Archives de la liste
- To: Nathalie Furmento <nathalie.furmento@labri.fr>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] automake version detection
- Date: Thu, 18 Aug 2016 10:30:59 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi Nathalie, I don't see the autogen.sh file in the starpu releases. But I could cheat with the following commands: $ sudo ln -s /usr/bin/aclocal-1.14 /usr/bin/aclocal-1.15 $ sudo ln -s /usr/bin/automake-1.14 /usr/bin/automake-1.15 Maybe aclocal and automake executables should be used instead of aclocal/automake-VERSION in starpu configure? Best, Florent Le 17/08/2016 16:51, Nathalie Furmento
a écrit :
The file aclocal.m4 states it was
# generated automatically by aclocal 1.15 -*- Autoconf -*- That's the version of aclocal we have on the machine. i would have supposed it would work with an older version, sorry about that. You should try to restart autogen.sh and see if it works better. Cheers, Nathalie Le 17/08/2016 à 11:01, Florent Pruvost a écrit : 57B427CE.7010101@inria.fr">Hi,
- [Starpu-devel] automake version detection, Florent Pruvost, 17/08/2016
- Re: [Starpu-devel] automake version detection, Nathalie Furmento, 17/08/2016
- Re: [Starpu-devel] automake version detection, Florent Pruvost, 18/08/2016
- Re: [Starpu-devel] automake version detection, Samuel Thibault, 18/08/2016
