Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] starpu autogen error with libtool on mac os x
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] starpu autogen error with libtool on mac os x
  • Date: Mon, 22 Aug 2016 14:57:41 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi Samuel,
Le 22/08/2016 13:24, Samuel Thibault a écrit :
Hello,
Florent Pruvost, on Mon 22 Aug 2016 13:04:02 +0200, wrote:
I have tried to build starpu-1.2.0rc6 on a mac os x 10.9.5 and I've got the
following error during the execution of the autogen script:
Why are you executing the autogen script? This is really not needed
unless you have modified configure.ac or some Makefile.am file.
Because in some systems the version of automake can be older than the one used in the configure script leading to some non compatibility issues.
In addition, we may use it in some starpu versions where the configure script is not existing.
Using the following environment variables fixes the problem:
export LIBTOOL=/opt/local/bin/glibtool
export LIBTOOLIZE=/opt/local/bin/glibtoolize
Florent
Haut de le page
