builtin_info[uns_fncode].implicit_p);
include/tree.h: In function 'builtin_decl_declared_p':
include/tree.h:5097:35: error: request for member 'decl' in something not=
include/tree.h:5098:31: error: request for member 'declared_p' in somethi=
&& builtin_info[uns_fncode].declared_p);
include/tree.h:5139:15: error: unknown type name 'cl_target_option'
static inline cl_target_option *
include/tree.h: In function 'target_opts_for_fn':
include/tree.h:5145:38: warning: return from incompatible pointer type [-=
Wincompatible-pointer-types]
return fn_opts =3D=3D NULL_TREE ? NULL : TREE_TARGET_OPTION (fn_opts);=
include/tree.h:5159:1: error: unknown type name 'namespace'
namespace wi
include/tree.h:5160:1: error: expected '=3D', ',', ';', 'asm' or '__attri=
include/tree.h:5205:3: error: expected '=3D', ',', ';', 'asm' or '__attri=
bute__' before ':' token
wi::int_traits <const_tree>::get_precision (const_tree tcst)
include/tree.h:5211:10: error: expected '=3D', ',', ';', 'asm' or '__attr=
ibute__' before ':' token
inline wi::storage_ref
include/tree.h:5219:25: error: expected '=3D', ',', ';', 'asm' or '__attr=
inline generic_wide_int <wi::extended_tree <WIDE_INT_MAX_PRECISION> >
include/tree.h:5225:25: error: expected '=3D', ',', ';', 'asm' or '__attr=
inline generic_wide_int <wi::extended_tree <ADDR_MAX_PRECISION> >
include/tree.h:5231:10: error: expected '=3D', ',', ';', 'asm' or '__attr=
template <int N>
include/tree.h:5238:10: error: expected '=3D', ',', ';', 'asm' or '__attr=
template <int N>
include/tree.h:5245:10: error: expected '=3D', ',', ';', 'asm' or '__attr=
template <int N>
include/tree.h:5252:10: error: expected '=3D', ',', ';', 'asm' or '__attr=
template <int N>
include/tree.h:5267:1: error: unknown type name 'namespace'
namespace wi
include/tree.h:5268:1: error: expected '=3D', ',', ';', 'asm' or '__attri=
include/tree.h:5277:10: error: expected '=3D', ',', ';', 'asm' or '__attr=
template <typename T>
include/tree.h:5289:8: error: unknown type name 'wide_int'
inline wide_int
include/tree.h:5290:3: error: expected '=3D', ',', ';', 'asm' or '__attri=
wi::min_value (const_tree type)
include/tree.h:5297:8: error: unknown type name 'wide_int'
inline wide_int
include/tree.h:5298:3: error: expected '=3D', ',', ';', 'asm' or '__attri=
wi::max_value (const_tree type)
include/tree.h: In function 'tree_int_cst_lt':
include/tree.h:5309:10: error: 'wi' undeclared (first use in this functio=
n)
return wi::lts_p (wi::to_widest (t1), wi::to_widest (t2));
include/tree.h:5309:12: error: expected ';' before ':' token
include/tree.h: In function 'tree_int_cst_le':
include/tree.h:5318:10: error: 'wi' undeclared (first use in this functio=
n)
return wi::les_p (wi::to_widest (t1), wi::to_widest (t2));
include/tree.h:5318:12: error: expected ';' before ':' token
include/tree.h: In function 'tree_int_cst_compare':
include/tree.h:5328:10: error: 'wi' undeclared (first use in this functio=
n)
return wi::cmps (wi::to_widest (t1), wi::to_widest (t2));
/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/gcc-6.1.0-7cl=
jeqxjfpkacgtkxus4p55nsms53dnv/lib64/gcc/x86_64-pc-linux-gnu/6.1.0/plugin/=
include/tree.h:5328:12: error: expected ';' before ':' token
include/tree.h:5344:14: error: unknown type name 'machine_mode'
tree *, machine_mode *, int *, int *,
include/tree.h: In function 'int_bit_position':
include/tree.h:5366:11: error: 'wi' undeclared (first use in this functio=
n)
return (wi::lshift (wi::to_offset (DECL_FIELD_OFFSET (field)), BITS_PE=
R_UNIT_LOG)
include/tree.h:5366:13: error: expected ')' before ':' token
R_UNIT_LOG)
include/tree.h: In function 'get_finish':
include/tree.h:5397:46: error: request for member 'm_finish' in something=
return get_range_from_loc (line_table, loc).m_finish;
include/tree.h:5402:29: error: expected ';', ',' or ')' before '&' token
extern void gt_ggc_mx (tree &);
include/tree.h:5403:29: error: expected ';', ',' or ')' before '&' token
extern void gt_pch_nx (tree &);
include/tree.h:5404:29: error: expected ';', ',' or ')' before '&' token
extern void gt_pch_nx (tree &, gt_pointer_operator, void *);
include/tree.h:5413:30: error: unknown type name 'source_range'
set_source_range (tree expr, source_range src_range);
include/tree.h:5415:15: error: unknown type name 'source_range'
inux-gnu/6.1.0/plugin/include/gimple.h:25:0,
from conftest.c:102:
include/tree-ssa-alias.h:97:26: error: unknown type name 'ao_ref'
extern void ao_ref_init (ao_ref *, tree);
include/tree-ssa-alias.h:98:44: error: unknown type name 'ao_ref'
extern void ao_ref_init_from_ptr_and_size (ao_ref *, tree, tree);
include/tree-ssa-alias.h:99:26: error: unknown type name 'ao_ref'
extern tree ao_ref_base (ao_ref *);
include/tree-ssa-alias.h:100:41: error: unknown type name 'ao_ref'
extern alias_set_type ao_ref_alias_set (ao_ref *);
include/tree-ssa-alias.h:101:46: error: unknown type name 'ao_ref'
extern alias_set_type ao_ref_base_alias_set (ao_ref *);
include/tree-ssa-alias.h:105:37: error: unknown type name 'ao_ref'
extern bool ref_may_alias_global_p (ao_ref *);
include/tree-ssa-alias.h:107:33: error: unknown type name 'ao_ref'
extern bool refs_may_alias_p_1 (ao_ref *, ao_ref *, bool);
include/tree-ssa-alias.h:107:43: error: unknown type name 'ao_ref'
include/tree-ssa-alias.h:110:39: error: unknown type name 'gimple'
extern bool ref_maybe_used_by_stmt_p (gimple *, tree);
include/tree-ssa-alias.h:111:39: error: unknown type name 'gimple'
extern bool ref_maybe_used_by_stmt_p (gimple *, ao_ref *);
include/tree-ssa-alias.h:111:49: error: unknown type name 'ao_ref'
include/tree-ssa-alias.h:112:40: error: unknown type name 'gimple'
extern bool stmt_may_clobber_global_p (gimple *);
include/tree-ssa-alias.h:113:37: error: unknown type name 'gimple'
extern bool stmt_may_clobber_ref_p (gimple *, tree);
include/tree-ssa-alias.h:114:39: error: unknown type name 'gimple'
extern bool stmt_may_clobber_ref_p_1 (gimple *, ao_ref *);
include/tree-ssa-alias.h:114:49: error: unknown type name 'ao_ref'
include/tree-ssa-alias.h:115:37: error: unknown type name 'gcall'
extern bool call_may_clobber_ref_p (gcall *, tree);
include/tree-ssa-alias.h:116:39: error: unknown type name 'gcall'
extern bool call_may_clobber_ref_p_1 (gcall *, ao_ref *);
include/tree-ssa-alias.h:116:48: error: unknown type name 'ao_ref'
include/tree-ssa-alias.h:117:31: error: unknown type name 'gimple'
extern bool stmt_kills_ref_p (gimple *, tree);
include/tree-ssa-alias.h:118:31: error: unknown type name 'gimple'
extern bool stmt_kills_ref_p (gimple *, ao_ref *);
include/tree-ssa-alias.h:118:41: error: unknown type name 'ao_ref'
include/tree-ssa-alias.h:119:39: error: unknown type name 'gimple'
extern tree get_continuation_for_phi (gimple *, ao_ref *,
include/tree-ssa-alias.h:119:49: error: unknown type name 'ao_ref'
include/tree-ssa-alias.h:121:21: error: unknown type name 'ao_ref'
void *(*)(ao_ref *, tree, void *, bool *),
include/tree-ssa-alias.h:122:11: error: expected ';', ',' or ')' before '=
void'
void *);
include/tree-ssa-alias.h:123:38: error: unknown type name 'ao_ref'
extern void *walk_non_aliased_vuses (ao_ref *, tree,
include/tree-ssa-alias.h:124:20: error: unknown type name 'ao_ref'
include/tree-ssa-alias.h:126:10: error: expected ';', ',' or ')' before '=
void'
include/tree-ssa-alias.h:129:41: error: unknown type name 'ao_ref'
extern unsigned int walk_aliased_vdefs (ao_ref *, tree,
include/tree-ssa-alias.h:130:15: error: unknown type name 'ao_ref'
bool (*)(ao_ref *, tree, void *),
include/tree-ssa-alias.h:131:6: error: expected ';', ',' or ')' before 'v=
oid'
void *, bitmap *,
include/tree-ssa-alias.h:136:32: error: expected ')' before '&' token
extern void debug (pt_solution &ref);
include/tree-ssa-alias.h:137:20: error: unknown type name 'pt_solution'
extern void debug (pt_solution *ptr);
inux-gnu/6.1.0/plugin/include/gimple.h:26:0,
include/gimple-expr.h:32:52: error: expected ';', ',' or ')' before '=3D'=
token
extern tree create_tmp_var_raw (tree, const char * =3D NULL);
include/gimple-expr.h:33:48: error: expected ';', ',' or ')' before '=3D'=
token
extern tree create_tmp_var (tree, const char * =3D NULL);
include/gimple-expr.h:34:48: error: expected ';', ',' or ')' before '=3D'=
token
extern tree create_tmp_reg (tree, const char * =3D NULL);
include/gimple-expr.h:153:1: error: conflicting types for 'extract_ops_fr=
om_tree'
extract_ops_from_tree (tree expr, enum tree_code *code, tree *op0,
include/gimple-expr.h:38:13: note: previous declaration of 'extract_ops_f=
rom_tree' was here
extern void extract_ops_from_tree (tree, enum tree_code *, tree *, tree =
include/gimple-expr.h: In function 'extract_ops_from_tree':
include/gimple-expr.h:157:3: error: too many arguments to function 'extra=
ct_ops_from_tree'
extract_ops_from_tree (expr, code, op0, op1, &op2);
include/gimple-expr.h:153:1: note: declared here
In file included from conftest.c:102:0:
include/gimple.h: At top level:
include/gimple.h:28:9: error: unknown type name 'gimple'
typedef gimple *gimple_seq_node;
include/gimple.h:41:9: error: expected '=3D', ',', ';', 'asm' or '__attri=
template<typename T> struct remove_pointer { typedef T type; };
include/gimple.h:42:9: error: expected '=3D', ',', ';', 'asm' or '__attri=
template<typename T> struct remove_pointer<T *> { typedef T type; };
include/gimple.h:99:10: error: expected '=3D', ',', ';', 'asm' or '__attr=
include/gimple.h:105:10: error: expected '=3D', ',', ';', 'asm' or '__att=
ribute__' before '<' token
include/gimple.h:274:3: error: unknown type name 'gimple'
gimple *next;
include/gimple.h:275:3: error: unknown type name 'gimple'
gimple *GTY((skip)) prev;
include/gimple.h:283:34: error: expected identifier or '(' before ':' tok=
en
gimple_statement_with_ops_base : public gimple
include/gimple.h:299:29: error: expected identifier or '(' before ':' tok=
en
gimple_statement_with_ops : public gimple_statement_with_ops_base
include/gimple.h:314:41: error: expected identifier or '(' before ':' tok=
en
gimple_statement_with_memory_ops_base : public gimple_statement_with_o=
ps_base
include/gimple.h:329:36: error: expected identifier or '(' before ':' tok=
en
gimple_statement_with_memory_ops :
include/gimple.h:345:9: error: expected identifier or '(' before ':' toke=
n
gcall : public gimple_statement_with_memory_ops_base
include/gimple.h:372:24: error: expected identifier or '(' before ':' tok=
en
gimple_statement_omp : public gimple
include/gimple.h:384:9: error: expected identifier or '(' before ':' toke=
n
gbind : public gimple
include/gimple.h:408:10: error: expected identifier or '(' before ':' tok=
en
gcatch : public gimple
include/gimple.h:423:14: error: expected identifier or '(' before ':' tok=
en
geh_filter : public gimple
include/gimple.h:439:12: error: expected identifier or '(' before ':' tok=
en
geh_else : public gimple
include/gimple.h:450:11: error: expected identifier or '(' before ':' tok=
en
geh_mnt : public gimple
include/gimple.h:461:8: error: expected identifier or '(' before ':' toke=
n
gphi : public gimple
include/gimple.h:480:28: error: expected identifier or '(' before ':' tok=
en
gimple_statement_eh_ctrl : public gimple
include/gimple.h:490:9: error: expected identifier or '(' before ':' toke=
n
gresx : public gimple_statement_eh_ctrl
include/gimple.h:497:16: error: expected identifier or '(' before ':' tok=
en
geh_dispatch : public gimple_statement_eh_ctrl
include/gimple.h:507:8: error: expected identifier or '(' before ':' toke=
n
gtry : public gimple
include/gimple.h:537:24: error: expected identifier or '(' before ':' tok=
en
gimple_statement_wce : public gimple
include/gimple.h:555:8: error: expected identifier or '(' before ':' toke=
n
gasm : public gimple_statement_with_memory_ops_base
include/gimple.h:580:17: error: expected identifier or '(' before ':' tok=
en
gomp_critical : public gimple_statement_omp
include/gimple.h:613:12: error: expected identifier or '(' before ':' tok=
en
gomp_for : public gimple_statement_omp
include/gimple.h:636:40: error: expected identifier or '(' before ':' tok=
en
gimple_statement_omp_parallel_layout : public gimple_statement_omp
include/gimple.h:655:32: error: expected identifier or '(' before ':' tok=
en
gimple_statement_omp_taskreg : public gimple_statement_omp_parallel_la=
yout
include/gimple.h:664:17: error: expected identifier or '(' before ':' tok=
en
gomp_parallel : public gimple_statement_omp_taskreg
include/gimple.h:672:15: error: expected identifier or '(' before ':' tok=
en
gomp_target : public gimple_statement_omp_parallel_layout
include/gimple.h:681:13: error: expected identifier or '(' before ':' tok=
en
gomp_task : public gimple_statement_omp_taskreg
include/gimple.h:703:17: error: expected identifier or '(' before ':' tok=
en
gomp_sections : public gimple_statement_omp
include/gimple.h:722:17: error: expected identifier or '(' before ':' tok=
en
gomp_continue : public gimple
include/gimple.h:736:38: error: expected identifier or '(' before ':' tok=
en
gimple_statement_omp_single_layout : public gimple_statement_omp
include/gimple.h:745:15: error: expected identifier or '(' before ':' tok=
en
gomp_single : public gimple_statement_omp_single_layout
include/gimple.h:752:14: error: expected identifier or '(' before ':' tok=
en
gomp_teams : public gimple_statement_omp_single_layout
include/gimple.h:759:16: error: expected identifier or '(' before ':' tok=
en
gomp_ordered : public gimple_statement_omp_single_layout
include/gimple.h:771:20: error: expected identifier or '(' before ':' tok=
en
gomp_atomic_load : public gimple
include/gimple.h:783:44: error: expected identifier or '(' before ':' tok=
en
gimple_statement_omp_atomic_store_layout : public gimple
include/gimple.h:792:21: error: expected identifier or '(' before ':' tok=
en
gomp_atomic_store :
include/gimple.h:800:31: error: expected identifier or '(' before ':' tok=
en
gimple_statement_omp_return :
include/gimple.h:836:16: error: expected identifier or '(' before ':' tok=
en
gtransaction : public gimple_statement_with_memory_ops_base
include/gimple.h:861:9: error: expected identifier or '(' before ':' toke=
n
gcond : public gimple_statement_with_ops
include/gimple.h:872:10: error: expected identifier or '(' before ':' tok=
en
gdebug : public gimple_statement_with_ops
include/gimple.h:882:9: error: expected identifier or '(' before ':' toke=
n
ggoto : public gimple_statement_with_ops
include/gimple.h:892:10: error: expected identifier or '(' before ':' tok=
en
glabel : public gimple_statement_with_ops
include/gimple.h:902:11: error: expected identifier or '(' before ':' tok=
en
gswitch : public gimple_statement_with_ops
include/gimple.h:912:11: error: expected identifier or '(' before ':' tok=
en
gassign : public gimple_statement_with_memory_ops
include/gimple.h:923:11: error: expected identifier or '(' before ':' tok=
en
greturn : public gimple_statement_with_memory_ops
include/gimple.h:928:10: error: expected '=3D', ',', ';', 'asm' or '__att=
template <>
include/gimple.h:936:10: error: expected '=3D', ',', ';', 'asm' or '__att=
template <>
include/gimple.h:944:10: error: expected '=3D', ',', ';', 'asm' or '__att=
template <>
include/gimple.h:952:10: error: expected '=3D', ',', ';', 'asm' or '__att=
template <>
include/gimple.h:960:10: error: expected '=3D', ',', ';', 'asm' or '__att=
template <>
include/gimple.h:968:10: error: expected '=3D', ',', ';', 'asm' or '__att=
template <>
include/gimple.h:976:10: error: expected '=3D', ',', ';', 'asm' or '__att=
template <>
include/gimple.h:984:10: error: expected '=3D', ',', ';', 'asm' or '__att=
template <>
include/gimple.h:992:10: error: expected '=3D', ',', ';', 'asm' or '__att=
template <>
include/gimple.h:1000:10: error: expected '=3D', ',', ';', 'asm' or '__at=
tribute__' before '<' token
template <>
include/gimple.h:1008:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1016:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1024:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1032:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1040:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1048:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1056:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1064:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1072:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1080:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1088:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1096:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1104:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1112:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1120:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1128:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1136:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1144:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1152:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1160:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1168:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1176:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1184:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1192:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1200:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1208:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1216:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1224:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1232:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1240:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1248:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1256:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1264:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1272:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1280:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1288:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1296:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1304:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1312:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1320:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1328:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1336:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1344:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1352:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1360:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1368:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1376:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1384:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1392:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1409:8: error: unknown type name 'gimple'
extern gimple *currently_expanding_gimple_stmt;
include/gimple.h:1412:1: error: unknown type name 'gimple'
gimple *gimple_alloc_stat (enum gimple_code, unsigned MEM_STAT_DECL);
include/gimple.h:1412:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1413:1: error: unknown type name 'greturn'
greturn *gimple_build_return (tree);
include/gimple.h:1413:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1414:36: error: unknown type name 'gcall'
void gimple_call_reset_alias_info (gcall *);
include/gimple.h:1415:1: error: unknown type name 'gcall'
gcall *gimple_build_call_vec (tree, vec<tree> );
include/gimple.h:1415:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1415:37: error: unknown type name 'vec'
include/gimple.h:1416:1: error: unknown type name 'gcall'
gcall *gimple_build_call (tree, unsigned, ...);
include/gimple.h:1416:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1417:1: error: unknown type name 'gcall'
gcall *gimple_build_call_valist (tree, unsigned, va_list);
include/gimple.h:1417:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1418:1: error: unknown type name 'gcall'
gcall *gimple_build_call_internal (enum internal_fn, unsigned, ...);
include/gimple.h:1418:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1419:1: error: unknown type name 'gcall'
gcall *gimple_build_call_internal_vec (enum internal_fn, vec<tree> );
include/gimple.h:1419:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1419:58: error: unknown type name 'vec'
include/gimple.h:1420:1: error: unknown type name 'gcall'
gcall *gimple_build_call_from_tree (tree);
