Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] automake version detection
- Date: Wed, 17 Aug 2016 11:01:02 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
This is a multi-part message in MIME format. Hi,
On the Inria CI platform I try to build starpu 1.2.0-rc5 on a Ubuntu-14.04 vm but after configure it fails because aclocal-1.15 is missing. I just have aclocal-1.14 on this system.
==> 'make' '-j2'
CDPATH="${ZSH_VERSION+.}:" && cd . && /bin/bash /tmp/ci/spack-stage/spack-stage-TG9rM0/starpu-1.2.0rc5/build-aux/missing aclocal-1.15 -I m4
/tmp/ci/spack-stage/spack-stage-TG9rM0/starpu-1.2.0rc5/build-aux/missing: line 81: aclocal-1.15: command not found
WARNING: 'aclocal-1.15' is missing on your system.
Any idea why StarPU is trying to use aclocal-1.15? Is this a minimal version required to build starpu 1.2.0-rc5?
Best,
Florent
This file contains any messages produced by compilers while running configure, to aid debugging if configure makes a mistake. It was created by StarPU configure 1.2.0rc5, which was generated by GNU Autoconf 2.69. Invocation command line was $ ./configure --prefix=/builds/spack/opt/spack/linux-x86_64/gcc-4.8/starpu-1.2.0rc5-24z5f3ubmzropahfnwsaqz7up6hoykbs --disable-build-doc --disable-starpu-top --with-fxt=/builds/spack/opt/spack/linux-x86_64/gcc-4.8/fxt-0.3.1-kzb77zly4fisqhedpc3eborqra6jspjf --enable-paje-codelet-details --with-hwloc=/builds/spack/opt/spack/linux-x86_64/gcc-4.8/hwloc-1.11.3-h5rqz3ba56snhid26cox3r76jnhbjjrc --disable-cuda --disable-opencl --enable-openmp=no ## --------- ## ## Platform. ## ## --------- ## hostname = ubuntu-14-04-1-amd64 uname -m = x86_64 uname -r = 3.13.0-32-generic uname -s = Linux uname -v = #57-Ubuntu SMP Tue Jul 15 03:51:08 UTC 2014 /usr/bin/uname -p = unknown /bin/uname -X = unknown /bin/arch = unknown /usr/bin/arch -k = unknown /usr/convex/getsysinfo = unknown /usr/bin/hostinfo = unknown /bin/machine = unknown /usr/bin/oslevel = unknown /bin/universe = unknown
- [Starpu-devel] automake version detection, Florent Pruvost, 17/08/2016
- Re: [Starpu-devel] automake version detection, Nathalie Furmento, 17/08/2016
- Re: [Starpu-devel] automake version detection, Florent Pruvost, 18/08/2016
- Re: [Starpu-devel] automake version detection, Samuel Thibault, 18/08/2016