include/gimple.h:1420:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1421:1: error: unknown type name 'gassign'
gassign *gimple_build_assign (tree, tree CXX_MEM_STAT_INFO);
include/gimple.h:1421:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1422:1: error: unknown type name 'gassign'
gassign *gimple_build_assign (tree, enum tree_code,
include/gimple.h:1422:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1422:10: error: conflicting types for 'gimple_build_assi=
gn'
include/gimple.h:1421:10: note: previous declaration of 'gimple_build_ass=
ign' was here
include/gimple.h:1424:1: error: unknown type name 'gassign'
include/gimple.h:1424:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1424:10: error: conflicting types for 'gimple_build_assi=
gn'
ign' was here
include/gimple.h:1426:1: error: unknown type name 'gassign'
gassign *gimple_build_assign (tree, enum tree_code, tree CXX_MEM_STAT_IN=
FO);
include/gimple.h:1426:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1426:10: error: conflicting types for 'gimple_build_assi=
gn'
FO);
ign' was here
include/gimple.h:1427:1: error: unknown type name 'gcond'
gcond *gimple_build_cond (enum tree_code, tree, tree, tree, tree);
include/gimple.h:1427:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1428:1: error: unknown type name 'gcond'
gcond *gimple_build_cond_from_tree (tree, tree, tree);
include/gimple.h:1428:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1429:43: error: unknown type name 'gcond'
void gimple_cond_set_condition_from_tree (gcond *, tree);
include/gimple.h:1430:1: error: unknown type name 'glabel'
glabel *gimple_build_label (tree label);
include/gimple.h:1430:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1431:1: error: unknown type name 'ggoto'
ggoto *gimple_build_goto (tree dest);
include/gimple.h:1431:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1432:1: error: unknown type name 'gimple'
gimple *gimple_build_nop (void);
include/gimple.h:1432:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1433:1: error: unknown type name 'gbind'
gbind *gimple_build_bind (tree, gimple_seq, tree);
include/gimple.h:1433:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1434:1: error: unknown type name 'gasm'
gasm *gimple_build_asm_vec (const char *, vec<tree, va_gc> *,
include/gimple.h:1434:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1434:43: error: unknown type name 'vec'
include/gimple.h:1434:53: error: unknown type name 'va_gc'
include/gimple.h:1435:6: error: unknown type name 'vec'
vec<tree, va_gc> *, vec<tree, va_gc> *,
include/gimple.h:1435:16: error: unknown type name 'va_gc'
include/gimple.h:1435:26: error: unknown type name 'vec'
include/gimple.h:1435:36: error: unknown type name 'va_gc'
include/gimple.h:1436:6: error: unknown type name 'vec'
include/gimple.h:1436:16: error: unknown type name 'va_gc'
include/gimple.h:1437:1: error: unknown type name 'gcatch'
gcatch *gimple_build_catch (tree, gimple_seq);
include/gimple.h:1437:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1438:1: error: unknown type name 'geh_filter'
geh_filter *gimple_build_eh_filter (tree, gimple_seq);
include/gimple.h:1438:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1439:1: error: unknown type name 'geh_mnt'
geh_mnt *gimple_build_eh_must_not_throw (tree);
include/gimple.h:1439:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1440:1: error: unknown type name 'geh_else'
geh_else *gimple_build_eh_else (gimple_seq, gimple_seq);
include/gimple.h:1440:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1441:1: error: unknown type name 'gtry'
gtry *gimple_build_try (gimple_seq, gimple_seq,
include/gimple.h:1441:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1443:1: error: unknown type name 'gimple'
gimple *gimple_build_wce (gimple_seq);
include/gimple.h:1443:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1444:1: error: unknown type name 'gresx'
gresx *gimple_build_resx (int);
include/gimple.h:1444:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1445:1: error: unknown type name 'gswitch'
gswitch *gimple_build_switch_nlabels (unsigned, tree, tree);
include/gimple.h:1445:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1446:1: error: unknown type name 'gswitch'
gswitch *gimple_build_switch (tree, tree, vec<tree> );
include/gimple.h:1446:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1446:43: error: unknown type name 'vec'
include/gimple.h:1447:1: error: unknown type name 'geh_dispatch'
geh_dispatch *gimple_build_eh_dispatch (int);
include/gimple.h:1447:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1448:1: error: unknown type name 'gdebug'
gdebug *gimple_build_debug_bind_stat (tree, tree, gimple * MEM_STAT_DECL=
include/gimple.h:1448:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1448:51: error: unknown type name 'gimple'
include/gimple.h:1451:1: error: unknown type name 'gdebug'
gdebug *gimple_build_debug_source_bind_stat (tree, tree, gimple * MEM_ST=
AT_DECL);
include/gimple.h:1451:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1451:58: error: unknown type name 'gimple'
AT_DECL);
include/gimple.h:1454:1: error: unknown type name 'gomp_critical'
gomp_critical *gimple_build_omp_critical (gimple_seq, tree, tree);
include/gimple.h:1454:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1455:1: error: unknown type name 'gomp_for'
gomp_for *gimple_build_omp_for (gimple_seq, int, tree, size_t, gimple_se=
q);
include/gimple.h:1455:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1456:1: error: unknown type name 'gomp_parallel'
gomp_parallel *gimple_build_omp_parallel (gimple_seq, tree, tree, tree);=
include/gimple.h:1456:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1457:1: error: unknown type name 'gomp_task'
gomp_task *gimple_build_omp_task (gimple_seq, tree, tree, tree, tree,
include/gimple.h:1457:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1459:1: error: unknown type name 'gimple'
gimple *gimple_build_omp_section (gimple_seq);
include/gimple.h:1459:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1460:1: error: unknown type name 'gimple'
gimple *gimple_build_omp_master (gimple_seq);
include/gimple.h:1460:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1461:1: error: unknown type name 'gimple'
gimple *gimple_build_omp_grid_body (gimple_seq);
include/gimple.h:1461:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1462:1: error: unknown type name 'gimple'
gimple *gimple_build_omp_taskgroup (gimple_seq);
include/gimple.h:1462:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1463:1: error: unknown type name 'gomp_continue'
gomp_continue *gimple_build_omp_continue (tree, tree);
include/gimple.h:1463:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1464:1: error: unknown type name 'gomp_ordered'
gomp_ordered *gimple_build_omp_ordered (gimple_seq, tree);
include/gimple.h:1464:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1465:1: error: unknown type name 'gimple'
gimple *gimple_build_omp_return (bool);
include/gimple.h:1465:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1466:1: error: unknown type name 'gomp_sections'
gomp_sections *gimple_build_omp_sections (gimple_seq, tree);
include/gimple.h:1466:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1467:1: error: unknown type name 'gimple'
gimple *gimple_build_omp_sections_switch (void);
include/gimple.h:1467:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1468:1: error: unknown type name 'gomp_single'
gomp_single *gimple_build_omp_single (gimple_seq, tree);
include/gimple.h:1468:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1469:1: error: unknown type name 'gomp_target'
gomp_target *gimple_build_omp_target (gimple_seq, int, tree);
include/gimple.h:1469:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1470:1: error: unknown type name 'gomp_teams'
gomp_teams *gimple_build_omp_teams (gimple_seq, tree);
include/gimple.h:1470:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1471:1: error: unknown type name 'gomp_atomic_load'
gomp_atomic_load *gimple_build_omp_atomic_load (tree, tree);
include/gimple.h:1471:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1472:1: error: unknown type name 'gomp_atomic_store'
gomp_atomic_store *gimple_build_omp_atomic_store (tree);
include/gimple.h:1472:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1473:1: error: unknown type name 'gtransaction'
gtransaction *gimple_build_transaction (gimple_seq);
include/gimple.h:1473:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1474:48: error: unknown type name 'gimple'
extern void gimple_seq_add_stmt (gimple_seq *, gimple *);
include/gimple.h:1475:63: error: unknown type name 'gimple'
extern void gimple_seq_add_stmt_without_update (gimple_seq *, gimple *);=
include/gimple.h:1478:59: error: unknown type name 'gimple_stmt_iterator'=
extern void annotate_all_with_location_after (gimple_seq, gimple_stmt_it=
erator,
include/gimple.h:1483:39: error: unknown type name 'gimple'
bool gimple_call_same_target_p (const gimple *, const gimple *);
include/gimple.h:1483:55: error: unknown type name 'gimple'
include/gimple.h:1484:30: error: unknown type name 'gimple'
int gimple_call_flags (const gimple *);
include/gimple.h:1485:34: error: unknown type name 'gcall'
int gimple_call_arg_flags (const gcall *, unsigned);
include/gimple.h:1486:37: error: unknown type name 'gcall'
int gimple_call_return_flags (const gcall *);
include/gimple.h:1487:28: error: unknown type name 'gimple'
bool gimple_assign_copy_p (gimple *);
include/gimple.h:1488:37: error: unknown type name 'gimple'
bool gimple_assign_ssa_name_copy_p (gimple *);
include/gimple.h:1489:33: error: unknown type name 'gimple'
bool gimple_assign_unary_nop_p (gimple *);
include/gimple.h:1490:21: error: unknown type name 'gimple'
void gimple_set_bb (gimple *, basic_block);
include/gimple.h:1491:39: error: unknown type name 'gimple_stmt_iterator'=
void gimple_assign_set_rhs_from_tree (gimple_stmt_iterator *, tree);
include/gimple.h:1492:38: error: unknown type name 'gimple_stmt_iterator'=
void gimple_assign_set_rhs_with_ops (gimple_stmt_iterator *, enum tree_c=
ode,
include/gimple.h:1494:28: error: unknown type name 'gimple'
tree gimple_get_lhs (const gimple *);
include/gimple.h:1495:22: error: unknown type name 'gimple'
void gimple_set_lhs (gimple *, tree);
include/gimple.h:1496:1: error: unknown type name 'gimple'
gimple *gimple_copy (gimple *);
include/gimple.h:1496:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1496:22: error: unknown type name 'gimple'
include/gimple.h:1497:37: error: unknown type name 'gimple'
bool gimple_has_side_effects (const gimple *);
include/gimple.h:1498:29: error: unknown type name 'gimple'
bool gimple_could_trap_p_1 (gimple *, bool, bool);
include/gimple.h:1499:27: error: unknown type name 'gimple'
bool gimple_could_trap_p (gimple *);
include/gimple.h:1500:38: error: unknown type name 'gimple'
bool gimple_assign_rhs_could_trap_p (gimple *);
include/gimple.h:1504:1: error: unknown type name 'gcall'
gcall *gimple_call_copy_skip_args (gcall *, bitmap);
include/gimple.h:1504:1: note: use 'struct' keyword to refer to the type
include/gimple.h:1504:36: error: unknown type name 'gcall'
include/gimple.h:1509:49: error: unknown type name 'gimple'
extern bool gimple_ior_addresses_taken (bitmap, gimple *);
include/gimple.h:1510:59: error: unknown type name 'gimple'
extern bool gimple_builtin_call_types_compatible_p (const gimple *, tree=
include/gimple.h:1511:8: error: unknown type name 'combined_fn'
extern combined_fn gimple_call_combined_fn (const gimple *);
include/gimple.h:1511:51: error: unknown type name 'gimple'
include/gimple.h:1512:42: error: unknown type name 'gimple'
extern bool gimple_call_builtin_p (const gimple *);
include/gimple.h:1513:42: error: unknown type name 'gimple'
extern bool gimple_call_builtin_p (const gimple *, enum built_in_class);=
include/gimple.h:1513:13: error: conflicting types for 'gimple_call_built=
in_p'
include/gimple.h:1512:13: note: previous declaration of 'gimple_call_buil=
tin_p' was here
include/gimple.h:1514:42: error: unknown type name 'gimple'
extern bool gimple_call_builtin_p (const gimple *, enum built_in_functio=
n);
include/gimple.h:1514:13: error: conflicting types for 'gimple_call_built=
in_p'
n);
tin_p' was here
include/gimple.h:1515:49: error: unknown type name 'gasm'
extern bool gimple_asm_clobbers_memory_p (const gasm *);
include/gimple.h:1517:32: error: unknown type name 'gimple'
extern bool nonfreeing_call_p (gimple *);
include/gimple.h:1518:32: error: unknown type name 'gimple'
extern bool nonbarrier_call_p (gimple *);
include/gimple.h:1519:34: error: unknown type name 'gimple'
extern bool infer_nonnull_range (gimple *, tree);
include/gimple.h:1520:49: error: unknown type name 'gimple'
extern bool infer_nonnull_range_by_dereference (gimple *, tree);
include/gimple.h:1521:47: error: unknown type name 'gimple'
extern bool infer_nonnull_range_by_attribute (gimple *, tree);
include/gimple.h:1522:34: error: expected ')' before '<' token
extern void sort_case_labels (vec<tree>);
include/gimple.h:1523:54: error: expected ')' before '<' token
extern void preprocess_case_label_vec_for_gimple (vec<tree>, tree, tree =
include/gimple.h:1526:63: error: unknown type name 'gimple'
extern void maybe_remove_unused_call_args (struct function *, gimple *);=
include/gimple.h: In function 'gimple_stmt_max_uid':
include/gimple.h:1541:12: error: 'struct function' has no member named 'l=
ast_stmt_uid'
return fn->last_stmt_uid;
include/gimple.h: In function 'set_gimple_stmt_max_uid':
include/gimple.h:1548:5: error: 'struct function' has no member named 'la=
st_stmt_uid'
fn->last_stmt_uid =3D maxid;
include/gimple.h: In function 'inc_gimple_stmt_max_uid':
include/gimple.h:1555:12: error: 'struct function' has no member named 'l=
ast_stmt_uid'
return fn->last_stmt_uid++;
include/gimple.h:1569:15: error: unknown type name 'gimple'
static inline gimple *
include/gimple.h:1579:15: error: unknown type name 'gbind'
static inline gbind *
include/gimple.h: In function 'gimple_seq_first_stmt_as_a_bind':
include/gimple.h:1583:10: error: 'as_a' undeclared (first use in this fun=
ction)
return as_a <gbind *> (n);
include/gimple.h:1583:16: error: 'gbind' undeclared (first use in this fu=
nction)
include/gimple.h:1583:23: error: expected expression before '>' token
include/gimple.h: In function 'gimple_seq_last':
include/gimple.h:1592:15: error: request for member 'prev' in something n=
ot a structure or union
return s ? s->prev : NULL;
include/gimple.h:1598:15: error: unknown type name 'gimple'
include/gimple.h: In function 'gimple_seq_set_last':
include/gimple.h:1611:8: error: request for member 'prev' in something no=
(*ps)->prev =3D last;
include/gimple.h:1635:29: error: unknown type name 'gimple'
gimple_seq_alloc_with_stmt (gimple *stmt)
include/gimple.h: In function 'bb_seq':
include/gimple.h:1648:15: error: 'const struct basic_block_def' has no me=
mber named 'flags'
return (!(bb->flags & BB_RTL)) ? bb->il.gimple.seq : NULL;
include/gimple.h:1648:38: error: 'const struct basic_block_def' has no me=
mber named 'il'
include/gimple.h: In function 'bb_seq_addr':
include/gimple.h:1654:15: error: 'struct basic_block_def' has no member n=
amed 'flags'
return (!(bb->flags & BB_RTL)) ? &bb->il.gimple.seq : NULL;
include/gimple.h:1654:39: error: 'struct basic_block_def' has no member n=
amed 'il'
In file included from /home/lschnorr/spack-orion/opt/spack/linux-x86_64/g=
cc-6.1.1/gcc-6.1.0-7cljeqxjfpkacgtkxus4p55nsms53dnv/lib64/gcc/x86_64-pc-l=
from conftest.c:100:
include/gimple.h: In function 'set_bb_seq':
include/gimple.h:1662:28: error: 'struct basic_block_def' has no member n=
amed 'flags'
gcc_checking_assert (!(bb->flags & BB_RTL));
t'
include/gimple.h:1663:5: error: 'struct basic_block_def' has no member na=
med 'il'
bb->il.gimple.seq =3D seq;
include/gimple.h:1670:20: error: unknown type name 'gimple'
gimple_code (const gimple *g)
include/gimple.h: In function 'gimple_code':
include/gimple.h:1672:11: error: request for member 'code' in something n=
return g->code;
include/gimple.h:1689:29: error: unknown type name 'gimple'
gimple_statement_structure (gimple *gs)
include/gimple.h:1699:27: error: unknown type name 'gimple'
gimple_has_substatements (gimple *g)
include/gimple.h:1734:18: error: unknown type name 'gimple'
gimple_bb (const gimple *g)
include/gimple.h: In function 'gimple_bb':
include/gimple.h:1736:11: error: request for member 'bb' in something not=
return g->bb;
include/gimple.h:1743:21: error: unknown type name 'gimple'
gimple_block (const gimple *g)
inux-gnu/6.1.0/plugin/include/coretypes.h:350:0,
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:29,
include/gimple.h: In function 'gimple_block':
include/gimple.h:1745:27: error: request for member 'location' in somethi=
ng not a structure or union
return LOCATION_BLOCK (g->location);
include/input.h:59:27: note: in definition of macro 'LOCATION_BLOCK'
((tree) ((IS_ADHOC_LOC (LOC)) ? get_data_from_adhoc_loc (line_table, (=
LOC)) \
include/input.h:59:73: note: in definition of macro 'LOCATION_BLOCK'
LOC)) \
include/gimple.h:1752:19: error: unknown type name 'gimple'
gimple_set_block (gimple *g, tree block)
include/gimple.h:1761:24: error: unknown type name 'gimple'
gimple_location (const gimple *g)
include/gimple.h: In function 'gimple_location':
include/gimple.h:1763:11: error: request for member 'location' in somethi=
return g->location;
include/gimple.h:1770:29: error: unknown type name 'gimple'
gimple_location_safe (const gimple *g)
include/gimple.h:1778:22: error: unknown type name 'gimple'
gimple_set_location (gimple *g, location_t location)
include/gimple.h:1787:28: error: unknown type name 'gimple'
gimple_has_location (const gimple *g)
include/gimple.h:1796:24: error: unknown type name 'gimple'
gimple_filename (const gimple *stmt)
include/gimple.h:1805:22: error: unknown type name 'gimple'
gimple_lineno (const gimple *stmt)
include/gimple.h:1823:28: error: unknown type name 'gimple'
gimple_no_warning_p (const gimple *stmt)
include/gimple.h: In function 'gimple_no_warning_p':
include/gimple.h:1825:14: error: request for member 'no_warning' in somet=
hing not a structure or union
return stmt->no_warning;
include/gimple.h:1831:24: error: unknown type name 'gimple'
gimple_set_no_warning (gimple *stmt, bool no_warning)
include/gimple.h:1849:21: error: unknown type name 'gimple'
gimple_set_visited (gimple *stmt, bool visited_p)
include/gimple.h:1867:19: error: unknown type name 'gimple'
gimple_visited_p (gimple *stmt)
include/gimple.h:1884:17: error: unknown type name 'gimple'
gimple_set_plf (gimple *stmt, enum plf_mask plf, bool val_p)
include/gimple.h:1904:13: error: unknown type name 'gimple'
gimple_plf (gimple *stmt, enum plf_mask plf)
include/gimple.h:1918:17: error: unknown type name 'gimple'
gimple_set_uid (gimple *g, unsigned uid)
include/gimple.h:1932:19: error: unknown type name 'gimple'
gimple_uid (const gimple *g)
include/gimple.h: In function 'gimple_uid':
include/gimple.h:1934:11: error: request for member 'uid' in something no=
return g->uid;
include/gimple.h:1941:24: error: unknown type name 'gimple'
gimple_init_singleton (gimple *g)
include/gimple.h:1951:23: error: unknown type name 'gimple'
gimple_has_ops (const gimple *g)
include/gimple.h:1956:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1964:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1975:27: error: unknown type name 'gimple'
gimple_has_mem_ops (const gimple *g)
include/gimple.h:1980:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1988:10: error: expected '=3D', ',', ';', 'asm' or '__at=
template <>
include/gimple.h:1999:23: error: unknown type name 'gimple'
gimple_use_ops (const gimple *g)
include/gimple.h: In function 'gimple_use_ops':
include/gimple.h:2001:9: error: unknown type name 'gimple_statement_with_=
ops'
const gimple_statement_with_ops *ops_stmt =3D
include/gimple.h:2002:5: error: 'dyn_cast' undeclared (first use in this =
function)
dyn_cast <const gimple_statement_with_ops *> (g);
include/gimple.h:2002:15: error: expected expression before 'const'
include/gimple.h:2005:18: error: request for member 'use_ops' in somethin=
return ops_stmt->use_ops;
include/gimple.h:2012:21: error: unknown type name 'gimple'
gimple_set_use_ops (gimple *g, struct use_optype_d *use)
include/gimple.h:2023:20: error: unknown type name 'gimple'
gimple_vuse (const gimple *g)
include/gimple.h: In function 'gimple_vuse':
include/gimple.h:2025:9: error: unknown type name 'gimple_statement_with_=
memory_ops'
const gimple_statement_with_memory_ops *mem_ops_stmt =3D
include/gimple.h:2026:6: error: 'dyn_cast' undeclared (first use in this =
function)
dyn_cast <const gimple_statement_with_memory_ops *> (g);
include/gimple.h:2026:16: error: expected expression before 'const'
include/gimple.h:2029:22: error: request for member 'vuse' in something n=
return mem_ops_stmt->vuse;
include/gimple.h:2035:20: error: unknown type name 'gimple'
gimple_vdef (const gimple *g)
include/gimple.h: In function 'gimple_vdef':
include/gimple.h:2037:9: error: unknown type name 'gimple_statement_with_=
memory_ops'
include/gimple.h:2038:6: error: 'dyn_cast' undeclared (first use in this =
function)
include/gimple.h:2038:16: error: expected expression before 'const'
include/gimple.h:2041:22: error: request for member 'vdef' in something n=
return mem_ops_stmt->vdef;
include/gimple.h:2047:18: error: unknown type name 'gimple'
gimple_vuse_ptr (gimple *g)
include/gimple.h:2059:18: error: unknown type name 'gimple'
gimple_vdef_ptr (gimple *g)
include/gimple.h:2071:18: error: unknown type name 'gimple'
gimple_set_vuse (gimple *g, tree vuse)
include/gimple.h:2081:18: error: unknown type name 'gimple'
gimple_set_vdef (gimple *g, tree vdef)
include/gimple.h:2093:26: error: unknown type name 'gimple'
gimple_modified_p (const gimple *g)
include/gimple.h: In function 'gimple_modified_p':
include/gimple.h:2095:41: error: request for member 'modified' in somethi=
return (gimple_has_ops (g)) ? (bool) g->modified : false;
include/gimple.h:2103:22: error: unknown type name 'gimple'
gimple_set_modified (gimple *s, bool modifiedp)
include/gimple.h:2117:25: error: unknown type name 'gimple'
gimple_expr_code (const gimple *stmt)
include/gimple.h: In function 'gimple_expr_code':
include/gimple.h:2121:33: error: request for member 'subcode' in somethin=
return (enum tree_code) stmt->subcode;
include/gimple.h:2133:32: error: unknown type name 'gimple'
gimple_has_volatile_ops (const gimple *stmt)
include/gimple.h: In function 'gimple_has_volatile_ops':
include/gimple.h:2136:16: error: request for member 'has_volatile_ops' in=
something not a structure or union
return stmt->has_volatile_ops;
include/gimple.h:2145:30: error: unknown type name 'gimple'
gimple_set_has_volatile_ops (gimple *stmt, bool volatilep)
include/gimple.h:2154:30: error: unknown type name 'gimple'
gimple_in_transaction (const gimple *stmt)
include/gimple.h:2162:29: error: unknown type name 'gimple'
gimple_references_memory_p (gimple *stmt)
include/gimple.h:2171:27: error: unknown type name 'gimple'
gimple_omp_subcode (const gimple *s)
include/gimple.h: In function 'gimple_omp_subcode':
include/gimple.h:2175:11: error: request for member 'subcode' in somethin=
return s->subcode;
include/gimple.h:2181:25: error: unknown type name 'gimple'
gimple_omp_set_subcode (gimple *s, unsigned int subcode)
include/gimple.h:2192:31: error: unknown type name 'gimple'
gimple_omp_return_set_nowait (gimple *s)
include/gimple.h:2203:35: error: unknown type name 'gimple'
gimple_omp_return_nowait_p (const gimple *g)
include/gimple.h:2213:28: error: unknown type name 'gimple'
gimple_omp_return_set_lhs (gimple *g, tree lhs)
include/gimple.h:2224:30: error: unknown type name 'gimple'
gimple_omp_return_lhs (const gimple *g)
include/gimple.h: In function 'gimple_omp_return_lhs':
include/gimple.h:2226:9: error: unknown type name 'gimple_statement_omp_r=
eturn'
const gimple_statement_omp_return *omp_return_stmt =3D
include/gimple.h:2227:5: error: 'as_a' undeclared (first use in this func=
tion)
as_a <const gimple_statement_omp_return *> (g);
include/gimple.h:2227:11: error: expected expression before 'const'
include/gimple.h:2228:25: error: request for member 'val' in something no=
return omp_return_stmt->val;
include/gimple.h:2235:28: error: unknown type name 'gimple'
gimple_omp_return_lhs_ptr (gimple *g)
include/gimple.h:2247:34: error: unknown type name 'gimple'
gimple_omp_section_last_p (const gimple *g)
include/gimple.h:2257:30: error: unknown type name 'gimple'
gimple_omp_section_set_last (gimple *g)
include/gimple.h:2268:39: error: unknown type name 'gimple'
gimple_omp_parallel_combined_p (const gimple *g)
include/gimple.h:2279:37: error: unknown type name 'gimple'
gimple_omp_parallel_set_combined_p (gimple *g, bool combined_p)
include/gimple.h:2293:39: error: unknown type name 'gimple'
gimple_omp_atomic_need_value_p (const gimple *g)
include/gimple.h:2304:35: error: unknown type name 'gimple'
gimple_omp_atomic_set_need_value (gimple *g)
include/gimple.h:2316:36: error: unknown type name 'gimple'
gimple_omp_atomic_seq_cst_p (const gimple *g)
include/gimple.h:2327:32: error: unknown type name 'gimple'
gimple_omp_atomic_set_seq_cst (gimple *g)
include/gimple.h:2338:23: error: unknown type name 'gimple'
gimple_num_ops (const gimple *gs)
include/gimple.h: In function 'gimple_num_ops':
include/gimple.h:2340:12: error: request for member 'num_ops' in somethin=
return gs->num_ops;
include/gimple.h:2347:21: error: unknown type name 'gimple'
gimple_set_num_ops (gimple *gs, unsigned num_ops)
include/gimple.h:2356:13: error: unknown type name 'gimple'
gimple_ops (gimple *gs)
include/gimple.h:2373:18: error: unknown type name 'gimple'
gimple_op (const gimple *gs, unsigned i)
include/gimple.h: In function 'gimple_op':
include/gimple.h:2378:14: warning: implicit declaration of function 'gimp=
le_ops' [-Wimplicit-function-declaration]
return gimple_ops (CONST_CAST_GIMPLE (gs))[i];
include/system.h:1081:42: error: unknown type name 'gimple'
#define CONST_CAST_GIMPLE(X) CONST_CAST (gimple *, (X))
include/system.h:1057:63: note: in definition of macro 'CONST_CAST2'
#define CONST_CAST2(TOTYPE,FROMTYPE,X) ((__extension__(union {FROMTYPE _=
q; TOTYPE _nq;})(X))._nq)
include/system.h:1081:30: note: in expansion of macro 'CONST_CAST'
include/gimple.h:2378:26: note: in expansion of macro 'CONST_CAST_GIMPLE'=
include/system.h:1057:76: note: in definition of macro 'CONST_CAST2'
include/gimple.h:2378:49: error: subscripted value is neither array nor p=
ointer nor vector
include/gimple.h:2387:16: error: unknown type name 'gimple'
gimple_op_ptr (gimple *gs, unsigned i)
include/gimple.h:2401:16: error: unknown type name 'gimple'
gimple_set_op (gimple *gs, unsigned i, tree op)
include/gimple.h:2415:25: error: unknown type name 'gimple'
is_gimple_assign (const gimple *gs)
include/gimple.h:2432:26: error: unknown type name 'gassign'
gimple_assign_lhs (const gassign *gs)
include/gimple.h: In function 'gimple_assign_lhs':
include/gimple.h:2434:12: error: request for member 'op' in something not=
return gs->op[0];
include/gimple.h:2438:26: error: unknown type name 'gimple'
gimple_assign_lhs (const gimple *gs)
include/gimple.h:2438:1: error: redefinition of 'gimple_assign_lhs'
include/gimple.h:2432:1: note: previous definition of 'gimple_assign_lhs'=
was here
include/gimple.h:2440:9: error: unknown type name 'gassign'
const gassign *ass =3D GIMPLE_CHECK2<const gassign *> (gs);
include/gimple.h:2440:24: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:2440:38: error: expected expression before 'const'
include/gimple.h:2448:24: error: unknown type name 'gassign'
gimple_assign_lhs_ptr (gassign *gs)
include/gimple.h:2454:24: error: unknown type name 'gimple'
gimple_assign_lhs_ptr (gimple *gs)
include/gimple.h:2464:24: error: unknown type name 'gassign'
gimple_assign_set_lhs (gassign *gs, tree lhs)
include/gimple.h:2473:24: error: unknown type name 'gimple'
gimple_assign_set_lhs (gimple *gs, tree lhs)
include/gimple.h:2483:27: error: unknown type name 'gassign'
gimple_assign_rhs1 (const gassign *gs)
include/gimple.h: In function 'gimple_assign_rhs1':
include/gimple.h:2485:12: error: request for member 'op' in something not=
return gs->op[1];
include/gimple.h:2489:27: error: unknown type name 'gimple'
gimple_assign_rhs1 (const gimple *gs)
include/gimple.h:2489:1: error: redefinition of 'gimple_assign_rhs1'
include/gimple.h:2483:1: note: previous definition of 'gimple_assign_rhs1=
' was here
include/gimple.h:2491:9: error: unknown type name 'gassign'
include/gimple.h:2491:24: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:2491:38: error: expected expression before 'const'
include/gimple.h:2500:25: error: unknown type name 'gassign'
gimple_assign_rhs1_ptr (gassign *gs)
include/gimple.h:2506:25: error: unknown type name 'gimple'
gimple_assign_rhs1_ptr (gimple *gs)
include/gimple.h:2515:25: error: unknown type name 'gassign'
gimple_assign_set_rhs1 (gassign *gs, tree rhs)
include/gimple.h:2521:25: error: unknown type name 'gimple'
gimple_assign_set_rhs1 (gimple *gs, tree rhs)
include/gimple.h:2532:27: error: unknown type name 'gassign'
gimple_assign_rhs2 (const gassign *gs)
include/gimple.h: In function 'gimple_assign_rhs2':
include/gimple.h:2535:14: error: request for member 'op' in something not=
return gs->op[2];
include/gimple.h:2541:27: error: unknown type name 'gimple'
gimple_assign_rhs2 (const gimple *gs)
include/gimple.h:2541:1: error: redefinition of 'gimple_assign_rhs2'
include/gimple.h:2532:1: note: previous definition of 'gimple_assign_rhs2=
' was here
include/gimple.h:2543:9: error: unknown type name 'gassign'
include/gimple.h:2543:24: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:2543:38: error: expected expression before 'const'
include/gimple.h:2552:25: error: unknown type name 'gassign'
gimple_assign_rhs2_ptr (gassign *gs)
include/gimple.h:2559:25: error: unknown type name 'gimple'
gimple_assign_rhs2_ptr (gimple *gs)
include/gimple.h:2569:25: error: unknown type name 'gassign'
gimple_assign_set_rhs2 (gassign *gs, tree rhs)
include/gimple.h:2576:25: error: unknown type name 'gimple'
gimple_assign_set_rhs2 (gimple *gs, tree rhs)
include/gimple.h:2586:27: error: unknown type name 'gassign'
gimple_assign_rhs3 (const gassign *gs)
include/gimple.h: In function 'gimple_assign_rhs3':
include/gimple.h:2589:14: error: request for member 'op' in something not=
return gs->op[3];
include/gimple.h:2595:27: error: unknown type name 'gimple'
gimple_assign_rhs3 (const gimple *gs)
include/gimple.h:2595:1: error: redefinition of 'gimple_assign_rhs3'
include/gimple.h:2586:1: note: previous definition of 'gimple_assign_rhs3=
' was here
include/gimple.h:2597:9: error: unknown type name 'gassign'
include/gimple.h:2597:24: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:2597:38: error: expected expression before 'const'
include/gimple.h:2605:25: error: unknown type name 'gimple'
gimple_assign_rhs3_ptr (gimple *gs)
include/gimple.h:2616:25: error: unknown type name 'gassign'
gimple_assign_set_rhs3 (gassign *gs, tree rhs)
include/gimple.h:2623:25: error: unknown type name 'gimple'
gimple_assign_set_rhs3 (gimple *gs, tree rhs)
include/gimple.h:2634:33: error: unknown type name 'gimple_stmt_iterator'=
gimple_assign_set_rhs_with_ops (gimple_stmt_iterator *gsi, enum tree_cod=
e code,
include/gimple.h:2644:33: error: unknown type name 'gimple_stmt_iterator'=
e code,
include/gimple.h:2653:41: error: unknown type name 'gassign'
gimple_assign_nontemporal_move_p (const gassign *gs)
include/gimple.h: In function 'gimple_assign_nontemporal_move_p':
include/gimple.h:2655:12: error: request for member 'nontemporal_move' in=
return gs->nontemporal_move;
include/gimple.h:2661:37: error: unknown type name 'gimple'
gimple_assign_set_nontemporal_move (gimple *gs, bool nontemporal)
include/gimple.h:2673:31: error: unknown type name 'gassign'
gimple_assign_rhs_code (const gassign *gs)
include/gimple.h: In function 'gimple_assign_rhs_code':
include/gimple.h:2675:44: error: request for member 'subcode' in somethin=
enum tree_code code =3D (enum tree_code) gs->subcode;
In file included from conftest.c:101:0:
include/gimple.h:2680:25: error: request for member 'op' in something not=
code =3D TREE_CODE (gs->op[1]);
include/tree.h:247:44: note: in definition of macro 'TREE_CODE'
#define TREE_CODE(NODE) ((enum tree_code) (NODE)->base.code)
include/gimple.h:2686:31: error: unknown type name 'gimple'
gimple_assign_rhs_code (const gimple *gs)
include/gimple.h:2686:1: error: redefinition of 'gimple_assign_rhs_code'
include/gimple.h:2673:1: note: previous definition of 'gimple_assign_rhs_=
code' was here
include/gimple.h:2688:9: error: unknown type name 'gassign'
include/gimple.h:2688:24: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:2688:38: error: expected expression before 'const'
include/gimple.h:2697:29: error: unknown type name 'gimple'
gimple_assign_set_rhs_code (gimple *s, enum tree_code code)
include/gimple.h:2709:32: error: unknown type name 'gimple'
gimple_assign_rhs_class (const gimple *gs)
include/gimple.h:2721:31: error: unknown type name 'gimple'
gimple_assign_single_p (const gimple *gs)
include/gimple.h:2730:23: error: unknown type name 'gimple'
gimple_store_p (const gimple *gs)
include/gimple.h:2739:29: error: unknown type name 'gimple'
gimple_assign_load_p (const gimple *gs)
include/gimple.h:2756:29: error: unknown type name 'gimple'
gimple_assign_cast_p (const gimple *s)
include/gimple.h:2772:25: error: unknown type name 'gimple'
gimple_clobber_p (const gimple *s)
include/gimple.h:2781:23: error: unknown type name 'gimple'
is_gimple_call (const gimple *gs)
include/gimple.h:2789:24: error: unknown type name 'gcall'
gimple_call_lhs (const gcall *gs)
include/gimple.h: In function 'gimple_call_lhs':
include/gimple.h:2791:12: error: request for member 'op' in something not=
return gs->op[0];
include/gimple.h:2795:24: error: unknown type name 'gimple'
gimple_call_lhs (const gimple *gs)
include/gimple.h:2795:1: error: redefinition of 'gimple_call_lhs'
include/gimple.h:2789:1: note: previous definition of 'gimple_call_lhs' w=
as here
include/gimple.h:2797:9: error: unknown type name 'gcall'
const gcall *gc =3D GIMPLE_CHECK2<const gcall *> (gs);
include/gimple.h:2797:21: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:2797:35: error: expected expression before 'const'
include/gimple.h:2805:22: error: unknown type name 'gcall'
gimple_call_lhs_ptr (gcall *gs)
include/gimple.h:2811:22: error: unknown type name 'gimple'
gimple_call_lhs_ptr (gimple *gs)
include/gimple.h:2821:22: error: unknown type name 'gcall'
gimple_call_set_lhs (gcall *gs, tree lhs)
include/gimple.h:2829:22: error: unknown type name 'gimple'
gimple_call_set_lhs (gimple *gs, tree lhs)
include/gimple.h:2840:31: error: unknown type name 'gcall'
gimple_call_internal_p (const gcall *gs)
include/gimple.h: In function 'gimple_call_internal_p':
include/gimple.h:2842:13: error: request for member 'subcode' in somethin=
return (gs->subcode & GF_CALL_INTERNAL) !=3D 0;
include/gimple.h:2846:31: error: unknown type name 'gimple'
gimple_call_internal_p (const gimple *gs)
include/gimple.h:2846:1: error: redefinition of 'gimple_call_internal_p'
include/gimple.h:2840:1: note: previous definition of 'gimple_call_intern=
al_p' was here
include/gimple.h:2848:9: error: unknown type name 'gcall'
include/gimple.h:2848:21: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:2848:35: error: expected expression before 'const'
include/gimple.h:2857:34: error: unknown type name 'gcall'
gimple_call_with_bounds_p (const gcall *gs)
include/gimple.h: In function 'gimple_call_with_bounds_p':
include/gimple.h:2859:13: error: request for member 'subcode' in somethin=
return (gs->subcode & GF_CALL_WITH_BOUNDS) !=3D 0;
include/gimple.h:2863:34: error: unknown type name 'gimple'
gimple_call_with_bounds_p (const gimple *gs)
include/gimple.h:2863:1: error: redefinition of 'gimple_call_with_bounds_=
p'
include/gimple.h:2857:1: note: previous definition of 'gimple_call_with_b=
ounds_p' was here
include/gimple.h:2865:9: error: unknown type name 'gcall'
include/gimple.h:2865:21: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:2865:35: error: expected expression before 'const'
include/gimple.h:2874:30: error: unknown type name 'gcall'
gimple_call_set_with_bounds (gcall *gs, bool with_bounds)
include/gimple.h:2883:30: error: unknown type name 'gimple'
gimple_call_set_with_bounds (gimple *gs, bool with_bounds)
include/gimple.h:2893:32: error: unknown type name 'gcall'
gimple_call_internal_fn (const gcall *gs)
include/gimple.h: In function 'gimple_call_internal_fn':
include/gimple.h:2896:12: error: request for member 'u' in something not =
return gs->u.internal_fn;
include/gimple.h:2900:32: error: unknown type name 'gimple'
gimple_call_internal_fn (const gimple *gs)
include/gimple.h:2900:1: error: redefinition of 'gimple_call_internal_fn'=
include/gimple.h:2893:1: note: previous definition of 'gimple_call_intern=
al_fn' was here
include/gimple.h:2902:9: error: unknown type name 'gcall'
include/gimple.h:2902:21: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:2902:35: error: expected expression before 'const'
include/gimple.h:2909:38: error: unknown type name 'gcall'
gimple_call_internal_unique_p (const gcall *gs)
include/gimple.h:2915:38: error: unknown type name 'gimple'
gimple_call_internal_unique_p (const gimple *gs)
include/gimple.h:2915:1: error: redefinition of 'gimple_call_internal_uni=
que_p'
include/gimple.h:2909:1: note: previous definition of 'gimple_call_intern=
al_unique_p' was here
include/gimple.h: In function 'gimple_call_internal_unique_p':
include/gimple.h:2917:9: error: unknown type name 'gcall'
include/gimple.h:2917:21: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:2917:35: error: expected expression before 'const'
include/gimple.h:2925:32: error: unknown type name 'gcall'
gimple_call_set_ctrl_altering (gcall *s, bool ctrl_altering_p)
include/gimple.h:2934:32: error: unknown type name 'gimple'
gimple_call_set_ctrl_altering (gimple *s, bool ctrl_altering_p)
include/gimple.h:2944:36: error: unknown type name 'gcall'
gimple_call_ctrl_altering_p (const gcall *gs)
include/gimple.h: In function 'gimple_call_ctrl_altering_p':
include/gimple.h:2946:13: error: request for member 'subcode' in somethin=
return (gs->subcode & GF_CALL_CTRL_ALTERING) !=3D 0;
include/gimple.h:2950:36: error: unknown type name 'gimple'
gimple_call_ctrl_altering_p (const gimple *gs)
include/gimple.h:2950:1: error: redefinition of 'gimple_call_ctrl_alterin=
g_p'
include/gimple.h:2944:1: note: previous definition of 'gimple_call_ctrl_a=
ltering_p' was here
include/gimple.h:2952:9: error: unknown type name 'gcall'
include/gimple.h:2952:21: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:2952:35: error: expected expression before 'const'
include/gimple.h:2960:27: error: unknown type name 'gcall'
gimple_call_fntype (const gcall *gs)
include/gimple.h: In function 'gimple_call_fntype':
include/gimple.h:2964:12: error: request for member 'u' in something not =
return gs->u.fntype;
include/gimple.h:2968:27: error: unknown type name 'gimple'
gimple_call_fntype (const gimple *gs)
include/gimple.h:2968:1: error: redefinition of 'gimple_call_fntype'
include/gimple.h:2960:1: note: previous definition of 'gimple_call_fntype=
' was here
include/gimple.h:2970:9: error: unknown type name 'gcall'
const gcall *call_stmt =3D GIMPLE_CHECK2<const gcall *> (gs);
include/gimple.h:2970:28: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:2970:42: error: expected expression before 'const'
include/gimple.h:2977:25: error: unknown type name 'gcall'
gimple_call_set_fntype (gcall *call_stmt, tree fntype)
include/gimple.h:2988:23: error: unknown type name 'gcall'
gimple_call_fn (const gcall *gs)
include/gimple.h: In function 'gimple_call_fn':
include/gimple.h:2990:12: error: request for member 'op' in something not=
return gs->op[1];
include/gimple.h:2994:23: error: unknown type name 'gimple'
gimple_call_fn (const gimple *gs)
include/gimple.h:2994:1: error: redefinition of 'gimple_call_fn'
/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/gcc-6.1.0-7cl=
jeqxjfpkacgtkxus4p55nsms53dnv/lib64/gcc/x86_64-pc-linux-gnu/6.1.0/plugin/=
include/gimple.h:2988:1: note: previous definition of 'gimple_call_fn' wa=
s here
include/gimple.h:2996:9: error: unknown type name 'gcall'
include/gimple.h:2996:21: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:2996:35: error: expected expression before 'const'
include/gimple.h:3004:21: error: unknown type name 'gcall'
gimple_call_fn_ptr (gcall *gs)
include/gimple.h:3010:21: error: unknown type name 'gimple'
gimple_call_fn_ptr (gimple *gs)
include/gimple.h:3020:21: error: unknown type name 'gcall'
gimple_call_set_fn (gcall *gs, tree fn)
include/gimple.h:3030:25: error: unknown type name 'gcall'
gimple_call_set_fndecl (gcall *gs, tree decl)
include/gimple.h:3038:25: error: unknown type name 'gimple'
gimple_call_set_fndecl (gimple *gs, tree decl)
include/gimple.h:3048:30: error: unknown type name 'gcall'
gimple_call_set_internal_fn (gcall *call_stmt, enum internal_fn fn)
include/gimple.h:3060:27: error: unknown type name 'gcall'
gimple_call_fndecl (const gcall *gs)
include/gimple.h:3066:27: error: unknown type name 'gimple'
gimple_call_fndecl (const gimple *gs)
include/gimple.h:3066:1: error: redefinition of 'gimple_call_fndecl'
include/gimple.h:3060:1: note: previous definition of 'gimple_call_fndecl=
' was here
include/gimple.h: In function 'gimple_call_fndecl':
include/gimple.h:3068:9: error: unknown type name 'gcall'
include/gimple.h:3068:21: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:3068:35: error: expected expression before 'const'
include/gimple.h:3076:32: error: unknown type name 'gcall'
gimple_call_return_type (const gcall *gs)
include/gimple.h:3092:26: error: unknown type name 'gcall'
gimple_call_chain (const gcall *gs)
include/gimple.h: In function 'gimple_call_chain':
include/gimple.h:3094:12: error: request for member 'op' in something not=
return gs->op[2];
include/gimple.h:3098:26: error: unknown type name 'gimple'
gimple_call_chain (const gimple *gs)
include/gimple.h:3098:1: error: redefinition of 'gimple_call_chain'
include/gimple.h:3092:1: note: previous definition of 'gimple_call_chain'=
was here
include/gimple.h:3100:9: error: unknown type name 'gcall'
include/gimple.h:3100:21: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:3100:35: error: expected expression before 'const'
include/gimple.h:3108:24: error: unknown type name 'gcall'
gimple_call_chain_ptr (gcall *call_stmt)
include/gimple.h:3116:24: error: unknown type name 'gcall'
gimple_call_set_chain (gcall *call_stmt, tree chain)
include/gimple.h:3125:29: error: unknown type name 'gcall'
gimple_call_num_args (const gcall *gs)
include/gimple.h:3131:29: error: unknown type name 'gimple'
gimple_call_num_args (const gimple *gs)
include/gimple.h:3131:1: error: redefinition of 'gimple_call_num_args'
include/gimple.h:3125:1: note: previous definition of 'gimple_call_num_ar=
gs' was here
include/gimple.h: In function 'gimple_call_num_args':
include/gimple.h:3133:9: error: unknown type name 'gcall'
include/gimple.h:3133:21: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:3133:35: error: expected expression before 'const'
include/gimple.h:3141:24: error: unknown type name 'gcall'
gimple_call_arg (const gcall *gs, unsigned index)
include/gimple.h: In function 'gimple_call_arg':
include/gimple.h:3144:12: error: request for member 'op' in something not=
return gs->op[index + 3];
include/gimple.h:3148:24: error: unknown type name 'gimple'
gimple_call_arg (const gimple *gs, unsigned index)
include/gimple.h:3148:1: error: redefinition of 'gimple_call_arg'
include/gimple.h:3141:1: note: previous definition of 'gimple_call_arg' w=
as here
include/gimple.h:3150:9: error: unknown type name 'gcall'
include/gimple.h:3150:21: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:3150:35: error: expected expression before 'const'
include/gimple.h:3159:22: error: unknown type name 'gcall'
gimple_call_arg_ptr (gcall *gs, unsigned index)
include/gimple.h:3166:22: error: unknown type name 'gimple'
gimple_call_arg_ptr (gimple *gs, unsigned index)
include/gimple.h:3176:22: error: unknown type name 'gcall'
gimple_call_set_arg (gcall *gs, unsigned index, tree arg)
include/gimple.h:3183:22: error: unknown type name 'gimple'
gimple_call_set_arg (gimple *gs, unsigned index, tree arg)
include/gimple.h:3195:23: error: unknown type name 'gcall'
gimple_call_set_tail (gcall *s, bool tail_p)
include/gimple.h:3207:21: error: unknown type name 'gcall'
gimple_call_tail_p (gcall *s)
include/gimple.h:3218:34: error: unknown type name 'gcall'
gimple_call_set_return_slot_opt (gcall *s, bool return_slot_opt_p)
include/gimple.h:3230:32: error: unknown type name 'gcall'
gimple_call_return_slot_opt_p (gcall *s)
include/gimple.h:3240:29: error: unknown type name 'gcall'
gimple_call_set_from_thunk (gcall *s, bool from_thunk_p)
include/gimple.h:3252:27: error: unknown type name 'gcall'
gimple_call_from_thunk_p (gcall *s)
include/gimple.h:3262:30: error: unknown type name 'gcall'
gimple_call_set_va_arg_pack (gcall *s, bool pass_arg_pack_p)
include/gimple.h:3275:28: error: unknown type name 'gcall'
gimple_call_va_arg_pack_p (gcall *s)
include/gimple.h:3284:31: error: unknown type name 'gcall'
gimple_call_noreturn_p (const gcall *s)
include/gimple.h:3290:31: error: unknown type name 'gimple'
gimple_call_noreturn_p (const gimple *s)
include/gimple.h:3290:1: error: redefinition of 'gimple_call_noreturn_p'
include/gimple.h:3284:1: note: previous definition of 'gimple_call_noretu=
rn_p' was here
include/gimple.h: In function 'gimple_call_noreturn_p':
include/gimple.h:3292:9: error: unknown type name 'gcall'
const gcall *gc =3D GIMPLE_CHECK2<const gcall *> (s);
include/gimple.h:3292:21: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:3292:35: error: expected expression before 'const'
include/gimple.h: At top level:
include/gimple.h:3301:26: error: unknown type name 'gcall'
gimple_call_set_nothrow (gcall *s, bool nothrow_p)
include/gimple.h:3312:24: error: unknown type name 'gcall'
gimple_call_nothrow_p (gcall *s)
include/gimple.h:3323:33: error: unknown type name 'gcall'
gimple_call_set_alloca_for_var (gcall *s, bool for_var)
include/gimple.h:3334:31: error: unknown type name 'gcall'
gimple_call_alloca_for_var_p (gcall *s)
include/gimple.h:3342:25: error: unknown type name 'gcall'
gimple_call_copy_flags (gcall *dest_call, gcall *orig_call)
include/gimple.h:3342:43: error: unknown type name 'gcall'
include/gimple.h:3352:22: error: unknown type name 'gcall'
gimple_call_use_set (gcall *call_stmt)
include/gimple.h:3362:26: error: unknown type name 'gcall'
gimple_call_clobber_set (gcall *call_stmt)
include/gimple.h:3372:17: error: unknown type name 'gimple'
gimple_has_lhs (gimple *stmt)
include/gimple.h:3385:25: error: unknown type name 'gcond'
gimple_cond_code (const gcond *gs)
include/gimple.h: In function 'gimple_cond_code':
include/gimple.h:3387:29: error: request for member 'subcode' in somethin=
return (enum tree_code) gs->subcode;
include/gimple.h:3391:25: error: unknown type name 'gimple'
gimple_cond_code (const gimple *gs)
include/gimple.h:3391:1: error: redefinition of 'gimple_cond_code'
include/gimple.h:3385:1: note: previous definition of 'gimple_cond_code' =
was here
include/gimple.h:3393:9: error: unknown type name 'gcond'
const gcond *gc =3D GIMPLE_CHECK2<const gcond *> (gs);
include/gimple.h:3393:21: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:3393:35: error: expected expression before 'const'
include/gimple.h:3401:23: error: unknown type name 'gcond'
gimple_cond_set_code (gcond *gs, enum tree_code code)
include/gimple.h:3410:24: error: unknown type name 'gcond'
gimple_cond_lhs (const gcond *gs)
include/gimple.h: In function 'gimple_cond_lhs':
include/gimple.h:3412:12: error: request for member 'op' in something not=
return gs->op[0];
include/gimple.h:3416:24: error: unknown type name 'gimple'
gimple_cond_lhs (const gimple *gs)
include/gimple.h:3416:1: error: redefinition of 'gimple_cond_lhs'
include/gimple.h:3410:1: note: previous definition of 'gimple_cond_lhs' w=
as here
include/gimple.h:3418:9: error: unknown type name 'gcond'
include/gimple.h:3418:21: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:3418:35: error: expected expression before 'const'
include/gimple.h:3426:22: error: unknown type name 'gcond'
gimple_cond_lhs_ptr (gcond *gs)
include/gimple.h:3435:22: error: unknown type name 'gcond'
gimple_cond_set_lhs (gcond *gs, tree lhs)
include/gimple.h:3444:24: error: unknown type name 'gcond'
gimple_cond_rhs (const gcond *gs)
include/gimple.h: In function 'gimple_cond_rhs':
include/gimple.h:3446:12: error: request for member 'op' in something not=
return gs->op[1];
include/gimple.h:3450:24: error: unknown type name 'gimple'
gimple_cond_rhs (const gimple *gs)
include/gimple.h:3450:1: error: redefinition of 'gimple_cond_rhs'
include/gimple.h:3444:1: note: previous definition of 'gimple_cond_rhs' w=
as here
include/gimple.h:3452:9: error: unknown type name 'gcond'
include/gimple.h:3452:21: error: 'GIMPLE_CHECK2' undeclared (first use in=
this function)
include/gimple.h:3452:35: error: expected expression before 'const'
include/gimple.h:3460:22: error: unknown type name 'gcond'
gimple_cond_rhs_ptr (gcond *gs)
include/gimple.h:3470:22: error: unknown type name 'gcond'
gimple_cond_set_rhs (gcond *gs, tree rhs)
include/gimple.h:3480:31: error: unknown type name 'gcond'
gimple_cond_true_label (const gcond *gs)
include/gimple.h: In function 'gimple_cond_true_label':
include/gimple.h:3482:12: error: request for member 'op' in something not=
return gs->op[2];
include/gimple.h:3490:29: error: unknown type name 'gcond'
gimple_cond_set_true_label (gcond *gs, tree label)
include/gimple.h:3500:30: error: unknown type name 'gcond'
gimple_cond_set_false_label (gcond *gs, tree label)
include/gimple.h:3510:32: error: unknown type name 'gcond'
gimple_cond_false_label (const gcond *gs)
include/gimple.h: In function 'gimple_cond_false_label':
include/gimple.h:3512:12: error: request for member 'op' in something not=
return gs->op[3];
include/gimple.h:3519:25: error: unknown type name 'gcond'
gimple_cond_make_false (gcond *gs)
include/gimple.h:3530:24: error: unknown type name 'gcond'
gimple_cond_make_true (gcond *gs)
include/gimple.h:3541:27: error: unknown type name 'gcond'
gimple_cond_true_p (const gcond *gs)
include/gimple.h:3566:28: error: unknown type name 'gcond'
gimple_cond_false_p (const gcond *gs)
include/gimple.h:3590:28: error: unknown type name 'gcond'
gimple_cond_set_condition (gcond *stmt, enum tree_code code, tree lhs,
include/gimple.h:3601:27: error: unknown type name 'glabel'
gimple_label_label (const glabel *gs)
include/gimple.h: In function 'gimple_label_label':
include/gimple.h:3603:12: error: request for member 'op' in something not=
return gs->op[0];
include/gimple.h:3611:25: error: unknown type name 'glabel'
gimple_label_set_label (glabel *gs, tree label)
include/gimple.h:3620:25: error: unknown type name 'gimple'
gimple_goto_dest (const gimple *gs)
include/gimple.h:3630:23: error: unknown type name 'ggoto'
gimple_goto_set_dest (ggoto *gs, tree dest)
include/gimple.h:3639:25: error: unknown type name 'gbind'
gimple_bind_vars (const gbind *bind_stmt)
include/gimple.h: In function 'gimple_bind_vars':
include/gimple.h:3641:19: error: request for member 'vars' in something n=
return bind_stmt->vars;
include/gimple.h:3649:23: error: unknown type name 'gbind'
gimple_bind_set_vars (gbind *bind_stmt, tree vars)
include/gimple.h:3659:26: error: unknown type name 'gbind'
gimple_bind_append_vars (gbind *bind_stmt, tree vars)
include/gimple.h:3666:23: error: unknown type name 'gbind'
gimple_bind_body_ptr (gbind *bind_stmt)
include/gimple.h:3674:19: error: unknown type name 'gbind'
gimple_bind_body (gbind *gs)
include/gimple.h:3684:23: error: unknown type name 'gbind'
gimple_bind_set_body (gbind *bind_stmt, gimple_seq seq)
include/gimple.h:3693:23: error: unknown type name 'gbind'
gimple_bind_add_stmt (gbind *bind_stmt, gimple *stmt)
include/gimple.h:3693:41: error: unknown type name 'gimple'
include/gimple.h:3702:22: error: unknown type name 'gbind'
gimple_bind_add_seq (gbind *bind_stmt, gimple_seq seq)
include/gimple.h:3712:26: error: unknown type name 'gbind'
gimple_bind_block (const gbind *bind_stmt)
include/gimple.h: In function 'gimple_bind_block':
include/gimple.h:3714:19: error: request for member 'block' in something =
return bind_stmt->block;
include/gimple.h:3722:24: error: unknown type name 'gbind'
gimple_bind_set_block (gbind *bind_stmt, tree block)
include/gimple.h:3733:27: error: unknown type name 'gasm'
gimple_asm_ninputs (const gasm *asm_stmt)
include/gimple.h: In function 'gimple_asm_ninputs':
include/gimple.h:3735:18: error: request for member 'ni' in something not=
return asm_stmt->ni;
include/gimple.h:3742:28: error: unknown type name 'gasm'
gimple_asm_noutputs (const gasm *asm_stmt)
include/gimple.h: In function 'gimple_asm_noutputs':
include/gimple.h:3744:18: error: request for member 'no' in something not=
return asm_stmt->no;
include/gimple.h:3751:29: error: unknown type name 'gasm'
gimple_asm_nclobbers (const gasm *asm_stmt)
include/gimple.h: In function 'gimple_asm_nclobbers':
include/gimple.h:3753:18: error: request for member 'nc' in something not=
return asm_stmt->nc;
include/gimple.h:3759:27: error: unknown type name 'gasm'
gimple_asm_nlabels (const gasm *asm_stmt)
include/gimple.h: In function 'gimple_asm_nlabels':
include/gimple.h:3761:18: error: request for member 'nl' in something not=
return asm_stmt->nl;
include/gimple.h:3767:28: error: unknown type name 'gasm'
gimple_asm_input_op (const gasm *asm_stmt, unsigned index)
In file included from conftest.c:102:0:
include/gimple.h: In function 'gimple_asm_input_op':
include/gimple.h:3769:47: error: request for member 'ni' in something not=
gcc_gimple_checking_assert (index < asm_stmt->ni);
include/gimple.h:97:56: note: in definition of macro 'gcc_gimple_checking=
_assert'
#define gcc_gimple_checking_assert(EXPR) ((void)(0 && (EXPR)))
include/gimple.h:3770:18: error: request for member 'op' in something not=
return asm_stmt->op[index + asm_stmt->no];
include/gimple.h:3770:39: error: request for member 'no' in something not=
include/gimple.h:3776:26: error: unknown type name 'gasm'
gimple_asm_set_input_op (gasm *asm_stmt, unsigned index, tree in_op)
include/gimple.h:3787:29: error: unknown type name 'gasm'
gimple_asm_output_op (const gasm *asm_stmt, unsigned index)
include/gimple.h: In function 'gimple_asm_output_op':
include/gimple.h:3789:47: error: request for member 'no' in something not=
gcc_gimple_checking_assert (index < asm_stmt->no);
_assert'
include/gimple.h:3790:18: error: request for member 'op' in something not=
return asm_stmt->op[index];
include/gimple.h:3796:27: error: unknown type name 'gasm'
gimple_asm_set_output_op (gasm *asm_stmt, unsigned index, tree out_op)
include/gimple.h:3807:30: error: unknown type name 'gasm'
gimple_asm_clobber_op (const gasm *asm_stmt, unsigned index)
include/gimple.h: In function 'gimple_asm_clobber_op':
include/gimple.h:3809:47: error: request for member 'nc' in something not=
gcc_gimple_checking_assert (index < asm_stmt->nc);
_assert'
include/gimple.h:3810:18: error: request for member 'op' in something not=
return asm_stmt->op[index + asm_stmt->ni + asm_stmt->no];
include/gimple.h:3810:39: error: request for member 'ni' in something not=
include/gimple.h:3810:54: error: request for member 'no' in something not=
include/gimple.h:3817:28: error: unknown type name 'gasm'
gimple_asm_set_clobber_op (gasm *asm_stmt, unsigned index, tree clobber_=
op)
include/gimple.h:3827:28: error: unknown type name 'gasm'
gimple_asm_label_op (const gasm *asm_stmt, unsigned index)
include/gimple.h: In function 'gimple_asm_label_op':
include/gimple.h:3829:47: error: request for member 'nl' in something not=
gcc_gimple_checking_assert (index < asm_stmt->nl);
_assert'
include/gimple.h:3830:18: error: request for member 'op' in something not=
return asm_stmt->op[index + asm_stmt->ni + asm_stmt->nc];
include/gimple.h:3830:39: error: request for member 'ni' in something not=
include/gimple.h:3830:54: error: request for member 'nc' in something not=
include/gimple.h:3836:26: error: unknown type name 'gasm'
gimple_asm_set_label_op (gasm *asm_stmt, unsigned index, tree label_op)
include/gimple.h:3847:26: error: unknown type name 'gasm'
gimple_asm_string (const gasm *asm_stmt)
include/gimple.h: In function 'gimple_asm_string':
include/gimple.h:3849:18: error: request for member 'string' in something=
return asm_stmt->string;
include/gimple.h:3856:30: error: unknown type name 'gasm'
gimple_asm_volatile_p (const gasm *asm_stmt)
include/gimple.h: In function 'gimple_asm_volatile_p':
include/gimple.h:3858:19: error: request for member 'subcode' in somethin=
return (asm_stmt->subcode & GF_ASM_VOLATILE) !=3D 0;
include/gimple.h:3865:26: error: unknown type name 'gasm'
gimple_asm_set_volatile (gasm *asm_stmt, bool volatile_p)
include/gimple.h:3877:23: error: unknown type name 'gasm'
gimple_asm_set_input (gasm *asm_stmt, bool input_p)
include/gimple.h:3889:27: error: unknown type name 'gasm'
gimple_asm_input_p (const gasm *asm_stmt)
include/gimple.h: In function 'gimple_asm_input_p':
include/gimple.h:3891:19: error: request for member 'subcode' in somethin=
return (asm_stmt->subcode & GF_ASM_INPUT) !=3D 0;
include/gimple.h:3898:27: error: unknown type name 'gcatch'
gimple_catch_types (const gcatch *catch_stmt)
include/gimple.h: In function 'gimple_catch_types':
include/gimple.h:3900:20: error: request for member 'types' in something =
return catch_stmt->types;
include/gimple.h:3907:25: error: unknown type name 'gcatch'
gimple_catch_types_ptr (gcatch *catch_stmt)
include/gimple.h:3917:27: error: unknown type name 'gcatch'
gimple_catch_handler_ptr (gcatch *catch_stmt)
include/gimple.h:3927:23: error: unknown type name 'gcatch'
gimple_catch_handler (gcatch *catch_stmt)
include/gimple.h:3936:25: error: unknown type name 'gcatch'
gimple_catch_set_types (gcatch *catch_stmt, tree t)
include/gimple.h:3945:27: error: unknown type name 'gcatch'
gimple_catch_set_handler (gcatch *catch_stmt, gimple_seq handler)
include/gimple.h:3954:31: error: unknown type name 'gimple'
gimple_eh_filter_types (const gimple *gs)
include/gimple.h: In function 'gimple_eh_filter_types':
include/gimple.h:3956:9: error: unknown type name 'geh_filter'
const geh_filter *eh_filter_stmt =3D as_a <const geh_filter *> (gs);
include/gimple.h:3956:38: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:3956:44: error: expected expression before 'const'
include/gimple.h:3957:24: error: request for member 'types' in something =
return eh_filter_stmt->types;
include/gimple.h:3965:29: error: unknown type name 'gimple'
gimple_eh_filter_types_ptr (gimple *gs)
include/gimple.h:3976:31: error: unknown type name 'gimple'
gimple_eh_filter_failure_ptr (gimple *gs)
include/gimple.h:3987:27: error: unknown type name 'gimple'
gimple_eh_filter_failure (gimple *gs)
include/gimple.h:3997:29: error: unknown type name 'geh_filter'
gimple_eh_filter_set_types (geh_filter *eh_filter_stmt, tree types)
include/gimple.h:4007:31: error: unknown type name 'geh_filter'
gimple_eh_filter_set_failure (geh_filter *eh_filter_stmt,
include/gimple.h:4016:34: error: unknown type name 'geh_mnt'
gimple_eh_must_not_throw_fndecl (geh_mnt *eh_mnt_stmt)
include/gimple.h:4024:38: error: unknown type name 'geh_mnt'
gimple_eh_must_not_throw_set_fndecl (geh_mnt *eh_mnt_stmt,
include/gimple.h:4033:28: error: unknown type name 'geh_else'
gimple_eh_else_n_body_ptr (geh_else *eh_else_stmt)
include/gimple.h:4039:24: error: unknown type name 'geh_else'
gimple_eh_else_n_body (geh_else *eh_else_stmt)
include/gimple.h:4045:28: error: unknown type name 'geh_else'
gimple_eh_else_e_body_ptr (geh_else *eh_else_stmt)
include/gimple.h:4051:24: error: unknown type name 'geh_else'
gimple_eh_else_e_body (geh_else *eh_else_stmt)
include/gimple.h:4057:28: error: unknown type name 'geh_else'
gimple_eh_else_set_n_body (geh_else *eh_else_stmt, gimple_seq seq)
include/gimple.h:4063:28: error: unknown type name 'geh_else'
gimple_eh_else_set_e_body (geh_else *eh_else_stmt, gimple_seq seq)
include/gimple.h:4074:24: error: unknown type name 'gimple'
gimple_try_kind (const gimple *gs)
include/gimple.h: In function 'gimple_try_kind':
include/gimple.h:4077:37: error: request for member 'subcode' in somethin=
return (enum gimple_try_flags) (gs->subcode & GIMPLE_TRY_KIND);
include/gimple.h:4084:22: error: unknown type name 'gtry'
gimple_try_set_kind (gtry *gs, enum gimple_try_flags kind)
include/gimple.h:4096:36: error: unknown type name 'gimple'
gimple_try_catch_is_cleanup (const gimple *gs)
include/gimple.h: In function 'gimple_try_catch_is_cleanup':
include/gimple.h:4099:13: error: request for member 'subcode' in somethin=
return (gs->subcode & GIMPLE_TRY_CATCH_IS_CLEANUP) !=3D 0;
include/gimple.h:4107:22: error: unknown type name 'gimple'
gimple_try_eval_ptr (gimple *gs)
include/gimple.h:4117:18: error: unknown type name 'gimple'
gimple_try_eval (gimple *gs)
include/gimple.h:4127:25: error: unknown type name 'gimple'
gimple_try_cleanup_ptr (gimple *gs)
include/gimple.h:4138:21: error: unknown type name 'gimple'
gimple_try_cleanup (gimple *gs)
include/gimple.h:4147:34: error: unknown type name 'gtry'
gimple_try_set_catch_is_cleanup (gtry *g, bool catch_is_cleanup)
include/gimple.h:4161:22: error: unknown type name 'gtry'
gimple_try_set_eval (gtry *try_stmt, gimple_seq eval)
include/gimple.h:4171:25: error: unknown type name 'gtry'
gimple_try_set_cleanup (gtry *try_stmt, gimple_seq cleanup)
include/gimple.h:4180:25: error: unknown type name 'gimple'
gimple_wce_cleanup_ptr (gimple *gs)
include/gimple.h:4190:21: error: unknown type name 'gimple'
gimple_wce_cleanup (gimple *gs)
include/gimple.h:4199:25: error: unknown type name 'gimple'
gimple_wce_set_cleanup (gimple *gs, gimple_seq cleanup)
include/gimple.h:4209:35: error: unknown type name 'gimple'
gimple_wce_cleanup_eh_only (const gimple *gs)
include/gimple.h: In function 'gimple_wce_cleanup_eh_only':
include/gimple.h:4212:12: error: request for member 'subcode' in somethin=
return gs->subcode !=3D 0;
include/gimple.h:4219:33: error: unknown type name 'gimple'
gimple_wce_set_cleanup_eh_only (gimple *gs, bool eh_only_p)
include/gimple.h:4229:28: error: unknown type name 'gimple'
gimple_phi_capacity (const gimple *gs)
include/gimple.h: In function 'gimple_phi_capacity':
include/gimple.h:4231:9: error: unknown type name 'gphi'
const gphi *phi_stmt =3D as_a <const gphi *> (gs);
include/gimple.h:4231:26: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:4231:32: error: expected expression before 'const'
include/gimple.h:4232:18: error: request for member 'capacity' in somethi=
return phi_stmt->capacity;
include/gimple.h:4241:28: error: unknown type name 'gimple'
gimple_phi_num_args (const gimple *gs)
include/gimple.h: In function 'gimple_phi_num_args':
include/gimple.h:4243:9: error: unknown type name 'gphi'
include/gimple.h:4243:26: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:4243:32: error: expected expression before 'const'
include/gimple.h:4244:18: error: request for member 'nargs' in something =
return phi_stmt->nargs;
include/gimple.h:4251:26: error: unknown type name 'gimple'
gimple_phi_result (const gimple *gs)
include/gimple.h: In function 'gimple_phi_result':
include/gimple.h:4253:9: error: unknown type name 'gphi'
include/gimple.h:4253:26: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:4253:32: error: expected expression before 'const'
include/gimple.h:4254:18: error: request for member 'result' in something=
return phi_stmt->result;
include/gimple.h:4260:24: error: unknown type name 'gimple'
gimple_phi_result_ptr (gimple *gs)
include/gimple.h:4269:24: error: unknown type name 'gphi'
gimple_phi_set_result (gphi *phi, tree result)
include/gimple.h:4281:17: error: unknown type name 'gimple'
gimple_phi_arg (gimple *gs, unsigned index)
include/gimple.h:4292:21: error: unknown type name 'gphi'
gimple_phi_set_arg (gphi *phi, unsigned index, struct phi_arg_d * phiarg=
inux-gnu/6.1.0/plugin/include/gcc-plugin.h:28:0,
include/gimple.h: In function 'phi_nodes':
include/gimple.h:4304:28: error: 'const struct basic_block_def' has no me=
mber named 'flags'
include/system.h:738:49: note: in definition of macro 'gcc_checking_asser=
t'
#define gcc_checking_assert(EXPR) ((void)(0 && (EXPR)))
include/gimple.h:4305:12: error: 'const struct basic_block_def' has no me=
mber named 'il'
return bb->il.gimple.phi_nodes;
include/gimple.h: In function 'phi_nodes_ptr':
include/gimple.h:4313:28: error: 'struct basic_block_def' has no member n=
amed 'flags'
t'
include/gimple.h:4314:13: error: 'struct basic_block_def' has no member n=
amed 'il'
return &bb->il.gimple.phi_nodes;
include/gimple.h:4320:21: error: unknown type name 'gimple'
gimple_phi_arg_def (gimple *gs, size_t index)
include/gimple.h:4329:25: error: unknown type name 'gphi'
gimple_phi_arg_def_ptr (gphi *phi, size_t index)
include/gimple.h:4337:22: error: unknown type name 'gphi'
gimple_phi_arg_edge (gphi *phi, size_t i)
include/gimple.h:4345:26: error: unknown type name 'gphi'
gimple_phi_arg_location (gphi *phi, size_t i)
include/gimple.h:4353:36: error: unknown type name 'gphi'
gimple_phi_arg_location_from_edge (gphi *phi, edge e)
include/gimple.h:4361:30: error: unknown type name 'gphi'
gimple_phi_arg_set_location (gphi *phi, size_t i, source_location loc)
include/gimple.h:4369:30: error: unknown type name 'gphi'
gimple_phi_arg_has_location (gphi *phi, size_t i)
include/gimple.h:4378:27: error: unknown type name 'gresx'
gimple_resx_region (const gresx *resx_stmt)
include/gimple.h: In function 'gimple_resx_region':
include/gimple.h:4380:19: error: request for member 'region' in something=
return resx_stmt->region;
include/gimple.h:4386:25: error: unknown type name 'gresx'
gimple_resx_set_region (gresx *resx_stmt, int region)
include/gimple.h:4394:34: error: unknown type name 'geh_dispatch'
gimple_eh_dispatch_region (const geh_dispatch *eh_dispatch_stmt)
include/gimple.h: In function 'gimple_eh_dispatch_region':
include/gimple.h:4396:26: error: request for member 'region' in something=
return eh_dispatch_stmt->region;
include/gimple.h:4403:32: error: unknown type name 'geh_dispatch'
gimple_eh_dispatch_set_region (geh_dispatch *eh_dispatch_stmt, int regio=
n)
include/gimple.h:4411:33: error: unknown type name 'gswitch'
gimple_switch_num_labels (const gswitch *gs)
include/gimple.h:4424:31: error: unknown type name 'gswitch'
gimple_switch_set_num_labels (gswitch *g, unsigned nlabels)
include/gimple.h:4434:28: error: unknown type name 'gswitch'
gimple_switch_index (const gswitch *gs)
include/gimple.h: In function 'gimple_switch_index':
include/gimple.h:4436:12: error: request for member 'op' in something not=
return gs->op[0];
include/gimple.h:4443:26: error: unknown type name 'gswitch'
gimple_switch_index_ptr (gswitch *gs)
include/gimple.h:4452:26: error: unknown type name 'gswitch'
gimple_switch_set_index (gswitch *gs, tree index)
include/gimple.h:4463:28: error: unknown type name 'gswitch'
gimple_switch_label (const gswitch *gs, unsigned index)
include/gimple.h: In function 'gimple_switch_label':
include/gimple.h:4466:12: error: request for member 'op' in something not=
return gs->op[index + 1];
include/gimple.h:4472:26: error: unknown type name 'gswitch'
gimple_switch_set_label (gswitch *gs, unsigned index, tree label)
include/gimple.h:4483:36: error: unknown type name 'gswitch'
gimple_switch_default_label (const gswitch *gs)
include/gimple.h:4493:34: error: unknown type name 'gswitch'
gimple_switch_set_default_label (gswitch *gs, tree label)
include/gimple.h:4502:24: error: unknown type name 'gimple'
is_gimple_debug (const gimple *gs)
include/gimple.h:4510:28: error: unknown type name 'gimple'
gimple_debug_bind_p (const gimple *s)
include/gimple.h: In function 'gimple_debug_bind_p':
include/gimple.h:4513:13: error: request for member 'subcode' in somethin=
return s->subcode =3D=3D GIMPLE_DEBUG_BIND;
include/gimple.h:4521:28: error: unknown type name 'gimple'
gimple_debug_bind_get_var (gimple *dbg)
include/gimple.h:4532:30: error: unknown type name 'gimple'
gimple_debug_bind_get_value (gimple *dbg)
include/gimple.h:4543:34: error: unknown type name 'gimple'
gimple_debug_bind_get_value_ptr (gimple *dbg)
include/gimple.h:4553:28: error: unknown type name 'gimple'
gimple_debug_bind_set_var (gimple *dbg, tree var)
include/gimple.h:4564:30: error: unknown type name 'gimple'
gimple_debug_bind_set_value (gimple *dbg, tree value)
include/gimple.h:4579:32: error: unknown type name 'gimple'
gimple_debug_bind_reset_value (gimple *dbg)
include/gimple.h:4590:32: error: unknown type name 'gimple'
gimple_debug_bind_has_value_p (gimple *dbg)
include/gimple.h:4602:35: error: unknown type name 'gimple'
gimple_debug_source_bind_p (const gimple *s)
include/gimple.h: In function 'gimple_debug_source_bind_p':
include/gimple.h:4605:13: error: request for member 'subcode' in somethin=
return s->subcode =3D=3D GIMPLE_DEBUG_SOURCE_BIND;
include/gimple.h:4613:35: error: unknown type name 'gimple'
gimple_debug_source_bind_get_var (gimple *dbg)
include/gimple.h:4624:37: error: unknown type name 'gimple'
gimple_debug_source_bind_get_value (gimple *dbg)
include/gimple.h:4635:41: error: unknown type name 'gimple'
gimple_debug_source_bind_get_value_ptr (gimple *dbg)
include/gimple.h:4645:35: error: unknown type name 'gimple'
gimple_debug_source_bind_set_var (gimple *dbg, tree var)
include/gimple.h:4656:37: error: unknown type name 'gimple'
gimple_debug_source_bind_set_value (gimple *dbg, tree value)
include/gimple.h:4666:19: error: unknown type name 'gimple'
get_lineno (const gimple *stmt)
include/gimple.h:4683:22: error: unknown type name 'gimple'
gimple_omp_body_ptr (gimple *gs)
include/gimple.h:4691:18: error: unknown type name 'gimple'
gimple_omp_body (gimple *gs)
include/gimple.h:4699:22: error: unknown type name 'gimple'
gimple_omp_set_body (gimple *gs, gimple_seq body)
include/gimple.h:4708:33: error: unknown type name 'gomp_critical'
gimple_omp_critical_name (const gomp_critical *crit_stmt)
include/gimple.h: In function 'gimple_omp_critical_name':
include/gimple.h:4710:19: error: request for member 'name' in something n=
return crit_stmt->name;
include/gimple.h:4718:31: error: unknown type name 'gomp_critical'
gimple_omp_critical_name_ptr (gomp_critical *crit_stmt)
include/gimple.h:4728:31: error: unknown type name 'gomp_critical'
gimple_omp_critical_set_name (gomp_critical *crit_stmt, tree name)
include/gimple.h:4737:36: error: unknown type name 'gomp_critical'
gimple_omp_critical_clauses (const gomp_critical *crit_stmt)
include/gimple.h: In function 'gimple_omp_critical_clauses':
include/gimple.h:4739:19: error: request for member 'clauses' in somethin=
return crit_stmt->clauses;
include/gimple.h:4747:34: error: unknown type name 'gomp_critical'
gimple_omp_critical_clauses_ptr (gomp_critical *crit_stmt)
include/gimple.h:4757:34: error: unknown type name 'gomp_critical'
gimple_omp_critical_set_clauses (gomp_critical *crit_stmt, tree clauses)=
include/gimple.h:4766:35: error: unknown type name 'gomp_ordered'
gimple_omp_ordered_clauses (const gomp_ordered *ord_stmt)
include/gimple.h: In function 'gimple_omp_ordered_clauses':
include/gimple.h:4768:18: error: request for member 'clauses' in somethin=
return ord_stmt->clauses;
include/gimple.h:4776:33: error: unknown type name 'gomp_ordered'
gimple_omp_ordered_clauses_ptr (gomp_ordered *ord_stmt)
include/gimple.h:4786:33: error: unknown type name 'gomp_ordered'
gimple_omp_ordered_set_clauses (gomp_ordered *ord_stmt, tree clauses)
include/gimple.h:4795:28: error: unknown type name 'gimple'
gimple_omp_for_kind (const gimple *g)
include/gimple.h:4805:26: error: unknown type name 'gomp_for'
gimple_omp_for_set_kind (gomp_for *g, int kind)
include/gimple.h:4816:34: error: unknown type name 'gimple'
gimple_omp_for_combined_p (const gimple *g)
include/gimple.h:4827:32: error: unknown type name 'gomp_for'
gimple_omp_for_set_combined_p (gomp_for *g, bool combined_p)
include/gimple.h:4840:39: error: unknown type name 'gimple'
gimple_omp_for_combined_into_p (const gimple *g)
include/gimple.h:4851:37: error: unknown type name 'gomp_for'
gimple_omp_for_set_combined_into_p (gomp_for *g, bool combined_p)
include/gimple.h:4863:31: error: unknown type name 'gimple'
gimple_omp_for_clauses (const gimple *gs)
include/gimple.h: In function 'gimple_omp_for_clauses':
include/gimple.h:4865:9: error: unknown type name 'gomp_for'
const gomp_for *omp_for_stmt =3D as_a <const gomp_for *> (gs);
include/gimple.h:4865:34: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:4865:40: error: expected expression before 'const'
include/gimple.h:4866:22: error: request for member 'clauses' in somethin=
return omp_for_stmt->clauses;
include/gimple.h:4874:29: error: unknown type name 'gimple'
gimple_omp_for_clauses_ptr (gimple *gs)
include/gimple.h:4885:29: error: unknown type name 'gimple'
gimple_omp_for_set_clauses (gimple *gs, tree clauses)
include/gimple.h:4895:26: error: unknown type name 'gimple'
gimple_omp_for_collapse (gimple *gs)
include/gimple.h:4905:28: error: unknown type name 'gimple'
gimple_omp_for_cond (const gimple *gs, size_t i)
include/gimple.h: In function 'gimple_omp_for_cond':
include/gimple.h:4907:9: error: unknown type name 'gomp_for'
include/gimple.h:4907:34: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:4907:40: error: expected expression before 'const'
include/gimple.h:4908:47: error: request for member 'collapse' in somethi=
gcc_gimple_checking_assert (i < omp_for_stmt->collapse);
_assert'
include/gimple.h:4909:22: error: request for member 'iter' in something n=
return omp_for_stmt->iter[i].cond;
include/gimple.h:4916:26: error: unknown type name 'gimple'
gimple_omp_for_set_cond (gimple *gs, size_t i, enum tree_code cond)
include/gimple.h:4928:29: error: unknown type name 'gimple'
gimple_omp_for_index (const gimple *gs, size_t i)
include/gimple.h: In function 'gimple_omp_for_index':
include/gimple.h:4930:9: error: unknown type name 'gomp_for'
include/gimple.h:4930:34: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:4930:40: error: expected expression before 'const'
include/gimple.h:4931:47: error: request for member 'collapse' in somethi=
_assert'
include/gimple.h:4932:22: error: request for member 'iter' in something n=
return omp_for_stmt->iter[i].index;
include/gimple.h:4939:27: error: unknown type name 'gimple'
gimple_omp_for_index_ptr (gimple *gs, size_t i)
include/gimple.h:4950:27: error: unknown type name 'gimple'
gimple_omp_for_set_index (gimple *gs, size_t i, tree index)
include/gimple.h:4961:31: error: unknown type name 'gimple'
gimple_omp_for_initial (const gimple *gs, size_t i)
include/gimple.h: In function 'gimple_omp_for_initial':
include/gimple.h:4963:9: error: unknown type name 'gomp_for'
include/gimple.h:4963:34: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:4963:40: error: expected expression before 'const'
include/gimple.h:4964:47: error: request for member 'collapse' in somethi=
_assert'
include/gimple.h:4965:22: error: request for member 'iter' in something n=
return omp_for_stmt->iter[i].initial;
include/gimple.h:4972:29: error: unknown type name 'gimple'
gimple_omp_for_initial_ptr (gimple *gs, size_t i)
include/gimple.h:4983:29: error: unknown type name 'gimple'
gimple_omp_for_set_initial (gimple *gs, size_t i, tree initial)
include/gimple.h:4994:29: error: unknown type name 'gimple'
gimple_omp_for_final (const gimple *gs, size_t i)
include/gimple.h: In function 'gimple_omp_for_final':
include/gimple.h:4996:9: error: unknown type name 'gomp_for'
include/gimple.h:4996:34: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:4996:40: error: expected expression before 'const'
include/gimple.h:4997:47: error: request for member 'collapse' in somethi=
_assert'
include/gimple.h:4998:22: error: request for member 'iter' in something n=
return omp_for_stmt->iter[i].final;
include/gimple.h:5005:27: error: unknown type name 'gimple'
gimple_omp_for_final_ptr (gimple *gs, size_t i)
include/gimple.h:5016:27: error: unknown type name 'gimple'
gimple_omp_for_set_final (gimple *gs, size_t i, tree final)
include/gimple.h:5027:28: error: unknown type name 'gimple'
gimple_omp_for_incr (const gimple *gs, size_t i)
include/gimple.h: In function 'gimple_omp_for_incr':
include/gimple.h:5029:9: error: unknown type name 'gomp_for'
include/gimple.h:5029:34: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:5029:40: error: expected expression before 'const'
include/gimple.h:5030:47: error: request for member 'collapse' in somethi=
_assert'
include/gimple.h:5031:22: error: request for member 'iter' in something n=
return omp_for_stmt->iter[i].incr;
include/gimple.h:5038:26: error: unknown type name 'gimple'
gimple_omp_for_incr_ptr (gimple *gs, size_t i)
include/gimple.h:5049:26: error: unknown type name 'gimple'
gimple_omp_for_set_incr (gimple *gs, size_t i, tree incr)
include/gimple.h:5061:30: error: unknown type name 'gimple'
gimple_omp_for_pre_body_ptr (gimple *gs)
include/gimple.h:5072:26: error: unknown type name 'gimple'
gimple_omp_for_pre_body (gimple *gs)
include/gimple.h:5082:30: error: unknown type name 'gimple'
gimple_omp_for_set_pre_body (gimple *gs, gimple_seq pre_body)
include/gimple.h:5091:34: error: unknown type name 'gomp_for'
gimple_omp_for_grid_phony (const gomp_for *omp_for)
include/gimple.h:5099:32: error: unknown type name 'gomp_for'
gimple_omp_for_set_grid_phony (gomp_for *omp_for, bool value)
include/gimple.h:5110:36: error: unknown type name 'gimple'
gimple_omp_parallel_clauses (const gimple *gs)
include/gimple.h: In function 'gimple_omp_parallel_clauses':
include/gimple.h:5112:9: error: unknown type name 'gomp_parallel'
const gomp_parallel *omp_parallel_stmt =3D as_a <const gomp_parallel *=
> (gs);
include/gimple.h:5112:44: error: 'as_a' undeclared (first use in this fun=
ction)
> (gs);
include/gimple.h:5112:50: error: expected expression before 'const'
> (gs);
include/gimple.h:5113:27: error: request for member 'clauses' in somethin=
return omp_parallel_stmt->clauses;
include/gimple.h:5120:34: error: unknown type name 'gomp_parallel'
gimple_omp_parallel_clauses_ptr (gomp_parallel *omp_parallel_stmt)
include/gimple.h:5129:34: error: unknown type name 'gomp_parallel'
gimple_omp_parallel_set_clauses (gomp_parallel *omp_parallel_stmt,
include/gimple.h:5139:37: error: unknown type name 'gomp_parallel'
gimple_omp_parallel_child_fn (const gomp_parallel *omp_parallel_stmt)
include/gimple.h: In function 'gimple_omp_parallel_child_fn':
include/gimple.h:5141:27: error: request for member 'child_fn' in somethi=
return omp_parallel_stmt->child_fn;
include/gimple.h:5148:35: error: unknown type name 'gomp_parallel'
gimple_omp_parallel_child_fn_ptr (gomp_parallel *omp_parallel_stmt)
include/gimple.h:5157:35: error: unknown type name 'gomp_parallel'
gimple_omp_parallel_set_child_fn (gomp_parallel *omp_parallel_stmt,
include/gimple.h:5168:37: error: unknown type name 'gomp_parallel'
gimple_omp_parallel_data_arg (const gomp_parallel *omp_parallel_stmt)
include/gimple.h: In function 'gimple_omp_parallel_data_arg':
include/gimple.h:5170:27: error: request for member 'data_arg' in somethi=
return omp_parallel_stmt->data_arg;
include/gimple.h:5177:35: error: unknown type name 'gomp_parallel'
gimple_omp_parallel_data_arg_ptr (gomp_parallel *omp_parallel_stmt)
include/gimple.h:5186:35: error: unknown type name 'gomp_parallel'
gimple_omp_parallel_set_data_arg (gomp_parallel *omp_parallel_stmt,
include/gimple.h:5195:39: error: unknown type name 'gomp_parallel'
gimple_omp_parallel_grid_phony (const gomp_parallel *stmt)
include/gimple.h:5203:37: error: unknown type name 'gomp_parallel'
gimple_omp_parallel_set_grid_phony (gomp_parallel *stmt, bool value)
include/gimple.h:5214:32: error: unknown type name 'gimple'
gimple_omp_task_clauses (const gimple *gs)
include/gimple.h: In function 'gimple_omp_task_clauses':
include/gimple.h:5216:9: error: unknown type name 'gomp_task'
const gomp_task *omp_task_stmt =3D as_a <const gomp_task *> (gs);
include/gimple.h:5216:36: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:5216:42: error: expected expression before 'const'
include/gimple.h:5217:23: error: request for member 'clauses' in somethin=
return omp_task_stmt->clauses;
include/gimple.h:5224:30: error: unknown type name 'gimple'
gimple_omp_task_clauses_ptr (gimple *gs)
include/gimple.h:5235:30: error: unknown type name 'gimple'
gimple_omp_task_set_clauses (gimple *gs, tree clauses)
include/gimple.h:5246:35: error: unknown type name 'gimple'
gimple_omp_task_taskloop_p (const gimple *g)
include/gimple.h:5257:33: error: unknown type name 'gimple'
gimple_omp_task_set_taskloop_p (gimple *g, bool taskloop_p)
include/gimple.h:5270:33: error: unknown type name 'gimple'
gimple_omp_task_child_fn (const gimple *gs)
include/gimple.h: In function 'gimple_omp_task_child_fn':
include/gimple.h:5272:9: error: unknown type name 'gomp_task'
include/gimple.h:5272:36: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:5272:42: error: expected expression before 'const'
include/gimple.h:5273:23: error: request for member 'child_fn' in somethi=
return omp_task_stmt->child_fn;
include/gimple.h:5280:31: error: unknown type name 'gimple'
gimple_omp_task_child_fn_ptr (gimple *gs)
include/gimple.h:5290:31: error: unknown type name 'gimple'
gimple_omp_task_set_child_fn (gimple *gs, tree child_fn)
include/gimple.h:5301:33: error: unknown type name 'gimple'
gimple_omp_task_data_arg (const gimple *gs)
include/gimple.h: In function 'gimple_omp_task_data_arg':
include/gimple.h:5303:9: error: unknown type name 'gomp_task'
include/gimple.h:5303:36: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:5303:42: error: expected expression before 'const'
include/gimple.h:5304:23: error: request for member 'data_arg' in somethi=
ng not a structure or union
return omp_task_stmt->data_arg;
include/gimple.h:5311:31: error: unknown type name 'gimple'
gimple_omp_task_data_arg_ptr (gimple *gs)
include/gimple.h:5321:31: error: unknown type name 'gimple'
gimple_omp_task_set_data_arg (gimple *gs, tree data_arg)
include/gimple.h:5331:35: error: unknown type name 'gimple'
gimple_omp_taskreg_clauses (const gimple *gs)
include/gimple.h: In function 'gimple_omp_taskreg_clauses':
include/gimple.h:5333:9: error: unknown type name 'gimple_statement_omp_t=
askreg'
const gimple_statement_omp_taskreg *omp_taskreg_stmt
include/gimple.h:5334:7: error: 'as_a' undeclared (first use in this func=
tion)
=3D as_a <const gimple_statement_omp_taskreg *> (gs);
include/gimple.h:5334:13: error: expected expression before 'const'
include/gimple.h:5335:26: error: request for member 'clauses' in somethin=
return omp_taskreg_stmt->clauses;
include/gimple.h:5342:33: error: unknown type name 'gimple'
gimple_omp_taskreg_clauses_ptr (gimple *gs)
include/gimple.h:5354:33: error: unknown type name 'gimple'
gimple_omp_taskreg_set_clauses (gimple *gs, tree clauses)
include/gimple.h:5365:36: error: unknown type name 'gimple'
gimple_omp_taskreg_child_fn (const gimple *gs)
include/gimple.h: In function 'gimple_omp_taskreg_child_fn':
include/gimple.h:5367:9: error: unknown type name 'gimple_statement_omp_t=
askreg'
include/gimple.h:5368:7: error: 'as_a' undeclared (first use in this func=
tion)
include/gimple.h:5368:13: error: expected expression before 'const'
include/gimple.h:5369:26: error: request for member 'child_fn' in somethi=
return omp_taskreg_stmt->child_fn;
include/gimple.h:5376:34: error: unknown type name 'gimple'
gimple_omp_taskreg_child_fn_ptr (gimple *gs)
include/gimple.h:5387:34: error: unknown type name 'gimple'
gimple_omp_taskreg_set_child_fn (gimple *gs, tree child_fn)
include/gimple.h:5399:36: error: unknown type name 'gimple'
gimple_omp_taskreg_data_arg (const gimple *gs)
include/gimple.h: In function 'gimple_omp_taskreg_data_arg':
include/gimple.h:5401:9: error: unknown type name 'gimple_statement_omp_t=
askreg'
include/gimple.h:5402:7: error: 'as_a' undeclared (first use in this func=
tion)
include/gimple.h:5402:13: error: expected expression before 'const'
include/gimple.h:5403:26: error: request for member 'data_arg' in somethi=
return omp_taskreg_stmt->data_arg;
include/gimple.h:5410:34: error: unknown type name 'gimple'
gimple_omp_taskreg_data_arg_ptr (gimple *gs)
include/gimple.h:5421:34: error: unknown type name 'gimple'
gimple_omp_taskreg_set_data_arg (gimple *gs, tree data_arg)
include/gimple.h:5432:32: error: unknown type name 'gimple'
gimple_omp_task_copy_fn (const gimple *gs)
include/gimple.h: In function 'gimple_omp_task_copy_fn':
include/gimple.h:5434:9: error: unknown type name 'gomp_task'
include/gimple.h:5434:36: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:5434:42: error: expected expression before 'const'
include/gimple.h:5435:23: error: request for member 'copy_fn' in somethin=
return omp_task_stmt->copy_fn;
include/gimple.h:5442:30: error: unknown type name 'gimple'
gimple_omp_task_copy_fn_ptr (gimple *gs)
include/gimple.h:5452:30: error: unknown type name 'gimple'
gimple_omp_task_set_copy_fn (gimple *gs, tree copy_fn)
include/gimple.h:5462:33: error: unknown type name 'gimple'
gimple_omp_task_arg_size (const gimple *gs)
include/gimple.h: In function 'gimple_omp_task_arg_size':
include/gimple.h:5464:9: error: unknown type name 'gomp_task'
include/gimple.h:5464:36: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:5464:42: error: expected expression before 'const'
include/gimple.h:5465:23: error: request for member 'arg_size' in somethi=
return omp_task_stmt->arg_size;
include/gimple.h:5472:31: error: unknown type name 'gimple'
gimple_omp_task_arg_size_ptr (gimple *gs)
include/gimple.h:5482:31: error: unknown type name 'gimple'
gimple_omp_task_set_arg_size (gimple *gs, tree arg_size)
include/gimple.h:5492:34: error: unknown type name 'gimple'
gimple_omp_task_arg_align (const gimple *gs)
include/gimple.h: In function 'gimple_omp_task_arg_align':
include/gimple.h:5494:9: error: unknown type name 'gomp_task'
include/gimple.h:5494:36: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:5494:42: error: expected expression before 'const'
include/gimple.h:5495:23: error: request for member 'arg_align' in someth=
ing not a structure or union
return omp_task_stmt->arg_align;
include/gimple.h:5502:32: error: unknown type name 'gimple'
gimple_omp_task_arg_align_ptr (gimple *gs)
include/gimple.h:5512:32: error: unknown type name 'gimple'
gimple_omp_task_set_arg_align (gimple *gs, tree arg_align)
include/gimple.h:5522:34: error: unknown type name 'gimple'
gimple_omp_single_clauses (const gimple *gs)
include/gimple.h: In function 'gimple_omp_single_clauses':
include/gimple.h:5524:9: error: unknown type name 'gomp_single'
const gomp_single *omp_single_stmt =3D as_a <const gomp_single *> (gs)=
include/gimple.h:5524:40: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:5524:46: error: expected expression before 'const'
include/gimple.h:5525:25: error: request for member 'clauses' in somethin=
return omp_single_stmt->clauses;
include/gimple.h:5532:32: error: unknown type name 'gimple'
gimple_omp_single_clauses_ptr (gimple *gs)
include/gimple.h:5542:32: error: unknown type name 'gomp_single'
gimple_omp_single_set_clauses (gomp_single *omp_single_stmt, tree clause=
s)
include/gimple.h:5551:34: error: unknown type name 'gimple'
gimple_omp_target_clauses (const gimple *gs)
include/gimple.h: In function 'gimple_omp_target_clauses':
include/gimple.h:5553:9: error: unknown type name 'gomp_target'
const gomp_target *omp_target_stmt =3D as_a <const gomp_target *> (gs)=
include/gimple.h:5553:40: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:5553:46: error: expected expression before 'const'
include/gimple.h:5554:25: error: request for member 'clauses' in somethin=
return omp_target_stmt->clauses;
include/gimple.h:5561:32: error: unknown type name 'gimple'
gimple_omp_target_clauses_ptr (gimple *gs)
include/gimple.h:5571:32: error: unknown type name 'gomp_target'
gimple_omp_target_set_clauses (gomp_target *omp_target_stmt,
include/gimple.h:5581:31: error: unknown type name 'gimple'
gimple_omp_target_kind (const gimple *g)
include/gimple.h:5591:29: error: unknown type name 'gomp_target'
gimple_omp_target_set_kind (gomp_target *g, int kind)
include/gimple.h:5601:35: error: unknown type name 'gomp_target'
gimple_omp_target_child_fn (const gomp_target *omp_target_stmt)
include/gimple.h: In function 'gimple_omp_target_child_fn':
include/gimple.h:5603:25: error: request for member 'child_fn' in somethi=
return omp_target_stmt->child_fn;
include/gimple.h:5610:33: error: unknown type name 'gomp_target'
gimple_omp_target_child_fn_ptr (gomp_target *omp_target_stmt)
include/gimple.h:5619:33: error: unknown type name 'gomp_target'
gimple_omp_target_set_child_fn (gomp_target *omp_target_stmt,
include/gimple.h:5630:35: error: unknown type name 'gomp_target'
gimple_omp_target_data_arg (const gomp_target *omp_target_stmt)
include/gimple.h: In function 'gimple_omp_target_data_arg':
include/gimple.h:5632:25: error: request for member 'data_arg' in somethi=
return omp_target_stmt->data_arg;
include/gimple.h:5639:33: error: unknown type name 'gomp_target'
gimple_omp_target_data_arg_ptr (gomp_target *omp_target_stmt)
include/gimple.h:5648:33: error: unknown type name 'gomp_target'
gimple_omp_target_set_data_arg (gomp_target *omp_target_stmt,
include/gimple.h:5658:33: error: unknown type name 'gimple'
gimple_omp_teams_clauses (const gimple *gs)
include/gimple.h: In function 'gimple_omp_teams_clauses':
include/gimple.h:5660:9: error: unknown type name 'gomp_teams'
const gomp_teams *omp_teams_stmt =3D as_a <const gomp_teams *> (gs);
include/gimple.h:5660:38: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:5660:44: error: expected expression before 'const'
include/gimple.h:5661:24: error: request for member 'clauses' in somethin=
return omp_teams_stmt->clauses;
include/gimple.h:5668:31: error: unknown type name 'gimple'
gimple_omp_teams_clauses_ptr (gimple *gs)
include/gimple.h:5678:31: error: unknown type name 'gomp_teams'
gimple_omp_teams_set_clauses (gomp_teams *omp_teams_stmt, tree clauses)
include/gimple.h:5686:36: error: unknown type name 'gomp_teams'
gimple_omp_teams_grid_phony (const gomp_teams *omp_teams_stmt)
include/gimple.h:5694:34: error: unknown type name 'gomp_teams'
gimple_omp_teams_set_grid_phony (gomp_teams *omp_teams_stmt, bool value)=
include/gimple.h:5705:36: error: unknown type name 'gimple'
gimple_omp_sections_clauses (const gimple *gs)
include/gimple.h: In function 'gimple_omp_sections_clauses':
include/gimple.h:5707:9: error: unknown type name 'gomp_sections'
const gomp_sections *omp_sections_stmt =3D as_a <const gomp_sections *=
> (gs);
include/gimple.h:5707:44: error: 'as_a' undeclared (first use in this fun=
ction)
> (gs);
include/gimple.h:5707:50: error: expected expression before 'const'
> (gs);
include/gimple.h:5708:27: error: request for member 'clauses' in somethin=
return omp_sections_stmt->clauses;
include/gimple.h:5715:34: error: unknown type name 'gimple'
gimple_omp_sections_clauses_ptr (gimple *gs)
include/gimple.h:5726:34: error: unknown type name 'gimple'
gimple_omp_sections_set_clauses (gimple *gs, tree clauses)
include/gimple.h:5737:36: error: unknown type name 'gimple'
gimple_omp_sections_control (const gimple *gs)
include/gimple.h: In function 'gimple_omp_sections_control':
include/gimple.h:5739:9: error: unknown type name 'gomp_sections'
> (gs);
include/gimple.h:5739:44: error: 'as_a' undeclared (first use in this fun=
ction)
> (gs);
include/gimple.h:5739:50: error: expected expression before 'const'
> (gs);
include/gimple.h:5740:27: error: request for member 'control' in somethin=
return omp_sections_stmt->control;
include/gimple.h:5748:34: error: unknown type name 'gimple'
gimple_omp_sections_control_ptr (gimple *gs)
include/gimple.h:5759:34: error: unknown type name 'gimple'
gimple_omp_sections_set_control (gimple *gs, tree control)
include/gimple.h:5769:34: error: unknown type name 'gomp_atomic_store'
gimple_omp_atomic_store_set_val (gomp_atomic_store *store_stmt, tree val=
include/gimple.h:5778:36: error: unknown type name 'gomp_atomic_store'
gimple_omp_atomic_store_val (const gomp_atomic_store *store_stmt)
include/gimple.h: In function 'gimple_omp_atomic_store_val':
include/gimple.h:5780:20: error: request for member 'val' in something no=
return store_stmt->val;
include/gimple.h:5787:34: error: unknown type name 'gomp_atomic_store'
gimple_omp_atomic_store_val_ptr (gomp_atomic_store *store_stmt)
include/gimple.h:5796:33: error: unknown type name 'gomp_atomic_load'
gimple_omp_atomic_load_set_lhs (gomp_atomic_load *load_stmt, tree lhs)
include/gimple.h:5805:35: error: unknown type name 'gomp_atomic_load'
gimple_omp_atomic_load_lhs (const gomp_atomic_load *load_stmt)
include/gimple.h: In function 'gimple_omp_atomic_load_lhs':
include/gimple.h:5807:19: error: request for member 'lhs' in something no=
return load_stmt->lhs;
include/gimple.h:5814:33: error: unknown type name 'gomp_atomic_load'
gimple_omp_atomic_load_lhs_ptr (gomp_atomic_load *load_stmt)
include/gimple.h:5823:33: error: unknown type name 'gomp_atomic_load'
gimple_omp_atomic_load_set_rhs (gomp_atomic_load *load_stmt, tree rhs)
include/gimple.h:5832:35: error: unknown type name 'gomp_atomic_load'
gimple_omp_atomic_load_rhs (const gomp_atomic_load *load_stmt)
include/gimple.h: In function 'gimple_omp_atomic_load_rhs':
include/gimple.h:5834:19: error: request for member 'rhs' in something no=
return load_stmt->rhs;
include/gimple.h:5841:33: error: unknown type name 'gomp_atomic_load'
gimple_omp_atomic_load_rhs_ptr (gomp_atomic_load *load_stmt)
include/gimple.h:5850:40: error: unknown type name 'gomp_continue'
gimple_omp_continue_control_def (const gomp_continue *cont_stmt)
include/gimple.h: In function 'gimple_omp_continue_control_def':
include/gimple.h:5852:19: error: request for member 'control_def' in some=
thing not a structure or union
return cont_stmt->control_def;
include/gimple.h:5858:38: error: unknown type name 'gomp_continue'
gimple_omp_continue_control_def_ptr (gomp_continue *cont_stmt)
include/gimple.h:5866:38: error: unknown type name 'gomp_continue'
gimple_omp_continue_set_control_def (gomp_continue *cont_stmt, tree def)=
include/gimple.h:5875:40: error: unknown type name 'gomp_continue'
gimple_omp_continue_control_use (const gomp_continue *cont_stmt)
include/gimple.h: In function 'gimple_omp_continue_control_use':
include/gimple.h:5877:19: error: request for member 'control_use' in some=
return cont_stmt->control_use;
include/gimple.h:5884:38: error: unknown type name 'gomp_continue'
gimple_omp_continue_control_use_ptr (gomp_continue *cont_stmt)
include/gimple.h:5893:38: error: unknown type name 'gomp_continue'
gimple_omp_continue_set_control_use (gomp_continue *cont_stmt, tree use)=
include/gimple.h:5902:30: error: unknown type name 'gtransaction'
gimple_transaction_body_ptr (gtransaction *transaction_stmt)
include/gimple.h:5910:26: error: unknown type name 'gtransaction'
gimple_transaction_body (gtransaction *transaction_stmt)
include/gimple.h:5918:38: error: unknown type name 'gtransaction'
gimple_transaction_label_norm (const gtransaction *transaction_stmt)
include/gimple.h: In function 'gimple_transaction_label_norm':
include/gimple.h:5920:26: error: request for member 'label_norm' in somet=
return transaction_stmt->label_norm;
include/gimple.h:5924:36: error: unknown type name 'gtransaction'
gimple_transaction_label_norm_ptr (gtransaction *transaction_stmt)
include/gimple.h:5930:40: error: unknown type name 'gtransaction'
gimple_transaction_label_uninst (const gtransaction *transaction_stmt)
include/gimple.h: In function 'gimple_transaction_label_uninst':
include/gimple.h:5932:26: error: request for member 'label_uninst' in som=
ething not a structure or union
return transaction_stmt->label_uninst;
include/gimple.h:5936:38: error: unknown type name 'gtransaction'
gimple_transaction_label_uninst_ptr (gtransaction *transaction_stmt)
include/gimple.h:5942:38: error: unknown type name 'gtransaction'
gimple_transaction_label_over (const gtransaction *transaction_stmt)
include/gimple.h: In function 'gimple_transaction_label_over':
include/gimple.h:5944:26: error: request for member 'label_over' in somet=
return transaction_stmt->label_over;
include/gimple.h:5948:36: error: unknown type name 'gtransaction'
gimple_transaction_label_over_ptr (gtransaction *transaction_stmt)
include/gimple.h:5956:35: error: unknown type name 'gtransaction'
gimple_transaction_subcode (const gtransaction *transaction_stmt)
include/gimple.h: In function 'gimple_transaction_subcode':
include/gimple.h:5958:26: error: request for member 'subcode' in somethin=
return transaction_stmt->subcode;
include/gimple.h:5965:30: error: unknown type name 'gtransaction'
gimple_transaction_set_body (gtransaction *transaction_stmt,
include/gimple.h:5974:36: error: unknown type name 'gtransaction'
gimple_transaction_set_label_norm (gtransaction *transaction_stmt, tree =
label)
include/gimple.h:5980:38: error: unknown type name 'gtransaction'
gimple_transaction_set_label_uninst (gtransaction *transaction_stmt, tre=
e label)
include/gimple.h:5986:36: error: unknown type name 'gtransaction'
gimple_transaction_set_label_over (gtransaction *transaction_stmt, tree =
label)
include/gimple.h:5994:33: error: unknown type name 'gtransaction'
gimple_transaction_set_subcode (gtransaction *transaction_stmt,
include/gimple.h:6003:27: error: unknown type name 'greturn'
gimple_return_retval_ptr (greturn *gs)
include/gimple.h:6011:29: error: unknown type name 'greturn'
gimple_return_retval (const greturn *gs)
include/gimple.h: In function 'gimple_return_retval':
include/gimple.h:6013:12: error: request for member 'op' in something not=
return gs->op[0];
include/gimple.h:6020:27: error: unknown type name 'greturn'
gimple_return_set_retval (greturn *gs, tree retval)
include/gimple.h:6029:29: error: unknown type name 'gimple'
gimple_return_retbnd (const gimple *gs)
include/gimple.h:6039:27: error: unknown type name 'gimple'
gimple_return_set_retbnd (gimple *gs, tree retval)
include/gimple.h:6069:22: error: unknown type name 'gimple'
is_gimple_omp (const gimple *stmt)
include/gimple.h:6084:27: error: unknown type name 'gimple'
is_gimple_omp_oacc (const gimple *stmt)
include/gimple.h:6120:32: error: unknown type name 'gimple'
is_gimple_omp_offloaded (const gimple *stmt)
include/gimple.h:6144:21: error: unknown type name 'gimple'
gimple_nop_p (const gimple *g)
include/gimple.h:6153:23: error: unknown type name 'gimple'
is_gimple_resx (const gimple *gs)
include/gimple.h:6162:25: error: unknown type name 'gimple'
gimple_expr_type (const gimple *stmt)
include/gimple.h: In function 'gimple_expr_type':
include/gimple.h:6171:13: error: unknown type name 'gcall'
const gcall *call_stmt =3D as_a <const gcall *> (stmt);
include/gimple.h:6171:32: error: 'as_a' undeclared (first use in this fun=
ction)
include/gimple.h:6171:38: error: expected expression before 'const'
include/gimple.h:6227:32: error: unknown type name 'gimple'
gimple_do_not_emit_location_p (gimple *g)
include/gimple.h:6236:34: error: unknown type name 'gimple'
gimple_set_do_not_emit_location (gimple *g)
conftest.c:105:45: warning: missing terminating ' character
Beware, this compiler is a fake. Don't use it.
conftest.c:108:21: error: unknown type name 'gimple'
tree fndecl; gimple call;
conftest.c:108:21: note: use 'struct' keyword to refer to the type
conftest.c: In function 'foo':
conftest.c:116:17: warning: implicit declaration of function 'lookup_name=
' [-Wimplicit-function-declaration]
return lookup_name (get_identifier ("puts"));
conftest.c:116:30: warning: implicit declaration of function 'get_identif=
ier' [-Wimplicit-function-declaration]
conftest.c:116:17: warning: return makes pointer from integer without a c=
ast [-Wint-conversion]
conftest.c: In function 'main':
conftest.c:119:13: warning: assignment makes integer from pointer without=
a cast [-Wint-conversion]
call =3D gimple_build_call (fndecl, 0);
configure:32736: $? =3D 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "StarPU"
| #define PACKAGE_TARNAME "starpu"
| #define PACKAGE_VERSION "1.3.0"
| #define PACKAGE_STRING "StarPU 1.3.0"
| #define PACKAGE_BUGREPORT "starpu-devel@lists.gforge.inria.fr"
| #define PACKAGE_URL "http://runtime.bordeaux.inria.fr/StarPU/"
| #define STARPU_MAJOR_VERSION 1
| #define STARPU_MINOR_VERSION 3
| #define STARPU_RELEASE_VERSION 0
| #define PACKAGE "starpu"
| #define VERSION "1.3.0"
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_DLFCN_H 1
| #define LT_OBJDIR ".libs/"
| #define restrict __restrict
| #define STARPU_MIC_USE_RMA 1
| #define STARPU_LINUX_SYS 1
| #define SIZEOF_VOID_P 8
| #define STARPU_BUILD_DIR "/tmp/lschnorr/spack-stage/spack-stage-AgZLf5/=
trunk"
| #define STARPU_SRC_DIR "/tmp/lschnorr/spack-stage/spack-stage-AgZLf5/tr=
unk/."
| #define STARPU_HAVE_STRUCT_TIMESPEC /**/
| #define STARPU_HAVE_UNISTD_H 1
| #define HAVE_LIBPTHREAD 1
| #define HAVE_SYSCONF 1
| #define HAVE_PTHREAD_SPIN_LOCK /**/
| #define STARPU_HAVE_PTHREAD_SPIN_LOCK /**/
| #define STARPU_HAVE_PTHREAD_BARRIER /**/
| #define HAVE_PTHREAD_SETAFFINITY_NP 1
| #define HAVE_POSIX_MEMALIGN 1
| #define STARPU_HAVE_POSIX_MEMALIGN 1
| #define HAVE_MEMALIGN 1
| #define STARPU_HAVE_MEMALIGN 1
| #define STARPU_USE_DRAND48 1
| #define STARPU_USE_ERAND48_R 1
| #define STARPU_HAVE_STRERROR_R 1
| #define STARPU_HAVE_SETENV 1
| #define STARPU_HAVE_UNSETENV 1
| #define STARPU_HAVE_NEARBYINTF 1
| #define STARPU_HAVE_RINTF 1
| #define HAVE_MALLOC_H 1
| #define STARPU_HAVE_MALLOC_H 1
| #define HAVE_VALGRIND_VALGRIND_H 1
| #define STARPU_HAVE_VALGRIND_H 1
| #define HAVE_VALGRIND_MEMCHECK_H 1
| #define STARPU_HAVE_MEMCHECK_H 1
| #define HAVE_VALGRIND_HELGRIND_H 1
| #define STARPU_HAVE_HELGRIND_H 1
| #define STARPU_HAVE_SCHED_YIELD 1
| #define HAVE_AIO_H 1
| #define HAVE_MKOSTEMP 1
| #define HAVE_PREAD 1
| #define HAVE_PWRITE 1
| #define STARPU_HAVE_SYNC_VAL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_BOOL_COMPARE_AND_SWAP 1
| #define STARPU_HAVE_SYNC_FETCH_AND_ADD 1
| #define STARPU_HAVE_SYNC_FETCH_AND_OR 1
| #define STARPU_HAVE_SYNC_LOCK_TEST_AND_SET 1
| #define STARPU_HAVE_SYNC_SYNCHRONIZE 1
| #define STARPU_HAVE_LIBNUMA /**/
| #define STARPU_NMAX_SCHED_CTXS 10
| #define STARPU_MAXCPUS 64
| #define STARPU_USE_CPU 1
| #define STARPU_MAXCUDADEVS 4
| #define STARPU_MAXOPENCLDEVS 8
| #define STARPU_NON_BLOCKING_DRIVERS 1
| #define STARPU_MAXMICDEVS 4
| #define STARPU_MAXMICCORES 120
| #define STARPU_MAXSCCDEVS 47
| #define STARPU_MAXMPKERNELS 10
| #define STARPU_USE_FXT 1
| #define CONFIG_FUT 1
| #define HAVE_ENABLE_FUT_FLUSH 1
| #define HAVE_FUT_SET_FILENAME 1
| #define HAVE_DECL_ENABLE_FUT_FLUSH 0
| #define HAVE_DECL_FUT_SET_FILENAME 0
| #define STARPU_ENABLE_PAJE_CODELET_DETAILS 1
| #define STARPU_NMAXBUFS 8
| #define STARPU_MAXNODES 4
| #define STARPU_USE_ALLOCATION_CACHE 1
| #define HAVE_LIBRT 1
| #define HAVE_CLOCK_GETTIME 1
| #define STARPU_NMAXWORKERS 64
| #define STARPU_NMAX_COMBINEDWORKERS 64
| #define STARPU_MAXIMPLEMENTATIONS 4
| #define STARPU_HISTORYMAXERROR 50
| #define STARPU_HAVE_FC /**/
| /* end confdefs.h. */
| #include <gcc-plugin.h>
| #include <tree.h>
| #include <gimple.h>
|=20
| #if defined __INTEL_COMPILER || defined __ICC
| #endif
|=20
| int
| main ()
| /* Clang 3.1 doesn't support nested functions, so try to
| discriminate it this way. */
| tree foo (void)
| fndecl =3D foo ();
| return 0;
configure:32752: result: no
configure:33036: WARNING: GCC plug-ins not supported; StarPU's GCC plug-i=
n will not be built
configure:33174: checking for OpenMP runtime support
configure:33191: result: no
configure:33221: checking for SOCL
configure:33236: result: no
configure:33285: checking for gdb
configure:33303: found /usr/bin/gdb
configure:33316: result: /usr/bin/gdb
configure:33544: checking whether OpenGL rendering is enabled
configure:33548: result: no
configure:33559: checking for X
configure:33667: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -E -D_=
GNU_SOURCE conftest.c
conftest.c:101:22: fatal error: X11/Xlib.h: No such file or directory
#include <X11/Xlib.h>
compilation terminated.
configure:33667: $? =3D 1
| /* confdefs.h */
trunk"
unk/."
| #define STARPU_GDB_PATH "/usr/bin/gdb"
configure:33698: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
test -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE -gdwarf-2 -g3 conftest.=
c -lX11 -lrt -lm -lpthread >&5
configure:33698: $? =3D 1
| /* confdefs.h */
trunk"
unk/."
| int
| main ()
| XrmInitialize ()
| return 0;
configure:33737: result: no
configure:34715: checking for library containing sgemm_
configure:34746: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
c >&5
/tmp/ccrgiaWx.o: In function `main':
/tmp/lschnorr/spack-stage/spack-stage-AgZLf5/trunk/conftest.c:113: undefi=
ned reference to `sgemm_'
collect2: error: ld returned 1 exit status
configure:34746: $? =3D 1
| /* confdefs.h */
trunk"
unk/."
| #define X_DISPLAY_MISSING 1
|=20
| /* Override any GCC internal prototype to avoid an error.
| Use char because int might match the return type of a GCC
| builtin and then its argument prototype would still apply. */
| #ifdef __cplusplus
| extern "C"
| #endif
| char sgemm_ ();
| int
| main ()
| return sgemm_ ();
| return 0;
c -lblas >&5
configure:34746: $? =3D 0
configure:34763: result: -lblas
configure:34834: checking which BLAS lib should be used
configure:34836: result: system
configure:34860: checking for FFTW
configure:34868: $PKG_CONFIG --exists --print-errors "fftw3"
Package fftw3 was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3.pc'
to the PKG_CONFIG_PATH environment variable
No package 'fftw3' found
configure:34871: $? =3D 1
configure:34886: $PKG_CONFIG --exists --print-errors "fftw3"
configure:34889: $? =3D 1
configure:34917: result: no
configure:34947: checking for FFTWF
configure:34955: $PKG_CONFIG --exists --print-errors "fftw3f"
Package fftw3f was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3f.pc'
No package 'fftw3f' found
configure:34958: $? =3D 1
configure:34973: $PKG_CONFIG --exists --print-errors "fftw3f"
configure:34976: $? =3D 1
configure:35004: result: no
configure:35034: checking for FFTWL
configure:35042: $PKG_CONFIG --exists --print-errors "fftw3l"
Package fftw3l was not found in the pkg-config search path.
Perhaps you should add the directory containing `fftw3l.pc'
No package 'fftw3l' found
configure:35045: $? =3D 1
configure:35060: $PKG_CONFIG --exists --print-errors "fftw3l"
configure:35063: $? =3D 1
configure:35091: result: no
configure:35267: checking hwloc.h usability
configure:35267: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -c -O3 =
-g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE -I/home/lschnorr/spack-orion/opt/s=
pack/linux-x86_64/gcc-6.1.0/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx=
/include conftest.c >&5
configure:35267: $? =3D 0
configure:35267: result: yes
configure:35267: checking hwloc.h presence
configure:35267: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -E -D_=
GNU_SOURCE -I/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0=
/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx/include conftest.c
configure:35267: checking for hwloc.h
configure:35276: checking for main in -lhwloc
configure:35295: /home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -o conf=
test -O3 -g -O2 -gdwarf-2 -g3 -D_GNU_SOURCE -I/home/lschnorr/spack-or=
ion/opt/spack/linux-x86_64/gcc-6.1.0/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rut=
n55ljz2nx/include -gdwarf-2 -g3 -L/home/lschnorr/spack-orion/opt/spack/=
linux-x86_64/gcc-6.1.0/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx/lib =
conftest.c -lhwloc -lrt -lm -lpthread >&5
/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/hwloc-1.11.3-=
j3wlufl4afo5kvid3vv4rutn55ljz2nx/lib/libhwloc.so: undefined reference to =
`clGetPlatformIDs@OPENCL_1.0'
`clGetDeviceIDs@OPENCL_1.0'
`clGetPlatformInfo@OPENCL_1.0'
`clGetDeviceInfo@OPENCL_1.0'
configure:35295: $? =3D 1
| /* confdefs.h */
trunk"
unk/."
| #define STARPU_SYSTEM_BLAS 1
|=20
|=20
| int
| main ()
| return main ();
| return 0;
configure:35304: result: no
configure:35327: error: cannot find hwloc
## Cache variables. ##
ac_cv_build=3Dx86_64-pc-linux-gnu
ac_cv_c_compiler_gnu=3Dyes
ac_cv_c_restrict=3D__restrict
ac_cv_cxx_compiler_gnu=3Dyes
ac_cv_env_BLAS_LIBS_set=3D
ac_cv_env_BLAS_LIBS_value=3D
ac_cv_env_CCC_set=3D
ac_cv_env_CCC_value=3D
ac_cv_env_CC_set=3Dset
ac_cv_env_CC_value=3D/home/lschnorr/spack-orion/lib/spack/env/gcc/gcc
ac_cv_env_CFLAGS_set=3D
ac_cv_env_CFLAGS_value=3D
ac_cv_env_CPPFLAGS_set=3D
ac_cv_env_CPPFLAGS_value=3D
ac_cv_env_CPP_set=3D
ac_cv_env_CPP_value=3D
ac_cv_env_CXXCPP_set=3D
ac_cv_env_CXXCPP_value=3D
ac_cv_env_CXXFLAGS_set=3D
ac_cv_env_CXXFLAGS_value=3D
ac_cv_env_CXX_set=3Dset
ac_cv_env_CXX_value=3D/home/lschnorr/spack-orion/lib/spack/env/gcc/g++
ac_cv_env_F77_set=3Dset
ac_cv_env_F77_value=3D/home/lschnorr/spack-orion/lib/spack/env/gcc/gfortr=
an
ac_cv_env_FCFLAGS_set=3D
ac_cv_env_FCFLAGS_value=3D
ac_cv_env_FC_set=3Dset
ac_cv_env_FC_value=3D/home/lschnorr/spack-orion/lib/spack/env/gcc/gfortra=
n
ac_cv_env_FFLAGS_set=3D
ac_cv_env_FFLAGS_value=3D
ac_cv_env_FFTWF_CFLAGS_set=3D
ac_cv_env_FFTWF_CFLAGS_value=3D
ac_cv_env_FFTWF_LIBS_set=3D
ac_cv_env_FFTWF_LIBS_value=3D
ac_cv_env_FFTWL_CFLAGS_set=3D
ac_cv_env_FFTWL_CFLAGS_value=3D
ac_cv_env_FFTWL_LIBS_set=3D
ac_cv_env_FFTWL_LIBS_value=3D
ac_cv_env_FFTW_CFLAGS_set=3D
ac_cv_env_FFTW_CFLAGS_value=3D
ac_cv_env_FFTW_LIBS_set=3D
ac_cv_env_FFTW_LIBS_value=3D
ac_cv_env_FXT_CFLAGS_set=3D
ac_cv_env_FXT_CFLAGS_value=3D
ac_cv_env_FXT_LDFLAGS_set=3D
ac_cv_env_FXT_LDFLAGS_value=3D
ac_cv_env_FXT_LIBS_set=3D
ac_cv_env_FXT_LIBS_value=3D
ac_cv_env_HWLOC_CFLAGS_set=3D
ac_cv_env_HWLOC_CFLAGS_value=3D
ac_cv_env_HWLOC_LIBS_set=3D
ac_cv_env_HWLOC_LIBS_value=3D
ac_cv_env_LDFLAGS_set=3D
ac_cv_env_LDFLAGS_value=3D
ac_cv_env_LIBS_set=3D
ac_cv_env_LIBS_value=3D
ac_cv_env_LT_SYS_LIBRARY_PATH_set=3D
ac_cv_env_LT_SYS_LIBRARY_PATH_value=3D
ac_cv_env_MAGMA_CFLAGS_set=3D
ac_cv_env_MAGMA_CFLAGS_value=3D
ac_cv_env_MAGMA_LIBS_set=3D
ac_cv_env_MAGMA_LIBS_value=3D
ac_cv_env_NVCCFLAGS_set=3D
ac_cv_env_NVCCFLAGS_value=3D
ac_cv_env_NVCC_set=3D
ac_cv_env_NVCC_value=3D
ac_cv_env_PKG_CONFIG_set=3D
ac_cv_env_PKG_CONFIG_value=3D
ac_cv_env_POTI_CFLAGS_set=3D
ac_cv_env_POTI_CFLAGS_value=3D
ac_cv_env_POTI_LIBS_set=3D
ac_cv_env_POTI_LIBS_value=3D
ac_cv_env_STARPU_MS_LIB_set=3D
ac_cv_env_STARPU_MS_LIB_value=3D
ac_cv_env_XMKMF_set=3D
ac_cv_env_XMKMF_value=3D
ac_cv_env_build_alias_set=3D
ac_cv_env_build_alias_value=3D
ac_cv_env_host_alias_set=3D
ac_cv_env_host_alias_value=3D
ac_cv_env_target_alias_set=3D
ac_cv_env_target_alias_value=3D
ac_cv_f77_compiler_gnu=3Dyes
ac_cv_fc_compiler_gnu=3Dyes
ac_cv_func_clock_gettime=3Dyes
ac_cv_func_drand48=3Dyes
ac_cv_func_enable_fut_flush=3Dyes
ac_cv_func_erand48_r=3Dyes
ac_cv_func_fut_set_filename=3Dyes
ac_cv_func_memalign=3Dyes
ac_cv_func_mkostemp=3Dyes
ac_cv_func_nearbyintf=3Dyes
ac_cv_func_posix_memalign=3Dyes
ac_cv_func_pread=3Dyes
ac_cv_func_pthread_barrier_init=3Dyes
ac_cv_func_pthread_setaffinity_np=3Dyes
ac_cv_func_pthread_spin_lock=3Dyes
ac_cv_func_pwrite=3Dyes
ac_cv_func_rintf=3Dyes
ac_cv_func_sched_yield=3Dyes
ac_cv_func_setenv=3Dyes
ac_cv_func_strerror_r=3Dyes
ac_cv_func_sysconf=3Dyes
ac_cv_func_unsetenv=3Dyes
ac_cv_have_decl_enable_fut_flush=3Dno
ac_cv_have_decl_fut_set_filename=3Dno
ac_cv_have_gcc_plugins=3Dno
ac_cv_have_sync_bool_compare_and_swap=3Dyes
ac_cv_have_sync_fetch_and_add=3Dyes
ac_cv_have_sync_fetch_and_or=3Dyes
ac_cv_have_sync_lock_test_and_set=3Dyes
ac_cv_have_sync_synchronize=3Dyes
ac_cv_have_sync_val_compare_and_swap=3Dyes
ac_cv_have_x=3Dhave_x=3Dno
ac_cv_header_Ayudame_h=3Dno
ac_cv_header_RCCE_h=3Dno
ac_cv_header_aio_h=3Dyes
ac_cv_header_dlfcn_h=3Dyes
ac_cv_header_glpk_h=3Dno
ac_cv_header_hwloc_h=3Dyes
ac_cv_header_inttypes_h=3Dyes
ac_cv_header_malloc_h=3Dyes
ac_cv_header_memory_h=3Dyes
ac_cv_header_stdc=3Dyes
ac_cv_header_stdint_h=3Dyes
ac_cv_header_stdlib_h=3Dyes
ac_cv_header_string_h=3Dyes
ac_cv_header_strings_h=3Dyes
ac_cv_header_sys_stat_h=3Dyes
ac_cv_header_sys_types_h=3Dyes
ac_cv_header_unistd_h=3Dyes
ac_cv_header_valgrind_helgrind_h=3Dyes
ac_cv_header_valgrind_memcheck_h=3Dyes
ac_cv_header_valgrind_valgrind_h=3Dyes
ac_cv_host=3Dx86_64-pc-linux-gnu
ac_cv_lib_RCCE_bigflags_nongory_nopwrmgmt_RCCE_init=3Dno
ac_cv_lib_glpk_main=3Dno
ac_cv_lib_hwloc=3Dac_cv_lib_hwloc_main
ac_cv_lib_hwloc_main=3Dno
ac_cv_lib_pthread_pthread_create=3Dyes
ac_cv_lib_rt_clock_gettime=3Dyes
ac_cv_lib_ws2_32=3Dac_cv_lib_ws2_32_main
ac_cv_lib_ws2_32_main=3Dno
ac_cv_objext=3Do
ac_cv_path_EGREP=3D'/bin/grep -E'
ac_cv_path_FGREP=3D'/bin/grep -F'
ac_cv_path_GDB=3D/usr/bin/gdb
ac_cv_path_GREP=3D/bin/grep
ac_cv_path_SED=3D/bin/sed
ac_cv_path_ac_pt_PKG_CONFIG=3D/usr/bin/pkg-config
ac_cv_path_install=3D'/usr/bin/install -c'
ac_cv_path_lt_DD=3D/bin/dd
ac_cv_path_mkdir=3D/bin/mkdir
ac_cv_path_mpiexec_path=3Dno
ac_cv_path_svncommand=3D/usr/bin/svn
ac_cv_path_svnversioncommand=3D/usr/bin/svnversion
ac_cv_prog_AWK=3Dgawk
ac_cv_prog_BASH=3D/bin/bash
ac_cv_prog_CPP=3D'/home/lschnorr/spack-orion/lib/spack/env/gcc/gcc -E'
ac_cv_prog_CXXCPP=3D'/home/lschnorr/spack-orion/lib/spack/env/gcc/g++ -E'=
ac_cv_prog_PROG_DATE=3Ddate
ac_cv_prog_PROG_STAT=3Dgstat
ac_cv_prog_ac_ct_AR=3Dar
ac_cv_prog_ac_ct_CC=3D/home/lschnorr/spack-orion/lib/spack/env/gcc/gcc
ac_cv_prog_ac_ct_MANIFEST_TOOL=3Dmt
ac_cv_prog_ac_ct_OBJDUMP=3Dobjdump
ac_cv_prog_ac_ct_RANLIB=3Dranlib
ac_cv_prog_ac_ct_STRIP=3Dstrip
ac_cv_prog_cc_c89=3D
ac_cv_prog_cc_g=3Dyes
ac_cv_prog_cxx_g=3Dyes
ac_cv_prog_f77_g=3Dyes
ac_cv_prog_fc_g=3Dyes
ac_cv_prog_make_make_set=3Dyes
ac_cv_search_set_mempolicy=3D-lnuma
ac_cv_search_sgemm_=3D-lblas
ac_cv_search_sqrt=3D-lm
ac_cv_sizeof_void_p=3D8
ac_cv_target=3Dx86_64-pc-linux-gnu
ac_cv_type_cufftDoubleComplex=3Dno
ac_cv_type_struct_timespec=3Dyes
am_cv_CC_dependencies_compiler_type=3Dgcc3
am_cv_CXX_dependencies_compiler_type=3Dgcc3
am_cv_ar_interface=3Dar
am_cv_make_support_nested_variables=3Dyes
am_cv_prog_cc_c_o=3Dyes
lt_cv_ar_at_file=3D@
lt_cv_archive_cmds_need_lc=3Dno
lt_cv_deplibs_check_method=3Dpass_all
lt_cv_file_magic_cmd=3D'$MAGIC_CMD'
lt_cv_file_magic_test_file=3D
lt_cv_ld_reload_flag=3D-r
lt_cv_nm_interface=3D'BSD nm'
lt_cv_objdir=3D.libs
lt_cv_path_LD=3D/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1=
=2E1/binutils-2.26-xxp2w7twwu65gypscb7dz4lfhowwcuxg/bin/ld
lt_cv_path_LDCXX=3D'/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc=
-6.1.1/binutils-2.26-xxp2w7twwu65gypscb7dz4lfhowwcuxg/bin/ld -m elf_x86_6=
4'
lt_cv_path_NM=3D'/usr/bin/nm -B'
lt_cv_path_mainfest_tool=3Dno
lt_cv_prog_compiler_c_o=3Dyes
lt_cv_prog_compiler_c_o_CXX=3Dyes
lt_cv_prog_compiler_c_o_F77=3Dyes
lt_cv_prog_compiler_c_o_FC=3Dyes
lt_cv_prog_compiler_pic=3D'-fPIC -DPIC'
lt_cv_prog_compiler_pic_CXX=3D'-fPIC -DPIC'
lt_cv_prog_compiler_pic_F77=3D-fPIC
lt_cv_prog_compiler_pic_FC=3D-fPIC
lt_cv_prog_compiler_pic_works=3Dyes
lt_cv_prog_compiler_pic_works_CXX=3Dyes
lt_cv_prog_compiler_pic_works_F77=3Dyes
lt_cv_prog_compiler_pic_works_FC=3Dyes
lt_cv_prog_compiler_rtti_exceptions=3Dno
lt_cv_prog_compiler_static_works=3Dyes
lt_cv_prog_compiler_static_works_CXX=3Dyes
lt_cv_prog_compiler_static_works_F77=3Dyes
lt_cv_prog_compiler_static_works_FC=3Dyes
lt_cv_prog_gnu_ld=3Dyes
lt_cv_prog_gnu_ldcxx=3Dyes
lt_cv_sharedlib_from_linklib_cmd=3D'printf %s\n'
lt_cv_shlibpath_overrides_runpath=3Dno
lt_cv_sys_global_symbol_pipe=3D'sed -n -e '\''s/^.*[ ]\([ABCDGIRSTW][ABC=
DGIRSTW]*\)[ ][ ]*\([_A-Za-z][_A-Za-z0-9]*\)$/\1 \2 \2/p'\'' | sed
/ __gnu_lto/d'\'''
lt_cv_sys_global_symbol_to_c_name_address=3D'sed -n -e '\''s/^: \(.*\) .*=
$/ {"\1", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW][ABCDGIRSTW]* .* \(.*=
\)$/ {"\1", (void *) \&\1},/p'\'''
lt_cv_sys_global_symbol_to_c_name_address_lib_prefix=3D'sed -n -e '\''s/^=
: \(.*\) .*$/ {"\1", (void *) 0},/p'\'' -e '\''s/^[ABCDGIRSTW][ABCDGIRST=
W]* .* \(lib.*\)$/ {"\1", (void *) \&\1},/p'\'' -e '\''s/^[ABCDGIRSTW][A=
BCDGIRSTW]* .* \(.*\)$/ {"lib\1", (void *) \&\1},/p'\'''
lt_cv_sys_global_symbol_to_cdecl=3D'sed -n -e '\''s/^T .* \(.*\)$/extern =
int \1();/p'\'' -e '\''s/^[ABCDGIRSTW][ABCDGIRSTW]* .* \(.*\)$/extern cha=
r \1;/p'\'''
lt_cv_sys_global_symbol_to_import=3D
lt_cv_sys_max_cmd_len=3D1572864
lt_cv_to_host_file_cmd=3Dfunc_convert_file_noop
lt_cv_to_tool_file_cmd=3Dfunc_convert_file_noop
lt_cv_truncate_bin=3D'/bin/dd bs=3D4096 count=3D1'
pkg_cv_FXT_CFLAGS=3D-I/home/lschnorr/spack-orion/opt/spack/linux-x86_64/g=
cc-6.1.0/fxt-0.3.1-7cplb2duxldnevckobjnofq6tgpxffck/include
pkg_cv_FXT_LIBS=3D'-L/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gc=
c-6.1.0/fxt-0.3.1-7cplb2duxldnevckobjnofq6tgpxffck/lib -lfxt'
## Output variables. ##
ACLOCAL=3D'${SHELL} /tmp/lschnorr/spack-stage/spack-stage-AgZLf5/trunk/bu=
ild-aux/missing aclocal-1.15'
AMDEPBACKSLASH=3D'\'
AMDEP_FALSE=3D'#'
AMDEP_TRUE=3D''
AMTAR=3D'$${TAR-tar}'
AM_BACKSLASH=3D'\'
AM_DEFAULT_V=3D'$(AM_DEFAULT_VERBOSITY)'
AM_DEFAULT_VERBOSITY=3D'0'
AM_V=3D'$(V)'
AR=3D'ar'
AS=3D'as'
ATLASDIR=3D''
ATLAS_BLAS_LIB_FALSE=3D''
ATLAS_BLAS_LIB_TRUE=3D'#'
AUTOCONF=3D'${SHELL} /tmp/lschnorr/spack-stage/spack-stage-AgZLf5/trunk/b=
uild-aux/missing autoconf'
AUTOHEADER=3D'${SHELL} /tmp/lschnorr/spack-stage/spack-stage-AgZLf5/trunk=
/build-aux/missing autoheader'
AUTOMAKE=3D'${SHELL} /tmp/lschnorr/spack-stage/spack-stage-AgZLf5/trunk/b=
uild-aux/missing automake-1.15'
AWK=3D'gawk'
BASH=3D'/bin/bash'
BLAS_LIB=3D'system'
BLAS_LIBS=3D''
BUILD_DOC_FALSE=3D''
BUILD_DOC_TRUE=3D''
BUILD_EXAMPLES_FALSE=3D'#'
BUILD_EXAMPLES_TRUE=3D''
BUILD_GCC_PLUGIN_FALSE=3D''
BUILD_GCC_PLUGIN_TRUE=3D'#'
BUILD_SOCL_FALSE=3D''
BUILD_SOCL_TRUE=3D'#'
BUILD_STARPUFFT_EXAMPLES_FALSE=3D''
BUILD_STARPUFFT_EXAMPLES_TRUE=3D'#'
BUILD_STARPUFFT_FALSE=3D''
BUILD_STARPUFFT_TRUE=3D'#'
BUILD_STARPU_TOP_FALSE=3D''
BUILD_STARPU_TOP_TRUE=3D'#'
BUILD_TESTS_FALSE=3D'#'
BUILD_TESTS_TRUE=3D''
CC=3D'/home/lschnorr/spack-orion/lib/spack/env/gcc/gcc'
CCDEPMODE=3D'depmode=3Dgcc3'
CC_OR_MPICC=3D'/home/lschnorr/spack-orion/lib/spack/env/gcc/gcc'
CFLAGS=3D'-O3 -g -O2 -gdwarf-2 -g3 '
COVERAGE=3D'no'
CPPFLAGS=3D' -D_GNU_SOURCE -I/home/lschnorr/spack-orion/opt/spack/linux-=
x86_64/gcc-6.1.0/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx/include'
CXX=3D'/home/lschnorr/spack-orion/lib/spack/env/gcc/g++'
CXXDEPMODE=3D'depmode=3Dgcc3'
CXXFLAGS=3D'-O3 -g -O2 -gdwarf-2 -g3 '
CYGPATH_W=3D'echo'
DEFS=3D''
DEPDIR=3D'.deps'
DLLTOOL=3D'false'
DSYMUTIL=3D''
DUMPBIN=3D''
ECHO_C=3D''
ECHO_N=3D'-n'
ECHO_T=3D''
EXEEXT=3D''
F77=3D'/home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran'
FC=3D'/home/lschnorr/spack-orion/lib/spack/env/gcc/gfortran'
FCFLAGS=3D'-g -O2'
FFLAGS=3D'-g -O2'
FFTWF_CFLAGS=3D''
FFTWF_LIBS=3D''
FFTWL_CFLAGS=3D''
FFTWL_LIBS=3D''
FFTW_CFLAGS=3D''
FFTW_LIBS=3D''
FXTDIR=3D'/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/fxt=
-0.3.1-7cplb2duxldnevckobjnofq6tgpxffck'
FXT_CFLAGS=3D'-I/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1=
=2E0/fxt-0.3.1-7cplb2duxldnevckobjnofq6tgpxffck/include '
FXT_LDFLAGS=3D''
FXT_LIBS=3D'-L/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0=
/fxt-0.3.1-7cplb2duxldnevckobjnofq6tgpxffck/lib -lfxt '
GCC_FOR_PLUGIN=3D''
GCC_FOR_PLUGIN_LIBTOOL_TAG=3D''
GCC_PLUGIN_DIR_PKGCONFIG=3D''
GCC_PLUGIN_INCLUDE_DIR=3D'/home/lschnorr/spack-orion/opt/spack/linux-x86_=
64/gcc-6.1.1/gcc-6.1.0-7cljeqxjfpkacgtkxus4p55nsms53dnv/lib64/gcc/x86_64-=
pc-linux-gnu/6.1.0/plugin/include'
GCC_PLUGIN_PKGCONFIG=3D''
GDB=3D'/usr/bin/gdb'
GLOBAL_AM_CFLAGS=3D' -Wall -Werror=3Dimplicit -Werror=3Dimplicit-function=
-declaration'
GOTODIR=3D''
GOTO_BLAS_LIB_FALSE=3D''
GOTO_BLAS_LIB_TRUE=3D'#'
GREP=3D'/bin/grep'
GUILE=3D''
HAVE_FFTWFL=3D''
HAVE_OPENGL_FALSE=3D''
HAVE_OPENGL_TRUE=3D'#'
HAVE_PTR_DEREFS_MAY_ALIAS_P_FALSE=3D''
HAVE_PTR_DEREFS_MAY_ALIAS_P_TRUE=3D'#'
HAVE_X11_FALSE=3D''
HAVE_X11_TRUE=3D'#'
HELP2MAN=3D''
HWLOC_CFLAGS=3D''
HWLOC_LIBS=3D''
HWLOC_REQUIRES=3D''
ICC=3D''
INSTALL_DATA=3D'${INSTALL} -m 644'
INSTALL_PROGRAM=3D'${INSTALL}'
INSTALL_SCRIPT=3D'${INSTALL}'
INSTALL_STRIP_PROGRAM=3D'$(install_sh) -c -s'
LD=3D'/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.1/binutil=
s-2.26-xxp2w7twwu65gypscb7dz4lfhowwcuxg/bin/ld -m elf_x86_64'
LDFLAGS=3D' -gdwarf-2 -g3 -L/home/lschnorr/spack-orion/opt/spack/linux-x=
86_64/gcc-6.1.0/hwloc-1.11.3-j3wlufl4afo5kvid3vv4rutn55ljz2nx/lib'
LIBOBJS=3D''
LIBS=3D'-lrt -lm -lpthread '
LIBSOCL_INTERFACE_AGE=3D'0'
LIBSOCL_INTERFACE_CURRENT=3D'0'
LIBSOCL_INTERFACE_REVISION=3D'0'
LIBSTARPUFFT_INTERFACE_AGE=3D'0'
LIBSTARPUFFT_INTERFACE_CURRENT=3D'0'
LIBSTARPUFFT_INTERFACE_REVISION=3D'0'
LIBSTARPUMPI_INTERFACE_AGE=3D'0'
LIBSTARPUMPI_INTERFACE_CURRENT=3D'0'
LIBSTARPUMPI_INTERFACE_REVISION=3D'0'
LIBSTARPU_INTERFACE_AGE=3D'0'
LIBSTARPU_INTERFACE_CURRENT=3D'0'
LIBSTARPU_INTERFACE_REVISION=3D'0'
LIBSTARPU_LDFLAGS=3D''
LIBSTARPU_LINK=3D''
LIBTOOL=3D'$(SHELL) $(top_builddir)/libtool'
LIPO=3D''
LN_S=3D'ln -s'
LTLIBOBJS=3D''
LT_SYS_LIBRARY_PATH=3D''
MAGMA_CFLAGS=3D''
MAGMA_LIBS=3D''
MAKEINFO=3D'${SHELL} /tmp/lschnorr/spack-stage/spack-stage-AgZLf5/trunk/b=
uild-aux/missing makeinfo'
MANIFEST_TOOL=3D':'
MKDIR_P=3D'/bin/mkdir -p'
MKL_BLAS_LIB_FALSE=3D''
MKL_BLAS_LIB_TRUE=3D'#'
MPICC=3D'no'
MPICC_LDFLAGS=3D''
MPIEXEC=3D''
MPIEXEC_ARGS=3D''
MPIFORT=3D''
NMEDIT=3D''
NO_BLAS_LIB_FALSE=3D''
NO_BLAS_LIB_TRUE=3D'#'
NVCC=3D''
NVCCFLAGS=3D''
OBJDUMP=3D'objdump'
OBJEXT=3D'o'
OPENMP_CFLAGS=3D''
OTOOL64=3D''
OTOOL=3D''
PACKAGE=3D'starpu'
PACKAGE_BUGREPORT=3D'starpu-devel@lists.gforge.inria.fr'
PACKAGE_NAME=3D'StarPU'
PACKAGE_STRING=3D'StarPU 1.3.0'
PACKAGE_TARNAME=3D'starpu'
PACKAGE_URL=3D'http://runtime.bordeaux.inria.fr/StarPU/'
PACKAGE_VERSION=3D'1.3.0'
PATH_SEPARATOR=3D':'
PKG_CONFIG=3D'/usr/bin/pkg-config'
POTI_CFLAGS=3D''
POTI_LIBS=3D''
PROG_DATE=3D'date'
PROG_STAT=3D'gstat'
QMAKE=3D''
QWT_PRI=3D''
RANLIB=3D'ranlib'
RUN_GCC_PLUGIN_TESTS_FALSE=3D''
RUN_GCC_PLUGIN_TESTS_TRUE=3D'#'
SED=3D'/bin/sed'
SET_MAKE=3D''
SHELL=3D'/bin/bash'
SIMGRID_CFLAGS=3D''
SIMGRID_LIBS=3D''
SOCL_OCL_LIB_OPENCL_DIR=3D''
SOCL_VENDORS=3D''
STARPU_BLAS_LDFLAGS=3D' -lblas '
STARPU_BUILD_DIR=3D'/tmp/lschnorr/spack-stage/spack-stage-AgZLf5/trunk'
STARPU_BUILD_SC_HYPERVISOR_FALSE=3D''
STARPU_BUILD_SC_HYPERVISOR_TRUE=3D'#'
STARPU_COI_CPPFLAGS=3D''
STARPU_COI_LDFLAGS=3D''
STARPU_COVERAGE_ENABLED_FALSE=3D''
STARPU_COVERAGE_ENABLED_TRUE=3D'#'
STARPU_COVERITY_FALSE=3D''
STARPU_COVERITY_TRUE=3D'#'
STARPU_CROSS_COMPILING_FALSE=3D''
STARPU_CROSS_COMPILING_TRUE=3D'#'
STARPU_CUDA_CPPFLAGS=3D''
STARPU_CUDA_FORTRAN_LDFLAGS=3D''
STARPU_CUDA_LDFLAGS=3D''
STARPU_CUFFT_LDFLAGS=3D''
STARPU_CURAND_LDFLAGS=3D''
STARPU_DEVEL_FALSE=3D''
STARPU_DEVEL_TRUE=3D'#'
STARPU_EFFECTIVE_VERSION=3D'1.3'
STARPU_EXPORTED_LIBS=3D''
STARPU_EXPORT_DYNAMIC=3D''
STARPU_GCC_VERSION_MAJOR=3D''
STARPU_GCC_VERSION_MINOR=3D''
STARPU_GLPK_LDFLAGS=3D' '
STARPU_HAVE_AM111_FALSE=3D''
STARPU_HAVE_AM111_TRUE=3D''
STARPU_HAVE_CUFFTDOUBLECOMPLEX_FALSE=3D''
STARPU_HAVE_CUFFTDOUBLECOMPLEX_TRUE=3D'#'
STARPU_HAVE_DARWIN_FALSE=3D''
STARPU_HAVE_DARWIN_TRUE=3D'#'
STARPU_HAVE_F77_H=3D''
STARPU_HAVE_F77_H_FALSE=3D''
STARPU_HAVE_F77_H_TRUE=3D''
STARPU_HAVE_FC_FALSE=3D'#'
STARPU_HAVE_FC_TRUE=3D''
STARPU_HAVE_FFTW=3D''
STARPU_HAVE_FFTWF=3D''
STARPU_HAVE_FFTWF_FALSE=3D''
STARPU_HAVE_FFTWF_TRUE=3D'#'
STARPU_HAVE_FFTWL_FALSE=3D''
STARPU_HAVE_FFTWL_TRUE=3D'#'
STARPU_HAVE_FFTW_FALSE=3D''
STARPU_HAVE_FFTW_TRUE=3D'#'
STARPU_HAVE_HELP2MAN_FALSE=3D''
STARPU_HAVE_HELP2MAN_TRUE=3D''
STARPU_HAVE_HWLOC=3D''
STARPU_HAVE_HWLOC_FALSE=3D''
STARPU_HAVE_HWLOC_TRUE=3D'#'
STARPU_HAVE_ICC_FALSE=3D''
STARPU_HAVE_ICC_TRUE=3D''
STARPU_HAVE_LEVELDB_FALSE=3D''
STARPU_HAVE_LEVELDB_TRUE=3D'#'
STARPU_HAVE_MAGMA=3D''
STARPU_HAVE_MAGMA_FALSE=3D''
STARPU_HAVE_MAGMA_TRUE=3D'#'
STARPU_HAVE_MPIFORT_FALSE=3D''
STARPU_HAVE_MPIFORT_TRUE=3D'#'
STARPU_HAVE_MS_LIB_FALSE=3D''
STARPU_HAVE_MS_LIB_TRUE=3D'#'
STARPU_HAVE_OPENMP_FALSE=3D''
STARPU_HAVE_OPENMP_TRUE=3D'#'
STARPU_HAVE_WINDOWS_FALSE=3D''
STARPU_HAVE_WINDOWS_TRUE=3D'#'
STARPU_HWLOC_HAVE_TOPOLOGY_DUP_FALSE=3D''
STARPU_HWLOC_HAVE_TOPOLOGY_DUP_TRUE=3D''
STARPU_LEVELDB_LDFLAGS=3D''
STARPU_LIBNUMA_LDFLAGS=3D' -lnuma '
STARPU_LINUX_SYS_FALSE=3D'#'
STARPU_LINUX_SYS_TRUE=3D''
STARPU_LONG_CHECK_FALSE=3D''
STARPU_LONG_CHECK_TRUE=3D'#'
STARPU_MAJOR_VERSION=3D'1'
STARPU_MINOR_VERSION=3D'3'
STARPU_MPI_CHECK_FALSE=3D''
STARPU_MPI_CHECK_TRUE=3D'#'
STARPU_MS_LIB=3D''
STARPU_MS_LIB_ARCH=3D'X64'
STARPU_NEW_CHECK_FALSE=3D''
STARPU_NEW_CHECK_TRUE=3D'#'
STARPU_OPENCL_CPPFLAGS=3D''
STARPU_OPENCL_DATAdir=3D''
STARPU_OPENCL_LDFLAGS=3D''
STARPU_OPENGL_RENDER=3D'no'
STARPU_OPENGL_RENDER_LDFLAGS=3D''
STARPU_OPENMP_FALSE=3D''
STARPU_OPENMP_TRUE=3D'#'
STARPU_PERF_DEBUG=3D'no'
STARPU_QUICK_CHECK_FALSE=3D''
STARPU_QUICK_CHECK_TRUE=3D'#'
STARPU_QWT_INCLUDE=3D''
STARPU_QWT_LDFLAGS=3D''
STARPU_RCCE_CFLAGS=3D''
STARPU_RCCE_CPPFLAGS=3D''
STARPU_RCCE_LDFLAGS=3D''
STARPU_RELEASE_VERSION=3D'0'
STARPU_SANITIZE_FALSE=3D''
STARPU_SANITIZE_TRUE=3D''
STARPU_SCIF_CPPFLAGS=3D''
STARPU_SCIF_LDFLAGS=3D''
STARPU_SC_HYPERVISOR=3D''
STARPU_SC_HYPERVISOR_DEBUG=3D'no'
STARPU_SC_HYPERVISOR_DEBUG_FALSE=3D''
STARPU_SC_HYPERVISOR_DEBUG_TRUE=3D'#'
STARPU_SIMGRID_FALSE=3D''
STARPU_SIMGRID_TRUE=3D'#'
STARPU_SRC_DIR=3D'/tmp/lschnorr/spack-stage/spack-stage-AgZLf5/trunk/.'
STARPU_USE_CPU=3D'yes'
STARPU_USE_CPU_FALSE=3D'#'
STARPU_USE_CPU_TRUE=3D''
STARPU_USE_CUDA=3D'no'
STARPU_USE_CUDA_FALSE=3D''
STARPU_USE_CUDA_TRUE=3D'#'
STARPU_USE_FXT=3D'yes'
STARPU_USE_FXT_FALSE=3D'#'
STARPU_USE_FXT_TRUE=3D''
STARPU_USE_MIC_FALSE=3D''
STARPU_USE_MIC_TRUE=3D'#'
STARPU_USE_MP_FALSE=3D''
STARPU_USE_MP_TRUE=3D'#'
STARPU_USE_OPENCL=3D'no'
STARPU_USE_OPENCL_FALSE=3D''
STARPU_USE_OPENCL_TRUE=3D'#'
STARPU_USE_SCC_FALSE=3D''
STARPU_USE_SCC_TRUE=3D'#'
STARPU_USE_SC_HYPERVISOR_FALSE=3D''
STARPU_USE_SC_HYPERVISOR_TRUE=3D'#'
STARPU_USE_SOCL_FALSE=3D''
STARPU_USE_SOCL_TRUE=3D'#'
STARPU_USE_TOP=3D'no'
STRIP=3D'strip'
SYSTEM_BLAS_LIB_FALSE=3D'#'
SYSTEM_BLAS_LIB_TRUE=3D''
USE_MPI=3D'no'
USE_MPI_FALSE=3D''
USE_MPI_TRUE=3D'#'
VERSION=3D'1.3.0'
XMKMF=3D''
X_CFLAGS=3D''
X_EXTRA_LIBS=3D''
X_LIBS=3D''
X_PRE_LIBS=3D''
YACC=3D'${SHELL} /tmp/lschnorr/spack-stage/spack-stage-AgZLf5/trunk/build=
-aux/missing bison'
ac_ct_AR=3D'ar'
ac_ct_CC=3D'/home/lschnorr/spack-orion/lib/spack/env/gcc/gcc'
ac_ct_CXX=3D''
ac_ct_DUMPBIN=3D''
ac_ct_F77=3D''
ac_ct_FC=3D''
am__EXEEXT_FALSE=3D''
am__EXEEXT_TRUE=3D''
am__fastdepCC_FALSE=3D'#'
am__fastdepCC_TRUE=3D''
am__fastdepCXX_FALSE=3D'#'
am__fastdepCXX_TRUE=3D''
am__include=3D'include'
am__isrc=3D''
am__leading_dot=3D'.'
am__nodep=3D'_no'
am__quote=3D''
am__tar=3D'$${TAR-tar} chof - "$$tardir"'
am__untar=3D'$${TAR-tar} xf -'
bindir=3D'${exec_prefix}/bin'
build=3D'x86_64-pc-linux-gnu'
build_alias=3D''
build_cpu=3D'x86_64'
build_os=3D'linux-gnu'
build_vendor=3D'pc'
datadir=3D'${datarootdir}'
datarootdir=3D'${prefix}/share'
docdir=3D'${datarootdir}/doc/${PACKAGE_TARNAME}'
doxygencommand=3D''
dvidir=3D'${docdir}'
epstopdfcommand=3D''
exec_prefix=3D'NONE'
gccplugindir=3D''
host=3D'x86_64-pc-linux-gnu'
host_alias=3D''
host_cpu=3D'x86_64'
host_os=3D'linux-gnu'
host_vendor=3D'pc'
htmldir=3D'${docdir}'
includedir=3D'${prefix}/include'
infodir=3D'${datarootdir}/info'
install_sh=3D'${SHELL} /tmp/lschnorr/spack-stage/spack-stage-AgZLf5/trunk=
/build-aux/install-sh'
libdir=3D'${exec_prefix}/lib'
libexecdir=3D'${exec_prefix}/libexec'
localedir=3D'${datarootdir}/locale'
localstatedir=3D'${prefix}/var'
mandir=3D'${datarootdir}/man'
mkdir_p=3D'$(MKDIR_P)'
mpicc_path=3D'no'
mpiexec_path=3D''
mpifort_path=3D''
oldincludedir=3D'/usr/include'
pdfdir=3D'${docdir}'
pdflatexcommand=3D''
pkglibdir=3D'${libdir}/starpu'
prefix=3D'/home/lschnorr/spack-orion/opt/spack/linux-x86_64/gcc-6.1.0/sta=
rpu-svn-trunk-ew2ffhhvxulnikubqm76rijyluvps7ho'
program_transform_name=3D's,x,x,'
psdir=3D'${docdir}'
runstatedir=3D'${localstatedir}/run'
sbindir=3D'${exec_prefix}/sbin'
sharedstatedir=3D'${prefix}/com'
smpirun_path=3D''
svncommand=3D'/usr/bin/svn'
svnversioncommand=3D'/usr/bin/svnversion'
sysconfdir=3D'${prefix}/etc'
target=3D'x86_64-pc-linux-gnu'
target_alias=3D''
target_cpu=3D'x86_64'
target_os=3D'linux-gnu'
target_vendor=3D'pc'
## confdefs.h. ##
/* confdefs.h */
#define STARPU_BUILD_DIR "/tmp/lschnorr/spack-stage/spack-stage-AgZLf5/tr=
unk"
#define STARPU_SRC_DIR "/tmp/lschnorr/spack-stage/spack-stage-AgZLf5/trun=
k/."
configure: exit 1
--------------B1A021ED0280C43640C4BF1B--
- [no subject], Unknown, 16/12/2020
